Displays get no signal on boot after update
Hello all,
After running the latest updates I find that my displays lose signal when the login screen is supposed to come on. Trying an alternate TTY doesn’t do anything (even attempted to log in both normally and on another and running commands like startx despite not being able to see). But nothing seems to work.
Using my Live USB the computer boots fine. So I chroot in and ran sudo pacman -Syyu, but it says everything’s up-to-date, so I guess the update came through fine.
I ran a few informative commands as recommended by the How To topic;
mhwd-kernel
[manjaro /]# mhwd-kernel --listinstalled
Currently running: 6.1.30-1-MANJARO (linux61)
   * linux510
   * linux515
   * linux61
mhwd
[manjaro /]# mhwd --listinstalled
> Installed PCI configs:
           video-linux            2018.05.04                true            PCI
inxi
[manjaro /]# inxi --full --admin --filter --width
12System:
  12Kernel 6.1.30-1-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 12.2.1
    12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_XFCE_2213 quiet
    systemd.show_status=1 splash apparmor=1 security=apparmor driver=free
    nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  12Desktop Xfce 12v 4.18.1 12tk Gtk 12v 3.24.36 12dm N/A 12Distro Manjaro Linux
    12base Arch Linux
12Machine:
  12Type Desktop 12Mobo Gigabyte 12model B650 GAMING X AX 12v x.x 12serial N/A
    12UEFI American Megatrends LLC. 12v F9a 12date 07/21/2023
12CPU:
  12Info 12model AMD Ryzen 7 7800X3D 12socket AM5 12bits 64 12type MT MCP 12arch Zen 4
    12gen 5 12level v4 12note check 12built 2022+ 12process TSMC n5 (5nm) 12family 0x19 (25)
    12model-id 0x61 (97) 12stepping 2 12microcode 0xA601203
  12Topology 12cpus 1x 12cores 8 12tpc 2 12threads 16 12smt enabled 12cache 12L1 512 KiB
    12desc d-8x32 KiB; i-8x32 KiB 12L2 8 MiB 12desc 8x1024 KiB 12L3 96 MiB 12desc 1x96 MiB
  12Speed (MHz) 12avg 3300 12high 4200 12min/max 3000/5049 12boost enabled
    12base/boost 4200/5050 12scaling 12driver acpi-cpufreq 12governor schedutil
    12volts 1.3 V 12ext-clock 100 MHz 12cores 121 4200 122 3000 123 4200 124 3000 125 3000
    126 4200 127 3000 128 3000 129 4200 1210 3000 1211 3000 1212 3000 1213 3000 1214 3000 1215 3000
    1216 3000 12bogomips 134196
  12Flags avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  12Vulnerabilities
  12Type itlb_multihit 12status Not affected
  12Type l1tf 12status Not affected
  12Type mds 12status Not affected
  12Type meltdown 12status Not affected
  12Type mmio_stale_data 12status Not affected
  12Type retbleed 12status Not affected
  12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via
  12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer
  12Type spectre_v2 12mitigation Retpolines, IBPB: conditional, IBRS_FW, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  12Type srbds 12status Not affected
  12Type tsx_async_abort 12status Not affected
12Graphics:
  12Device-1 AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] 12vendor Tul / PowerColor
    12driver amdgpu 12v kernel 12arch RDNA-3 12code Navi-3x 12process TSMC n5 (5nm)
    12built 2022+ 12pcie 12gen 4 12speed 16 GT/s 12lanes 16 12ports 12active DP-1,DP-2
    12empty DP-3,HDMI-A-1 12bus-ID 03:00.0 12chip-ID 1002:744c 12class-ID 0300
  12Device-2 AMD Raphael 12vendor Gigabyte 12driver amdgpu 12v kernel 12arch RDNA-2
    12code Navi-2x 12process TSMC n7 (7nm) 12built 2020-22 12pcie 12gen 4 12speed 16 GT/s
    12lanes 16 12ports 12active none 12empty DP-4, DP-5, DP-6, HDMI-A-2 12bus-ID 12:00.0
    12chip-ID 1002:164e 12class-ID 0300 12temp 41.0 C
  12Display 12server X.Org 12v 21.1.8 12driver 12gpu amdgpu 12display-ID :0.0 12screens 1
  12Screen-1 0 12s-res 3840x1080 12s-dpi 96 12s-size 1016x285mm (40.00x11.22")
    12s-diag 1055mm (41.54")
  12Monitor-1 DP-1 12mapped DisplayPort-0 12pos primary,right 12model AOC 24G1WG4
    12serial <filter> 12built 2019 12res 1920x1080 12dpi 94 12gamma 1.2
    12size 521x293mm (20.51x11.54") 12diag 598mm (23.5") 12ratio 16:9 12modes
    12max 1920x1080 12min 720x400
  12Monitor-2 DP-2 12mapped DisplayPort-1 12pos left 12model AOC 24G1WG4
  12API OpenGL 12v 4.6 Mesa 23.1.5 12renderer AMD Radeon RX 7900 XTX (gfx1100 LLVM
    15.0.7 DRM 3.49 6.1.30-1-MANJARO) 12direct-render Yes
12Audio:
  12Device-1 AMD 12driver snd_hda_intel 12v kernel 12pcie 12gen 4 12speed 16 GT/s 12lanes 16
    12bus-ID 03:00.1 12chip-ID 1002:ab30 12class-ID 0403
  12Device-2 AMD Rembrandt Radeon High Definition Audio 12driver snd_hda_intel
    12v kernel 12pcie 12gen 4 12speed 16 GT/s 12lanes 16 12bus-ID 12:00.1 12chip-ID 1002:1640
    12class-ID 0403
  12Device-3 AMD Family 17h/19h HD Audio 12vendor Gigabyte 12driver snd_hda_intel
    12v kernel 12pcie 12gen 4 12speed 16 GT/s 12lanes 16 12bus-ID 12:00.6 12chip-ID 1022:15e3
    12class-ID 0403
  12Device-4 Roland Rubix44 12driver snd-usb-audio 12type USB 12rev 2.0
    12speed 480 Mb/s 12lanes 1 12mode 2.0 12bus-ID 1-2:2 12chip-ID 0582:01e1 12class-ID fe01
  12API ALSA 12v k6.1.30-1-MANJARO 12status kernel-api 12with aoss 12type oss-emulator
    12tools alsactl,alsamixer,amixer
  12Server-1 sndiod 12v N/A 12status off 12tools aucat,midicat,sndioctl
  12Server-2 PipeWire 12v 0.3.77 12status off 12with 121 pipewire-pulse 12status off
    122 wireplumber 12status off 123 pipewire-alsa 12type plugin 124 pw-jack 12type plugin
    12tools pactl,pw-cat,pw-cli,wpctl
12Network:
  12Device-1 Realtek RTL8125 2.5GbE 12vendor Gigabyte 12driver r8169 12v kernel 12pcie
    12gen 2 12speed 5 GT/s 12lanes 1 12port e000 12bus-ID 0e:00.0 12chip-ID 10ec:8125
    12class-ID 0200
  12IF enp14s0 12state up 12speed 1000 Mbps 12duplex full 12mac <filter>
  12Device-2 Intel Wi-Fi 6 AX210/AX211/AX411 160MHz 12driver iwlwifi 12v kernel
    12pcie 12gen 2 12speed 5 GT/s 12lanes 1 12bus-ID 0f:00.0 12chip-ID 8086:2725
    12class-ID 0280
  12IF wlp15s0 12state down 12mac <filter>
12Bluetooth:
  12Device-1 Intel AX210 Bluetooth 12driver btusb 12v 0.8 12type USB 12rev 2.0
    12speed 12 Mb/s 12lanes 1 12mode 1.1 12bus-ID 1-9:5 12chip-ID 8087:0032 12class-ID e001
  12Report rfkill 12ID hci0 12rfk-id 2 12state down 12bt-service N/A 12rfk-block
    12hardware no 12software no 12address see --recommends
12Drives:
  12Local Storage 12total 2.37 TiB 12used 1.24 TiB (52.4%)
  12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor Western Digital
    12model WDS480G2G0C-00AJM0 12size 447.13 GiB 12block-size 12physical 512 B
    12logical 512 B 12speed 31.6 Gb/s 12lanes 4 12tech SSD 12serial <filter>
    12fw-rev 231800WD 12temp 39.9 C
  12SMART yes 12health PASSED 12on 235d 7h 12cycles 538
    12read-units 2,193,731 [1.12 TB] 12written-units 1,838,439 [941 GB]
  12ID-2 /dev/sda 12maj-min 8:0 12vendor PNY 12model CS900 2TB SSD 12size 1.82 TiB
    12block-size 12physical 512 B 12logical 512 B 12sata 3.1 12speed 6.0 Gb/s 12tech SSD
    12serial <filter> 12fw-rev 0600 12temp 19 C
  12SMART yes 12state enabled 12health PASSED 12on 66d 3h 12cycles 141 12written 2.2 MiB
  12ID-3 /dev/sdb 12maj-min 8:16 12vendor SanDisk 12model Ultra 12size 114.61 GiB
    12block-size 12physical 512 B 12logical 512 B 12type USB 12rev 3.2 12spd 5 Gb/s 12lanes 1
    12mode 3.2 gen-1x1 12tech N/A 12serial <filter> 12fw-rev 1.00
  12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
12Partition:
  12ID-1 / 12raw-size 446.63 GiB 12size 438.55 GiB (98.19%) 12used 41.06 GiB (9.4%)
    12fs ext4 12block-size 4096 B 12dev /dev/nvme0n1p2 12maj-min 259:2
  12ID-2 /boot/efi 12raw-size 512 MiB 12size 511 MiB (99.80%) 12used 288 KiB (0.1%)
    12fs vfat 12block-size 512 B 12dev /dev/nvme0n1p1 12maj-min 259:1
  12ID-3 /home 12raw-size 1.82 TiB 12size 1.79 TiB (98.37%) 12used 1.2 TiB (67.0%)
    12fs ext4 12block-size 4096 B 12dev /dev/sda1 12maj-min 8:1
12Swap:
  12Alert No swap data was found.
12Sensors:
  12System Temperatures 12cpu 49.5 C 12mobo N/A
  12Fan Speeds (RPM) N/A
  12GPU 12device amdgpu 12temp 41.0 C 12device amdgpu 12temp 56.0 C 12mem 62.0 C 12fan 0
    12watts 23.00
12Info:
  12Processes 0 12Uptime 25m 12wakeups 0 12Memory 12total 32 GiB 12note est.
  12available 30.51 GiB 12used 3.64 GiB (11.9%) 12Init systemd 12v 253
  12default graphical 12tool systemctl 12Compilers 12gcc 13.2.1 12clang 15.0.7 12Packages
  12pm pacman 12pkgs 1970 12libs 493 12tools pamac 12Client Unknown Client: systemd
  12inxi 3.3.28
And also found the command for the last boot kernel messages; journalctl, where I noticed this sequence of errors
[manjaro /]# journalctl -b -1
Aug 12 17:54:58 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* flip_done timed out
Aug 12 17:54:58 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* [CRTC:67:crtc-0] commit wait timed out
Aug 12 17:55:08 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* flip_done timed out
Aug 12 17:55:08 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* [CRTC:70:crtc-1] commit wait timed out
Aug 12 17:55:18 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* flip_done timed out
Aug 12 17:55:18 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* [CONNECTOR:78:DP-1] commit wait timed out
Aug 12 17:55:29 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* flip_done timed out
Aug 12 17:55:29 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* [CONNECTOR:86:DP-2] commit wait timed out
Aug 12 17:55:39 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* flip_done timed out
Aug 12 17:55:39 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* [PLANE:50:plane-2] commit wait timed out
Aug 12 17:55:49 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* flip_done timed out
Aug 12 17:55:49 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* [PLANE:55:plane-3] commit wait timed out
Lastly I’m using two cheap AOC curved 144Hz monitors connected via DP (no daisy-chaining).
Any advice on how to fix my display output?
[edit]
I’ve also tested going to runlevel 3 via a one-time edit of GRUB, same result; my display goes “no signal” and the same errors still show up in last boot’s journalctl
[/edit]
[edit2]
On the release topic someone suggested it may be an issue with the amd-ucode package, so I followed the instructions, to no avail.
[/edit2]
The only thing I see which differs from my setup is the kernel as I am using 6.4.
Let me say - older kernels like 5.10 and 5.15 is not likely to work well with your hardware.
I am going to suggest you install linux64 in your chroot (I noted you cannot even get into TTY)
Another option is to navigate - in chroot -
cd /var/cache/pacman/pkg
ls amd-ucode*
The current package is named amd-ucode-20230810.7be2766d-1-any.pkg.tar.xz
It may work or it may not - you can use pacman -U to install the previous amd-ucode from your cache - possibly (from memory - please check your listing for correct filename)
pacman -U amd-ucode-20230724.59fbffa9-1-any.pkg.tar.zst
Thanks for the suggestion.
I wasn’t using the old kernels, just never deleted them. So did that now.
I installed the older amd-ucode package, but unfortunately the same result still
[manjaro /]# pacman -Q | grep amd-ucode
amd-ucode 20230724.59fbffa9-1
Still the same result and errors in journalctl;
Aug 13 13:29:22 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* flip_done timed out
Aug 13 13:29:22 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* [CRTC:67:crtc-0] commit wait timed out
Aug 13 13:29:32 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* flip_done timed out
Aug 13 13:29:32 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* [CRTC:70:crtc-1] commit wait timed out
Aug 13 13:29:42 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* flip_done timed out
Aug 13 13:29:42 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* [CONNECTOR:78:DP-1] commit wait timed out
Aug 13 13:29:52 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* flip_done timed out
Aug 13 13:29:52 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* [CONNECTOR:86:DP-2] commit wait timed out
Aug 13 13:30:02 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* flip_done timed out
Aug 13 13:30:02 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* [PLANE:50:plane-2] commit wait timed out
Aug 13 13:30:12 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* flip_done timed out
Aug 13 13:30:12 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* [PLANE:55:plane-3] commit wait timed out
Aug 13 13:30:12 AndyStation kernel: ------------[ cut here ]------------
Aug 13 13:30:12 AndyStation kernel: WARNING: CPU: 6 PID: 1398 at drivers/gpu/drm/amd/amdgpu/../display/amdgpu_dm/amdgpu_dm.c:7899 amdgpu_dm_atomic_commit_tail+0x2ee3/0x2f40 [amdgpu]
Aug 13 13:30:12 AndyStation kernel: Modules linked in: cmac algif_hash algif_skcipher af_alg xt_CHECKSUM xt_MASQUERADE xt_conntrack ipt_REJECT nf_reject_ipv4 xt_tcpudp nft_compat nft_chain_>
Aug 13 13:30:12 AndyStation kernel:  i2c_piix4 rfkill libphy k10temp cec soundcore video wmi acpi_cpufreq mac_hid uinput dm_multipath crypto_user fuse dm_mod loop bpf_preload ip_tables x_ta>
Aug 13 13:30:12 AndyStation kernel: CPU: 6 PID: 1398 Comm: Xorg.wrap Tainted: G        W          6.1.44-1-MANJARO #1 a5ae25468b7d8bc523fd3843f165bfe956aae550
Aug 13 13:30:12 AndyStation kernel: Hardware name: Gigabyte Technology Co., Ltd. B650 GAMING X AX/B650 GAMING X AX, BIOS F9a 07/21/2023
Aug 13 13:30:12 AndyStation kernel: RIP: 0010:amdgpu_dm_atomic_commit_tail+0x2ee3/0x2f40 [amdgpu]
Aug 13 13:30:12 AndyStation kernel: Code: 6b fa ff ff 45 31 c9 49 8b 4d 28 48 39 4f 28 41 0f 95 c1 48 85 f6 0f 85 46 f6 ff ff e9 45 f6 ff ff 0f 0b 0f 0b e9 bc f3 ff ff <0f> 0b e9 22 f3 ff f>
Aug 13 13:30:12 AndyStation kernel: RSP: 0018:ffffa1554179f910 EFLAGS: 00010002
Aug 13 13:30:12 AndyStation kernel: RAX: 0000000000000002 RBX: 0000000000000282 RCX: 0000000000000000
Aug 13 13:30:12 AndyStation kernel: RDX: 0000000000000001 RSI: 0000000000000297 RDI: ffff9531d8480170
Aug 13 13:30:12 AndyStation kernel: RBP: ffffa1554179fc70 R08: ffffa1554179f87c R09: ffffa1554179f874
Aug 13 13:30:12 AndyStation kernel: R10: ffffa1554179f878 R11: ffff9531cc7cd400 R12: ffff9531d5457918
Aug 13 13:30:12 AndyStation kernel: R13: 0000000000000000 R14: ffff9531d8747a00 R15: ffff9531d5457800
Aug 13 13:30:12 AndyStation kernel: FS:  00007f9ba32ce680(0000) GS:ffff9538f8780000(0000) knlGS:0000000000000000
Aug 13 13:30:12 AndyStation kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Aug 13 13:30:12 AndyStation kernel: CR2: 00007fc98c015aa8 CR3: 0000000146184000 CR4: 0000000000750ee0
Aug 13 13:30:12 AndyStation kernel: PKRU: 55555554
Aug 13 13:30:12 AndyStation kernel: Call Trace:
Aug 13 13:30:12 AndyStation kernel:  <TASK>
Aug 13 13:30:12 AndyStation kernel:  ? amdgpu_dm_atomic_commit_tail+0x2ee3/0x2f40 [amdgpu cb9cb9350806a65d51a4ece6e16115d4e1e9af94]
Aug 13 13:30:12 AndyStation kernel:  ? __warn+0x7d/0xd0
Aug 13 13:30:12 AndyStation kernel:  ? report_bug+0xe6/0x150
Aug 13 13:30:12 AndyStation kernel:  ? handle_bug+0x3c/0x80
Aug 13 13:30:12 AndyStation kernel:  ? exc_invalid_op+0x17/0x70
Aug 13 13:30:12 AndyStation kernel:  ? asm_exc_invalid_op+0x1a/0x20
Aug 13 13:30:12 AndyStation kernel:  commit_tail+0x94/0x130
Aug 13 13:30:12 AndyStation kernel:  drm_atomic_helper_commit+0x11a/0x140
Aug 13 13:30:12 AndyStation kernel:  drm_atomic_commit+0x9a/0xd0
Aug 13 13:30:12 AndyStation kernel:  ? drm_plane_get_damage_clips.cold+0x1c/0x1c
Aug 13 13:30:12 AndyStation kernel:  drm_client_modeset_commit_atomic+0x203/0x250
Aug 13 13:30:12 AndyStation kernel:  drm_client_modeset_commit_locked+0x5a/0x160
Aug 13 13:30:12 AndyStation kernel:  drm_client_modeset_commit+0x25/0x40
Aug 13 13:30:12 AndyStation kernel:  drm_fb_helper_lastclose+0x49/0x80
Aug 13 13:30:12 AndyStation kernel:  amdgpu_driver_lastclose_kms+0xe/0x20 [amdgpu cb9cb9350806a65d51a4ece6e16115d4e1e9af94]
Aug 13 13:30:12 AndyStation kernel:  drm_lastclose+0x32/0x50
Aug 13 13:30:12 AndyStation kernel:  drm_release+0xc2/0xe0
Aug 13 13:30:12 AndyStation kernel:  __fput+0x89/0x250
Aug 13 13:30:12 AndyStation kernel:  task_work_run+0x5d/0x90
Aug 13 13:30:12 AndyStation kernel:  exit_to_user_mode_prepare+0x1d9/0x1e0
Aug 13 13:30:12 AndyStation kernel:  syscall_exit_to_user_mode+0x1b/0x40
Aug 13 13:30:12 AndyStation kernel:  do_syscall_64+0x6c/0x90
Aug 13 13:30:12 AndyStation kernel:  ? __x86_return_thunk+0x9/0xa
Aug 13 13:30:12 AndyStation kernel:  ? do_user_addr_fault+0x237/0x580
Aug 13 13:30:12 AndyStation kernel:  ? exc_page_fault+0x7c/0x180
Aug 13 13:30:12 AndyStation kernel:  entry_SYSCALL_64_after_hwframe+0x69/0xd3
Aug 13 13:30:12 AndyStation kernel: RIP: 0033:0x7f9ba30ff184
Aug 13 13:30:12 AndyStation kernel: Code: 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 80 3d e5 71 14 00 00 74 13 b8 03 00 00 00 0f 05 <48> 3d 00 f0 ff ff 7>
Aug 13 13:30:12 AndyStation kernel: RSP: 002b:00007ffe5a7e3828 EFLAGS: 00000202 ORIG_RAX: 0000000000000003
Aug 13 13:30:12 AndyStation kernel: RAX: 0000000000000000 RBX: 0000000000000003 RCX: 00007f9ba30ff184
Aug 13 13:30:12 AndyStation kernel: RDX: 0000000000000000 RSI: 00000000c04064a0 RDI: 0000000000000003
Aug 13 13:30:12 AndyStation kernel: RBP: 0000000000000001 R08: 0000000000000064 R09: 0000000000000000
Aug 13 13:30:12 AndyStation kernel: R10: 00007f9ba3012340 R11: 0000000000000202 R12: 00007ffe5a7e3890
Aug 13 13:30:12 AndyStation kernel: R13: 0000000000000001 R14: 00000000c04064a0 R15: 0000000000000000
Aug 13 13:30:12 AndyStation kernel:  </TASK>
Aug 13 13:30:12 AndyStation kernel: ---[ end trace 0000000000000000 ]---
Aug 13 13:30:12 AndyStation kernel: WARNING: CPU: 6 PID: 1398 at drivers/gpu/drm/amd/amdgpu/../display/amdgpu_dm/amdgpu_dm.c:7481 amdgpu_dm_atomic_commit_tail+0x2eea/0x2f40 [amdgpu]
Aug 13 13:30:12 AndyStation kernel: RIP: 0010:amdgpu_dm_atomic_commit_tail+0x2eea/0x2f40 [amdgpu]
Aug 13 13:30:12 AndyStation kernel: Code: 49 8b 4d 28 48 39 4f 28 41 0f 95 c1 48 85 f6 0f 85 46 f6 ff ff e9 45 f6 ff ff 0f 0b 0f 0b e9 bc f3 ff ff 0f 0b e9 22 f3 ff ff <0f> 0b e9 3a f3 ff f>
Aug 13 13:30:12 AndyStation kernel: RSP: 0018:ffffa1554179f910 EFLAGS: 00010082
Aug 13 13:30:12 AndyStation kernel: RAX: 0000000000000001 RBX: 0000000000000282 RCX: 0000000000000000
Aug 13 13:30:12 AndyStation kernel:  ? amdgpu_dm_atomic_commit_tail+0x2eea/0x2f40 [amdgpu cb9cb9350806a65d51a4ece6e16115d4e1e9af94]
Aug 13 13:30:12 AndyStation kernel: RDX: 0000000000000001 RSI: 0000000000000293 RDI: ffff9531d8480170
Aug 13 13:30:12 AndyStation kernel: R10: ffffa1554179f878 R11: ffff9531cc7cd400 R12: ffff9531d5456918
Aug 13 13:30:12 AndyStation kernel: R13: 0000000000000001 R14: ffff9531d8744e00 R15: ffff9531d5456800
Aug 13 13:30:22 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* [CRTC:67:crtc-0] flip_done timed out
Aug 13 13:30:32 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* [CRTC:70:crtc-1] flip_done timed out
Aug 13 13:30:42 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* flip_done timed out
Aug 13 13:30:42 AndyStation kernel: amdgpu 0000:03:00.0: [drm] *ERROR* [CRTC:67:crtc-0] commit wait timed out
I am sorry for not being able to provide more answers - I simply don’t know anything when it comes to AMD and kernel code.
My only thought now is - how did linux64 pan out?
Do you have timeshift recovery option?
[Stable Update] 2023-08-11 - Kernels, Plasma, Nvidia, Firefox, Thunderbird, Pamac, Pipewire, Mesa
UPdate 2023-09-10: Avoid black screen on Ryzen 7
[Stable Update] 2023-08-29 - Kernels, Mesa, Deepin, Firefox, KDE Gear & Frameworks, Nvidia, Budgie
[Stable Update] 2024-03-13 - Plasma 5.27.11, Firefox, Thunderbird, AMDVLK, Qemu
[Stable Update] 2023-12-01 - Kernels, NVIDIA, Thunderbird, Deepin, PipeWire 1.0, QEMU
[Stable Update] 2023-11-28 - Kernels, Firefox, Appstream 1.0, Blender 4.0, Cinnamon
[Stable Update] 2023-12-10 - Kernels, Plasma, Phosh, Systemd, Cinnamon, Gnome, libpamac
[Stable Update] 2023-09-10 - Kernels, Systemd, Firefox, Thunderbird, LLVM
[Stable Update] 2024-03-06 - Kernels, Systemd, KDE Gear, Qt, GNOME, Firefox, Thunderbird
[Stable Update] 2023-12-13 - Kernels, Blender, KDE Gear, Pamac 11.7, Python, Haskell
[Stable Update] 2023-09-18 - Kernels, Mesa, Pipewire, Systemd, LibreOffice, KDE, Thunderbird
[Stable Update] 2023-10-04 - Kernels, Systemd, LibreOffice, NVIDIA, Mesa, GNOME, AMDVLK
[Stable Update] 2023-10-09 - Mesa, Grub, GlibC, Thunderbird, KDE Frameworks Renaming
[Stable Update] 2023-10-13 - Pipewire, Mattermost, Qt5, Haskell, Python
[Stable Update] 2023-11-13 - Kernels, KDE Gear, LibreOffice, LXQt, Pipewire, Phosh, Firefox, Thunderbird
[Stable Update] 2023-11-21 - Systemd, Gamescope-Plus, KDE Frameworks, Wine, Pipewire, Thunderbird
[Stable Update] 2023-12-15 - Kernels, Blender, Thunderbird, Xorg-Server, Xwayland, Warzone2100
[Stable Update] 2023-12-23 - Kernels, Grub, Mate, Deepin, Cinnamon, ICU, KDE Frameworks
[Stable Update] 2024-01-02 - Kernels, Systemd, Qemu, Plasma-Mobile, Deepin
[Stable Update] 2023-11-06 - Kernels, Gnome 45.1, Plasma 5.27.9, Firefox, Thunderbird, Pipewire
[Stable Update] 2024-02-21 - Kernels, KDE, VirtualBox, Calamares, ROCm, Firefox, Thunderbird
[Stable Update] 2024-01-13 - Kernels, Systemd, Qt5, Mesa, Dbus, Firefox, Thunderbird
I used mhwd-kernel to install 6.4 and used the grub menu to launch the new kernel. And we appear to be back. Replying this while logged in and not via a Live USB.
Also I now remember my Manjaro forum password because I had to type it quite a lot the last 17 hours xD
Arch infiltrator here to confirm that the same issue apparently affected me following a system update earlier today on the Arch 6.1.44-1-lts kernel.
After reboot, no video. chrooting in from a live ISO, amdgpu 0000:0c:00.0: [drm] *ERROR* flip_done timed out messages journalctl.
Maybe the newest AMD driver update doesn’t work on older kernels, like 6.1?
Rolling back my system to a June snapshot fixed it (these instructions are for Arch; they are NOT Manjaro-compatible):
  1. Comment everything in /etc/pacman.d/mirrorlist and add a mirror the archived date, 2023-06-30:
Server = https://archive.archlinux.org/repos/2023/06/30/$repo/os/$arch
  1. Update database and downgrade everything: pacman -Syyuu
  2. Reboot
