The glitches are the same on X11
output for log:
May 08 11:47:04 milos-hp kernel: #5 #6 #7 #8 #9 #10 #11
May 08 11:47:04 milos-hp kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
May 08 11:47:04 milos-hp kernel: pnp 00:04: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
May 08 11:47:04 milos-hp kernel: hpet_acpi_add: no address or irqs in _CRS
May 08 11:47:04 milos-hp kernel: tpm tpm0: [Firmware Bug]: TPM interrupt not working, polling instead
May 08 11:47:04 milos-hp kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
May 08 11:47:04 milos-hp kernel: usb: port power management may be unreliable
May 08 11:47:04 milos-hp kernel: memfd_create() without MFD_EXEC nor MFD_NOEXEC_SEAL, pid=1 'systemd'
May 08 11:47:04 milos-hp kernel: vboxdrv: loading out-of-tree module taints kernel.
May 08 11:47:04 milos-hp kernel: VBoxNetAdp: Successfully started.
May 08 11:47:04 milos-hp kernel: VBoxNetFlt: Successfully started.
May 08 11:47:04 milos-hp kernel: wmi_bus wmi_bus-PNP0C14:02: WQZZ data block query control method not found
May 08 11:47:04 milos-hp kernel: resource: resource sanity check: requesting [mem 0x00000000fedc0000-0x00000000fedcffff], which spans more than pnp 00:04 [mem 0xfedc0000-0xfedc7fff]
May 08 11:47:04 milos-hp kernel: caller igen6_probe+0x1a2/0x8d0 [igen6_edac] mapping multiple BARs
May 08 11:47:04 milos-hp kernel: hp_wmi: query 0x4 returned error 0x5
May 08 11:47:04 milos-hp kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
May 08 11:47:04 milos-hp kernel: thermal thermal_zone16: failed to read out thermal zone (-61)
May 08 11:47:04 milos-hp kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
May 08 11:47:05 milos-hp bluetoothd[458]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
May 08 11:47:05 milos-hp bluetoothd[458]: src/plugin.c:plugin_init() Failed to init vcp plugin
May 08 11:47:05 milos-hp bluetoothd[458]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
May 08 11:47:05 milos-hp bluetoothd[458]: src/plugin.c:plugin_init() Failed to init mcp plugin
May 08 11:47:05 milos-hp bluetoothd[458]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
May 08 11:47:05 milos-hp bluetoothd[458]: src/plugin.c:plugin_init() Failed to init bap plugin
May 08 11:47:05 milos-hp kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
May 08 11:47:06 milos-hp kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
May 08 11:47:06 milos-hp kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
May 08 11:47:06 milos-hp kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
May 08 11:47:06 milos-hp kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
May 08 11:47:06 milos-hp kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi3 overwritten
May 08 11:47:06 milos-hp kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi2 overwritten
May 08 11:47:06 milos-hp kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi1 overwritten
May 08 11:47:06 milos-hp kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Codec Output Pin1 overwritten
May 08 11:47:06 milos-hp kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Codec Input Pin1 overwritten
May 08 11:47:06 milos-hp kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Analog Codec Playback overwritten
May 08 11:47:06 milos-hp kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Digital Codec Playback overwritten
May 08 11:47:06 milos-hp kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Alt Analog Codec Playback overwritten
May 08 11:47:06 milos-hp kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Analog Codec Capture overwritten
May 08 11:47:06 milos-hp kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Digital Codec Capture overwritten
May 08 11:47:06 milos-hp kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Alt Analog Codec Capture overwritten
May 08 11:47:06 milos-hp kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
May 08 11:47:06 milos-hp kernel: kauditd_printk_skb: 30 callbacks suppressed
May 08 11:47:07 milos-hp systemd[573]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
May 08 11:47:07 milos-hp systemd[573]: Failed to start Update XDG user dir configuration.
May 08 11:47:07 milos-hp sddm-greeter[582]: QFont::fromString: Invalid description '(empty)'
May 08 11:47:07 milos-hp sddm-greeter[582]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffd59203250), parent's thread is QThread(0x555da1b88a60), current thread is QThread(0x555da1ce5030)
May 08 11:47:07 milos-hp sddm-greeter[582]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
May 08 11:47:07 milos-hp sddm-greeter[582]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
May 08 11:47:07 milos-hp sddm-greeter[582]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
May 08 11:47:07 milos-hp sddm-greeter[582]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
May 08 11:47:07 milos-hp sddm-greeter[582]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
May 08 11:47:07 milos-hp sddm-greeter[582]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.20'
May 08 11:47:07 milos-hp sddm-greeter[582]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.21'
May 08 11:47:14 milos-hp kernel: kauditd_printk_skb: 8 callbacks suppressed
May 08 11:47:15 milos-hp kwin_wayland[676]: No backend specified, automatically choosing drm
May 08 11:47:15 milos-hp kwin_wayland[676]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
May 08 11:47:15 milos-hp kwin_wayland[676]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
May 08 11:47:16 milos-hp ksplashqml[679]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
May 08 11:47:16 milos-hp ksplashqml[679]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
May 08 11:47:17 milos-hp ksmserver[785]: Qt: Session management error: networkIdsList argument is NULL
May 08 11:47:17 milos-hp kwalletd5[651]: kf.wallet.kwalletd: Wallet failed to get opened by PAM, error code is -9
May 08 11:47:17 milos-hp kernel: warning: `kded5' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
May 08 11:47:17 milos-hp plasmashell[856]: Checking screens: available: (QScreen(0x5606946bf5c0, name="eDP-1")) redundant: QHash() fake: QSet() all: (QScreen(0x5606946bf5c0, name="eDP-1"))
May 08 11:47:17 milos-hp plasmashell[856]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
May 08 11:47:17 milos-hp plasmashell[856]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
May 08 11:47:17 milos-hp org_kde_powerdevil[903]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
May 08 11:47:17 milos-hp pipewire[976]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
May 08 11:47:17 milos-hp pipewire[976]: mod.rt: found session bus but no portal
May 08 11:47:17 milos-hp kded5[787]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.30: cannot open shared object file: No such file or directory)"
May 08 11:47:17 milos-hp plasmashell[856]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
May 08 11:47:17 milos-hp org_kde_powerdevil[903]: org.kde.powerdevil: Handle button events action could not check for screen configuration
May 08 11:47:17 milos-hp kded5[787]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
May 08 11:47:17 milos-hp kioslave5[1044]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
May 08 11:47:17 milos-hp wireplumber[987]: <WpPortalPermissionStorePlugin:0x5602c91657a0> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
May 08 11:47:17 milos-hp plasmashell[856]: file:///usr/share/plasma/plasmoids/org.kde.kscreen/contents/ui/main.qml:30:5: Unable to assign [undefined] to bool
May 08 11:47:17 milos-hp plasmashell[856]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
May 08 11:47:17 milos-hp plasmashell[856]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
May 08 11:47:18 milos-hp plasmashell[856]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:95: TypeError: Cannot read property 'airplaneModeAvailable' of null
May 08 11:47:18 milos-hp plasmashell[856]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
May 08 11:47:18 milos-hp pulseaudio[1178]: stat('/etc/pulse/default.pa.d'): No such file or directory
May 08 11:47:18 milos-hp plasmashell[856]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
May 08 11:47:18 milos-hp plasmashell[856]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
May 08 11:47:18 milos-hp plasmashell[856]: kf5idletime_wayland: This plugin does not support polling idle time
May 08 11:47:18 milos-hp plasmashell[856]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
May 08 11:47:18 milos-hp bluetoothd[458]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
May 08 11:47:19 milos-hp plasmashell[856]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
May 08 11:47:20 milos-hp plasmashell[856]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
May 08 11:47:22 milos-hp plasmashell[856]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
May 08 11:47:23 milos-hp plasmashell[856]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
May 08 11:47:24 milos-hp plasmashell[856]: QString::arg: 2 argument(s) missing in google-chrome
May 08 11:47:24 milos-hp plasmashell[856]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:286: Unable to assign [undefined] to QString
May 08 11:47:24 milos-hp kwin_wayland[676]: kwin_core: Cannot grant a token to KWaylandServer::ClientConnection(0x55858179c160)
May 08 11:47:24 milos-hp kernel: kauditd_printk_skb: 13 callbacks suppressed
May 08 11:47:27 milos-hp plasmashell[856]: QString::arg: 2 argument(s) missing in org.kde.konsole
May 08 11:47:27 milos-hp konsole[1557]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
May 08 11:47:27 milos-hp konsole[1557]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
May 08 11:48:29 milos-hp plasmashell[856]: QString::arg: 2 argument(s) missing in google-chrome
May 08 11:48:29 milos-hp kwin_wayland[676]: kwin_core: Cannot grant a token to KWaylandServer::ClientConnection(0x5585817769d0)
May 08 11:48:29 milos-hp plasmashell[856]: error creating screencast "Could not find window id {f55164b6-f13c-4f3f-b79c-7cc322917528}"
May 08 11:49:49 milos-hp kwin_wayland[676]: kwin_libinput: Libinput: event9 - SYNA30D9:00 06CB:CEA4 Touchpad: kernel bug: Touch jump detected and discarded.
See https://wayland.freedesktop.org/libinput/doc/1.23.0/touchpad-jumping-cursors.html for details
May 08 11:50:13 milos-hp plasmashell[856]: org.kde.plasma.libtaskmanager: Got invalid activation app_id: ""
May 08 11:53:06 milos-hp plasmashell[856]: trying to show an empty dialog
May 08 11:53:06 milos-hp plasmashell[856]: kf5idletime_wayland: This plugin does not support polling idle time
May 08 11:53:06 milos-hp plasmashell[856]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
May 08 11:53:09 milos-hp plasmashell[856]: QString::arg: 2 argument(s) missing in org.kde.dolphin
May 08 11:53:09 milos-hp plasmashell[856]: kf5idletime_wayland: This plugin does not support polling idle time
May 08 11:53:23 milos-hp dolphin[2244]: qt.qpa.wayland: setGrabPopup called with a parent, QtWaylandClient::QWaylandXdgSurface(0x55c910a053e0) which does not match the current topmost grabbing popup, QtWaylandClient::QWaylandXdgSurface(0x55c910d3b9a0) According to the xdg-shell protocol, this is not allowed. The wayland QPA plugin is currently handling it by setting the parent to the topmost grabbing popup. Note, however, that this may cause positioning errors and popups closing unxpectedly because xdg-shell mandate that child popups close before parents
May 08 11:53:29 milos-hp plasmashell[856]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/DeviceItem.qml:174:5: Unable to assign [undefined] to QString
May 08 11:53:29 milos-hp plasmashell[856]: kf5idletime_wayland: This plugin does not support polling idle time
May 08 11:53:29 milos-hp plasmashell[856]: file:///usr/lib/qt/qml/org/kde/plasma/extras/ExpandableListItem.qml:291: TypeError: Cannot read property 'enabled' of null
May 08 11:53:32 milos-hp plasmashell[856]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
May 08 11:53:38 milos-hp plasmashell[856]: org.kde.kf5.kwindowsystem.kwayland: Failed to recreate shadow for PlasmaQuick::Dialog(0x560695c99630, name="popupWindow")
May 08 11:53:38 milos-hp plasmashell[856]: kf5idletime_wayland: This plugin does not support polling idle time
May 08 11:53:50 milos-hp kded5[787]: org.kde.plasma.nm.kded: Unhandled active connection state change: 3
May 08 11:53:50 milos-hp kscreenlocker_greet[2518]: kf.kirigami: Failed to find a Kirigami platform plugin
May 08 11:53:50 milos-hp kscreenlocker_greet[2518]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
May 08 11:56:04 milos-hp kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
May 08 11:56:04 milos-hp kernel: done.
May 08 11:56:08 milos-hp kded5[787]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/2”"
May 08 11:56:08 milos-hp kdeconnectd[1050]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/2”"
May 08 11:57:02 milos-hp plasmashell[856]: trying to show an empty dialog
May 08 11:59:53 milos-hp plasmashell[856]: org.kde.klipper: Invalid or non-local url for preview: QUrl("journalctl")
May 08 11:59:53 milos-hp plasmashell[856]: org.kde.klipper: Invalid or non-local url for preview: QUrl("-b0")
May 08 12:02:22 milos-hp kded5[787]: org.kde.plasma.nm.kded: Unhandled active connection state change: 3
May 08 12:02:23 milos-hp kscreenlocker_greet[2809]: kf.kirigami: Failed to find a Kirigami platform plugin
May 08 12:02:23 milos-hp kscreenlocker_greet[2809]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
May 08 12:05:16 milos-hp kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
May 08 12:05:16 milos-hp kernel: done.
May 08 12:05:20 milos-hp kded5[787]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/2”"
May 08 12:05:20 milos-hp kdeconnectd[1050]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/2”"
May 08 12:05:24 milos-hp plasmashell[856]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
May 08 12:05:25 milos-hp plasmashell[856]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
May 08 12:05:25 milos-hp plasmashell[856]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kicker/contents/ui/ItemListDialog.qml:73: TypeError: Cannot call method 'hasOwnProperty' of null
May 08 12:05:27 milos-hp ksmserver-logout-greeter[2957]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
May 08 12:05:29 milos-hp plasmashell[856]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:125: TypeError: Cannot read property 'compactRepresentationItem' of null
May 08 12:05:29 milos-hp kaccess[1063]: The X11 connection broke (error 1). Did the X11 server die?
May 08 12:05:29 milos-hp systemd[639]: app-kaccess@autostart.service: Failed with result 'exit-code'.
May 08 12:05:29 milos-hp kwin_wayland[676]: QtDBus: cannot relay signals from parent QObject(0x55858147ed20 "") unless they are emitted in the object's thread QThread(0x55858131aef8 "libinput-connection"). Current thread is QThread(0x5585812903b0 "").
May 08 12:05:29 milos-hp kded5[787]: The Wayland connection broke. Did the Wayland compositor die?
May 08 12:05:29 milos-hp kwalletd5[651]: The Wayland connection broke. Did the Wayland compositor die?
May 08 12:05:29 milos-hp plasmashell[856]: The Wayland connection broke. Did the Wayland compositor die?
May 08 12:05:29 milos-hp kactivitymanagerd[900]: The Wayland connection broke. Did the Wayland compositor die?
May 08 12:05:29 milos-hp polkit-kde-authentication-agent-1[902]: The Wayland connection broke. Did the Wayland compositor die?
May 08 12:05:29 milos-hp xdg-desktop-portal-kde[904]: The Wayland connection broke. Did the Wayland compositor die?
May 08 12:05:29 milos-hp kdeconnectd[1050]: The Wayland connection broke. Did the Wayland compositor die?
May 08 12:05:29 milos-hp msm_kde_notifier[1048]: The Wayland connection broke. Did the Wayland compositor die?
May 08 12:05:29 milos-hp org_kde_powerdevil[903]: The Wayland connection broke. Did the Wayland compositor die?
May 08 12:05:29 milos-hp pamac-tray-plasma[1066]: The Wayland connection broke. Did the Wayland compositor die?
May 08 12:05:29 milos-hp systemd[639]: plasma-kactivitymanagerd.service: Failed with result 'exit-code'.
May 08 12:05:29 milos-hp systemd[639]: plasma-polkit-agent.service: Failed with result 'exit-code'.
May 08 12:05:29 milos-hp systemd[639]: plasma-xdg-desktop-portal-kde.service: Failed with result 'exit-code'.
May 08 12:05:29 milos-hp systemd[639]: app-org.kde.kdeconnect.daemon@autostart.service: Failed with result 'exit-code'.
May 08 12:05:29 milos-hp systemd[639]: app-msm_kde_notifier@autostart.service: Failed with result 'exit-code'.
May 08 12:05:29 milos-hp systemd[639]: app-pamac\x2dtray\x2dplasma@autostart.service: Failed with result 'exit-code'.
May 08 12:05:29 milos-hp systemd[639]: plasma-kded.service: Failed with result 'exit-code'.
May 08 12:05:29 milos-hp systemd[639]: plasma-powerdevil.service: Failed with result 'exit-code'.
May 08 12:05:29 milos-hp systemd[639]: plasma-plasmashell.service: Failed with result 'exit-code'.
May 08 12:05:30 milos-hp pulseaudio[1178]: Error opening PCM device _ucm0001.hw:sofhdadsp,4: No such device
May 08 12:05:30 milos-hp pulseaudio[1178]: Error opening PCM device _ucm0001.hw:sofhdadsp,3: No such device
May 08 12:05:30 milos-hp pulseaudio[1178]: Error opening PCM device _ucm0001.hw:sofhdadsp: No such device
May 08 12:05:30 milos-hp pulseaudio[1178]: Error opening PCM device _ucm0001.hw:sofhdadsp,6: No such device
May 08 12:05:30 milos-hp systemd[3029]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
May 08 12:05:30 milos-hp systemd[3029]: Failed to start Update XDG user dir configuration.
May 08 12:05:30 milos-hp sddm-greeter[3038]: QFont::fromString: Invalid description '(empty)'
May 08 12:05:30 milos-hp sddm-greeter[3038]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffeeeafc3b0), parent's thread is QThread(0x56337e484a60), current thread is QThread(0x56337e5e15f0)
May 08 12:05:30 milos-hp sddm-greeter[3038]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
May 08 12:05:30 milos-hp sddm-greeter[3038]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
May 08 12:05:30 milos-hp sddm-greeter[3038]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
May 08 12:05:30 milos-hp sddm-greeter[3038]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
May 08 12:05:30 milos-hp sddm-greeter[3038]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
May 08 12:05:31 milos-hp sddm-greeter[3038]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
May 08 12:05:39 milos-hp kernel: kauditd_printk_skb: 4 callbacks suppressed
May 08 12:05:39 milos-hp wireplumber[987]: <WpPortalPermissionStorePlugin:0x5602c91657a0> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
May 08 12:05:39 milos-hp ksplashqml[3092]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
May 08 12:05:39 milos-hp ksplashqml[3092]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
May 08 12:05:39 milos-hp kwalletd5[3077]: kf.wallet.kwalletd: Wallet failed to get opened by PAM, error code is -9
May 08 12:05:39 milos-hp ksmserver[3154]: Qt: Session management error: networkIdsList argument is NULL
May 08 12:05:39 milos-hp ksmserver[3154]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.84'
May 08 12:05:39 milos-hp kwin_x11[3158]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
May 08 12:05:39 milos-hp kwin_x11[3158]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
May 08 12:05:39 milos-hp plasmashell[3240]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
May 08 12:05:39 milos-hp plasmashell[3240]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
May 08 12:05:39 milos-hp plasmashell[3240]: Checking screens: available: (QScreen(0x5577396c5110, name="eDP-1")) redundant: QHash() fake: QSet() all: (QScreen(0x5577396c5110, name="eDP-1"))
May 08 12:05:39 milos-hp org_kde_powerdevil[3296]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
May 08 12:05:40 milos-hp kded5[3157]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.84'
May 08 12:05:40 milos-hp kded5[3157]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.30: cannot open shared object file: No such file or directory)"
May 08 12:05:40 milos-hp kded5[3157]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
May 08 12:05:40 milos-hp kioslave5[3403]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
May 08 12:05:40 milos-hp org_kde_powerdevil[3296]: org.kde.powerdevil: Handle button events action could not check for screen configuration
May 08 12:05:40 milos-hp org_kde_powerdevil[3296]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
May 08 12:05:40 milos-hp plasmashell[3240]: file:///usr/share/plasma/plasmoids/org.kde.kscreen/contents/ui/main.qml:30:5: Unable to assign [undefined] to bool
May 08 12:05:40 milos-hp plasmashell[3240]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
May 08 12:05:40 milos-hp plasmashell[3240]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
May 08 12:05:40 milos-hp plasmashell[3240]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:95: TypeError: Cannot read property 'airplaneModeAvailable' of null
May 08 12:05:40 milos-hp plasmashell[3240]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
May 08 12:05:40 milos-hp plasmashell[3240]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
May 08 12:05:40 milos-hp plasmashell[3240]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
May 08 12:05:40 milos-hp pulseaudio[3524]: stat('/etc/pulse/default.pa.d'): No such file or directory
May 08 12:05:41 milos-hp plasmashell[3240]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
May 08 12:05:42 milos-hp plasmashell[3240]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
May 08 12:05:45 milos-hp plasmashell[3240]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
May 08 12:05:52 milos-hp konsole[3852]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
May 08 12:05:52 milos-hp konsole[3852]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
