Ok, so I am very very very new to Manjaro & Linux so, today I was trying to install hydra 7 got this error
sudo pacman -S hydra ![]()
resolving dependencies…
:: installing icu (72.1-1) breaks dependency ‘libicuuc.so=71-64’ required by harfbuzz-icu
:: installing icu (72.1-1) breaks dependency ‘icu<71.2’ required by manjaro-settings-manager
:: installing icu (72.1-1) breaks dependency ‘libicuuc.so=71-64’ required by raptor
You need to update your system before you can safely install new packages. pamac can help you with that. If you want to use pacman you need to remember that.
Always update before installing new packages.
With pacman do:
sudo pacman -Syu hydra
Hi @Sandy1, and welcome!
First things first:
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
- [HowTo] Provide System Information,
- [HowTo] Post screenshots and links,
- [HowTo] Request support, and
- [HowTo] Post command output and file content as preformatted text.
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Also, if your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Next:
I am unable to find a hydra 7, the closest I find is hydra in the community reepository:
$ pamac search hydra
hydra 9.4-1 community
Very fast network logon cracker which support many different services
That it is actually Arch Linux’s pacman’s installation command, and while that command should, in theory work, I recommend Manjaro’s pamac instead. And while we’re at it let’s start by refreshing the mirrors:
sudo pacman-mirrors --fasttrack 5
This will select the 5 fastest mirrors to you.
Now, let’s try installing that package:
pamac install hydra
Hope it helps!
I got this error
sudo pacman -Syu hydra ✔
[sudo] password for swastik:
Sw@Sorry, try again.
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: Replace at-spi2-atk with extra/at-spi2-core? [Y/n]
:: Replace atk with extra/at-spi2-core? [Y/n]
:: Replace kwayland-server with extra/kwin? [Y/n]
:: Replace lib32-atk with multilib/lib32-at-spi2-core? [Y/n]
:: Replace steam-manjaro with multilib/steam? [Y/n]
:: Replace steam-native with multilib/steam-native-runtime? [Y/n]
resolving dependencies...
warning: dependency cycle detected:
warning: mesa will be installed before its libglvnd dependency
warning: smbclient will be installed before its cifs-utils dependency
warning: lib32-mesa will be installed before its lib32-libglvnd dependency
warning: rubygems will be installed before its ruby dependency
warning: ruby-abbrev will be installed before its ruby dependency
warning: ruby-base64 will be installed before its ruby dependency
warning: ruby-benchmark will be installed before its ruby dependency
warning: ruby-bigdecimal will be installed before its ruby dependency
warning: ruby-bundler will be installed before its ruby dependency
warning: ruby-cgi will be installed before its ruby dependency
warning: ruby-csv will be installed before its ruby dependency
warning: ruby-date will be installed before its ruby dependency
warning: ruby-delegate will be installed before its ruby dependency
warning: ruby-did_you_mean will be installed before its ruby dependency
warning: ruby-digest will be installed before its ruby dependency
warning: ruby-drb will be installed before its ruby dependency
warning: ruby-ruby2_keywords will be installed before its ruby dependency
warning: ruby-english will be installed before its ruby dependency
warning: ruby-erb will be installed before its ruby dependency
warning: ruby-etc will be installed before its ruby dependency
warning: ruby-fcntl will be installed before its ruby dependency
warning: ruby-fiddle will be installed before its ruby dependency
warning: ruby-fileutils will be installed before its ruby dependency
warning: ruby-find will be installed before its ruby dependency
warning: ruby-forwardable will be installed before its ruby dependency
warning: ruby-getoptlong will be installed before its ruby dependency
warning: ruby-io-console will be installed before its ruby dependency
warning: ruby-io-nonblock will be installed before its ruby dependency
warning: ruby-io-wait will be installed before its ruby dependency
warning: ruby-ipaddr will be installed before its ruby dependency
warning: ruby-irb will be installed before its ruby dependency
warning: ruby-reline will be installed before its ruby dependency
warning: ruby-json will be installed before its ruby dependency
warning: ruby-logger will be installed before its ruby dependency
warning: ruby-mutex_m will be installed before its ruby dependency
warning: ruby-net-http will be installed before its ruby dependency
warning: ruby-uri will be installed before its ruby dependency
warning: ruby-open-uri will be installed before its ruby dependency
warning: ruby-stringio will be installed before its ruby dependency
warning: ruby-time will be installed before its ruby dependency
warning: ruby-psych will be installed before its ruby dependency
warning: ruby-racc will be installed before its ruby dependency
warning: ruby-rdoc will be installed before its ruby dependency
warning: ruby-tmpdir will be installed before its ruby dependency
warning: ruby-minitest will be installed before its ruby dependency
warning: ruby-power_assert will be installed before its ruby dependency
warning: ruby-test-unit will be installed before its ruby dependency
warning: ruby-bundledgems will be installed before its ruby dependency
Packages (695) acpid-2.0.34-1 afpfs-ng-0.8.2-2 aha-0.5.1-2 alsa-card-profiles-1:0.3.59-2 alsa-lib-1.2.8-1 alsa-ucm-conf-1.2.8-1 alsa-utils-1.2.8-1 android-tools-33.0.3-1 android-udev-20220903-1
aom-3.5.0-1 appstream-0.15.5-1 appstream-glib-0.8.1-1 appstream-qt-0.15.5-1 apr-1.7.0-3 apr-util-1.6.1-9 archlinux-appstream-data-20221014-1 ark-22.08.2-1 at-spi2-atk-2.38.0-1 [removal]
at-spi2-core-2.46.0-2 atk-2.38.0-1 [removal] attica-5.99.0-1 baloo-5.99.0-1 baloo-widgets-22.08.2-1 binutils-2.39-3 bluedevil-1:5.26.2-1 bluez-5.65-3 bluez-libs-5.65-3 bluez-qt-5.99.0-1
boost-libs-1.80.0-3 breeze-5.26.2-1 breeze-icons-5.99.0-1 btrfs-progs-6.0-1 ca-certificates-20220905-1 ca-certificates-mozilla-3.84-1 ca-certificates-utils-20220905-1 chromaprint-1.5.1-4
cifs-utils-7.0-1 clang-14.0.6-3 cmake-3.24.2-1 cpupower-6.0-1 curl-7.86.0-1 cython-0.29.32-2 dbus-1.14.4-1 device-mapper-2.03.16-2 dhclient-4.4.3.P1-1 dmraid-1.0.0.rc16.3-14
dnsmasq-2.87-1 dolphin-22.08.2-1 dolphin-plugins-22.08.2-1 double-conversion-3.2.1-1 easyeffects-6.3.0-1 enchant-2.3.3-2 expat-2.5.0-1 extra-cmake-modules-5.99.0-1 f2fs-tools-1.15.0-2
faad2-2.10.1-1 faudio-22.10-1 ffmpeg-2:5.1.2-1 ffmpegthumbs-22.08.2-1 file-5.43-1 filesystem-2022.10.18-1 firefox-106.0.4-1 firefox-i18n-en-us-106.0.4-1 flac-1.4.2-1 flashrom-1.2-4
flatpak-1:1.14.0-1 fluidsynth-2.3.0-2 fmt-9.1.0-1 fontconfig-2:2.14.1-2 fortune-mod-3.14.1-1 frameworkintegration-5.99.0-1 freeglut-3.4.0-1 freerdp-2:2.8.1-2 fuse-common-3.12.0-1
fuse3-3.12.0-1 fwupd-1.8.6-1 fwupd-efi-1.3-1 game-devices-udev-0.18-1 gawk-5.2.0-3 gc-8.2.2-1 gcab-1.5-1 gcc-12.2.0-1 gcc-libs-12.2.0-1 gcr-3.41.1-2 gdk-pixbuf2-2.42.10-1
geoclue-2.6.0-3 geocode-glib-3.26.4-1 gettext-0.21.1-1 ghostscript-10.0.0-1 git-2.38.1-1 glew-2.2.0-5 glib-networking-1:2.74.0-1 glib2-2.74.1-1 glibc-2.36-6 glibmm-2.66.5-1
glslang-11.11.0-1 gnome-desktop-1:42.4-1 gnome-desktop-4-1:42.4-1 gnome-desktop-common-1:42.4-1 gnupg-2.2.40-1 gnustep-base-1.28.0-5 gnutls-3.7.8-1 gobject-introspection-runtime-1.74.0-1
gpgme-1.18.0-1 grantlee-5.3.0-1 grep-3.8-2 grub-2.06.r261.g2f4430cc0-3 gsm-1.0.22-1 gst-libav-1.20.4-1 gst-plugin-pipewire-1:0.3.59-2 gst-plugins-bad-1.20.4-1 gst-plugins-bad-libs-1.20.4-1
gst-plugins-base-1.20.4-1 gst-plugins-base-libs-1.20.4-1 gst-plugins-good-1.20.4-1 gst-plugins-ugly-1.20.4-1 gstreamer-1.20.4-1 gtk-update-icon-cache-1:4.8.2-1
gtk3-1:3.24.34+r156+g812b3930d0-1 gtk4-1:4.8.2-1 gwenview-22.08.2-1 harfbuzz-5.3.1-3 harfbuzz-icu-5.3.1-3 hdparm-9.65-1 highway-1.0.1-1 hunspell-1.7.1-1 hwdata-0.363-1 hwinfo-22.1-1
iana-etc-20221025-1 icu-72.1-1 imagemagick-7.1.0.51-1 imath-3.1.5-3 imlib2-1.9.1-2 inetutils-2.3-1 intel-ucode-20220809-1 inxi-3.3.23.1-1 iproute2-6.0.0-1 iso-codes-4.11.0-2
jdk17-openjdk-17.0.5.u1-1 jre17-openjdk-17.0.5.u1-1 jre17-openjdk-headless-17.0.5.u1-1 kaccounts-integration-22.08.2-1 kaccounts-providers-22.08.2-1 kactivities-5.99.0-1
kactivities-stats-5.99.0-1 kactivitymanagerd-5.26.2-1 kamera-22.08.2-1 karchive-5.99.0-1 kate-22.08.2-1 kauth-5.99.0-1 kbookmarks-5.99.0-1 kcalc-22.08.2-1 kcmutils-5.99.0-2
kcodecs-5.99.0-1 kcompletion-5.99.0-1 kconfig-5.99.0-1 kconfigwidgets-5.99.0-1 kcontacts-1:5.99.0-1 kcoreaddons-5.99.0-1 kcrash-5.99.0-1 kdbusaddons-5.99.0-1 kde-cli-tools-5.26.2-1
kde-gtk-config-5.26.2-1 kdeclarative-5.99.0-1 kdeconnect-22.08.2-1 kdecoration-5.26.2-1 kded-5.99.0-1 kdegraphics-mobipocket-22.08.2-1 kdegraphics-thumbnailers-22.08.2-1
kdelibs4support-5.99.0-1 kdenetwork-filesharing-22.08.2-1 kdeplasma-addons-5.26.2-1 kdesu-5.99.0-1 kdnssd-5.99.0-1 kdoctools-5.99.0-1 kdsoap-2.1.1-1 kemoticons-5.99.0-1
kfilemetadata-5.99.0-1 kfind-22.08.2-1 kgamma5-5.26.2-1 kglobalaccel-5.99.0-1 kguiaddons-5.99.0-2 khelpcenter-22.08.2-1 kholidays-1:5.99.0-1 khotkeys-5.26.2-1 khtml-5.99.0-1
ki18n-5.99.0-1 kiconthemes-5.99.0-1 kidletime-5.99.0-1 kimageformats-5.99.0-2 kinfocenter-5.26.2-1 kinit-5.99.0-1 kio-5.99.0-1 kio-extras-22.08.2-1 kirigami2-5.99.0-1 kitemmodels-5.99.0-1
kitemviews-5.99.0-1 kjobwidgets-5.99.0-1 kjs-5.99.0-1 kmenuedit-5.26.2-1 knewstuff-5.99.0-1 knotifications-5.99.0-1 knotifyconfig-5.99.0-1 konsole-22.08.2-1 konversation-22.08.2-1
kpackage-5.99.0-1 kparts-5.99.0-1 kpeople-5.99.0-1 kpipewire-5.26.2-1 kpmcore-22.08.2-1 kpty-5.99.0-1 kquickcharts-5.99.0-1 krb5-1.20-1 krunner-5.99.0-1 kscreen-5.26.2-1
kscreenlocker-5.26.2-1 kservice-5.99.0-1 ksshaskpass-5.26.2-1 ksystemlog-22.08.2-1 ksystemstats-5.26.2-1 ktexteditor-5.99.0-1 ktextwidgets-5.99.0-1 kunitconversion-5.99.0-1
kwallet-5.99.0-1 kwallet-pam-5.26.2-1 kwalletmanager-22.08.2-1 kwayland-5.99.0-1 kwayland-integration-5.26.2-1 kwayland-server-5.24.6-1 [removal] kwidgetsaddons-5.99.0-1 kwin-5.26.2.1-2
kwindowsystem-5.99.0-1 kwrited-5.26.2-1 kxmlgui-5.99.0-1 layer-shell-qt-5.26.2-1 ldb-2:2.6.1-1 ldns-1.8.3-1 less-1:608-1 lib32-alsa-lib-1.2.8-1 lib32-at-spi2-core-2.46.0-2
lib32-atk-2.38.0-1 [removal] lib32-curl-7.86.0-1 lib32-dbus-1.14.4-1 lib32-expat-2.5.0-2 lib32-faudio-22.10-1 lib32-flac-1.4.2-1 lib32-fontconfig-2:2.14.1-2 lib32-freeglut-3.4.0-1
lib32-gcc-libs-12.2.0-1 lib32-gdk-pixbuf2-2.42.10-1 lib32-glib2-2.74.1-1 lib32-glibc-2.36-6 lib32-gnutls-3.7.8-1 lib32-gtk2-2.24.33-2 lib32-harfbuzz-5.3.1-3 lib32-icu-72.1-1
lib32-krb5-1.20-1 lib32-libcap-2.66-1 lib32-libcurl-compat-7.86.0-1 lib32-libcurl-gnutls-7.86.0-1 lib32-libdrm-2.4.113-1 lib32-libffi-3.4.4-1 lib32-libglvnd-1.5.0-1
lib32-libjpeg-turbo-2.1.4-2 lib32-libnm-1.40.2-1 lib32-libpng-1.6.38-1 lib32-libsndfile-1.1.0-2 lib32-libtasn1-4.19.0-1 lib32-libtiff-4.4.0-4 lib32-libtirpc-1.3.3-1 lib32-libva-2.15.0-6
lib32-libva-mesa-driver-22.2.1-1 lib32-libvpx1.3-1.3.0-3 lib32-libwebp-1.2.4-1 lib32-libxml2-2.10.3-2 lib32-mesa-22.2.1-1 lib32-mesa-vdpau-22.2.1-1 lib32-nspr-4.35-1 lib32-nss-3.84-1
lib32-pango-1:1.50.11-1 lib32-pcre-8.45-3 lib32-pcre2-10.40-3 lib32-pipewire-1:0.3.59-2 lib32-readline-8.2.0-1 lib32-sdl12-compat-1.2.56-1 lib32-sdl2-2.24.1-1 lib32-sdl2_image-2.6.1-1
lib32-smpeg-0.4.5-4 lib32-sqlite-3.39.3-1 lib32-systemd-251.7-1 lib32-util-linux-2.38.1-1 lib32-vulkan-icd-loader-1.3.226-1 lib32-vulkan-intel-22.2.1-1 lib32-vulkan-radeon-22.2.1-1
lib32-xz-5.2.7-1 lib32-zlib-1.2.13-1 libaccounts-glib-1.26-1 libadwaita-1:1.2.0-1 libatomic_ops-7.6.14-1 libblockdev-2.28-1 libbluray-1.3.3-1 libbpf-1.0.1-1 libbsd-0.11.7-1 libcap-2.66-1
libcbor-0.9.0-1 libcdio-2.1.0-3 libcdr-0.1.7-5 libcurl-compat-7.86.0-1 libcurl-gnutls-7.86.0-1 libde265-1.0.9-1 libdrm-2.4.113-3 libe-book-0.1.3-12 libebml-1.4.4-1 libetonyek-0.1.10-2
libevdev-1.13.0-1 libevent-2.1.12-2 libfbclient-4.0.0.2496-1 libffi-3.4.4-1 libfontenc-1.1.6-1 libgit2-1:1.5.0-1 libglvnd-1.5.0-1 libgpg-error-1.46-1 libgssglue-0.7-1 libgusb-0.4.2-1
libhandy-1.8.0-1 libheif-1.13.0-2 libibus-1.5.27-1 libical-3.0.16-2 libimagequant-4.0.4-1 libinih-56-1 libixion-0.17.0-3 libjcat-0.1.11-1 libjpeg-turbo-2.1.4-2 libjxl-0.7.0-3
libkdcraw-22.08.2-1 libkexiv2-22.08.2-1 libksba-1.6.2-1 libkscreen-5.26.2-1 libksysguard-5.26.2-1 libltc-1.3.2-1 libmalcontent-0.10.5-1 libmatroska-1.7.1-1 libmaxminddb-1.7.1-1
libmbim-1.28.0-1 libmemcached-awesome-1.1.2-1 libmm-glib-1.20.0-1 libmspub-0.1.4-13 libnfs-5.0.2-1 libnftnl-1.2.3-1 libnghttp2-1.50.0-1 libnm-1.40.2-1 libopenmpt-0.6.6-2 liborcus-0.17.2-3
libpamac-11.3.1-3 libpamac-flatpak-plugin-11.3.1-3 libpciaccess-0.17-1 libpng-1.6.38-1 libqalculate-4.4.0-2 libqmi-1.32.0-1 libqxp-0.0.2-9 libreoffice-still-7.3.6-4 librsvg-2:2.55.1-1
libsmbios-2.4.3-5 libsndfile-1.1.0-3 libsoup-2.74.3-1 libsoup3-3.2.1-1 libspectre-0.2.10-2 libssh-0.10.4-1 libtasn1-4.19.0-1 libtiff-4.4.0-4 libtirpc-1.3.3-1 libtool-2.4.7-5
libtorrent-rasterbar-1:2.0.8-1 liburcu-0.13.2-1 libutf8proc-2.7.0-2 libva-2.16.0-1 libva-mesa-driver-22.2.1-1 libvisio-0.1.7-8 libwacom-2.5.0-1 libwebp-1.2.4-1 libwpe-1.14.0-1
libxau-1.0.10-1 libxcvt-0.1.2-1 libxext-1.3.5-1 libxfont2-2.0.6-1 libxft-2.3.6-1 libxinerama-1.1.5-1 libxkbfile-1.1.1-1 libxml++-3.2.4-1 libxml2-2.10.3-2 libxmu-1.1.4-1
libxrender-0.9.11-1 libxshmfence-1.3.1-1 libxslt-1.1.37-2 libxtst-1.2.4-1 libxxf86vm-1.1.5-1 libzmf-0.0.2-13 lilv-0.24.20-1 linux-firmware-20220913.f09bebf-1
linux-firmware-whence-20220913.f09bebf-1 linux510-5.10.151-1 linux515-5.15.76-1 linux60-6.0.6-1 lirc-1:0.10.2-1 lsof-4.96.4-1 lsp-plugins-1.2.3-1 lua-5.4.4-2
luajit-2.1.0.beta3.r449.gdad04f17-1 lutris-0.5.11-1 lv2-1.18.10-1 lvm2-2.03.16-2 lz4-1:1.9.4-1 man-db-2.11.0-1 man-pages-6.01-1 manjaro-alsa-20221002-1 manjaro-pipewire-20221015-2
manjaro-release-22.0.0pre3-1 manjaro-settings-manager-0.5.7-11 manjaro-settings-manager-kcm-0.5.7-11 manjaro-settings-manager-knotifier-0.5.7-11 mariadb-libs-10.9.3-1 memtest86+-6.00-1
mesa-22.2.1-1 mesa-vdpau-22.2.1-1 mhwd-0.6.5-23 mhwd-db-0.6.5-23 mhwd-nvidia-520.56.06-2 mhwd-nvidia-390xx-390.154-2 mhwd-nvidia-470xx-470.141.03-3 milou-5.26.2-1 minizip-1:1.2.13-1
mkinitcpio-32-2 modemmanager-1.20.0-1 modemmanager-qt-5.99.0-1 mongo-c-driver-1.23.1-1 mujs-1.3.0-1 nano-6.4-1 ndctl-74-1 neon-0.32.4-1 nerd-fonts-noto-sans-mono-2.2.2-1 nettle-3.8.1-1
networkmanager-1.40.2-1 networkmanager-openvpn-1.10.0-1 networkmanager-qt-5.99.0-1 nfs-utils-2.6.2-1 nfsidmap-2.6.2-1 noto-fonts-20220810-1 nspr-4.35-1 nss-3.84-1 obs-studio-28.0.3-2
okular-22.08.2-1 openmpi-4.1.4-4 openpmix-4.2.2-1 openssh-9.1p1-1 orc-0.4.32-2 ostree-2022.6-1 oxygen-5.26.2-1 oxygen-icons-1:5.99.0-1 oxygen-sounds-5.26.2-1 pacman-6.0.2-2
pamac-cli-10.4.2-2 pamac-gtk-10.4.2-2 pambase-20221020-1 pango-1:1.50.11-1 partitionmanager-22.08.2-1 pcre-8.45-3 pcre2-10.40-3 pcsclite-1.9.9-1 perl-html-parser-3.79-1
perl-http-message-6.41-1 perl-uri-5.16-1 pinentry-1.2.1-1 pipewire-1:0.3.59-2 pipewire-alsa-1:0.3.59-2 pipewire-audio-1:0.3.59-2 pipewire-pulse-1:0.3.59-2 pipewire-zeroconf-1:0.3.59-2
pixman-0.42.0-1 plasma-desktop-5.26.2-1 plasma-framework-5.99.0-1 plasma-integration-5.26.2-1 plasma-nm-5.26.2-1 plasma-pa-5.26.2-1 plasma-systemmonitor-5.26.2-1 plasma-workspace-5.26.2-1
polkit-122-1 polkit-kde-agent-5.26.2-1 poppler-22.10.0-1 poppler-qt5-22.10.0-1 postgresql-libs-14.5-2 powerdevil-5.26.2-1 powertop-2.15-1 ppp-2.4.9-2 prison-5.99.0-1 protobuf-21.7-1
protobuf-c-1.4.1-1 purpose-5.99.0-1 pyside6-6.4.0.1-1 python-3.10.8-2 python-appdirs-1.4.4-7 python-autocommand-2.2.1-1 python-certifi-2022.09.24-1 python-idna-3.4-1
python-importlib-metadata-5.0.0-1 python-inflect-6.0.2-1 python-jaraco.context-4.1.2-1 python-jaraco.functools-3.5.2-1 python-jaraco.text-3.10.0-1 python-markdown-3.4.1-2
python-more-itertools-9.0.0-1 python-nspektr-0.4.0-2 python-ordered-set-4.1.0-1 python-pillow-9.3.0-1 python-pydantic-1.10.2-1 python-pyqt5-5.15.7-2 python-setuptools-1:63.4.3-1
python-six-1.16.0-6 python-systemd-235-1 python-trove-classifiers-2022.10.19-1 python-typing_extensions-4.4.0-1 python-urllib3-1.26.12-1 python-validate-pyproject-0.10.1-1
python-zipp-3.10.0-1 qbittorrent-4.4.5-1 qca-qt5-2.3.5-1 qqc2-desktop-style-5.99.0-1 qt5-base-5.15.6+kde+r181-1 qt5-declarative-5.15.6+kde+r20-1 qt5-graphicaleffects-5.15.6+kde+r0-1
qt5-imageformats-5.15.6+kde+r5-1 qt5-location-5.15.6+kde+r3-1 qt5-multimedia-5.15.6+kde+r1-1 qt5-quickcontrols-5.15.6+kde+r0-1 qt5-quickcontrols2-5.15.6+kde+r5-1 qt5-script-5.15.11-1
qt5-sensors-5.15.6+kde+r0-1 qt5-speech-5.15.6+kde+r1-1 qt5-svg-5.15.6+kde+r9-1 qt5-tools-5.15.6+kde+r1-1 qt5-translations-5.15.6+kde+r2-1 qt5-virtualkeyboard-5.15.6+kde+r1-1
qt5-wayland-5.15.6+kde+r50-1 qt5-webchannel-5.15.6+kde+r3-1 qt5-webengine-5.15.11-1 qt5-x11extras-5.15.6+kde+r0-1 qt6-base-6.4.0-2 qt6-declarative-6.4.0-2 qt6-svg-6.4.0-1
qt6-translations-6.4.0-1 raptor-2.0.15-20 rav1e-0.5.1-2 readline-8.2.0-1 rsync-3.2.7-1 rubberband-3.1.1-1 ruby-3.0.4-18 ruby-abbrev-0.1.0-3 ruby-base64-0.1.1-3 ruby-benchmark-0.2.0-3
ruby-bigdecimal-3.1.2-3 ruby-bundledgems-3.0.4-18 ruby-bundler-2.3.23-1 ruby-cgi-0.3.3-1 ruby-csv-3.2.5-3 ruby-date-3.2.2-3 ruby-delegate-0.2.0-3 ruby-did_you_mean-1.6.1-3
ruby-digest-3.1.0-5 ruby-drb-2.1.0-4 ruby-english-0.7.1-3 ruby-erb-2.2.3-4 ruby-etc-1.3.0-5 ruby-fcntl-1.0.1-3 ruby-fiddle-1.1.0-3 ruby-fileutils-1.6.0-3 ruby-find-0.1.1-3
ruby-forwardable-1.3.2-5 ruby-getoptlong-0.1.1-2 ruby-io-console-0.5.11-2 ruby-io-nonblock-0.1.0-2 ruby-io-wait-0.2.3-3 ruby-ipaddr-1.2.4-2 ruby-irb-1.4.2-1 ruby-json-2.6.2-2
ruby-logger-1.5.1-2 ruby-minitest-5.16.3-1 ruby-mutex_m-0.1.1-2 ruby-net-http-0.2.2-2 ruby-open-uri-0.2.0-3 ruby-power_assert-2.0.2-1 ruby-psych-4.0.6-1 ruby-racc-1.6.0-3 ruby-rdoc-6.4.0-4
ruby-reline-0.3.1-2 ruby-ruby2_keywords-0.0.5-1 ruby-stdlib-3.0.4-18 ruby-stringio-3.0.2-4 ruby-test-unit-3.5.5-1 ruby-time-0.2.0-4 ruby-tmpdir-0.1.2-3 ruby-uri-0.11.0-5 rubygems-3.3.23-1
rust-1:1.64.0-1 samba-4.17.2-1 sddm-0.19.0-9 sddm-kcm-5.26.2-1 sdl12-compat-1.2.56-1 sdl2-2.24.1-1 sdl2_image-2.6.2-2 sdl2_mixer-2.6.2-1 sdl2_ttf-2.20.1-1 serd-0.30.16-1 serf-1.3.9-5
shadow-4.11.1-3 shared-mime-info-2.0+155+gf4e7cbc-1 shiboken6-6.4.0.1-1 signon-kwallet-extension-22.08.2-1 slang-2.3.3-1 smbclient-4.17.2-1 sof-firmware-2.2.2-1 solid-5.99.0-1
sonnet-5.99.0-1 sord-0.16.14-1 source-highlight-3.1.9-9 spectacle-22.08.2-1 sqlite-3.39.4-1 squashfs-tools-4.5.1-2 sratom-0.6.14-1 srt-1.5.1-1 steam-1.0.0.75-2
steam-manjaro-1.0.0.75-1 [removal] steam-native-1.0.0.70-2 [removal] steam-native-runtime-1.0.0.70-4 subversion-1.14.1-6 sudo-1.9.12-1 svt-av1-1.3.0-1 syndication-5.99.0-1
syntax-highlighting-5.99.0-1 systemd-251.7-1 systemd-libs-251.7-1 systemd-sysvcompat-251.7-1 systemsettings-5.26.2-1 taglib-1.13-1 threadweaver-5.99.0-1 tlp-1.5.0-5 tracker3-3.4.1-1
tzdata-2022f-1 unarchiver-1.10.7-7 unzip-6.0-19 upower-1.90.0-1 util-linux-2.38.1-1 util-linux-libs-2.38.1-1 vi-1:070224-6 vte-common-0.70.1-1 vte3-0.70.1-1 vulkan-headers-1:1.3.227-1
vulkan-icd-loader-1.3.226-1 vulkan-intel-22.2.1-1 vulkan-radeon-22.2.1-1 vulkan-tools-1.3.226-1 wayland-protocols-1.27-1 wayland-utils-1.1.0-1 webkit2gtk-2.38.1-1 webkit2gtk-4.1-2.38.1-1
wine-7.19-1 wireless-regdb-2022.08.12-1 wireplumber-0.4.12-1 wireshark-cli-4.0.1-1 wireshark-qt-4.0.1-1 wpa_supplicant-2:2.10-5 wpebackend-fdo-1.14.0-1 x264-3:0.164.r3095.baee400-4
xapian-core-1:1.4.20-1 xcb-util-cursor-0.1.4-1 xcb-util-image-0.4.1-2 xcb-util-keysyms-0.4.1-4 xcb-util-renderutil-0.3.10-1 xcb-util-wm-0.4.2-1 xdg-desktop-portal-1.15.0-1
xdg-desktop-portal-kde-5.26.2-1 xdg-user-dirs-0.18-1 xdg-utils-1.1.3+21+g1a58bc2-2 xf86-video-ati-1:19.1.0.r15.g7a6a34af-1 xfsprogs-5.19.0-2 xkeyboard-config-2.37-1 xmlsec-1.2.36-1
xorg-xsetroot-1.1.3-1 xorgproto-2022.2-1 xz-5.2.7-1 yakuake-22.08.2-1 yay-11.3.0-1 zbar-0.23.90-1 zensu-0.3-7 zlib-1:1.2.13-1 zsh-completions-0.34.0-2 hydra-9.4-1
Total Download Size: 931.46 MiB
Total Installed Size: 7275.84 MiB
Net Upgrade Size: 244.74 MiB
:: Retrieving packages...
gcc-libs-12.2.0-1-x86_64 13.4 MiB 1720 KiB/s 00:08 [#############################################################################] 100%
oxygen-icons-1:5.99.0-1-any 30.6 MiB 1844 KiB/s 00:17 [#############################################################################] 100%
lib32-gcc-libs-12.2.0-1-x86_64 29.8 MiB 2.10 MiB/s 00:14 [#############################################################################] 100%
noto-fonts-20220810-1-any 26.0 MiB 2.27 MiB/s 00:11 [#############################################################################] 100%
webkit2gtk-4.1-2.38.1-1-x86_64 24.0 MiB 2.06 MiB/s 00:12 [#############################################################################] 100%
webkit2gtk-2.38.1-1-x86_64 24.0 MiB 1289 KiB/s 00:19 [#############################################################################] 100%
wireshark-cli-4.0.1-1-x86_64 22.7 MiB 1063 KiB/s 00:22 [#############################################################################] 100%
plasma-workspace-5.26.2-1-x86_64 19.0 MiB 1645 KiB/s 00:12 [#############################################################################] 100%
archlinux-appstream-data-20221014-1-any.pkg.tar.zst failed to download
Total ( 9/670) 931.5 MiB 7.94 MiB/s 01:57 [#############################################################################] 100%
error: failed retrieving file 'archlinux-appstream-data-20221014-1-any.pkg.tar.zst' from mirror.albony.xyz : The requested URL returned error: 404
warning: failed to retrieve some files
error: failed to commit transaction (failed to retrieve some files)
Note: I am using the Indian mirrors
I am going try this again with the US mirrors & give the output
When was the last time you did an upgrade? Because it desperately needs an upgrade. So try and rebuild you mirror pool first:
This will rebuild the mirror pool to the 5 fastest mirrors.
Afterward, completely update the system:
- Start by updating the normal packages, a.k.a. packages from the repositories:
pamac upgrade --enable-downgrade
- The upgrade any packages from the AUR:
pamac upgrade --aur
This will update and, where applicable, download all packages as necessary.
When done, reboot and try the installation again:
pamac install hydra
Edit:
Fixed the upgrade command to split normal packages from AUR package upgrades.
I have seen it a lot and kept my opinion quiet - but it is generally bad advise.
I am sorry to say - this is the attempt-to-cover-all-options - and should not be recommended.
- While downgrade is possible it is unsupported.
- Custom packages should not be rebuild during a system sync
- Including development packages from AUR should never be necessary
I found that here, on the forum, posted by @Aragorn, and it only downloads packages that you have that are newer than the ones on the server. The equivalent of -Syuu IIRC. So it just syncs you system completely, not only one direction.
Edit:
Yes, I apologize, it slipped my mind to split the normal packages from the AUR. Best way would be:
Followed by, if successful:
pamac upgrade --aur
So, I updated my system using the US mirrors & here’s the output:
sudo pacman -Syyu ✔ 44s
core 165.4 KiB 184 KiB/s 00:01 [#############################################################################] 100%
extra 1861.7 KiB 649 KiB/s 00:03 [#############################################################################] 100%
community 7.5 MiB 868 KiB/s 00:09 [#############################################################################] 100%
multilib 173.3 KiB 125 KiB/s 00:01 [#############################################################################] 100%
warning: libglvnd will be installed before its mesa dependency
Packages (681) acpid-2.0.34-1 aha-0.5.1-2 alsa-card-profiles-1:0.3.59-2 alsa-lib-1.2.8-1 alsa-ucm-conf-1.2.8-1 alsa-utils-1.2.8-1 android-tools-33.0.3-1 android-udev-20220903-1 aom-3.5.0-1
appstream-0.15.5-1 appstream-glib-0.8.1-1 appstream-qt-0.15.5-1 archlinux-appstream-data-20221014-1 ark-22.08.2-1 at-spi2-atk-2.38.0-1 [removal] at-spi2-core-2.46.0-2 atk-2.38.0-1 [removal]
attica-5.99.0-1 baloo-5.99.0-1 baloo-widgets-22.08.2-1 binutils-2.39-3 bluedevil-1:5.26.2-1 bluez-5.65-3 bluez-libs-5.65-3 bluez-qt-5.99.0-1 boost-libs-1.80.0-3 breeze-5.26.2-1
breeze-icons-5.99.0-1 btrfs-progs-6.0-1 ca-certificates-20220905-1 ca-certificates-mozilla-3.84-1 ca-certificates-utils-20220905-1 chromaprint-1.5.1-4 cifs-utils-7.0-1 clang-14.0.6-3
cmake-3.24.2-1 cpupower-6.0-1 curl-7.86.0-1 cython-0.29.32-2 dbus-1.14.4-1 device-mapper-2.03.16-2 dhclient-4.4.3.P1-1 dmraid-1.0.0.rc16.3-14 dnsmasq-2.87-1 dolphin-22.08.2-1
dolphin-plugins-22.08.2-1 double-conversion-3.2.1-1 easyeffects-6.3.0-1 enchant-2.3.3-2 expat-2.5.0-1 extra-cmake-modules-5.99.0-1 f2fs-tools-1.15.0-2 faad2-2.10.1-1 faudio-22.10-1
ffmpeg-2:5.1.2-1 ffmpegthumbs-22.08.2-1 file-5.43-1 filesystem-2022.10.18-1 firefox-106.0.4-1 firefox-i18n-en-us-106.0.4-1 flac-1.4.2-1 flashrom-1.2-4 flatpak-1:1.14.0-1
fluidsynth-2.3.0-2 fmt-9.1.0-1 fontconfig-2:2.14.1-2 fortune-mod-3.14.1-1 frameworkintegration-5.99.0-1 freeglut-3.4.0-1 fuse-common-3.12.0-1 fuse3-3.12.0-1 fwupd-1.8.6-1 fwupd-efi-1.3-1
game-devices-udev-0.18-1 gawk-5.2.0-3 gc-8.2.2-1 gcab-1.5-1 gcc-12.2.0-1 gcc-libs-12.2.0-1 gcr-3.41.1-2 gdk-pixbuf2-2.42.10-1 geoclue-2.6.0-3 geocode-glib-3.26.4-1 gettext-0.21.1-1
ghostscript-10.0.0-1 git-2.38.1-1 glew-2.2.0-5 glib-networking-1:2.74.0-1 glib2-2.74.1-1 glibc-2.36-6 glibmm-2.66.5-1 glslang-11.11.0-1 gnome-desktop-1:42.4-1 gnome-desktop-4-1:42.4-1
gnome-desktop-common-1:42.4-1 gnupg-2.2.40-1 gnustep-base-1.28.0-5 gnutls-3.7.8-1 gobject-introspection-runtime-1.74.0-1 gpgme-1.18.0-1 grantlee-5.3.0-1 grep-3.8-2
grub-2.06.r261.g2f4430cc0-3 gsm-1.0.22-1 gst-libav-1.20.4-1 gst-plugin-pipewire-1:0.3.59-2 gst-plugins-bad-1.20.4-1 gst-plugins-bad-libs-1.20.4-1 gst-plugins-base-1.20.4-1
gst-plugins-base-libs-1.20.4-1 gst-plugins-good-1.20.4-1 gst-plugins-ugly-1.20.4-1 gstreamer-1.20.4-1 gtk-update-icon-cache-1:4.8.2-1 gtk3-1:3.24.34+r156+g812b3930d0-1 gtk4-1:4.8.2-1
gwenview-22.08.2-1 harfbuzz-5.3.1-3 harfbuzz-icu-5.3.1-3 hdparm-9.65-1 highway-1.0.1-1 hunspell-1.7.1-1 hwdata-0.363-1 hwinfo-22.1-1 iana-etc-20221025-1 icu-72.1-1 imagemagick-7.1.0.51-1
imath-3.1.5-3 imlib2-1.9.1-2 inetutils-2.3-1 intel-ucode-20220809-1 inxi-3.3.23.1-1 iproute2-6.0.0-1 iso-codes-4.11.0-2 jdk17-openjdk-17.0.5.u1-1 jre17-openjdk-17.0.5.u1-1
jre17-openjdk-headless-17.0.5.u1-1 kaccounts-integration-22.08.2-1 kaccounts-providers-22.08.2-1 kactivities-5.99.0-1 kactivities-stats-5.99.0-1 kactivitymanagerd-5.26.2-1 kamera-22.08.2-1
karchive-5.99.0-1 kate-22.08.2-1 kauth-5.99.0-1 kbookmarks-5.99.0-1 kcalc-22.08.2-1 kcmutils-5.99.0-2 kcodecs-5.99.0-1 kcompletion-5.99.0-1 kconfig-5.99.0-1 kconfigwidgets-5.99.0-1
kcontacts-1:5.99.0-1 kcoreaddons-5.99.0-1 kcrash-5.99.0-1 kdbusaddons-5.99.0-1 kde-cli-tools-5.26.2-1 kde-gtk-config-5.26.2-1 kdeclarative-5.99.0-1 kdeconnect-22.08.2-1
kdecoration-5.26.2-1 kded-5.99.0-1 kdegraphics-mobipocket-22.08.2-1 kdegraphics-thumbnailers-22.08.2-1 kdelibs4support-5.99.0-1 kdenetwork-filesharing-22.08.2-1 kdeplasma-addons-5.26.2-1
kdesu-5.99.0-1 kdnssd-5.99.0-1 kdoctools-5.99.0-1 kdsoap-2.1.1-1 kemoticons-5.99.0-1 kfilemetadata-5.99.0-1 kfind-22.08.2-1 kgamma5-5.26.2-1 kglobalaccel-5.99.0-1 kguiaddons-5.99.0-2
khelpcenter-22.08.2-1 kholidays-1:5.99.0-1 khotkeys-5.26.2-1 khtml-5.99.0-1 ki18n-5.99.0-1 kiconthemes-5.99.0-1 kidletime-5.99.0-1 kimageformats-5.99.0-2 kinfocenter-5.26.2-1
kinit-5.99.0-1 kio-5.99.0-1 kio-extras-22.08.2-1 kirigami2-5.99.0-1 kitemmodels-5.99.0-1 kitemviews-5.99.0-1 kjobwidgets-5.99.0-1 kjs-5.99.0-1 kmenuedit-5.26.2-1 knewstuff-5.99.0-1
knotifications-5.99.0-1 knotifyconfig-5.99.0-1 konsole-22.08.2-1 konversation-22.08.2-1 kpackage-5.99.0-1 kparts-5.99.0-1 kpeople-5.99.0-1 kpipewire-5.26.2-1 kpmcore-22.08.2-1
kpty-5.99.0-1 kquickcharts-5.99.0-1 krb5-1.20-1 krunner-5.99.0-1 kscreen-5.26.2-1 kscreenlocker-5.26.2-1 kservice-5.99.0-1 ksshaskpass-5.26.2-1 ksystemlog-22.08.2-1 ksystemstats-5.26.2-1
ktexteditor-5.99.0-1 ktextwidgets-5.99.0-1 kunitconversion-5.99.0-1 kwallet-5.99.0-1 kwallet-pam-5.26.2-1 kwalletmanager-22.08.2-1 kwayland-5.99.0-1 kwayland-integration-5.26.2-1
kwayland-server-5.24.6-1 [removal] kwidgetsaddons-5.99.0-1 kwin-5.26.2.1-2 kwindowsystem-5.99.0-1 kwrited-5.26.2-1 kxmlgui-5.99.0-1 layer-shell-qt-5.26.2-1 ldb-2:2.6.1-1 ldns-1.8.3-1
less-1:608-1 lib32-alsa-lib-1.2.8-1 lib32-at-spi2-core-2.46.0-2 lib32-atk-2.38.0-1 [removal] lib32-curl-7.86.0-1 lib32-dbus-1.14.4-1 lib32-expat-2.5.0-2 lib32-faudio-22.10-1
lib32-flac-1.4.2-1 lib32-fontconfig-2:2.14.1-2 lib32-freeglut-3.4.0-1 lib32-gcc-libs-12.2.0-1 lib32-gdk-pixbuf2-2.42.10-1 lib32-glib2-2.74.1-1 lib32-glibc-2.36-6 lib32-gnutls-3.7.8-1
lib32-gtk2-2.24.33-2 lib32-harfbuzz-5.3.1-3 lib32-icu-72.1-1 lib32-krb5-1.20-1 lib32-libcap-2.66-1 lib32-libcurl-compat-7.86.0-1 lib32-libcurl-gnutls-7.86.0-1 lib32-libdrm-2.4.113-1
lib32-libffi-3.4.4-1 lib32-libglvnd-1.5.0-1 lib32-libjpeg-turbo-2.1.4-2 lib32-libnm-1.40.2-1 lib32-libpng-1.6.38-1 lib32-libsndfile-1.1.0-2 lib32-libtasn1-4.19.0-1 lib32-libtiff-4.4.0-4
lib32-libtirpc-1.3.3-1 lib32-libva-2.15.0-6 lib32-libva-mesa-driver-22.2.1-1 lib32-libvpx1.3-1.3.0-3 lib32-libwebp-1.2.4-1 lib32-libxml2-2.10.3-2 lib32-mesa-22.2.1-1
lib32-mesa-vdpau-22.2.1-1 lib32-nspr-4.35-1 lib32-nss-3.84-1 lib32-pango-1:1.50.11-1 lib32-pcre-8.45-3 lib32-pcre2-10.40-3 lib32-pipewire-1:0.3.59-2 lib32-readline-8.2.0-1
lib32-sdl12-compat-1.2.56-1 lib32-sdl2-2.24.1-1 lib32-sdl2_image-2.6.1-1 lib32-smpeg-0.4.5-4 lib32-sqlite-3.39.3-1 lib32-systemd-251.7-1 lib32-util-linux-2.38.1-1
lib32-vulkan-icd-loader-1.3.226-1 lib32-vulkan-intel-22.2.1-1 lib32-vulkan-radeon-22.2.1-1 lib32-xz-5.2.7-1 lib32-zlib-1.2.13-1 libaccounts-glib-1.26-1 libadwaita-1:1.2.0-1
libatomic_ops-7.6.14-1 libblockdev-2.28-1 libbluray-1.3.3-1 libbpf-1.0.1-1 libbsd-0.11.7-1 libcap-2.66-1 libcbor-0.9.0-1 libcdio-2.1.0-3 libcdr-0.1.7-5 libcurl-compat-7.86.0-1
libcurl-gnutls-7.86.0-1 libde265-1.0.9-1 libdrm-2.4.113-3 libe-book-0.1.3-12 libebml-1.4.4-1 libetonyek-0.1.10-2 libevdev-1.13.0-1 libevent-2.1.12-2 libffi-3.4.4-1 libfontenc-1.1.6-1
libgit2-1:1.5.0-1 libglvnd-1.5.0-1 libgpg-error-1.46-1 libgusb-0.4.2-1 libhandy-1.8.0-1 libheif-1.13.0-2 libibus-1.5.27-1 libical-3.0.16-2 libimagequant-4.0.4-1 libinih-56-1
libixion-0.17.0-3 libjcat-0.1.11-1 libjpeg-turbo-2.1.4-2 libjxl-0.7.0-3 libkdcraw-22.08.2-1 libkexiv2-22.08.2-1 libksba-1.6.2-1 libkscreen-5.26.2-1 libksysguard-5.26.2-1 libltc-1.3.2-1
libmalcontent-0.10.5-1 libmatroska-1.7.1-1 libmaxminddb-1.7.1-1 libmbim-1.28.0-1 libmm-glib-1.20.0-1 libmspub-0.1.4-13 libnfs-5.0.2-1 libnftnl-1.2.3-1 libnghttp2-1.50.0-1 libnm-1.40.2-1
libopenmpt-0.6.6-2 liborcus-0.17.2-3 libpamac-11.3.1-3 libpamac-flatpak-plugin-11.3.1-3 libpciaccess-0.17-1 libpng-1.6.38-1 libqalculate-4.4.0-2 libqmi-1.32.0-1 libqxp-0.0.2-9
libreoffice-still-7.3.6-4 librsvg-2:2.55.1-1 libsmbios-2.4.3-5 libsndfile-1.1.0-3 libsoup-2.74.3-1 libsoup3-3.2.1-1 libspectre-0.2.10-2 libssh-0.10.4-1 libtasn1-4.19.0-1 libtiff-4.4.0-4
libtirpc-1.3.3-1 libtool-2.4.7-5 libtorrent-rasterbar-1:2.0.8-1 liburcu-0.13.2-1 libva-2.16.0-1 libva-mesa-driver-22.2.1-1 libvisio-0.1.7-8 libwacom-2.5.0-1 libwebp-1.2.4-1
libwpe-1.14.0-1 libxau-1.0.10-1 libxcvt-0.1.2-1 libxext-1.3.5-1 libxfont2-2.0.6-1 libxft-2.3.6-1 libxinerama-1.1.5-1 libxkbfile-1.1.1-1 libxml++-3.2.4-1 libxml2-2.10.3-2 libxmu-1.1.4-1
manjaro-release-22.0.0pre3-1 manjaro-settings-manager-0.5.7-11 manjaro-settings-manager-kcm-0.5.7-11 manjaro-settings-manager-knotifier-0.5.7-11 memtest86+-6.00-1 mesa-22.2.1-1
mesa-vdpau-22.2.1-1 mhwd-0.6.5-23 mhwd-db-0.6.5-23 mhwd-nvidia-520.56.06-2 mhwd-nvidia-390xx-390.154-2 mhwd-nvidia-470xx-470.141.03-3 milou-5.26.2-1 minizip-1:1.2.13-1 mkinitcpio-32-2
modemmanager-1.20.0-1 modemmanager-qt-5.99.0-1 mujs-1.3.0-1 nano-6.4-1 ndctl-74-1 neon-0.32.4-1 nerd-fonts-noto-sans-mono-2.2.2-1 nettle-3.8.1-1 networkmanager-1.40.2-1
networkmanager-openvpn-1.10.0-1 networkmanager-qt-5.99.0-1 nfs-utils-2.6.2-1 nfsidmap-2.6.2-1 noto-fonts-20220810-1 nspr-4.35-1 nss-3.84-1 obs-studio-28.0.3-2 okular-22.08.2-1
openmpi-4.1.4-4 openpmix-4.2.2-1 openssh-9.1p1-1 orc-0.4.32-2 ostree-2022.6-1 oxygen-5.26.2-1 oxygen-icons-1:5.99.0-1 oxygen-sounds-5.26.2-1 pacman-6.0.2-2 pamac-cli-10.4.2-2
pamac-gtk-10.4.2-2 pambase-20221020-1 pango-1:1.50.11-1 partitionmanager-22.08.2-1 pcre-8.45-3 pcre2-10.40-3 pcsclite-1.9.9-1 perl-html-parser-3.79-1 perl-http-message-6.41-1
perl-uri-5.16-1 pinentry-1.2.1-1 pipewire-1:0.3.59-2 pipewire-alsa-1:0.3.59-2 pipewire-audio-1:0.3.59-2 pipewire-pulse-1:0.3.59-2 pipewire-zeroconf-1:0.3.59-2 pixman-0.42.0-1
plasma-desktop-5.26.2-1 plasma-framework-5.99.0-1 plasma-integration-5.26.2-1 plasma-nm-5.26.2-1 plasma-pa-5.26.2-1 plasma-systemmonitor-5.26.2-1 plasma-workspace-5.26.2-1 polkit-122-1
polkit-kde-agent-5.26.2-1 poppler-22.10.0-1 poppler-qt5-22.10.0-1 powerdevil-5.26.2-1 powertop-2.15-1 ppp-2.4.9-2 prison-5.99.0-1 protobuf-21.7-1 protobuf-c-1.4.1-1 purpose-5.99.0-1
pyside6-6.4.0.1-1 python-3.10.8-2 python-appdirs-1.4.4-7 python-autocommand-2.2.1-1 python-certifi-2022.09.24-1 python-idna-3.4-1 python-importlib-metadata-5.0.0-1 python-inflect-6.0.2-1
python-jaraco.context-4.1.2-1 python-jaraco.functools-3.5.2-1 python-jaraco.text-3.10.0-1 python-markdown-3.4.1-2 python-more-itertools-9.0.0-1 python-nspektr-0.4.0-2
python-ordered-set-4.1.0-1 python-pillow-9.3.0-1 python-pydantic-1.10.2-1 python-pyqt5-5.15.7-2 python-setuptools-1:63.4.3-1 python-six-1.16.0-6 python-systemd-235-1
python-trove-classifiers-2022.10.19-1 python-typing_extensions-4.4.0-1 python-urllib3-1.26.12-1 python-validate-pyproject-0.10.1-1 python-zipp-3.10.0-1 qbittorrent-4.4.5-1 qca-qt5-2.3.5-1
qqc2-desktop-style-5.99.0-1 qt5-base-5.15.6+kde+r181-1 qt5-declarative-5.15.6+kde+r20-1 qt5-graphicaleffects-5.15.6+kde+r0-1 qt5-imageformats-5.15.6+kde+r5-1 qt5-location-5.15.6+kde+r3-1
qt5-multimedia-5.15.6+kde+r1-1 qt5-quickcontrols-5.15.6+kde+r0-1 qt5-quickcontrols2-5.15.6+kde+r5-1 qt5-script-5.15.11-1 qt5-sensors-5.15.6+kde+r0-1 qt5-speech-5.15.6+kde+r1-1
qt5-svg-5.15.6+kde+r9-1 qt5-tools-5.15.6+kde+r1-1 qt5-translations-5.15.6+kde+r2-1 qt5-virtualkeyboard-5.15.6+kde+r1-1 qt5-wayland-5.15.6+kde+r50-1 qt5-webchannel-5.15.6+kde+r3-1
qt5-webengine-5.15.11-1 qt5-x11extras-5.15.6+kde+r0-1 qt6-base-6.4.0-2 qt6-declarative-6.4.0-2 qt6-svg-6.4.0-1 qt6-translations-6.4.0-1 raptor-2.0.15-20 rav1e-0.5.1-2 readline-8.2.0-1
rsync-3.2.7-1 rubberband-3.1.1-1 ruby-3.0.4-18 ruby-abbrev-0.1.0-3 ruby-base64-0.1.1-3 ruby-benchmark-0.2.0-3 ruby-bigdecimal-3.1.2-3 ruby-bundledgems-3.0.4-18 ruby-bundler-2.3.23-1
ruby-cgi-0.3.3-1 ruby-csv-3.2.5-3 ruby-date-3.2.2-3 ruby-delegate-0.2.0-3 ruby-did_you_mean-1.6.1-3 ruby-digest-3.1.0-5 ruby-drb-2.1.0-4 ruby-english-0.7.1-3 ruby-erb-2.2.3-4
ruby-etc-1.3.0-5 ruby-fcntl-1.0.1-3 ruby-fiddle-1.1.0-3 ruby-fileutils-1.6.0-3 ruby-find-0.1.1-3 ruby-forwardable-1.3.2-5 ruby-getoptlong-0.1.1-2 ruby-io-console-0.5.11-2
ruby-io-nonblock-0.1.0-2 ruby-io-wait-0.2.3-3 ruby-ipaddr-1.2.4-2 ruby-irb-1.4.2-1 ruby-json-2.6.2-2 ruby-logger-1.5.1-2 ruby-minitest-5.16.3-1 ruby-mutex_m-0.1.1-2 ruby-net-http-0.2.2-2
ruby-open-uri-0.2.0-3 ruby-power_assert-2.0.2-1 ruby-psych-4.0.6-1 ruby-racc-1.6.0-3 ruby-rdoc-6.4.0-4 ruby-reline-0.3.1-2 ruby-ruby2_keywords-0.0.5-1 ruby-stdlib-3.0.4-18
ruby-stringio-3.0.2-4 ruby-test-unit-3.5.5-1 ruby-time-0.2.0-4 ruby-tmpdir-0.1.2-3 ruby-uri-0.11.0-5 rubygems-3.3.23-1 rust-1:1.64.0-1 samba-4.17.2-1 sddm-0.19.0-9 sddm-kcm-5.26.2-1
sdl12-compat-1.2.56-1 sdl2-2.24.1-1 sdl2_image-2.6.2-2 sdl2_mixer-2.6.2-1 sdl2_ttf-2.20.1-1 serd-0.30.16-1 shadow-4.11.1-3 shared-mime-info-2.0+155+gf4e7cbc-1 shiboken6-6.4.0.1-1
signon-kwallet-extension-22.08.2-1 slang-2.3.3-1 smbclient-4.17.2-1 sof-firmware-2.2.2-1 solid-5.99.0-1 sonnet-5.99.0-1 sord-0.16.14-1 source-highlight-3.1.9-9 spectacle-22.08.2-1
sqlite-3.39.4-1 squashfs-tools-4.5.1-2 sratom-0.6.14-1 srt-1.5.1-1 steam-1.0.0.75-2 steam-manjaro-1.0.0.75-1 [removal] steam-native-1.0.0.70-2 [removal] steam-native-runtime-1.0.0.70-4
sudo-1.9.12-1 svt-av1-1.3.0-1 syndication-5.99.0-1 syntax-highlighting-5.99.0-1 systemd-251.7-1 systemd-libs-251.7-1 systemd-sysvcompat-251.7-1 systemsettings-5.26.2-1 taglib-1.13-1
threadweaver-5.99.0-1 tlp-1.5.0-5 tracker3-3.4.1-1 tzdata-2022f-1 unarchiver-1.10.7-7 unzip-6.0-19 upower-1.90.0-1 util-linux-2.38.1-1 util-linux-libs-2.38.1-1 vi-1:070224-6
vte-common-0.70.1-1 vte3-0.70.1-1 vulkan-headers-1:1.3.227-1 vulkan-icd-loader-1.3.226-1 vulkan-intel-22.2.1-1 vulkan-radeon-22.2.1-1 vulkan-tools-1.3.226-1 wayland-protocols-1.27-1
wayland-utils-1.1.0-1 webkit2gtk-2.38.1-1 webkit2gtk-4.1-2.38.1-1 wine-7.19-1 wireless-regdb-2022.08.12-1 wireplumber-0.4.12-1 wireshark-cli-4.0.1-1 wireshark-qt-4.0.1-1
wpa_supplicant-2:2.10-5 wpebackend-fdo-1.14.0-1 x264-3:0.164.r3095.baee400-4 xapian-core-1:1.4.20-1 xcb-util-cursor-0.1.4-1 xcb-util-image-0.4.1-2 xcb-util-keysyms-0.4.1-4
xcb-util-renderutil-0.3.10-1 xcb-util-wm-0.4.2-1 xdg-desktop-portal-1.15.0-1 xdg-desktop-portal-kde-5.26.2-1 xdg-user-dirs-0.18-1 xdg-utils-1.1.3+21+g1a58bc2-2
xf86-video-ati-1:19.1.0.r15.g7a6a34af-1 xfsprogs-5.19.0-2 xkeyboard-config-2.37-1 xmlsec-1.2.36-1 xorg-xsetroot-1.1.3-1 xorgproto-2022.2-1 xz-5.2.7-1 yakuake-22.08.2-1 yay-11.3.0-1
Total Download Size: 719.51 MiB
Total Installed Size: 7186.68 MiB
Net Upgrade Size: 155.58 MiB
archlinux-appstream-data-20221014-1-any 18.0 MiB 1499 KiB/s 00:12 [#############################################################################] 100%
ghostscript-10.0.0-1-x86_64 16.3 MiB 1215 KiB/s 00:14 [#############################################################################] 100%
grub-2.06.r261.g2f4430cc0-3-x86_64 14.8 MiB 806 KiB/s 00:19 [#############################################################################] 100%
qt5-base-5.15.6+kde+r181-1-x86_64 13.0 MiB 1510 KiB/s 00:09 [#############################################################################] 100%
qt6-base-6.4.0-2-x86_64 12.8 MiB 1374 KiB/s 00:10 [#############################################################################] 100%
python-3.10.8-2-x86_64 12.0 MiB 1504 KiB/s 00:08 [#############################################################################] 100%
ffmpeg-2:5.1.2-1-x86_64 11.2 MiB 1038 KiB/s 00:11 [#############################################################################] 100%
icu-72.1-1-x86_64 11.0 MiB 878 KiB/s 00:13 [#############################################################################] 100%
qt6-declarative-6.4.0-2-x86_64 10.8 MiB 935 KiB/s 00:12 [#############################################################################] 100%
cmake-3.24.2-1-x86_64 10.4 MiB 1566 KiB/s 00:07 [#############################################################################] 100%
lib32-icu-72.1-1-x86_64 10.3 MiB 860 KiB/s 00:12 [#############################################################################] 100%
mesa-22.2.1-1-x86_64 10.2 MiB 873 KiB/s 00:12 [#############################################################################] 100%
qt5-virtualkeyboard-5.15.6+kde+r1-1-x86_64 10.0 MiB 918 KiB/s 00:11 [#############################################################################] 100%
lib32-mesa-22.2.1-1-x86_64 10.0 MiB 1277 KiB/s 00:08 [#############################################################################] 100%
glibc-2.36-6-x86_64 is up to date
libibus-1.5.27-1-x86_64 9.7 MiB 1593 KiB/s 00:06 [#############################################################################] 100%
kate-22.08.2-1-x86_64 9.0 MiB 1253 KiB/s 00:07 [#############################################################################] 100%
pyside6-6.4.0.1-1-x86_64 8.8 MiB 1532 KiB/s 00:06 [#############################################################################] 100%
systemd-251.7-1-x86_64 8.7 MiB 1409 KiB/s 00:06 [#############################################################################] 100%
kwin-5.26.2.1-2-x86_64 8.4 MiB 1641 KiB/s 00:05 [#############################################################################] 100%
samba-4.17.2-1-x86_64 8.2 MiB 969 KiB/s 00:09 [#############################################################################] 100%
kio-5.99.0-1-x86_64 8.0 MiB 1372 KiB/s 00:06 [#############################################################################] 100%
gtk3-1:3.24.34+r156+g812b3930d0-1-x86_64 7.7 MiB 1224 KiB/s 00:06 [#############################################################################] 100%
plasma-desktop-5.26.2-1-x86_64 7.6 MiB 758 KiB/s 00:10 [#############################################################################] 100%
okular-22.08.2-1-x86_64 7.0 MiB 1216 KiB/s 00:06 [#############################################################################] 100%
binutils-2.39-3-x86_64 6.9 MiB 952 KiB/s 00:07 [#############################################################################] 100%
gtk4-1:4.8.2-1-x86_64 6.9 MiB 1244 KiB/s 00:06 [#############################################################################] 100%
smbclient-4.17.2-1-x86_64 6.7 MiB 1093 KiB/s 00:06 [#############################################################################] 100%
gwenview-22.08.2-1-x86_64 6.7 MiB 875 KiB/s 00:08 [#############################################################################] 100%
breeze-icons-5.99.0-1-any 6.7 MiB 1183 KiB/s 00:06 [#############################################################################] 100%
git-2.38.1-1-x86_64 6.5 MiB 756 KiB/s 00:09 [#############################################################################] 100%
qbittorrent-4.4.5-1-x86_64 6.3 MiB 1183 KiB/s 00:05 [#############################################################################] 100%
fwupd-1.8.6-1-x86_64 5.5 MiB 869 KiB/s 00:06 [#############################################################################] 100%
man-pages-6.01-1-any 5.5 MiB 997 KiB/s 00:06 [#############################################################################] 100%
obs-studio-28.0.3-2-x86_64 5.3 MiB 1179 KiB/s 00:05 [#############################################################################] 100%
qt5-tools-5.15.6+kde+r1-1-x86_64 5.3 MiB 1246 KiB/s 00:04 [#############################################################################] 100%
qt5-declarative-5.15.6+kde+r20-1-x86_64 4.8 MiB 1145 KiB/s 00:04 [#############################################################################] 100%
khelpcenter-22.08.2-1-x86_64 4.8 MiB 1026 KiB/s 00:05 [#############################################################################] 100%
kwidgetsaddons-5.99.0-1-x86_64 4.8 MiB 1231 KiB/s 00:04 [#############################################################################] 100%
konversation-22.08.2-1-x86_64 4.7 MiB 1083 KiB/s 00:04 [#############################################################################] 100%
python-pyqt5-5.15.7-2-x86_64 4.4 MiB 922 KiB/s 00:05 [#############################################################################] 100%
lsp-plugins-1.2.3-1-x86_64 4.3 MiB 1217 KiB/s 00:04 [#############################################################################] 100%
wireshark-qt-4.0.1-1-x86_64 4.1 MiB 1382 KiB/s 00:03 [#############################################################################] 100%
dolphin-22.08.2-1-x86_64 4.1 MiB 926 KiB/s 00:05 [#############################################################################] 100%
plasma-framework-5.99.0-1-x86_64 4.0 MiB 1098 KiB/s 00:04 [#############################################################################] 100%
imath-3.1.5-3-x86_64 3.9 MiB 1490 KiB/s 00:03 [#############################################################################] 100%
intel-ucode-20220809-1-any 3.9 MiB 1014 KiB/s 00:04 [#############################################################################] 100%
glib2-2.74.1-1-x86_64 3.7 MiB 1266 KiB/s 00:03 [#############################################################################] 100%
manjaro-settings-manager-0.5.7-11-x86_64 3.7 MiB 1402 KiB/s 00:03 [#############################################################################] 100%
ktexteditor-5.99.0-1-x86_64 3.5 MiB 1122 KiB/s 00:03 [#############################################################################] 100%
librsvg-2:2.55.1-1-x86_64 3.5 MiB 1624 KiB/s 00:02 [#############################################################################] 100%
kdelibs4support-5.99.0-1-x86_64 3.5 MiB 902 KiB/s 00:04 [#############################################################################] 100%
networkmanager-1.40.2-1-x86_64 3.5 MiB 1100 KiB/s 00:03 [#############################################################################] 100%
lib32-mesa-vdpau-22.2.1-1-x86_64 3.5 MiB 1314 KiB/s 00:03 [#############################################################################] 100%
steam-1.0.0.75-2-x86_64 3.4 MiB 1083 KiB/s 00:03 [#############################################################################] 100%
sddm-0.19.0-9-x86_64 3.4 MiB 1652 KiB/s 00:02 [#############################################################################] 100%
lib32-glibc-2.36-6-x86_64 3.4 MiB 1042 KiB/s 00:03 [#############################################################################] 100%
libva-mesa-driver-22.2.1-1-x86_64 3.3 MiB 1395 KiB/s 00:02 [#############################################################################] 100%
lib32-libva-mesa-driver-22.2.1-1-x86_64 3.3 MiB 1128 KiB/s 00:03 [#############################################################################] 100%
mesa-vdpau-22.2.1-1-x86_64 3.2 MiB 1346 KiB/s 00:02 [#############################################################################] 100%
manjaro-settings-manager-kcm-0.5.7-11-x86_64 3.2 MiB 1041 KiB/s 00:03 [#############################################################################] 100%
iso-codes-4.11.0-2-any 3.2 MiB 1398 KiB/s 00:02 [#############################################################################] 100%
kwayland-5.99.0-1-x86_64 3.0 MiB 867 KiB/s 00:04 [#############################################################################] 100%
glslang-11.11.0-1-x86_64 2.9 MiB 1039 KiB/s 00:03 [#############################################################################] 100%
yay-11.3.0-1-x86_64 2.9 MiB 904 KiB/s 00:03 [#############################################################################] 100%
oxygen-5.26.2-1-x86_64 2.9 MiB 897 KiB/s 00:03 [#############################################################################] 100%
openmpi-4.1.4-4-x86_64 2.9 MiB 927 KiB/s 00:03 [#############################################################################] 100%
imagemagick-7.1.0.51-1-x86_64 2.8 MiB 1444 KiB/s 00:02 [#############################################################################] 100%
gnutls-3.7.8-1-x86_64 2.8 MiB 1024 KiB/s 00:03 [#############################################################################] 100%
ruby-3.0.4-18-x86_64 2.8 MiB 911 KiB/s 00:03 [#############################################################################] 100%
aom-3.5.0-1-x86_64 2.7 MiB 1625 KiB/s 00:02 [#############################################################################] 100%
libqalculate-4.4.0-2-x86_64 2.6 MiB 1307 KiB/s 00:02 [#############################################################################] 100%
libtorrent-rasterbar-1:2.0.8-1-x86_64 2.5 MiB 864 KiB/s 00:03 [#############################################################################] 100%
khtml-5.99.0-1-x86_64 2.5 MiB 1503 KiB/s 00:02 [#############################################################################] 100%
util-linux-2.38.1-1-x86_64 2.4 MiB 1290 KiB/s 00:02 [#############################################################################] 100%
lib32-vulkan-intel-22.2.1-1-x86_64 2.4 MiB 1323 KiB/s 00:02 [#############################################################################] 100%
gnupg-2.2.40-1-x86_64 2.3 MiB 1684 KiB/s 00:01 [#############################################################################] 100%
gnustep-base-1.28.0-5-x86_64 2.3 MiB 1907 KiB/s 00:01 [#############################################################################] 100%
xapian-core-1:1.4.20-1-x86_64 2.3 MiB 1419 KiB/s 00:02 [#############################################################################] 100%
appstream-0.15.5-1-x86_64 2.2 MiB 1602 KiB/s 00:01 [#############################################################################] 100%
vulkan-intel-22.2.1-1-x86_64 2.2 MiB 1492 KiB/s 00:02 [#############################################################################] 100%
libqmi-1.32.0-1-x86_64 2.2 MiB 1542 KiB/s 00:01 [#############################################################################] 100%
gst-plugins-bad-libs-1.20.4-1-x86_64 2.1 MiB 1409 KiB/s 00:02 [#############################################################################] 100%
gst-plugins-base-libs-1.20.4-1-x86_64 2.1 MiB 1437 KiB/s 00:02 [#############################################################################] 100%
partitionmanager-22.08.2-1-x86_64 2.1 MiB 1284 KiB/s 00:02 [#############################################################################] 100%
boost-libs-1.80.0-3-x86_64 2.1 MiB 1177 KiB/s 00:02 [#############################################################################] 100%
lib32-vulkan-radeon-22.2.1-1-x86_64 2.1 MiB 899 KiB/s 00:02 [#############################################################################] 100%
lib32-gtk2-2.24.33-2-x86_64 2.1 MiB 714 KiB/s 00:03 [#############################################################################] 100%
ksystemlog-22.08.2-1-x86_64 2.1 MiB 1141 KiB/s 00:02 [#############################################################################] 100%
protobuf-21.7-1-x86_64 2.0 MiB 875 KiB/s 00:02 [#############################################################################] 100%
svt-av1-1.3.0-1-x86_64 2.0 MiB 711 KiB/s 00:03 [#############################################################################] 100%
knewstuff-5.99.0-1-x86_64 2014.8 KiB 1051 KiB/s 00:02 [#############################################################################] 100%
gst-plugins-good-1.20.4-1-x86_64 2008.9 KiB 916 KiB/s 00:02 [#############################################################################] 100%
libjxl-0.7.0-3-x86_64 1998.9 KiB 675 KiB/s 00:03 [#############################################################################] 100%
khotkeys-5.26.2-1-x86_64 1987.6 KiB 898 KiB/s 00:02 [#############################################################################] 100%
ki18n-5.99.0-1-x86_64 1975.2 KiB 653 KiB/s 00:03 [#############################################################################] 100%
vulkan-radeon-22.2.1-1-x86_64 1956.6 KiB 1063 KiB/s 00:02 [#############################################################################] 100%
cython-0.29.32-2-x86_64 1924.8 KiB 948 KiB/s 00:02 [#############################################################################] 100%
qt5-translations-5.15.6+kde+r2-1-any 1043.0 B 240 B/s 00:04 [#############################################################################] 100%
lvm2-2.03.16-2-x86_64 1876.2 KiB 607 KiB/s 00:03 [#############################################################################] 100%
flatpak-1:1.14.0-1-x86_64 1875.8 KiB 924 KiB/s 00:02 [#############################################################################] 100%
kemoticons-5.99.0-1-x86_64 1868.1 KiB 1240 KiB/s 00:02 [#############################################################################] 100%
python-pydantic-1.10.2-1-x86_64 1865.1 KiB 1342 KiB/s 00:01 [#############################################################################] 100%
oxygen-sounds-5.26.2-1-any 1851.3 KiB 1226 KiB/s 00:02 [#############################################################################] 100%
gettext-0.21.1-1-x86_64 1823.4 KiB 1054 KiB/s 00:02 [#############################################################################] 100%
gstreamer-1.20.4-1-x86_64 1814.5 KiB 1418 KiB/s 00:01 [#############################################################################] 100%
sudo-1.9.12-1-x86_64 1762.4 KiB 1338 KiB/s 00:01 [#############################################################################] 100%
android-tools-33.0.3-1-x86_64 1745.7 KiB 1382 KiB/s 00:01 [#############################################################################] 100%
kxmlgui-5.99.0-1-x86_64 1733.1 KiB 1133 KiB/s 00:02 [#############################################################################] 100%
qt6-translations-6.4.0-1-any 1724.5 KiB 836 KiB/s 00:02 [#############################################################################] 100%
networkmanager-qt-5.99.0-1-x86_64 1701.9 KiB 562 KiB/s 00:03 [#############################################################################] 100%
konsole-22.08.2-1-x86_64 1616.1 KiB 870 KiB/s 00:02 [#############################################################################] 100%
frameworkintegration-5.99.0-1-x86_64 1590.3 KiB 646 KiB/s 00:02 [#############################################################################] 100%
wpa_supplicant-2:2.10-5-x86_64 1589.9 KiB 583 KiB/s 00:03 [#############################################################################] 100%
sqlite-3.39.4-1-x86_64 1582.6 KiB 791 KiB/s 00:02 [#############################################################################] 100%
nss-3.84-1-x86_64 1580.2 KiB 848 KiB/s 00:02 [#############################################################################] 100%
poppler-22.10.0-1-x86_64 1565.7 KiB 519 KiB/s 00:03 [#############################################################################] 100%
hwdata-0.363-1-any 1550.1 KiB 509 KiB/s 00:03 [#############################################################################] 100%
qt5-quickcontrols2-5.15.6+kde+r5-1-x86_64 1550.0 KiB 655 KiB/s 00:02 [#############################################################################] 100%
fortune-mod-3.14.1-1-x86_64 1524.6 KiB 539 KiB/s 00:03 [#############################################################################] 100%
rubberband-3.1.1-1-x86_64 1516.2 KiB 940 KiB/s 00:02 [#############################################################################] 100%
libetonyek-0.1.10-2-x86_64 1509.8 KiB 858 KiB/s 00:02 [#############################################################################] 100%
pcre2-10.40-3-x86_64 1467.0 KiB 799 KiB/s 00:02 [#############################################################################] 100%
rav1e-0.5.1-2-x86_64 1453.9 KiB 534 KiB/s 00:03 [#############################################################################] 100%
plasma-nm-5.26.2-1-x86_64 1452.9 KiB 490 KiB/s 00:03 [#############################################################################] 100%
ark-22.08.2-1-x86_64 1440.0 KiB 512 KiB/s 00:03 [#############################################################################] 100%
syntax-highlighting-5.99.0-1-x86_64 1425.4 KiB 440 KiB/s 00:03 [#############################################################################] 100%
kcoreaddons-5.99.0-1-x86_64 1417.2 KiB 519 KiB/s 00:03 [#############################################################################] 100%
grantlee-5.3.0-1-x86_64 1398.1 KiB 983 KiB/s 00:01 [#############################################################################] 100%
spectacle-22.08.2-1-x86_64 1386.9 KiB 939 KiB/s 00:01 [#############################################################################] 100%
unarchiver-1.10.7-7-x86_64 1344.3 KiB 1053 KiB/s 00:01 [#############################################################################] 100%
modemmanager-1.20.0-1-x86_64 1321.0 KiB 1129 KiB/s 00:01 [#############################################################################] 100%
krb5-1.20-1-x86_64 1271.0 KiB 1177 KiB/s 00:01 [#############################################################################] 100%
gawk-5.2.0-3-x86_64 1242.4 KiB 849 KiB/s 00:01 [#############################################################################] 100%
nerd-fonts-noto-sans-mono-2.2.2-1-any 1220.2 KiB 1043 KiB/s 00:01 [#############################################################################] 100%
lib32-glib2-2.74.1-1-x86_64 1218.6 KiB 1128 KiB/s 00:01 [#############################################################################] 100%
qt5-location-5.15.6+kde+r3-1-x86_64 1204.4 KiB 751 KiB/s 00:02 [#############################################################################] 100%
shadow-4.11.1-3-x86_64 1195.3 KiB 1010 KiB/s 00:01 [#############################################################################] 100%
xkeyboard-config-2.37-1-any 874.2 KiB 637 KiB/s 00:01 [#############################################################################] 100%
lutris-0.5.11-1-any 869.3 KiB 705 KiB/s 00:01 [#############################################################################] 100%
lib32-gnutls-3.7.8-1-x86_64 858.9 KiB 714 KiB/s 00:01 [#############################################################################] 100%
ktextwidgets-5.99.0-1-x86_64 858.1 KiB 718 KiB/s 00:01 [#############################################################################] 100%
pipewire-audio-1:0.3.59-2-x86_64 857.6 KiB 447 KiB/s 00:02 [#############################################################################] 100%
openpmix-4.2.2-1-x86_64 853.2 KiB 645 KiB/s 00:01 [#############################################################################] 100%
lib32-krb5-1.20-1-x86_64 849.2 KiB 756 KiB/s 00:01 [#############################################################################] 100%
libgit2-1:1.5.0-1-x86_64 847.9 KiB 611 KiB/s 00:01 [#############################################################################] 100%
bluez-5.65-3-x86_64 839.5 KiB 575 KiB/s 00:01 [#############################################################################] 100%
kcontacts-1:5.99.0-1-x86_64 834.0 KiB 717 KiB/s 00:01 [#############################################################################] 100%
solid-5.99.0-1-x86_64 830.8 KiB 670 KiB/s 00:01 [#############################################################################] 100%
libxml2-2.10.3-2-x86_64 827.6 KiB 664 KiB/s 00:01 [#############################################################################] 100%
slang-2.3.3-1-x86_64 826.0 KiB 726 KiB/s 00:01 [#############################################################################] 100%
lib32-systemd-251.7-1-x86_64 809.2 KiB 604 KiB/s 00:01 [#############################################################################] 100%
systemd-libs-251.7-1-x86_64 795.9 KiB 669 KiB/s 00:01 [#############################################################################] 100%
ostree-2022.6-1-x86_64 791.7 KiB 687 KiB/s 00:01 [#############################################################################] 100%
kwindowsystem-5.99.0-1-x86_64 787.3 KiB 727 KiB/s 00:01 [#############################################################################] 100%
libmm-glib-1.20.0-1-x86_64 786.0 KiB 382 KiB/s 00:02 [#############################################################################] 100%
x264-3:0.164.r3095.baee400-4-x86_64 778.0 KiB 681 KiB/s 00:01 [#############################################################################] 100%
gcr-3.41.1-2-x86_64 765.6 KiB 751 KiB/s 00:01 [#############################################################################] 100%
qt5-multimedia-5.15.6+kde+r1-1-x86_64 763.3 KiB 739 KiB/s 00:01 [#############################################################################] 100%
qca-qt5-2.3.5-1-x86_64 759.3 KiB 643 KiB/s 00:01 [#############################################################################] 100%
liborcus-0.17.2-3-x86_64 756.6 KiB 641 KiB/s 00:01 [#############################################################################] 100%
attica-5.99.0-1-x86_64 731.2 KiB 714 KiB/s 00:01 [#############################################################################] 100%
kservice-5.99.0-1-x86_64 728.6 KiB 592 KiB/s 00:01 [#############################################################################] 100%
xmlsec-1.2.36-1-x86_64 724.1 KiB 639 KiB/s 00:01 [#############################################################################] 100%
kcmutils-5.99.0-2-x86_64 718.9 KiB 658 KiB/s 00:01 [#############################################################################] 100%
lib32-harfbuzz-5.3.1-3-x86_64 710.4 KiB 708 KiB/s 00:01 [#############################################################################] 100%
libe-book-0.1.3-12-x86_64 702.3 KiB 704 KiB/s 00:01 [#############################################################################] 100%
ruby-rdoc-6.4.0-4-any 689.1 KiB 741 KiB/s 00:01 [#############################################################################] 100%
libopenmpt-0.6.6-2-x86_64 688.0 KiB 704 KiB/s 00:01 [#############################################################################] 100%
tracker3-3.4.1-1-x86_64 686.7 KiB 712 KiB/s 00:01 [#############################################################################] 100%
lib32-sdl2-2.24.1-1-x86_64 681.2 KiB 264 KiB/s 00:03 [#############################################################################] 100%
source-highlight-3.1.9-9-x86_64 675.3 KiB 330 KiB/s 00:02 [#############################################################################] 100%
lib32-sqlite-3.39.3-1-x86_64 666.1 KiB 485 KiB/s 00:01 [#############################################################################] 100%
sonnet-5.99.0-1-x86_64 664.0 KiB 647 KiB/s 00:01 [#############################################################################] 100%
ppp-2.4.9-2-x86_64 662.5 KiB 606 KiB/s 00:01 [#############################################################################] 100%
kpmcore-22.08.2-1-x86_64 656.3 KiB 684 KiB/s 00:01 [#############################################################################] 100%
python-pillow-9.3.0-1-x86_64 650.4 KiB 670 KiB/s 00:01 [#############################################################################] 100%
sof-firmware-2.2.2-1-x86_64 642.3 KiB 441 KiB/s 00:01 [#############################################################################] 100%
sdl2_ttf-2.20.1-1-x86_64 633.3 KiB 605 KiB/s 00:01 [#############################################################################] 100%
libvisio-0.1.7-8-x86_64 632.1 KiB 638 KiB/s 00:01 [#############################################################################] 100%
lib32-libvpx1.3-1.3.0-3-x86_64 625.8 KiB 526 KiB/s 00:01 [#############################################################################] 100%
kcompletion-5.99.0-1-x86_64 622.9 KiB 542 KiB/s 00:01 [#############################################################################] 100%
libical-3.0.16-2-x86_64 621.7 KiB 482 KiB/s 00:01 [#############################################################################] 100%
kdoctools-5.99.0-1-x86_64 613.2 KiB 575 KiB/s 00:01 [#############################################################################] 100%
shared-mime-info-2.0+155+gf4e7cbc-1-x86_64 608.2 KiB 602 KiB/s 00:01 [#############################################################################] 100%
kirigami2-5.99.0-1-x86_64 607.0 KiB 634 KiB/s 00:01 [#############################################################################] 100%
kcalc-22.08.2-1-x86_64 605.4 KiB 618 KiB/s 00:01 [#############################################################################] 100%
nano-6.4-1-x86_64 595.1 KiB 211 KiB/s 00:03 [#############################################################################] 100%
highway-1.0.1-1-x86_64 594.4 KiB 245 KiB/s 00:02 [#############################################################################] 100%
kitemmodels-5.99.0-1-x86_64 589.6 KiB 205 KiB/s 00:03 [#############################################################################] 100%
kbookmarks-5.99.0-1-x86_64 588.5 KiB 195 KiB/s 00:03 [#############################################################################] 100%
baloo-5.99.0-1-x86_64 584.0 KiB 214 KiB/s 00:03 [#############################################################################] 100%
python-setuptools-1:63.4.3-1-any 579.1 KiB 241 KiB/s 00:02 [#############################################################################] 100%
lib32-libxml2-2.10.3-2-x86_64 575.6 KiB 221 KiB/s 00:03 [#############################################################################] 100%
kwallet-5.99.0-1-x86_64 572.6 KiB 268 KiB/s 00:02 [#############################################################################] 100%
at-spi2-core-2.46.0-2-x86_64 566.2 KiB 185 KiB/s 00:03 [#############################################################################] 100%
rubygems-3.3.23-1-any 564.1 KiB 252 KiB/s 00:02 [#############################################################################] 100%
imlib2-1.9.1-2-x86_64 558.7 KiB 203 KiB/s 00:03 [#############################################################################] 100%
modemmanager-qt-5.99.0-1-x86_64 556.5 KiB 135 KiB/s 00:04 [#############################################################################] 100%
extra-cmake-modules-5.99.0-1-any 549.9 KiB 196 KiB/s 00:03 [#############################################################################] 100%
libmbim-1.28.0-1-x86_64 541.8 KiB 274 KiB/s 00:02 [#############################################################################] 100%
appstream-glib-0.8.1-1-x86_64 529.0 KiB 384 KiB/s 00:01 [#############################################################################] 100%
kiconthemes-5.99.0-1-x86_64 522.8 KiB 465 KiB/s 00:01 [#############################################################################] 100%
kdeclarative-5.99.0-1-x86_64 522.0 KiB 430 KiB/s 00:01 [#############################################################################] 100%
gdk-pixbuf2-2.42.10-1-x86_64 517.1 KiB 558 KiB/s 00:01 [#############################################################################] 100%
kitemviews-5.99.0-1-x86_64 511.2 KiB 413 KiB/s 00:01 [#############################################################################] 100%
nfs-utils-2.6.2-1-x86_64 486.3 KiB 516 KiB/s 00:01 [#############################################################################] 100%
alsa-lib-1.2.8-1-x86_64 484.9 KiB 371 KiB/s 00:01 [#############################################################################] 100%
knotifications-5.99.0-1-x86_64 483.2 KiB 503 KiB/s 00:01 [#############################################################################] 100%
ldns-1.8.3-1-x86_64 473.1 KiB 301 KiB/s 00:02 [#############################################################################] 100%
libhandy-1.8.0-1-x86_64 472.1 KiB 457 KiB/s 00:01 [#############################################################################] 100%
glew-2.2.0-5-x86_64 471.6 KiB 313 KiB/s 00:02 [#############################################################################] 100%
lib32-pcre2-10.40-3-x86_64 467.6 KiB 283 KiB/s 00:02 [#############################################################################] 100%
bluedevil-1:5.26.2-1-x86_64 464.2 KiB 260 KiB/s 00:02 [#############################################################################] 100%
libmspub-0.1.4-13-x86_64 461.3 KiB 136 KiB/s 00:03 [#############################################################################] 100%
gnome-desktop-common-1:42.4-1-x86_64 459.9 KiB 72.3 KiB/s 00:06 [#############################################################################] 100%
threadweaver-5.99.0-1-x86_64 458.9 KiB 186 KiB/s 00:02 [#############################################################################] 100%
libsoup-2.74.3-1-x86_64 458.8 KiB 238 KiB/s 00:02 [#############################################################################] 100%
polkit-122-1-x86_64 457.2 KiB 266 KiB/s 00:02 [#############################################################################] 100%
raptor-2.0.15-20-x86_64 455.3 KiB 259 KiB/s 00:02 [#############################################################################] 100%
libjpeg-turbo-2.1.4-2-x86_64 452.2 KiB 270 KiB/s 00:02 [#############################################################################] 100%
fmt-9.1.0-1-x86_64 449.2 KiB 284 KiB/s 00:02 [#############################################################################] 100%
gpgme-1.18.0-1-x86_64 448.7 KiB 293 KiB/s 00:02 [#############################################################################] 100%
lib32-libnm-1.40.2-1-x86_64 448.4 KiB 283 KiB/s 00:02 [#############################################################################] 100%
nettle-3.8.1-1-x86_64 443.2 KiB 223 KiB/s 00:02 [#############################################################################] 100%
kfind-22.08.2-1-x86_64 440.0 KiB 251 KiB/s 00:02 [#############################################################################] 100%
firefox-i18n-en-us-106.0.4-1-any 433.9 KiB 242 KiB/s 00:02 [#############################################################################] 100%
libadwaita-1:1.2.0-1-x86_64 420.6 KiB 145 KiB/s 00:03 [#############################################################################] 100%
kdsoap-2.1.1-1-x86_64 416.7 KiB 200 KiB/s 00:02 [#############################################################################] 100%
yakuake-22.08.2-1-x86_64 414.3 KiB 304 KiB/s 00:01 [#############################################################################] 100%
kholidays-1:5.99.0-1-x86_64 413.6 KiB 247 KiB/s 00:02 [#############################################################################] 100%
wireplumber-0.4.12-1-x86_64 412.0 KiB 285 KiB/s 00:01 [#############################################################################] 100%
libtool-2.4.7-5-x86_64 411.2 KiB 370 KiB/s 00:01 [#############################################################################] 100%
pango-1:1.50.11-1-x86_64 402.5 KiB 273 KiB/s 00:01 [#############################################################################] 100%
kfilemetadata-5.99.0-1-x86_64 402.5 KiB 345 KiB/s 00:01 [#############################################################################] 100%
kpeople-5.99.0-1-x86_64 401.4 KiB 290 KiB/s 00:01 [#############################################################################] 100%
krunner-5.99.0-1-x86_64 394.9 KiB 86.3 KiB/s 00:05 [#############################################################################] 100%
lib32-pcre-8.45-3-x86_64 394.2 KiB 126 KiB/s 00:03 [#############################################################################] 100%
lib32-alsa-lib-1.2.8-1-x86_64 394.0 KiB 217 KiB/s 00:02 [#############################################################################] 100%
libsoup3-3.2.1-1-x86_64 392.5 KiB 205 KiB/s 00:02 [#############################################################################] 100%
kjs-5.99.0-1-x86_64 391.6 KiB 158 KiB/s 00:02 [#############################################################################] 100%
dolphin-plugins-22.08.2-1-x86_64 391.5 KiB 162 KiB/s 00:02 [#############################################################################] 100%
ruby-bundler-2.3.23-1-any 391.3 KiB 221 KiB/s 00:02 [#############################################################################] 100%
dnsmasq-2.87-1-x86_64 387.2 KiB 220 KiB/s 00:02 [#############################################################################] 100%
lib32-util-linux-2.38.1-1-x86_64 384.0 KiB 209 KiB/s 00:02 [#############################################################################] 100%
inxi-3.3.23.1-1-any 381.7 KiB 278 KiB/s 00:01 [#############################################################################] 100%
karchive-5.99.0-1-x86_64 380.6 KiB 211 KiB/s 00:02 [#############################################################################] 100%
xz-5.2.7-1-x86_64 379.1 KiB 346 KiB/s 00:01 [#############################################################################] 100%
file-5.43-1-x86_64 373.5 KiB 305 KiB/s 00:01 [#############################################################################] 100%
taglib-1.13-1-x86_64 372.6 KiB 259 KiB/s 00:01 [#############################################################################] 100%
xdg-desktop-portal-1.15.0-1-x86_64 369.1 KiB 257 KiB/s 00:01 [#############################################################################] 100%
fontconfig-2:2.14.1-2-x86_64 366.1 KiB 232 KiB/s 00:02 [#############################################################################] 100%
ca-certificates-mozilla-3.84-1-x86_64 364.3 KiB 214 KiB/s 00:02 [#############################################################################] 100%
util-linux-libs-2.38.1-1-x86_64 359.2 KiB 360 KiB/s 00:01 [#############################################################################] 100%
systemsettings-5.26.2-1-x86_64 358.3 KiB 273 KiB/s 00:01 [#############################################################################] 100%
kcodecs-5.99.0-1-x86_64 356.9 KiB 173 KiB/s 00:02 [#############################################################################] 100%
ndctl-74-1-x86_64 356.7 KiB 43.6 KiB/s 00:08 [#############################################################################] 100%
libkscreen-5.26.2-1-x86_64 356.4 KiB 121 KiB/s 00:03 [#############################################################################] 100%
libglvnd-1.5.0-1-x86_64 353.8 KiB 154 KiB/s 00:02 [#############################################################################] 100%
libde265-1.0.9-1-x86_64 347.7 KiB 206 KiB/s 00:02 [#############################################################################] 100%
libwebp-1.2.4-1-x86_64 344.6 KiB 316 KiB/s 00:01 [#############################################################################] 100%
purpose-5.99.0-1-x86_64 339.6 KiB 217 KiB/s 00:02 [#############################################################################] 100%
libixion-0.17.0-3-x86_64 339.2 KiB 223 KiB/s 00:02 [#############################################################################] 100%
rsync-3.2.7-1-x86_64 336.0 KiB 225 KiB/s 00:01 [#############################################################################] 100%
kpackage-5.99.0-1-x86_64 332.4 KiB 184 KiB/s 00:02 [#############################################################################] 100%
gst-plugins-base-1.20.4-1-x86_64 331.0 KiB 134 KiB/s 00:02 [#############################################################################] 100%
kguiaddons-5.99.0-2-x86_64 329.6 KiB 135 KiB/s 00:02 [#############################################################################] 100%
hunspell-1.7.1-1-x86_64 328.0 KiB 88.9 KiB/s 00:04 [#############################################################################] 100%
kactivities-5.99.0-1-x86_64 325.1 KiB 128 KiB/s 00:03 [#############################################################################] 100%
kjobwidgets-5.99.0-1-x86_64 323.1 KiB 110 KiB/s 00:03 [#############################################################################] 100%
luajit-2.1.0.beta3.r449.gdad04f17-1-x86_64 320.7 KiB 180 KiB/s 00:02 [#############################################################################] 100%
kauth-5.99.0-1-x86_64 319.9 KiB 191 KiB/s 00:02 [#############################################################################] 100%
libdrm-2.4.113-3-x86_64 314.4 KiB 227 KiB/s 00:01 [#############################################################################] 100%
flac-1.4.2-1-x86_64 314.3 KiB 85.8 KiB/s 00:04 [#############################################################################] 100%
kdnssd-5.99.0-1-x86_64 313.1 KiB 114 KiB/s 00:03 [#############################################################################] 100%
lua-5.4.4-2-x86_64 310.0 KiB 108 KiB/s 00:03 [#############################################################################] 100%
libsndfile-1.1.0-3-x86_64 309.0 KiB 120 KiB/s 00:03 [#############################################################################] 100%
inetutils-2.3-1-x86_64 308.9 KiB 51.3 KiB/s 00:06 [#############################################################################] 100%
networkmanager-openvpn-1.10.0-1-x86_64 305.6 KiB 94.4 KiB/s 00:03 [#############################################################################] 100%
dbus-1.14.4-1-x86_64 304.9 KiB 12.3 KiB/s 00:25 [#############################################################################] 100%
libqxp-0.0.2-9-x86_64 299.8 KiB 73.9 KiB/s 00:04 [#############################################################################] 100%
device-mapper-2.03.16-2-x86_64 297.0 KiB 64.8 KiB/s 00:05 [#############################################################################] 100%
lib32-curl-7.86.0-1-x86_64 295.3 KiB 28.2 KiB/s 00:10 [#############################################################################] 100%
vulkan-tools-1.3.226-1-x86_64 294.5 KiB 145 KiB/s 00:02 [#############################################################################] 100%
lib32-libcurl-compat-7.86.0-1-x86_64 294.4 KiB 196 KiB/s 00:02 [#############################################################################] 100%
vte3-0.70.1-1-x86_64 291.2 KiB 125 KiB/s 00:02 [#############################################################################] 100%
kactivities-stats-5.99.0-1-x86_64 288.8 KiB 77.8 KiB/s 00:04 [#############################################################################] 100%
lib32-libcurl-gnutls-7.86.0-1-x86_64 288.7 KiB 144 KiB/s 00:02 [#############################################################################] 100%
manjaro-settings-manager-knotifier-0.5.7-11-x86_64 281.9 KiB 114 KiB/s 00:02 [#############################################################################] 100%
libcurl-compat-7.86.0-1-x86_64 280.6 KiB 33.8 KiB/s 00:08 [#############################################################################] 100%
libcurl-gnutls-7.86.0-1-x86_64 276.7 KiB 94.7 KiB/s 00:03 [#############################################################################] 100%
flashrom-1.2-4-x86_64 274.5 KiB 28.9 KiB/s 00:10 [#############################################################################] 100%
pixman-0.42.0-1-x86_64 270.3 KiB 112 KiB/s 00:02 [#############################################################################] 100%
libevent-2.1.12-2-x86_64 267.0 KiB 154 KiB/s 00:02 [#############################################################################] 100%
fluidsynth-2.3.0-2-x86_64 266.9 KiB 188 KiB/s 00:01 [#############################################################################] 100%
kglobalaccel-5.99.0-1-x86_64 265.4 KiB 158 KiB/s 00:02 [#############################################################################] 100%
libimagequant-4.0.4-1-x86_64 259.7 KiB 206 KiB/s 00:01 [#############################################################################] 100%
libcdio-2.1.0-3-x86_64 255.4 KiB 228 KiB/s 00:01 [#############################################################################] 100%
libheif-1.13.0-2-x86_64 252.1 KiB 230 KiB/s 00:01 [#############################################################################] 100%
lib32-libwebp-1.2.4-1-x86_64 251.0 KiB 192 KiB/s 00:01 [#############################################################################] 100%
zbar-0.23.90-1-x86_64 250.8 KiB 191 KiB/s 00:01 [#############################################################################] 100%
libpng-1.6.38-1-x86_64 248.2 KiB 224 KiB/s 00:01 [#############################################################################] 100%
kscreen-5.26.2-1-x86_64 244.6 KiB 270 KiB/s 00:01 [#############################################################################] 100%
kdesu-5.99.0-1-x86_64 243.2 KiB 213 KiB/s 00:01 [#############################################################################] 100%
plasma-pa-5.26.2-1-x86_64 242.5 KiB 216 KiB/s 00:01 [#############################################################################] 100%
xorgproto-2022.2-1-any 241.6 KiB 216 KiB/s 00:01 [#############################################################################] 100%
libgpg-error-1.46-1-x86_64 241.1 KiB 213 KiB/s 00:01 [#############################################################################] 100%
zsh-completions-0.34.0-2-any 237.5 KiB 202 KiB/s 00:01 [#############################################################################] 100%
plasma-systemmonitor-5.26.2-1-x86_64 235.2 KiB 192 KiB/s 00:01 [#############################################################################] 100%
gc-8.2.2-1-x86_64 233.2 KiB 223 KiB/s 00:01 [#############################################################################] 100%
lib32-pango-1:1.50.11-1-x86_64 230.2 KiB 216 KiB/s 00:01 [#############################################################################] 100%
kdbusaddons-5.99.0-1-x86_64 230.0 KiB 230 KiB/s 00:01 [#############################################################################] 100%
grep-3.8-2-x86_64 229.9 KiB 211 KiB/s 00:01 [#############################################################################] 100%
lib32-libjpeg-turbo-2.1.4-2-x86_64 227.2 KiB 221 KiB/s 00:01 [#############################################################################] 100%
libbpf-1.0.1-1-x86_64 226.7 KiB 177 KiB/s 00:01 [#############################################################################] 100%
lib32-libsndfile-1.1.0-2-x86_64 226.5 KiB 143 KiB/s 00:02 [#############################################################################] 100%
orc-0.4.32-2-x86_64 226.3 KiB 46.8 KiB/s 00:05 [#############################################################################] 100%
libblockdev-2.28-1-x86_64 226.1 KiB 128 KiB/s 00:02 [#############################################################################] 100%
poppler-qt5-22.10.0-1-x86_64 223.8 KiB 128 KiB/s 00:02 [#############################################################################] 100%
prison-5.99.0-1-x86_64 223.3 KiB 232 KiB/s 00:01 [#############################################################################] 100%
xdg-desktop-portal-kde-5.26.2-1-x86_64 223.3 KiB 190 KiB/s 00:01 [#############################################################################] 100%
gobject-introspection-runtime-1.74.0-1-x86_64 222.7 KiB 186 KiB/s 00:01 [#############################################################################] 100%
gst-plugins-ugly-1.20.4-1-x86_64 221.4 KiB 192 KiB/s 00:01 [#############################################################################] 100%
geoclue-2.6.0-3-x86_64 217.0 KiB 186 KiB/s 00:01 [#############################################################################] 100%
mujs-1.3.0-1-x86_64 215.3 KiB 136 KiB/s 00:02 [#############################################################################] 100%
faad2-2.10.1-1-x86_64 213.2 KiB 190 KiB/s 00:01 [#############################################################################] 100%
ldb-2:2.6.1-1-x86_64 213.2 KiB 152 KiB/s 00:01 [#############################################################################] 100%
libxslt-1.1.37-2-x86_64 209.1 KiB 200 KiB/s 00:01 [#############################################################################] 100%
f2fs-tools-1.15.0-2-x86_64 209.0 KiB 62.0 KiB/s 00:03 [#############################################################################] 100%
lib32-libtiff-4.4.0-4-x86_64 208.5 KiB 91.3 KiB/s 00:02 [#############################################################################] 100%
kpty-5.99.0-1-x86_64 207.9 KiB 164 KiB/s 00:01 [#############################################################################] 100%
neon-0.32.4-1-x86_64 206.3 KiB 131 KiB/s 00:02 [#############################################################################] 100%
knotifyconfig-5.99.0-1-x86_64 205.2 KiB 193 KiB/s 00:01 [#############################################################################] 100%
ruby-test-unit-3.5.5-1-any 204.7 KiB 126 KiB/s 00:02 [#############################################################################] 100%
squashfs-tools-4.5.1-2-x86_64 199.0 KiB 149 KiB/s 00:01 [#############################################################################] 100%
nspr-4.35-1-x86_64 198.3 KiB 191 KiB/s 00:01 [#############################################################################] 100%
lib32-libglvnd-1.5.0-1-x86_64 197.2 KiB 126 KiB/s 00:02 [#############################################################################] 100%
libsmbios-2.4.3-5-x86_64 196.9 KiB 153 KiB/s 00:01 [#############################################################################] 100%
libssh-0.10.4-1-x86_64 194.6 KiB 165 KiB/s 00:01 [#############################################################################] 100%
powertop-2.15-1-x86_64 192.6 KiB 174 KiB/s 00:01 [#############################################################################] 100%
pamac-gtk-10.4.2-2-x86_64 191.2 KiB 143 KiB/s 00:01 [#############################################################################] 100%
kscreenlocker-5.26.2-1-x86_64 190.1 KiB 123 KiB/s 00:02 [#############################################################################] 100%
kimageformats-5.99.0-2-x86_64 188.0 KiB 153 KiB/s 00:01 [#############################################################################] 100%
python-urllib3-1.26.12-1-any 186.2 KiB 196 KiB/s 00:01 [#############################################################################] 100%
libva-2.16.0-1-x86_64 185.2 KiB 149 KiB/s 00:01 [#############################################################################] 100%
jre17-openjdk-17.0.5.u1-1-x86_64 184.1 KiB 182 KiB/s 00:01 [#############################################################################] 100%
ksystemstats-5.26.2-1-x86_64 184.0 KiB 171 KiB/s 00:01 [#############################################################################] 100%
cpupower-6.0-1-x86_64 178.9 KiB 143 KiB/s 00:01 [#############################################################################] 100%
kactivitymanagerd-5.26.2-1-x86_64 178.7 KiB 90.9 KiB/s 00:02 [#############################################################################] 100%
qt6-svg-6.4.0-1-x86_64 178.4 KiB 146 KiB/s 00:01 [#############################################################################] 100%
libtirpc-1.3.3-1-x86_64 174.4 KiB 159 KiB/s 00:01 [#############################################################################] 100%
qt5-sensors-5.15.6+kde+r0-1-x86_64 173.9 KiB 179 KiB/s 00:01 [#############################################################################] 100%
kamera-22.08.2-1-x86_64 172.2 KiB 172 KiB/s 00:01 [#############################################################################] 100%
lib32-at-spi2-core-2.46.0-2-x86_64 171.6 KiB 173 KiB/s 00:01 [#############################################################################] 100%
libzmf-0.0.2-13-x86_64 169.3 KiB 143 KiB/s 00:01 [#############################################################################] 100%
libbsd-0.11.7-1-x86_64 166.6 KiB 132 KiB/s 00:01 [#############################################################################] 100%
vi-1:070224-6-x86_64 166.2 KiB 162 KiB/s 00:01 [#############################################################################] 100%
kgamma5-5.26.2-1-x86_64 161.8 KiB 175 KiB/s 00:01 [#############################################################################] 100%
pipewire-pulse-1:0.3.59-2-x86_64 160.9 KiB 174 KiB/s 00:01 [#############################################################################] 100%
plasma-integration-5.26.2-1-x86_64 159.2 KiB 157 KiB/s 00:01 [#############################################################################] 100%
xf86-video-ati-1:19.1.0.r15.g7a6a34af-1-x86_64 159.0 KiB 159 KiB/s 00:01 [#############################################################################] 100%
lv2-1.18.10-1-x86_64 158.1 KiB 164 KiB/s 00:01 [#############################################################################] 100%
sdl2_mixer-2.6.2-1-x86_64 154.2 KiB 165 KiB/s 00:01 [#############################################################################] 100%
lib32-flac-1.4.2-1-x86_64 154.0 KiB 146 KiB/s 00:01 [#############################################################################] 100%
qt5-svg-5.15.6+kde+r9-1-x86_64 149.1 KiB 147 KiB/s 00:01 [#############################################################################] 100%
lib32-fontconfig-2:2.14.1-2-x86_64 148.2 KiB 146 KiB/s 00:01 [#############################################################################] 100%
lib32-libdrm-2.4.113-1-x86_64 147.8 KiB 150 KiB/s 00:01 [#############################################################################] 100%
kidletime-5.99.0-1-x86_64 147.7 KiB 155 KiB/s 00:01 [#############################################################################] 100%
libnfs-5.0.2-1-x86_64 147.7 KiB 133 KiB/s 00:01 [#############################################################################] 100%
lib32-dbus-1.14.4-1-x86_64 145.1 KiB 154 KiB/s 00:01 [#############################################################################] 100%
upower-1.90.0-1-x86_64 144.9 KiB 141 KiB/s 00:01 [#############################################################################] 100%
unzip-6.0-19-x86_64 141.5 KiB 142 KiB/s 00:01 [#############################################################################] 100%
libltc-1.3.2-1-x86_64 141.4 KiB 145 KiB/s 00:01 [#############################################################################] 100%
lib32-readline-8.2.0-1-x86_64 141.1 KiB 149 KiB/s 00:01 [#############################################################################] 100%
lz4-1:1.9.4-1-x86_64 140.2 KiB 151 KiB/s 00:01 [#############################################################################] 100%
libksba-1.6.2-1-x86_64 140.2 KiB 134 KiB/s 00:01 [#############################################################################] 100%
glib-networking-1:2.74.0-1-x86_64 139.6 KiB 150 KiB/s 00:01 [#############################################################################] 100%
libmatroska-1.7.1-1-x86_64 139.5 KiB 133 KiB/s 00:01 [#############################################################################] 100%
libtasn1-4.19.0-1-x86_64 139.1 KiB 148 KiB/s 00:01 [#############################################################################] 100%
lib32-vulkan-icd-loader-1.3.226-1-x86_64 135.7 KiB 79.4 KiB/s 00:02 [#############################################################################] 100%
libkexiv2-22.08.2-1-x86_64 135.5 KiB 135 KiB/s 00:01 [#############################################################################] 100%
kcrash-5.99.0-1-x86_64 132.5 KiB 111 KiB/s 00:01 [#############################################################################] 100%
kinit-5.99.0-1-x86_64 131.7 KiB 148 KiB/s 00:01 [#############################################################################] 100%
pinentry-1.2.1-1-x86_64 131.0 KiB 135 KiB/s 00:01 [#############################################################################] 100%
vulkan-icd-loader-1.3.226-1-x86_64 130.0 KiB 116 KiB/s 00:01 [#############################################################################] 100%
lib32-libpng-1.6.38-1-x86_64 129.2 KiB 132 KiB/s 00:01 [#############################################################################] 100%
liburcu-0.13.2-1-x86_64 128.6 KiB 139 KiB/s 00:01 [#############################################################################] 100%
kaccounts-integration-22.08.2-1-x86_64 127.3 KiB 136 KiB/s 00:01 [#############################################################################] 100%
dmraid-1.0.0.rc16.3-14-x86_64 127.2 KiB 125 KiB/s 00:01 [#############################################################################] 100%
python-markdown-3.4.1-2-any 126.9 KiB 123 KiB/s 00:01 [#############################################################################] 100%
ruby-minitest-5.16.3-1-any 126.5 KiB 132 KiB/s 00:01 [#############################################################################] 100%
sdl12-compat-1.2.56-1-x86_64 125.9 KiB 131 KiB/s 00:01 [#############################################################################] 100%
faudio-22.10-1-x86_64 125.5 KiB 131 KiB/s 00:01 [#############################################################################] 100%
lib32-gdk-pixbuf2-2.42.10-1-x86_64 125.4 KiB 115 KiB/s 00:01 [#############################################################################] 100%
lib32-smpeg-0.4.5-4-x86_64 123.2 KiB 120 KiB/s 00:01 [#############################################################################] 100%
fuse3-3.12.0-1-x86_64 122.1 KiB 123 KiB/s 00:01 [#############################################################################] 100%
less-1:608-1-x86_64 121.5 KiB 124 KiB/s 00:01 [#############################################################################] 100%
libaccounts-glib-1.26-1-x86_64 119.0 KiB 124 KiB/s 00:01 [#############################################################################] 100%
kquickcharts-5.99.0-1-x86_64 118.1 KiB 124 KiB/s 00:01 [#############################################################################] 100%
kdenetwork-filesharing-22.08.2-1-x86_64 116.8 KiB 109 KiB/s 00:01 [#############################################################################] 100%
lib32-nspr-4.35-1-x86_64 116.1 KiB 112 KiB/s 00:01 [#############################################################################] 100%
gnome-desktop-4-1:42.4-1-x86_64 115.4 KiB 117 KiB/s 00:01 [#############################################################################] 100%
ruby-date-3.2.2-3-x86_64 115.0 KiB 117 KiB/s 00:01 [#############################################################################] 100%
ruby-irb-1.4.2-1-any 114.5 KiB 105 KiB/s 00:01 [#############################################################################] 100%
expat-2.5.0-1-x86_64 114.3 KiB 104 KiB/s 00:01 [#############################################################################] 100%
lib32-faudio-22.10-1-x86_64 113.7 KiB 87.2 KiB/s 00:01 [#############################################################################] 100%
libxfont2-2.0.6-1-x86_64 113.2 KiB 108 KiB/s 00:01 [#############################################################################] 100%
gnome-desktop-1:42.4-1-x86_64 113.0 KiB 117 KiB/s 00:01 [#############################################################################] 100%
libxmu-1.1.4-1-x86_64 76.2 KiB 60.5 KiB/s 00:01 [#############################################################################] 100%
libjcat-0.1.11-1-x86_64 75.8 KiB 65.3 KiB/s 00:01 [#############################################################################] 100%
appstream-qt-0.15.5-1-x86_64 75.5 KiB 68.6 KiB/s 00:01 [#############################################################################] 100%
libxkbfile-1.1.1-1-x86_64 75.2 KiB 75.5 KiB/s 00:01 [#############################################################################] 100%
pamac-cli-10.4.2-2-x86_64 75.1 KiB 81.9 KiB/s 00:01 [#############################################################################] 100%
qt5-webchannel-5.15.6+kde+r3-1-x86_64 74.9 KiB 69.6 KiB/s 00:01 [#############################################################################] 100%
kpipewire-5.26.2-1-x86_64 74.9 KiB 69.8 KiB/s 00:01 [#############################################################################] 100%
kaccounts-providers-22.08.2-1-x86_64 74.6 KiB 87.7 KiB/s 00:01 [#############################################################################] 100%
milou-5.26.2-1-x86_64 74.5 KiB 73.6 KiB/s 00:01 [#############################################################################] 100%
python-more-itertools-9.0.0-1-any 73.7 KiB 80.4 KiB/s 00:01 [#############################################################################] 100%
wayland-protocols-1.27-1-any 73.5 KiB 79.7 KiB/s 00:01 [#############################################################################] 100%
qt5-graphicaleffects-5.15.6+kde+r0-1-x86_64 73.2 KiB 66.9 KiB/s 00:01 [#############################################################################] 100%
memtest86+-6.00-1-any 72.6 KiB 79.3 KiB/s 00:01 [#############################################################################] 100%
perl-http-message-6.41-1-any 72.2 KiB 86.4 KiB/s 00:01 [#############################################################################] 100%
lib32-sdl12-compat-1.2.56-1-x86_64 71.4 KiB 85.6 KiB/s 00:01 [#############################################################################] 100%
lib32-expat-2.5.0-2-x86_64 69.7 KiB 83.6 KiB/s 00:01 [#############################################################################] 100%
libnftnl-1.2.3-1-x86_64 68.8 KiB 81.2 KiB/s 00:01 [#############################################################################] 100%
libebml-1.4.4-1-x86_64 68.7 KiB 69.9 KiB/s 00:01 [#############################################################################] 100%
alsa-ucm-conf-1.2.8-1-any 67.5 KiB 75.9 KiB/s 00:01 [#############################################################################] 100%
kde-gtk-config-5.26.2-1-x86_64 66.2 KiB 82.0 KiB/s 00:01 [#############################################################################] 100%
sdl2_image-2.6.2-2-x86_64 66.0 KiB 81.5 KiB/s 00:01 [#############################################################################] 100%
libmalcontent-0.10.5-1-x86_64 66.0 KiB 79.8 KiB/s 00:01 [#############################################################################] 100%
libatomic_ops-7.6.14-1-x86_64 65.6 KiB 81.3 KiB/s 00:01 [#############################################################################] 100%
polkit-kde-agent-5.26.2-1-x86_64 64.9 KiB 66.2 KiB/s 00:01 [#############################################################################] 100%
ruby-fiddle-1.1.0-3-x86_64 62.9 KiB 48.4 KiB/s 00:01 [#############################################################################] 100%
libevdev-1.13.0-1-x86_64 62.8 KiB 72.4 KiB/s 00:01 [#############################################################################] 100%
ruby-cgi-0.3.3-1-x86_64 61.2 KiB 61.8 KiB/s 00:01 [#############################################################################] 100%
libxft-2.3.6-1-x86_64 60.1 KiB 66.1 KiB/s 00:01 [#############################################################################] 100%
python-inflect-6.0.2-1-any 59.7 KiB 69.2 KiB/s 00:01 [#############################################################################] 100%
kded-5.99.0-1-x86_64 59.6 KiB 71.6 KiB/s 00:01 [#############################################################################] 100%
serd-0.30.16-1-x86_64 59.3 KiB 72.9 KiB/s 00:01 [#############################################################################] 100%
ruby-uri-0.11.0-5-any 58.0 KiB 71.8 KiB/s 00:01 [#############################################################################] 100%
python-systemd-235-1-x86_64 56.9 KiB 62.8 KiB/s 00:01 [#############################################################################] 100%
vte-common-0.70.1-1-x86_64 56.7 KiB 82.2 KiB/s 00:01 [#############################################################################] 100%
xdg-utils-1.1.3+21+g1a58bc2-2-any 56.2 KiB 82.3 KiB/s 00:01 [#############################################################################] 100%
double-conversion-3.2.1-1-x86_64 56.1 KiB 82.1 KiB/s 00:01 [#############################################################################] 100%
ruby-drb-2.1.0-4-any 55.4 KiB 67.0 KiB/s 00:01 [#############################################################################] 100%
enchant-2.3.3-2-x86_64 54.5 KiB 66.4 KiB/s 00:01 [#############################################################################] 100%
libwpe-1.14.0-1-x86_64 53.9 KiB 65.3 KiB/s 00:01 [#############################################################################] 100%
qt5-imageformats-5.15.6+kde+r5-1-x86_64 53.7 KiB 64.9 KiB/s 00:01 [#############################################################################] 100%
mkinitcpio-32-2-any 51.4 KiB 59.5 KiB/s 00:01 [#############################################################################] 100%
qt5-speech-5.15.6+kde+r1-1-x86_64 49.2 KiB 58.5 KiB/s 00:01 [#############################################################################] 100%
lib32-zlib-1.2.13-1-x86_64 47.3 KiB 56.6 KiB/s 00:01 [#############################################################################] 100%
gst-plugin-pipewire-1:0.3.59-2-x86_64 45.6 KiB 54.0 KiB/s 00:01 [#############################################################################] 100%
nfsidmap-2.6.2-1-x86_64 45.5 KiB 53.6 KiB/s 00:01 [#############################################################################] 100%
pipewire-zeroconf-1:0.3.59-2-x86_64 45.5 KiB 53.2 KiB/s 00:01 [#############################################################################] 100%
libffi-3.4.4-1-x86_64 45.3 KiB 52.3 KiB/s 00:01 [#############################################################################] 100%
chromaprint-1.5.1-4-x86_64 45.3 KiB 50.9 KiB/s 00:01 [#############################################################################] 100%
xdg-user-dirs-0.18-1-x86_64 43.7 KiB 50.8 KiB/s 00:01 [#############################################################################] 100%
libkdcraw-22.08.2-1-x86_64 43.5 KiB 51.3 KiB/s 00:01 [#############################################################################] 100%
ruby-digest-3.1.0-5-x86_64 42.6 KiB 50.1 KiB/s 00:01 [#############################################################################] 100%
python-typing_extensions-4.4.0-1-any 41.5 KiB 49.6 KiB/s 00:01 [#############################################################################] 100%
lib32-libtasn1-4.19.0-1-x86_64 40.3 KiB 48.5 KiB/s 00:01 [#############################################################################] 100%
kdegraphics-thumbnailers-22.08.2-1-x86_64 39.5 KiB 47.5 KiB/s 00:01 [#############################################################################] 100%
gsm-1.0.22-1-x86_64 39.1 KiB 47.7 KiB/s 00:01 [#############################################################################] 100%
libpamac-flatpak-plugin-11.3.1-3-x86_64 38.2 KiB 45.3 KiB/s 00:01 [#############################################################################] 100%
sord-0.16.14-1-x86_64 37.7 KiB 20.4 KiB/s 00:02 [#############################################################################] 100%
libcbor-0.9.0-1-x86_64 37.5 KiB 56.0 KiB/s 00:01 [#############################################################################] 100%
wpebackend-fdo-1.14.0-1-x86_64 37.5 KiB 55.7 KiB/s 00:01 [#############################################################################] 100%
kwayland-integration-5.26.2-1-x86_64 35.7 KiB 51.7 KiB/s 00:01 [#############################################################################] 100%
python-importlib-metadata-5.0.0-1-any 34.8 KiB 45.1 KiB/s 00:01 [#############################################################################] 100%
linux-firmware-whence-20220913.f09bebf-1-any 34.0 KiB 44.4 KiB/s 00:01 [#############################################################################] 100%
xcb-util-wm-0.4.2-1-x86_64 33.6 KiB 44.6 KiB/s 00:01 [#############################################################################] 100%
ruby-did_you_mean-1.6.1-3-any 31.8 KiB 41.6 KiB/s 00:01 [#############################################################################] 100%
libspectre-0.2.10-2-x86_64 30.7 KiB 41.7 KiB/s 00:01 [#############################################################################] 100%
libpciaccess-0.17-1-x86_64 21.8 KiB 33.5 KiB/s 00:01 [#############################################################################] 100%
layer-shell-qt-5.26.2-1-x86_64 21.6 KiB 33.2 KiB/s 00:01 [#############################################################################] 100%
manjaro-pipewire-20221015-2-any 21.4 KiB 30.6 KiB/s 00:01 [#############################################################################] 100%
ruby-erb-2.2.3-4-any 21.2 KiB 32.2 KiB/s 00:01 [#############################################################################] 100%
mhwd-nvidia-390xx-390.154-2-any 21.1 KiB 32.4 KiB/s 00:01 [#############################################################################] 100%
mhwd-nvidia-470xx-470.141.03-3-any 21.1 KiB 31.3 KiB/s 00:01 [#############################################################################] 100%
mhwd-nvidia-520.56.06-2-any 21.0 KiB 25.6 KiB/s 00:01 [#############################################################################] 100%
ruby-io-console-0.5.11-2-x86_64 20.6 KiB 25.3 KiB/s 00:01 [#############################################################################] 100%
kdegraphics-mobipocket-22.08.2-1-x86_64 20.0 KiB 24.2 KiB/s 00:01 [#############################################################################] 100%
ruby-etc-1.3.0-5-x86_64 19.9 KiB 31.4 KiB/s 00:01 [#############################################################################] 100%
python-autocommand-2.2.1-1-any 19.9 KiB 31.4 KiB/s 00:01 [#############################################################################] 100%
sratom-0.6.14-1-x86_64 19.5 KiB 31.6 KiB/s 00:01 [#############################################################################] 100%
steam-native-runtime-1.0.0.70-4-x86_64 19.3 KiB 31.5 KiB/s 00:01 [#############################################################################] 100%
ruby-ipaddr-1.2.4-2-any 19.2 KiB 31.3 KiB/s 00:01 [#############################################################################] 100%
lib32-libffi-3.4.4-1-x86_64 18.5 KiB 30.1 KiB/s 00:01 [#############################################################################] 100%
kwrited-5.26.2-1-x86_64 17.8 KiB 29.9 KiB/s 00:01 [#############################################################################] 100%
manjaro-alsa-20221002-1-any 17.8 KiB 29.5 KiB/s 00:01 [#############################################################################] 100%
xcb-util-image-0.4.1-2-x86_64 17.5 KiB 29.5 KiB/s 00:01 [#############################################################################] 100%
ruby-open-uri-0.2.0-3-any 17.5 KiB 29.3 KiB/s 00:01 [#############################################################################] 100%
python-jaraco.text-3.10.0-1-any 17.5 KiB 29.3 KiB/s 00:01 [#############################################################################] 100%
wayland-utils-1.1.0-1-x86_64 16.6 KiB 28.3 KiB/s 00:01 [#############################################################################] 100%
gtk-update-icon-cache-1:4.8.2-1-x86_64 16.5 KiB 28.1 KiB/s 00:01 [#############################################################################] 100%
ruby-benchmark-0.2.0-3-any 15.9 KiB 26.9 KiB/s 00:01 [#############################################################################] 100%
libinih-56-1-x86_64 15.7 KiB 27.5 KiB/s 00:01 [#############################################################################] 100%
libxxf86vm-1.1.5-1-x86_64 15.5 KiB 27.1 KiB/s 00:01 [#############################################################################] 100%
libfontenc-1.1.6-1-x86_64 15.4 KiB 16.0 KiB/s 00:01 [#############################################################################] 100%
ruby-time-0.2.0-4-any 15.2 KiB 38.6 KiB/s 00:00 [#############################################################################] 100%
manjaro-release-22.0.0pre3-1-any 14.8 KiB 38.1 KiB/s 00:00 [#############################################################################] 100%
qt5-x11extras-5.15.6+kde+r0-1-x86_64 14.7 KiB 38.1 KiB/s 00:00 [#############################################################################] 100%
python-appdirs-1.4.4-7-any 14.6 KiB 37.6 KiB/s 00:00 [#############################################################################] 100%
python-trove-classifiers-2022.10.19-1-any 14.4 KiB 37.3 KiB/s 00:00 [#############################################################################] 100%
signon-kwallet-extension-22.08.2-1-x86_64 14.0 KiB 36.1 KiB/s 00:00 [#############################################################################] 100%
aha-0.5.1-2-x86_64 13.8 KiB 35.5 KiB/s 00:00 [#############################################################################] 100%
python-ordered-set-4.1.0-1-any 13.7 KiB 35.2 KiB/s 00:00 [#############################################################################] 100%
ruby-getoptlong-0.1.1-2-any 13.6 KiB 35.7 KiB/s 00:00 [#############################################################################] 100%
kwallet-pam-5.26.2-1-x86_64 13.0 KiB 35.3 KiB/s 00:00 [#############################################################################] 100%
python-jaraco.functools-3.5.2-1-any 12.9 KiB 34.2 KiB/s 00:00 [#############################################################################] 100%
ruby-delegate-0.2.0-3-any 12.6 KiB 34.1 KiB/s 00:00 [#############################################################################] 100%
mhwd-db-0.6.5-23-any 11.9 KiB 31.4 KiB/s 00:00 [#############################################################################] 100%
python-zipp-3.10.0-1-any 11.6 KiB 31.7 KiB/s 00:00 [#############################################################################] 100%
xcb-util-cursor-0.1.4-1-x86_64 11.5 KiB 31.4 KiB/s 00:00 [#############################################################################] 100%
xorg-xsetroot-1.1.3-1-x86_64 11.3 KiB 30.4 KiB/s 00:00 [#############################################################################] 100%
ruby-forwardable-1.3.2-5-any 11.2 KiB 30.6 KiB/s 00:00 [#############################################################################] 100%
libxcvt-0.1.2-1-x86_64 11.1 KiB 30.2 KiB/s 00:00 [#############################################################################] 100%
libxau-1.0.10-1-x86_64 10.9 KiB 30.5 KiB/s 00:00 [#############################################################################] 100%
wireless-regdb-2022.08.12-1-any 10.9 KiB 29.6 KiB/s 00:00 [#############################################################################] 100%
ca-certificates-utils-20220905-1-any 10.3 KiB 28.1 KiB/s 00:00 [#############################################################################] 100%
ruby-io-wait-0.2.3-3-x86_64 9.9 KiB 27.1 KiB/s 00:00 [#############################################################################] 100%
libxinerama-1.1.5-1-x86_64 9.9 KiB 27.7 KiB/s 00:00 [#############################################################################] 100%
xcb-util-renderutil-0.3.10-1-x86_64 9.4 KiB 27.1 KiB/s 00:00 [#############################################################################] 100%
python-jaraco.context-4.1.2-1-any 9.2 KiB 26.2 KiB/s 00:00 [#############################################################################] 100%
python-nspektr-0.4.0-2-any 9.1 KiB 25.5 KiB/s 00:00 [#############################################################################] 100%
python-certifi-2022.09.24-1-any 8.6 KiB 19.7 KiB/s 00:00 [#############################################################################] 100%
ruby-fcntl-1.0.1-3-x86_64 8.3 KiB 23.8 KiB/s 00:00 [#############################################################################] 100%
android-udev-20220903-1-any 8.1 KiB 23.8 KiB/s 00:00 [#############################################################################] 100%
ruby-english-0.7.1-3-any 7.8 KiB 23.2 KiB/s 00:00 [#############################################################################] 100%
harfbuzz-icu-5.3.1-3-x86_64 7.8 KiB 22.6 KiB/s 00:00 [#############################################################################] 100%
ruby-base64-0.1.1-3-any 7.7 KiB 22.6 KiB/s 00:00 [#############################################################################] 100%
xcb-util-keysyms-0.4.1-4-x86_64 7.5 KiB 19.2 KiB/s 00:00 [#############################################################################] 100%
ruby-abbrev-0.1.0-3-any 7.4 KiB 21.5 KiB/s 00:00 [#############################################################################] 100%
ruby-io-nonblock-0.1.0-2-any 7.3 KiB 21.4 KiB/s 00:00 [#############################################################################] 100%
ruby-mutex_m-0.1.1-2-any 7.2 KiB 21.3 KiB/s 00:00 [#############################################################################] 100%
ruby-tmpdir-0.1.2-3-any 7.2 KiB 21.2 KiB/s 00:00 [#############################################################################] 100%
ruby-ruby2_keywords-0.0.5-1-any 7.2 KiB 17.2 KiB/s 00:00 [#############################################################################] 100%
ruby-find-0.1.1-3-any 7.0 KiB 15.6 KiB/s 00:00 [#############################################################################] 100%
systemd-sysvcompat-251.7-1-x86_64 6.5 KiB 15.9 KiB/s 00:00 [#############################################################################] 100%
libxshmfence-1.3.1-1-x86_64 5.7 KiB 13.8 KiB/s 00:00 [#############################################################################] 100%
pipewire-alsa-1:0.3.59-2-x86_64 4.9 KiB 15.2 KiB/s 00:00 [#############################################################################] 100%
pambase-20221020-1-any 3.1 KiB 9.81 KiB/s 00:00 [#############################################################################] 100%
fuse-common-3.12.0-1-x86_64 2.8 KiB 8.72 KiB/s 00:00 [#############################################################################] 100%
ruby-stdlib-3.0.4-18-x86_64 2.8 KiB 8.96 KiB/s 00:00 [#############################################################################] 100%
ruby-bundledgems-3.0.4-18-x86_64 2.6 KiB 8.46 KiB/s 00:00 [#############################################################################] 100%
ca-certificates-20220905-1-any 2.0 KiB 6.60 KiB/s 00:00 [#############################################################################] 100%
Total (648/648) 719.5 MiB 476 KiB/s 25:49 [#############################################################################] 100%
error: failed retrieving file 'qt5-translations-5.15.6+kde+r2-1-any.pkg.tar.zst' from mirror.fcix.net : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
(675/675) checking keys in keyring [#############################################################################] 100%
(675/675) checking package integrity [#############################################################################] 100%
error: filesystem: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/filesystem-2022.10.18-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] n
error: systemd-libs: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/systemd-libs-251.7-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] ^C
Interrupt signal received
Your system hasn’t been updated in some time, you should try again, and answer Y this time.
Yes, you do want to delete a corrupted file - why would you want to keep it?
You chose to give no answer at all - and interrupted the update process instead.
Run it again.
I do not know how to deal with the
error - which is the reason for the subsequent corrupted file error
Earlier when I tried to update it said to import these pgp signatures so i typed y in all of them
Output:
sudo pacman -Syu ✔
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: Replace at-spi2-atk with extra/at-spi2-core? [Y/n]
:: Replace atk with extra/at-spi2-core? [Y/n]
:: Replace kwayland-server with extra/kwin? [Y/n]
:: Replace lib32-atk with multilib/lib32-at-spi2-core? [Y/n]
:: Replace steam-manjaro with multilib/steam? [Y/n]
:: Replace steam-native with multilib/steam-native-runtime? [Y/n]
resolving dependencies...
warning: dependency cycle detected:
warning: libglvnd will be installed before its mesa dependency
warning: smbclient will be installed before its cifs-utils dependency
warning: lib32-mesa will be installed before its lib32-libglvnd dependency
warning: rubygems will be installed before its ruby dependency
warning: ruby-abbrev will be installed before its ruby dependency
warning: ruby-base64 will be installed before its ruby dependency
warning: ruby-benchmark will be installed before its ruby dependency
warning: ruby-bigdecimal will be installed before its ruby dependency
warning: ruby-bundler will be installed before its ruby dependency
warning: ruby-cgi will be installed before its ruby dependency
warning: ruby-csv will be installed before its ruby dependency
warning: ruby-date will be installed before its ruby dependency
warning: ruby-delegate will be installed before its ruby dependency
warning: ruby-did_you_mean will be installed before its ruby dependency
warning: ruby-digest will be installed before its ruby dependency
warning: ruby-drb will be installed before its ruby dependency
warning: ruby-ruby2_keywords will be installed before its ruby dependency
warning: ruby-english will be installed before its ruby dependency
warning: ruby-erb will be installed before its ruby dependency
warning: ruby-etc will be installed before its ruby dependency
warning: ruby-fcntl will be installed before its ruby dependency
warning: ruby-fiddle will be installed before its ruby dependency
warning: ruby-fileutils will be installed before its ruby dependency
warning: ruby-find will be installed before its ruby dependency
warning: ruby-forwardable will be installed before its ruby dependency
warning: ruby-getoptlong will be installed before its ruby dependency
warning: ruby-io-console will be installed before its ruby dependency
warning: ruby-io-nonblock will be installed before its ruby dependency
warning: ruby-io-wait will be installed before its ruby dependency
warning: ruby-ipaddr will be installed before its ruby dependency
warning: ruby-irb will be installed before its ruby dependency
warning: ruby-reline will be installed before its ruby dependency
warning: ruby-json will be installed before its ruby dependency
warning: ruby-logger will be installed before its ruby dependency
warning: ruby-mutex_m will be installed before its ruby dependency
warning: ruby-net-http will be installed before its ruby dependency
warning: ruby-uri will be installed before its ruby dependency
warning: ruby-open-uri will be installed before its ruby dependency
warning: ruby-stringio will be installed before its ruby dependency
warning: ruby-time will be installed before its ruby dependency
warning: ruby-psych will be installed before its ruby dependency
warning: ruby-racc will be installed before its ruby dependency
warning: ruby-rdoc will be installed before its ruby dependency
warning: ruby-tmpdir will be installed before its ruby dependency
warning: ruby-minitest will be installed before its ruby dependency
warning: ruby-power_assert will be installed before its ruby dependency
warning: ruby-test-unit will be installed before its ruby dependency
warning: ruby-bundledgems will be installed before its ruby dependency
Packages (681) acpid-2.0.34-1 aha-0.5.1-2 alsa-card-profiles-1:0.3.59-2 alsa-lib-1.2.8-1 alsa-ucm-conf-1.2.8-1 alsa-utils-1.2.8-1 android-tools-33.0.3-1 android-udev-20220903-1 aom-3.5.0-1
appstream-0.15.5-1 appstream-glib-0.8.1-1 appstream-qt-0.15.5-1 archlinux-appstream-data-20221014-1 ark-22.08.2-1 at-spi2-atk-2.38.0-1 [removal] at-spi2-core-2.46.0-2 atk-2.38.0-1 [removal]
attica-5.99.0-1 baloo-5.99.0-1 baloo-widgets-22.08.2-1 binutils-2.39-3 bluedevil-1:5.26.2-1 bluez-5.65-3 bluez-libs-5.65-3 bluez-qt-5.99.0-1 boost-libs-1.80.0-3 breeze-5.26.2-1
breeze-icons-5.99.0-1 btrfs-progs-6.0-1 ca-certificates-20220905-1 ca-certificates-mozilla-3.84-1 ca-certificates-utils-20220905-1 chromaprint-1.5.1-4 cifs-utils-7.0-1 clang-14.0.6-3
cmake-3.24.2-1 cpupower-6.0-1 curl-7.86.0-1 cython-0.29.32-2 dbus-1.14.4-1 device-mapper-2.03.16-2 dhclient-4.4.3.P1-1 dmraid-1.0.0.rc16.3-14 dnsmasq-2.87-1 dolphin-22.08.2-1
dolphin-plugins-22.08.2-1 double-conversion-3.2.1-1 easyeffects-6.3.0-1 enchant-2.3.3-2 expat-2.5.0-1 extra-cmake-modules-5.99.0-1 f2fs-tools-1.15.0-2 faad2-2.10.1-1 faudio-22.10-1
ffmpeg-2:5.1.2-1 ffmpegthumbs-22.08.2-1 file-5.43-1 filesystem-2022.10.18-1 firefox-106.0.4-1 firefox-i18n-en-us-106.0.4-1 flac-1.4.2-1 flashrom-1.2-4 flatpak-1:1.14.0-1
fluidsynth-2.3.0-2 fmt-9.1.0-1 fontconfig-2:2.14.1-2 fortune-mod-3.14.1-1 frameworkintegration-5.99.0-1 freeglut-3.4.0-1 fuse-common-3.12.0-1 fuse3-3.12.0-1 fwupd-1.8.6-1 fwupd-efi-1.3-1
game-devices-udev-0.18-1 gawk-5.2.0-3 gc-8.2.2-1 gcab-1.5-1 gcc-12.2.0-1 gcc-libs-12.2.0-1 gcr-3.41.1-2 gdk-pixbuf2-2.42.10-1 geoclue-2.6.0-3 geocode-glib-3.26.4-1 gettext-0.21.1-1
ghostscript-10.0.0-1 git-2.38.1-1 glew-2.2.0-5 glib-networking-1:2.74.0-1 glib2-2.74.1-1 glibc-2.36-6 glibmm-2.66.5-1 glslang-11.11.0-1 gnome-desktop-1:42.4-1 gnome-desktop-4-1:42.4-1
gnome-desktop-common-1:42.4-1 gnupg-2.2.40-1 gnustep-base-1.28.0-5 gnutls-3.7.8-1 gobject-introspection-runtime-1.74.0-1 gpgme-1.18.0-1 grantlee-5.3.0-1 grep-3.8-2
grub-2.06.r261.g2f4430cc0-3 gsm-1.0.22-1 gst-libav-1.20.4-1 gst-plugin-pipewire-1:0.3.59-2 gst-plugins-bad-1.20.4-1 gst-plugins-bad-libs-1.20.4-1 gst-plugins-base-1.20.4-1
gst-plugins-base-libs-1.20.4-1 gst-plugins-good-1.20.4-1 gst-plugins-ugly-1.20.4-1 gstreamer-1.20.4-1 gtk-update-icon-cache-1:4.8.2-1 gtk3-1:3.24.34+r156+g812b3930d0-1 gtk4-1:4.8.2-1
gwenview-22.08.2-1 harfbuzz-5.3.1-3 harfbuzz-icu-5.3.1-3 hdparm-9.65-1 highway-1.0.1-1 hunspell-1.7.1-1 hwdata-0.363-1 hwinfo-22.1-1 iana-etc-20221025-1 icu-72.1-1 imagemagick-7.1.0.51-1
imath-3.1.5-3 imlib2-1.9.1-2 inetutils-2.3-1 intel-ucode-20220809-1 inxi-3.3.23.1-1 iproute2-6.0.0-1 iso-codes-4.11.0-2 jdk17-openjdk-17.0.5.u1-1 jre17-openjdk-17.0.5.u1-1
jre17-openjdk-headless-17.0.5.u1-1 kaccounts-integration-22.08.2-1 kaccounts-providers-22.08.2-1 kactivities-5.99.0-1 kactivities-stats-5.99.0-1 kactivitymanagerd-5.26.2-1 kamera-22.08.2-1
karchive-5.99.0-1 kate-22.08.2-1 kauth-5.99.0-1 kbookmarks-5.99.0-1 kcalc-22.08.2-1 kcmutils-5.99.0-2 kcodecs-5.99.0-1 kcompletion-5.99.0-1 kconfig-5.99.0-1 kconfigwidgets-5.99.0-1
kcontacts-1:5.99.0-1 kcoreaddons-5.99.0-1 kcrash-5.99.0-1 kdbusaddons-5.99.0-1 kde-cli-tools-5.26.2-1 kde-gtk-config-5.26.2-1 kdeclarative-5.99.0-1 kdeconnect-22.08.2-1
kdecoration-5.26.2-1 kded-5.99.0-1 kdegraphics-mobipocket-22.08.2-1 kdegraphics-thumbnailers-22.08.2-1 kdelibs4support-5.99.0-1 kdenetwork-filesharing-22.08.2-1 kdeplasma-addons-5.26.2-1
kdesu-5.99.0-1 kdnssd-5.99.0-1 kdoctools-5.99.0-1 kdsoap-2.1.1-1 kemoticons-5.99.0-1 kfilemetadata-5.99.0-1 kfind-22.08.2-1 kgamma5-5.26.2-1 kglobalaccel-5.99.0-1 kguiaddons-5.99.0-2
khelpcenter-22.08.2-1 kholidays-1:5.99.0-1 khotkeys-5.26.2-1 khtml-5.99.0-1 ki18n-5.99.0-1 kiconthemes-5.99.0-1 kidletime-5.99.0-1 kimageformats-5.99.0-2 kinfocenter-5.26.2-1
kinit-5.99.0-1 kio-5.99.0-1 kio-extras-22.08.2-1 kirigami2-5.99.0-1 kitemmodels-5.99.0-1 kitemviews-5.99.0-1 kjobwidgets-5.99.0-1 kjs-5.99.0-1 kmenuedit-5.26.2-1 knewstuff-5.99.0-1
knotifications-5.99.0-1 knotifyconfig-5.99.0-1 konsole-22.08.2-1 konversation-22.08.2-1 kpackage-5.99.0-1 kparts-5.99.0-1 kpeople-5.99.0-1 kpipewire-5.26.2-1 kpmcore-22.08.2-1
kpty-5.99.0-1 kquickcharts-5.99.0-1 krb5-1.20-1 krunner-5.99.0-1 kscreen-5.26.2-1 kscreenlocker-5.26.2-1 kservice-5.99.0-1 ksshaskpass-5.26.2-1 ksystemlog-22.08.2-1 ksystemstats-5.26.2-1
ktexteditor-5.99.0-1 ktextwidgets-5.99.0-1 kunitconversion-5.99.0-1 kwallet-5.99.0-1 kwallet-pam-5.26.2-1 kwalletmanager-22.08.2-1 kwayland-5.99.0-1 kwayland-integration-5.26.2-1
kwayland-server-5.24.6-1 [removal] kwidgetsaddons-5.99.0-1 kwin-5.26.2.1-2 kwindowsystem-5.99.0-1 kwrited-5.26.2-1 kxmlgui-5.99.0-1 layer-shell-qt-5.26.2-1 ldb-2:2.6.1-1 ldns-1.8.3-1
less-1:608-1 lib32-alsa-lib-1.2.8-1 lib32-at-spi2-core-2.46.0-2 lib32-atk-2.38.0-1 [removal] lib32-curl-7.86.0-1 lib32-dbus-1.14.4-1 lib32-expat-2.5.0-2 lib32-faudio-22.10-1
lib32-flac-1.4.2-1 lib32-fontconfig-2:2.14.1-2 lib32-freeglut-3.4.0-1 lib32-gcc-libs-12.2.0-1 lib32-gdk-pixbuf2-2.42.10-1 lib32-glib2-2.74.1-1 lib32-glibc-2.36-6 lib32-gnutls-3.7.8-1
lib32-gtk2-2.24.33-2 lib32-harfbuzz-5.3.1-3 lib32-icu-72.1-1 lib32-krb5-1.20-1 lib32-libcap-2.66-1 lib32-libcurl-compat-7.86.0-1 lib32-libcurl-gnutls-7.86.0-1 lib32-libdrm-2.4.113-1
lib32-libffi-3.4.4-1 lib32-libglvnd-1.5.0-1 lib32-libjpeg-turbo-2.1.4-2 lib32-libnm-1.40.2-1 lib32-libpng-1.6.38-1 lib32-libsndfile-1.1.0-2 lib32-libtasn1-4.19.0-1 lib32-libtiff-4.4.0-4
lib32-libtirpc-1.3.3-1 lib32-libva-2.15.0-6 lib32-libva-mesa-driver-22.2.1-1 lib32-libvpx1.3-1.3.0-3 lib32-libwebp-1.2.4-1 lib32-libxml2-2.10.3-2 lib32-mesa-22.2.1-1
lib32-mesa-vdpau-22.2.1-1 lib32-nspr-4.35-1 lib32-nss-3.84-1 lib32-pango-1:1.50.11-1 lib32-pcre-8.45-3 lib32-pcre2-10.40-3 lib32-pipewire-1:0.3.59-2 lib32-readline-8.2.0-1
lib32-sdl12-compat-1.2.56-1 lib32-sdl2-2.24.1-1 lib32-sdl2_image-2.6.1-1 lib32-smpeg-0.4.5-4 lib32-sqlite-3.39.3-1 lib32-systemd-251.7-1 lib32-util-linux-2.38.1-1
lib32-vulkan-icd-loader-1.3.226-1 lib32-vulkan-intel-22.2.1-1 lib32-vulkan-radeon-22.2.1-1 lib32-xz-5.2.7-1 lib32-zlib-1.2.13-1 libaccounts-glib-1.26-1 libadwaita-1:1.2.0-1
libatomic_ops-7.6.14-1 libblockdev-2.28-1 libbluray-1.3.3-1 libbpf-1.0.1-1 libbsd-0.11.7-1 libcap-2.66-1 libcbor-0.9.0-1 libcdio-2.1.0-3 libcdr-0.1.7-5 libcurl-compat-7.86.0-1
libcurl-gnutls-7.86.0-1 libde265-1.0.9-1 libdrm-2.4.113-3 libe-book-0.1.3-12 libebml-1.4.4-1 libetonyek-0.1.10-2 libevdev-1.13.0-1 libevent-2.1.12-2 libffi-3.4.4-1 libfontenc-1.1.6-1
libgit2-1:1.5.0-1 libglvnd-1.5.0-1 libgpg-error-1.46-1 libgusb-0.4.2-1 libhandy-1.8.0-1 libheif-1.13.0-2 libibus-1.5.27-1 libical-3.0.16-2 libimagequant-4.0.4-1 libinih-56-1
libixion-0.17.0-3 libjcat-0.1.11-1 libjpeg-turbo-2.1.4-2 libjxl-0.7.0-3 libkdcraw-22.08.2-1 libkexiv2-22.08.2-1 libksba-1.6.2-1 libkscreen-5.26.2-1 libksysguard-5.26.2-1 libltc-1.3.2-1
libmalcontent-0.10.5-1 libmatroska-1.7.1-1 libmaxminddb-1.7.1-1 libmbim-1.28.0-1 libmm-glib-1.20.0-1 libmspub-0.1.4-13 libnfs-5.0.2-1 libnftnl-1.2.3-1 libnghttp2-1.50.0-1 libnm-1.40.2-1
libopenmpt-0.6.6-2 liborcus-0.17.2-3 libpamac-11.3.1-3 libpamac-flatpak-plugin-11.3.1-3 libpciaccess-0.17-1 libpng-1.6.38-1 libqalculate-4.4.0-2 libqmi-1.32.0-1 libqxp-0.0.2-9
libreoffice-still-7.3.6-4 librsvg-2:2.55.1-1 libsmbios-2.4.3-5 libsndfile-1.1.0-3 libsoup-2.74.3-1 libsoup3-3.2.1-1 libspectre-0.2.10-2 libssh-0.10.4-1 libtasn1-4.19.0-1 libtiff-4.4.0-4
libtirpc-1.3.3-1 libtool-2.4.7-5 libtorrent-rasterbar-1:2.0.8-1 liburcu-0.13.2-1 libva-2.16.0-1 libva-mesa-driver-22.2.1-1 libvisio-0.1.7-8 libwacom-2.5.0-1 libwebp-1.2.4-1
libwpe-1.14.0-1 libxau-1.0.10-1 libxcvt-0.1.2-1 libxext-1.3.5-1 libxfont2-2.0.6-1 libxft-2.3.6-1 libxinerama-1.1.5-1 libxkbfile-1.1.1-1 libxml++-3.2.4-1 libxml2-2.10.3-2 libxmu-1.1.4-1
libxrender-0.9.11-1 libxshmfence-1.3.1-1 libxslt-1.1.37-2 libxtst-1.2.4-1 libxxf86vm-1.1.5-1 libzmf-0.0.2-13 lilv-0.24.20-1 linux-firmware-20220913.f09bebf-1
linux-firmware-whence-20220913.f09bebf-1 linux510-5.10.151-1 linux515-5.15.76-1 linux60-6.0.6-1 lirc-1:0.10.2-1 lsof-4.96.4-1 lsp-plugins-1.2.3-1 lua-5.4.4-2
luajit-2.1.0.beta3.r449.gdad04f17-1 lutris-0.5.11-1 lv2-1.18.10-1 lvm2-2.03.16-2 lz4-1:1.9.4-1 man-db-2.11.0-1 man-pages-6.01-1 manjaro-alsa-20221002-1 manjaro-pipewire-20221015-2
manjaro-release-22.0.0pre3-1 manjaro-settings-manager-0.5.7-11 manjaro-settings-manager-kcm-0.5.7-11 manjaro-settings-manager-knotifier-0.5.7-11 memtest86+-6.00-1 mesa-22.2.1-1
mesa-vdpau-22.2.1-1 mhwd-0.6.5-23 mhwd-db-0.6.5-23 mhwd-nvidia-520.56.06-2 mhwd-nvidia-390xx-390.154-2 mhwd-nvidia-470xx-470.141.03-3 milou-5.26.2-1 minizip-1:1.2.13-1 mkinitcpio-32-2
modemmanager-1.20.0-1 modemmanager-qt-5.99.0-1 mujs-1.3.0-1 nano-6.4-1 ndctl-74-1 neon-0.32.4-1 nerd-fonts-noto-sans-mono-2.2.2-1 nettle-3.8.1-1 networkmanager-1.40.2-1
networkmanager-openvpn-1.10.0-1 networkmanager-qt-5.99.0-1 nfs-utils-2.6.2-1 nfsidmap-2.6.2-1 noto-fonts-20220810-1 nspr-4.35-1 nss-3.84-1 obs-studio-28.0.3-2 okular-22.08.2-1
openmpi-4.1.4-4 openpmix-4.2.2-1 openssh-9.1p1-1 orc-0.4.32-2 ostree-2022.6-1 oxygen-5.26.2-1 oxygen-icons-1:5.99.0-1 oxygen-sounds-5.26.2-1 pacman-6.0.2-2 pamac-cli-10.4.2-2
pamac-gtk-10.4.2-2 pambase-20221020-1 pango-1:1.50.11-1 partitionmanager-22.08.2-1 pcre-8.45-3 pcre2-10.40-3 pcsclite-1.9.9-1 perl-html-parser-3.79-1 perl-http-message-6.41-1
perl-uri-5.16-1 pinentry-1.2.1-1 pipewire-1:0.3.59-2 pipewire-alsa-1:0.3.59-2 pipewire-audio-1:0.3.59-2 pipewire-pulse-1:0.3.59-2 pipewire-zeroconf-1:0.3.59-2 pixman-0.42.0-1
plasma-desktop-5.26.2-1 plasma-framework-5.99.0-1 plasma-integration-5.26.2-1 plasma-nm-5.26.2-1 plasma-pa-5.26.2-1 plasma-systemmonitor-5.26.2-1 plasma-workspace-5.26.2-1 polkit-122-1
polkit-kde-agent-5.26.2-1 poppler-22.10.0-1 poppler-qt5-22.10.0-1 powerdevil-5.26.2-1 powertop-2.15-1 ppp-2.4.9-2 prison-5.99.0-1 protobuf-21.7-1 protobuf-c-1.4.1-1 purpose-5.99.0-1
pyside6-6.4.0.1-1 python-3.10.8-2 python-appdirs-1.4.4-7 python-autocommand-2.2.1-1 python-certifi-2022.09.24-1 python-idna-3.4-1 python-importlib-metadata-5.0.0-1 python-inflect-6.0.2-1
python-jaraco.context-4.1.2-1 python-jaraco.functools-3.5.2-1 python-jaraco.text-3.10.0-1 python-markdown-3.4.1-2 python-more-itertools-9.0.0-1 python-nspektr-0.4.0-2
python-ordered-set-4.1.0-1 python-pillow-9.3.0-1 python-pydantic-1.10.2-1 python-pyqt5-5.15.7-2 python-setuptools-1:63.4.3-1 python-six-1.16.0-6 python-systemd-235-1
python-trove-classifiers-2022.10.19-1 python-typing_extensions-4.4.0-1 python-urllib3-1.26.12-1 python-validate-pyproject-0.10.1-1 python-zipp-3.10.0-1 qbittorrent-4.4.5-1 qca-qt5-2.3.5-1
qqc2-desktop-style-5.99.0-1 qt5-base-5.15.6+kde+r181-1 qt5-declarative-5.15.6+kde+r20-1 qt5-graphicaleffects-5.15.6+kde+r0-1 qt5-imageformats-5.15.6+kde+r5-1 qt5-location-5.15.6+kde+r3-1
qt5-multimedia-5.15.6+kde+r1-1 qt5-quickcontrols-5.15.6+kde+r0-1 qt5-quickcontrols2-5.15.6+kde+r5-1 qt5-script-5.15.11-1 qt5-sensors-5.15.6+kde+r0-1 qt5-speech-5.15.6+kde+r1-1
qt5-svg-5.15.6+kde+r9-1 qt5-tools-5.15.6+kde+r1-1 qt5-translations-5.15.6+kde+r2-1 qt5-virtualkeyboard-5.15.6+kde+r1-1 qt5-wayland-5.15.6+kde+r50-1 qt5-webchannel-5.15.6+kde+r3-1
qt5-webengine-5.15.11-1 qt5-x11extras-5.15.6+kde+r0-1 qt6-base-6.4.0-2 qt6-declarative-6.4.0-2 qt6-svg-6.4.0-1 qt6-translations-6.4.0-1 raptor-2.0.15-20 rav1e-0.5.1-2 readline-8.2.0-1
rsync-3.2.7-1 rubberband-3.1.1-1 ruby-3.0.4-18 ruby-abbrev-0.1.0-3 ruby-base64-0.1.1-3 ruby-benchmark-0.2.0-3 ruby-bigdecimal-3.1.2-3 ruby-bundledgems-3.0.4-18 ruby-bundler-2.3.23-1
ruby-cgi-0.3.3-1 ruby-csv-3.2.5-3 ruby-date-3.2.2-3 ruby-delegate-0.2.0-3 ruby-did_you_mean-1.6.1-3 ruby-digest-3.1.0-5 ruby-drb-2.1.0-4 ruby-english-0.7.1-3 ruby-erb-2.2.3-4
ruby-etc-1.3.0-5 ruby-fcntl-1.0.1-3 ruby-fiddle-1.1.0-3 ruby-fileutils-1.6.0-3 ruby-find-0.1.1-3 ruby-forwardable-1.3.2-5 ruby-getoptlong-0.1.1-2 ruby-io-console-0.5.11-2
ruby-io-nonblock-0.1.0-2 ruby-io-wait-0.2.3-3 ruby-ipaddr-1.2.4-2 ruby-irb-1.4.2-1 ruby-json-2.6.2-2 ruby-logger-1.5.1-2 ruby-minitest-5.16.3-1 ruby-mutex_m-0.1.1-2 ruby-net-http-0.2.2-2
ruby-open-uri-0.2.0-3 ruby-power_assert-2.0.2-1 ruby-psych-4.0.6-1 ruby-racc-1.6.0-3 ruby-rdoc-6.4.0-4 ruby-reline-0.3.1-2 ruby-ruby2_keywords-0.0.5-1 ruby-stdlib-3.0.4-18
ruby-stringio-3.0.2-4 ruby-test-unit-3.5.5-1 ruby-time-0.2.0-4 ruby-tmpdir-0.1.2-3 ruby-uri-0.11.0-5 rubygems-3.3.23-1 rust-1:1.64.0-1 samba-4.17.2-1 sddm-0.19.0-9 sddm-kcm-5.26.2-1
sdl12-compat-1.2.56-1 sdl2-2.24.1-1 sdl2_image-2.6.2-2 sdl2_mixer-2.6.2-1 sdl2_ttf-2.20.1-1 serd-0.30.16-1 shadow-4.11.1-3 shared-mime-info-2.0+155+gf4e7cbc-1 shiboken6-6.4.0.1-1
signon-kwallet-extension-22.08.2-1 slang-2.3.3-1 smbclient-4.17.2-1 sof-firmware-2.2.2-1 solid-5.99.0-1 sonnet-5.99.0-1 sord-0.16.14-1 source-highlight-3.1.9-9 spectacle-22.08.2-1
sqlite-3.39.4-1 squashfs-tools-4.5.1-2 sratom-0.6.14-1 srt-1.5.1-1 steam-1.0.0.75-2 steam-manjaro-1.0.0.75-1 [removal] steam-native-1.0.0.70-2 [removal] steam-native-runtime-1.0.0.70-4
sudo-1.9.12-1 svt-av1-1.3.0-1 syndication-5.99.0-1 syntax-highlighting-5.99.0-1 systemd-251.7-1 systemd-libs-251.7-1 systemd-sysvcompat-251.7-1 systemsettings-5.26.2-1 taglib-1.13-1
threadweaver-5.99.0-1 tlp-1.5.0-5 tracker3-3.4.1-1 tzdata-2022f-1 unarchiver-1.10.7-7 unzip-6.0-19 upower-1.90.0-1 util-linux-2.38.1-1 util-linux-libs-2.38.1-1 vi-1:070224-6
vte-common-0.70.1-1 vte3-0.70.1-1 vulkan-headers-1:1.3.227-1 vulkan-icd-loader-1.3.226-1 vulkan-intel-22.2.1-1 vulkan-radeon-22.2.1-1 vulkan-tools-1.3.226-1 wayland-protocols-1.27-1
wayland-utils-1.1.0-1 webkit2gtk-2.38.1-1 webkit2gtk-4.1-2.38.1-1 wine-7.19-1 wireless-regdb-2022.08.12-1 wireplumber-0.4.12-1 wireshark-cli-4.0.1-1 wireshark-qt-4.0.1-1
wpa_supplicant-2:2.10-5 wpebackend-fdo-1.14.0-1 x264-3:0.164.r3095.baee400-4 xapian-core-1:1.4.20-1 xcb-util-cursor-0.1.4-1 xcb-util-image-0.4.1-2 xcb-util-keysyms-0.4.1-4
xcb-util-renderutil-0.3.10-1 xcb-util-wm-0.4.2-1 xdg-desktop-portal-1.15.0-1 xdg-desktop-portal-kde-5.26.2-1 xdg-user-dirs-0.18-1 xdg-utils-1.1.3+21+g1a58bc2-2
xf86-video-ati-1:19.1.0.r15.g7a6a34af-1 xfsprogs-5.19.0-2 xkeyboard-config-2.37-1 xmlsec-1.2.36-1 xorg-xsetroot-1.1.3-1 xorgproto-2022.2-1 xz-5.2.7-1 yakuake-22.08.2-1 yay-11.3.0-1
zbar-0.23.90-1 zensu-0.3-7 zlib-1:1.2.13-1 zsh-completions-0.34.0-2
Total Installed Size: 7186.68 MiB
Net Upgrade Size: 155.58 MiB
error: systemd: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/systemd-251.7-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: pacman: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/pacman-6.0.2-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: polkit: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/polkit-122-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: game-devices-udev: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/game-devices-udev-0.18-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: grub: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/grub-2.06.r261.g2f4430cc0-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: inxi: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/inxi-3.3.23.1-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lib32-systemd: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/lib32-systemd-251.7-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libpamac: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/libpamac-11.3.1-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libpamac-flatpak-plugin: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/libpamac-flatpak-plugin-11.3.1-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: linux-firmware-whence: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/linux-firmware-whence-20220913.f09bebf-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: linux-firmware: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/linux-firmware-20220913.f09bebf-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: mkinitcpio: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/mkinitcpio-32-2-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: linux510: signature from "Bernhard Landauer <bernhard@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/linux510-5.10.151-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: linux515: signature from "Manjaro Build Server <build@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/linux515-5.15.76-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: linux60: signature from "Manjaro Build Server <build@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/linux60-6.0.6-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lutris: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/lutris-0.5.11-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: manjaro-alsa: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/manjaro-alsa-20221002-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: manjaro-pipewire: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/manjaro-pipewire-20221015-2-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: manjaro-release: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/manjaro-release-22.0.0pre3-1-any.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)).
error: manjaro-settings-manager: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/manjaro-settings-manager-0.5.7-11-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: manjaro-settings-manager-kcm: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/manjaro-settings-manager-kcm-0.5.7-11-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: manjaro-settings-manager-knotifier: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/manjaro-settings-manager-knotifier-0.5.7-11-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: memtest86+: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/memtest86+-6.00-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: mhwd-nvidia: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/mhwd-nvidia-520.56.06-2-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: mhwd-nvidia-390xx: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/mhwd-nvidia-390xx-390.154-2-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: mhwd-nvidia-470xx: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/mhwd-nvidia-470xx-470.141.03-3-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: mhwd-db: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/mhwd-db-0.6.5-23-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: mhwd: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/mhwd-0.6.5-23-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: nerd-fonts-noto-sans-mono: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/nerd-fonts-noto-sans-mono-2.2.2-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: pamac-cli: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/pamac-cli-10.4.2-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: pamac-gtk: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/pamac-gtk-10.4.2-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: steam: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/steam-1.0.0.75-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: steam-native-runtime: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/steam-native-runtime-1.0.0.70-4-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: systemd-sysvcompat: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/systemd-sysvcompat-251.7-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: tlp: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/tlp-1.5.0-5-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: yay: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/yay-11.3.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: zensu: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/zensu-0.3-7-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package)
the update fails because the manjaro-keyring is not up to date
which causes every package to fail the validation
(telling you that it is corrupted - even though it is likely not)
This problem has been dealt with here quite often - you should be able to find relevant threads or even a wiki when you search …
It appears to me is that the “Mark Wagie” PGP Signature is a problem
You can look here: Pacman troubleshooting - Manjaro
what @Keruskerfuerst said - the section about “errors about keys”
Indeed. But it expired and doesn’t match because your system hasn’t been kept up-to-date, so you have to do as @Keruskerfuerst and @anon33601770 suggested:
Looks like a candidate for this howto:
I have completely installed a fresh brand-new installation of manjaro
And this is the error this time around
Thanks
my solution was:
sudo pacman-key --refresh-keys
