Relative newbie here. I was looking around the forums looking for a solution to setting up my new Archer T3U Plus and nothing was working. Getting ready to post and ask for help, I noticed that my inxi output showed:
Message: No USB data found. Server?
Confused, I checked to see if my laptop could even see my new wifi dongle at all:
[zak@server47 ~]$ lsusb
lsusb: error while loading shared libraries: libusb-1.0.so.0: wrong ELF class: ELFCLASS32
Checking around again, I could see that this problem pops up in relation to installing certain pieces of software, and so the fix usually involves tweaking that software installation process. But that’s not what I’m doing, my usb just seems to have blinked out on me, so, I’m not sure what to do — help!
[zak@server47 ~]$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.59-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=aeb29178-6fae-4767-924e-fe86c54b9abc rw quiet apparmor=1
security=apparmor udev.log_priority=3 usbcore.autosuspend=-1
Desktop: Budgie 10.5.3 info: budgie-panel wm: budgie-wm dm: LightDM 1.30.0
Type: Laptop System: Acer product: Aspire E5-576G v: V1.49 serial: <filter>
Mobo: KBL model: Ironman_SK v: V1.49 serial: <filter> UEFI: Insyde v: 1.49
date: 12/11/2018
ID-1: BAT1 charge: 35.8 Wh (100.0%) condition: 35.8/62.2 Wh (57.7%)
volts: 12.6 min: 11.1 model: PANASONIC AS16B5J type: Li-ion serial: <filter>
status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse B330/M330/M331
status: Discharging
RAM: total: 7.65 GiB used: 2.25 GiB (29.4%)
Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: EA cache: L2: 6 MiB bogomips: 28808
Speed: 646 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 646 2: 653 3: 648
4: 647 5: 651 6: 638 7: 638 8: 650
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Acer Incorporated ALI driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Acer Incorporated ALI
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1d10 class-ID: 0302
Display: x11 server: X.org 1.20.13 compositor: budgie-wm driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.6
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.10.59-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel port: 4000 bus-ID: 03:00.0 chip-ID: 8086:24fb class-ID: 0280
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 04:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0f1 state: down mac: <filter>
Local Storage: total: 238.47 GiB used: 76.43 GiB (32.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: 1100 MTFDDAV256TBN
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: A020 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUE1N rev: 1.00
dev-links: cdrom
ID-1: / raw-size: 78.12 GiB size: 76.35 GiB (97.73%) used: 25.88 GiB (33.9%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: aeb29178-6fae-4767-924e-fe86c54b9abc
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: C206-C2A6
ID-3: /home raw-size: 151.25 GiB size: 147.87 GiB (97.77%)
used: 50.55 GiB (34.2%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: e28ae277-227a-4c04-97c3-e674637f1bd4
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 8d995362-9998-40cd-8fe5-76c32fca21ad
System Temperatures: cpu: 44.0 C mobo: N/A
Processes: 278 Uptime: 12m wakeups: 3 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1421 pacman: 1407 lib: 336 snap: 14
Shell: Bash v: 5.1.8 running-in: gnome-terminal inxi: 3.3.06
