GRUB_DISABLE_OS_PROBER flag appears to be ignored in /etc/default/grub
After updating to version 2.04-17 re-generating the grub config with the update-grub command ignores the fact that GRUB_DISABLE_OS_PROBER=true is set in /etc/default/grub.
The partition structure is as below - even though GRUB_DISABLE_OS_PROBER is set to true os-prober is still invoked and Windows Boot Manager is added to the boot menu. This does not occur in 2.04-16. The os-prober version is 1.77-1 but this has not changed.
The issue occurs on both 5.4 and 5.10 series kernels.
In either case a manually added ‘Windows 10’ entry is still included.
Device             Start        End    Sectors   Size Type
/dev/nvme0n1p1      2048     206847     204800   100M EFI System
/dev/nvme0n1p2    206848     239615      32768    16M Microsoft reserved
/dev/nvme0n1p3    239616  314355132  314115517 149.8G Microsoft basic data
/dev/nvme0n1p4 314357760  315391999    1034240   505M Windows recovery environment
/dev/nvme0n1p5 315392000  416055295  100663296    48G Linux swap
/dev/nvme0n1p6 416055296 2000409230 1584353935 755.5G Linux filesystem
The Manjaro root on /dev/nvme0n1p6 is formatted as BTRFS.
Contents of /etc/default/grub:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=menu
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="udev.log_priority=3 resume=/dev/disk/by-uuid/24c990f4-9f95-4e04-8c87-7fd493933443 zswap.enabled=1"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
#GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically
GRUB_ROOT_FS_RO=true
/etc/grub.d/40_custom (custom chainloader for Windows 10):
#!/bin/sh
exec tail -n +3 $0
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
menuentry 'Windows 10' --class windows --class os {
    search --fs-uuid --no-floppy --set=root 5AA1-1EFF
    chainloader (${root})/EFI/Microsoft/Boot/bootmgfw.efi
Working around this problem by removing os-prober is not a solution for me as it is a dependency of several manjaro-tools* packages which I use.
Welcome to the forum! :wink:
It may indeed be a bug ─ note: the Manjaro Development category is not for bug reports but for actual code contributions ─ but you don’t have to remove it. Just unset its execute permission, as I have done. :wink:
:arrow_down:
sudo chmod 644 /etc/grub.d/30_os-prober
Thank you.
The reason I reported the possible bug in the Development section was because of the instruction here:
To my surprise I haven’t been able to find a public bug tracking service for Manjaro like I have other distros, though perhaps I am missing something. Alternatively, perhaps this package is unmodified from vanilla Arch and I should be reporting it there?
Well, reporting bugs is (among other things) what the Feedback category is for. :wink:
It’s a Manjaro package, albeit (of course) that we don’t develop grub itself. But we do apply our own customization to it.
I have now invited the grub maintainer to this thread so he can come and take a look. :wink:
update-grub is calling this:
[phil@development ~]$ cat /usr/bin/update-grub
#! /bin/sh
set -e
exec grub-mkconfig -o /boot/grub/grub.cfg "$@"
Try to set the value in config to FALSE and see what happens. See also here. I think they had a logic issue upstream. Will try to patch it on our end.
Fix is now upstream: [PATCH] templates: Properly disable the os-prober by default
Hi,
This post resume what to do
https://forum.manjaro.org/t/stable-update-2021-03-08-kernels-plasma-5-21-2-haskell-kodi-grub-kde-dev/56877/19
in your linked upstream patch is:
if [ "x${GRUB_DISABLE_OS_PROBER}" = "xfalse" ]; then
but in Manjaro /etc/grub.d/30_os-prober is:
if [ "x${GRUB_DISABLE_OS_PROBER}" != "xfalse" ]; then
is/was this intentional reversal of logic? exit 0 leaves the script? so manjaro version seems righter… but I am confused now :smiley:
