ERROR: Failed to mount 'UUID=189...' on real root
I fresh installed the latest version of Manjaro Yonada from scratch via USB, but I got an error like this:
ERROR: Failed to mount 'UUID=18935ce8-36c5-48ba-8b86-8e61f72841ae' on real root
You are now being dropped into an emergency shell.
sh: can't access tty; job control turned off
[rootfs ~]#
My computer model is Asus Vivobok Go 14/15
Fast Boot is off.
Secure boot is also disabled.
I don’t know much about Linux by the way.
Hi @theszester, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip for legibility: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Note that the above text is partially pre-prepared as a general introduction for new forum users. Please take the time to follow links given and learn how to create effective support requests and encourage quality responses.
:bangbang: Tip :bangbang:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
As I’m a moderator on the forum, I have taken the liberty of doing this for you, this time.
Note that the above text is partially pre-prepared as a general introduction for new forum Users. Please take the time to to understand how it is done and encourage quality responses.
And I expect you’ll benefit from:
I wrote what you said to the USB Live terminal. And something like this:
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64
    lang=en_US keytable=us tz=UTC misobasedir=manjaro
    misolabel=MANJARO_KDE_2421 quiet systemd.show_status=1 splash driver=free
    nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Type: Laptop System: ASUSTeK product: Vivobook Go E1504GA_E1504GA v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: E1504GA v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: E1504GA.305
    date: 03/15/2024
  ID-1: BAT0 charge: 24.6 Wh (58.7%) condition: 41.9/41.9 Wh (100.0%)
    volts: 11.5 min: 11.8 model: X160535 type: Li-ion serial: N/A
    status: discharging
  System RAM: total: 8 GiB available: 7.39 GiB used: 1.56 GiB (21.1%)
  Array-1: capacity: 64 GiB slots: 2 modules: 1 EC: None
  Device-1: Controller0-ChannelA type: DDR4 detail: synchronous size: 8 GiB
    speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: Micron Technology
    part-no: 4ATF1G64HZ-3G2F1 serial: N/A
  Device-2: Controller1-ChannelA-DIMM0 type: no module installed
  Info: model: Intel N100 bits: 64 type: MCP arch: Alder Lake level: v3
    note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6
    model-id: 0xBE (190) stepping: 0 microcode: 0x1A
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported> cache:
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 1x2 MiB L3: 6 MiB
    desc: 1x6 MiB
  Speed (MHz): avg: 700 min/max: 700/3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 700 2: 700 3: 700 4: 700 bogomips: 6452
  Flags: 3dnowprefetch abm acpi adx aperfmperf apic arat arch_capabilities
    arch_lbr arch_perfmon art avx avx2 avx_vnni bmi1 bmi2 bts cat_l2 cdp_l2
    clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16 cx8 de
    ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
    lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
    nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs pge pku
    pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
    sdbg sep serialize sha_ni smap smep split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip user_shstk vme vmx vnmi vpclmulqdq
    vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
  Device-1: Intel Alder Lake-N [UHD Graphics] vendor: ASUSTeK driver: i915
    v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm built: 2020-21
    ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46d1
    class-ID: 0300
  Device-2: Sonix ASUS HD webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 2b7e:b868
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x15e7 built: 2023 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 chroma: red: x: 0.592 y: 0.349 green: x: 0.329
    y: 0.557 blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
    modes: 1920x1080
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL-N)
    device-ID: 8086:46d1 memory: 3.61 GiB unified: yes
  API: Vulkan v: 1.4.303 layers: N/A device: 0 type: integrated-gpu
    name: Intel Graphics (ADL-N) driver: N/A device-ID: 8086:46d1
    surfaces: xcb,xlib
  Device-1: Intel Alder Lake-N PCH High Definition Audio vendor: ASUSTeK
    driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
    snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:54c8 class-ID: 0401
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0
    chip-ID: 10ec:c821 class-ID: 0280
  IF: wlp1s0 state: down mac: <filter>
  WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
  Device-1: IMC Networks Bluetooth Radio driver: btusb v: 0.8 type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:3 chip-ID: 13d3:3556
  Local Storage: total: 267.04 GiB used: 0 KiB (0.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: USB 3.2Gen1
    size: 28.67 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
    spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 1.00 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 model: HN8T15DEHKX075 size: 238.37 GiB
    block-size: physical: 4096 B logical: 4096 B tech: N/A serial: N/A
    fw-rev: A802 scheme: GPT
  Message: No partition data found.
  ID-1: /dev/sda1 maj-min: 8:1 size: 4.03 GiB fs: iso9660
  ID-2: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 97A3-D79B
  ID-3: /dev/sdb1 maj-min: 8:17 size: 300 MiB fs: vfat label: N/A
    uuid: 0E4E-6CFD
  ID-4: /dev/sdb2 maj-min: 8:18 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-5: /dev/sdb3 maj-min: 8:19 size: 138.13 GiB fs: ntfs label: N/A
    uuid: F6BC506EBC502AFF
  ID-6: /dev/sdb4 maj-min: 8:20 size: 643 MiB fs: ntfs label: N/A
    uuid: 921617FC1617E051
  ID-7: /dev/sdb5 maj-min: 8:21 size: 99.29 GiB fs: ext4 label: N/A
    uuid: 18935ce3-36c5-48ba-8b86-8e61f72841ae
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-6:2 info: Sonix ASUS HD webcam type: video driver: uvcvideo
    interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 2b7e:b868 class-ID: fe01 serial: <filter>
  Device-2: 1-8:3 info: IMC Networks Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 13d3:3556 class-ID: e001 serial: <filter>
  Device-1: 2-1:2 info: SanDisk Ultra Flair type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5591 class-ID: 0806
    serial: <filter>
  System Temperatures: cpu: 49.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1248 libs: 327 tools: pamac pm: flatpak pkgs: 0
    1: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    2: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    3: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    4: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    5: https://manjaro.kurdy.org/stable/$repo/$arch
    6: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    7: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    8: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    9: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    10: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    11: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    12: https://linorg.usp.br/manjaro/stable/$repo/$arch
    13: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    14: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    15: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    16: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    17: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    18: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    19: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    20: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
    21: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    22: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    23: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    24: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
    25: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    26: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    27: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    28: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    29: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    30: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    31: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    32: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    33: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    34: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    35: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    36: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    37: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    38: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    39: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    40: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    41: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    42: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    43: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    44: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    45: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    46: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    47: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    48: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    49: http://manjaro.mirror.ac.za/stable/$repo/$arch
    50: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    51: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    52: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    53: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    54: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    55: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    56: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    57: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    58: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    59: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    60: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    61: https://mirrors.netix.net/manjaro/stable/$repo/$arch
    62: https://mirror.23m.com/manjaro/stable/$repo/$arch
    63: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    64: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    65: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    66: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    67: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    68: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    69: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    70: https://mirror.seahost.de/manjaro/stable/$repo/$arch
    71: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    72: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    73: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    74: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    75: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    76: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    77: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    78: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    79: http://manjaro.grena.ge/stable/$repo/$arch
    80: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
    81: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    82: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    83: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    84: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    85: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    86: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    87: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    88: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    89: https://manjaro.ynh.ovh/stable/$repo/$arch
    90: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    91: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    92: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    93: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    94: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    95: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
    96: https://repos.silknet.com/manjaro/stable/$repo/$arch
    97: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    98: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    99: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    100: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    101: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    102: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    103: https://mirrors2.manjaro.org/stable/$repo/$arch
    104: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    105: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    106: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    107: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    108: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    109: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    110: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    111: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    112: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    113: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    114: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    115: https://mirrors.piconets.webwerks.in/manjaro-mirror/stable/$repo/$arch
    116: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    117: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    118: https://mirror.init7.net/manjaro/stable/$repo/$arch
    119: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    120: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    121: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    122: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    123: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    124: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    125: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    126: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    127: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    128: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    129: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    130: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
    131: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    132: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 190
  1: cpu: 100% command: ps pid: 2190 mem: 3.41 MiB (0.0%)
  2: cpu: 17.8% command: plasmashell pid: 1226 mem: 275.6 MiB (3.6%)
  3: cpu: 7.7% command: kwin_x11 pid: 1188 mem: 167.9 MiB (2.2%)
  4: cpu: 6.1% command: gpg-agent pid: 705 mem: 4.07 MiB (0.0%)
  5: cpu: 5.8% command: zsh pid: 1869 mem: 8.42 MiB (0.1%)
  Memory top: 5 of 190
  1: mem: 275.6 MiB (3.6%) command: plasmashell pid: 1226 cpu: 17.8%
  2: mem: 167.9 MiB (2.2%) command: kwin_x11 pid: 1188 cpu: 7.7%
  3: mem: 119.4 MiB (1.5%) command: konsole pid: 1851 cpu: 2.1%
  4: mem: 112.6 MiB (1.4%) command: yakuake pid: 1511 cpu: 3.0%
  5: mem: 106.8 MiB (1.4%) command: kded6 pid: 1185 cpu: 1.9%
  Processes: 190 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
    test_resume image: 2.91 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: N/A Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.36```
Not the same UUID here. 18935ce3 not 18935ce8. So it clearly mounts the wrong UUID or is it a typo?
Please check what UUID is written on this partition at /etc/fstab. It is a text file.
I think it is typo. File:
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=0E4E-6CFD                            /boot/efi      vfat    defaults,umask=0077 0 2
UUID=18935ce3-36c5-48ba-8b86-8e61f72841ae /              ext4    defaults   0 1
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0```
I also tried to mount command manuel on error screen. But it says mount: /dev/sdb5: can't find in /etc/fstab
It looks like your drive is a UFS and not an NVME. I’m not familiar with it. But it looks like the driver needs to be added explicitly, like the initcpio here: https://askubuntu.com/a/1477057
So, you need to edit the file: /etc/mkinitcpio.conf and replace MODULES=() with MODULES=(ufshcd-core ufshcd-pci) and then recreate the image:
# Enter the local installation
sudo manjaro-chroot -a
# Then rebuild the image
sudo mkinitcpio -P
exit
Now the driver should be included and mounting should be possible.
Booted!!! Thank you :sob:
