I am trying to get this working again after having to change my kernel
$ inxi -Nazy
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
$ pamac build rtl8822bu-dkms-git
See this log …
$ pamac list --installed | egrep “linux[0-9]{2,3}-headers”
linux414-headers 4.14.277-1 core 89.5 MB
linux510-headers 5.10.114-1 core 129.7 MB
linux515-headers 5.15.38-1 core 138.5 MB
linux517-headers 5.17.6-1 core 143.8 MB
linux54-headers 5.4.192-1 core 119.1 MB
I have re-booted but I cannot see wifi in Networks
Hi @psionman ,
I wonder whether you can read the following post in order to solve your problem or give use some extra information about your system.
I read the log and the transactions were successfully, as I could understand.
‘Attempting to Setup TP-Link Archer T3U Plus, Discovered USB Not Working (!) [SOLVED, (with T3U Driver Info)]’
Hope this help, regards
Thanks
I’ve read that and it appears that the problem there is a 32-bit version of libusb
I get
$ lsusb
Bus 003 Device 003: ID 046d:0892 Logitech, Inc. C920 HD Pro Webcam
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 002: ID 04e8:327e Samsung Electronics Co., Ltd ML-2510 Series
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 004: ID 2357:012d TP-Link Archer T3U [Realtek RTL8812BU]
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 003: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 005 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
What sort of extra information could I give?
uninstall the rtl8822bu-dkms-git driver then reboot, install it again and reboot
Thanks - t ried that. Still no sign of wifi networks
I have looked at this post and
$ sudo modprobe rtl88x2bu
$ sudo modprobe 88x2bu
$ sudo modprobe rtl88x2bu-dkms
all fail
Hi @psionman,
I did some searching and came across this page, which seems like it might be it. And the 88x2bu driver is in the AUR:
$ pamac search 88x2bu
rtl88x2bu-dkms-git 5.13.1.r149.7f96b19-1 AUR
Kernel module for Realtek rtl88x2bu WiFi chipset
So, uninstall the other one:
pamac remove rtl8822bu-dkms-git
And install this one:
pamac build rtl88x2bu-dkms-git
If successful, reboot and see if it works.
Hope this helps!
you didnt provide any info on your system:
inxi -Fazy
Hi @2old4gaming,
Please rather start a new thread than hijacking an existing/old one.
Also, in order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
@psionman From the chip ID of your card (10ec:8168) and this page, it seems that this other driver is more appropriate for your card: AUR (en) - r8168-dkms
After installing and rebooting you have to make sure that the correct module is being used, for example with inxi. If your card is still using the r8169 driver, probably you have to blacklist it.
