Debug_shell not working
Hi all,
I try to debug linux boot with systemd debug_shell, but I am not able to get into the shell. Until now, the debug_shell is activated by grub kernel parameters and by debug_shell.service. I try all this because the system has problems starting some services during boot if I do not boot windows in advance. My hope was to get more information with the debug_shell if only I could get this shell started/switched into.
My hardware is a Lenovo ideapad Duet 3 10IGL5. Linux kernel version is
 ~$  uname -a
Linux ideapad 5.15.19-1-MANJARO #1 SMP PREEMPT Tue Feb 1 16:58:17 UTC 2022 x86_64 GNU/Linux
The kernel command line is
 ~$ cat /proc/cmdline
BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=d1b85899-cc2f-489e-8ed8-a89062284a10 rw fbcon=rotate:1 systemd.debug-shell=1 apparmor=1 security=apparmor udev.log_priority=3
Switching into the shell should happen by Ctrl-Alt-F9. Due to the keyboard layout of the 10IGL5 I press Ctrl-Alt-Fn-F9. This works after a successful boot but not when the system is waiting for the services to start. Nevertheless, I also tried other combinations. But all without success.
sid
As requested in [HowTo] Provide System Information I provide the output of inxi.
    ~  inxi --admin --verbosity=7 --filter --width         ✔
  Kernel: 5.15.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
  Type: Detachable System: LENOVO product: 82AT v: IdeaPad Duet 3 10IGL5
    serial: <superuser required> Chassis: type: 32 v: IdeaPad Duet 3 10IGL5
  Mobo: LENOVO model: LNVNB161216 v: SDK0T31556 WIN
    serial: <superuser required> UEFI: LENOVO v: EQCN29WW date: 08/11/2021
  ID-1: BAT0 charge: 31.1 Wh (100.0%) condition: 31.1/30.0 Wh (103.8%)
    volts: 8.7 min: 7.7 model: SMP L19M2PD7 type: Li-ion serial: <filter>
    status: Full cycles: 11
  Device-1: hid-0018:04F3:2BD6.0001-battery model: ELAN901C:00 04F3:2BD6
    serial: N/A charge: N/A status: N/A
  RAM: total: 7.57 GiB used: 2.71 GiB (35.8%)
  RAM Report:
  Info: model: Intel Pentium Silver N5030 bits: 64 type: MCP
    arch: Goldmont Plus family: 6 model-id: 0x7A (122) stepping: 8
    microcode: 0x1A
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
    desc: d-4x24 KiB; i-4x32 KiB L2: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 2855 high: 3069 min/max: 800/3100 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 2785 2: 2785 3: 2784
    4: 3069 bogomips: 8756
  Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
    arch_perfmon art bts cat_l2 cdp_l2 clflush clflushopt cmov constant_tsc
    cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
    flexpriority fpu fsgsbase fxsr ht ibpb ibrs ibrs_enhanced ida intel_pt
    lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc
    nopl nx pae pat pbe pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse
    pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep sha_ni smap
    smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
    tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vme vmx vnmi vpid
    x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Device-1: Intel GeminiLake [UHD Graphics 605] vendor: Lenovo driver: i915
    v: kernel bus-ID: 00:02.0 chip-ID: 8086:3184 class-ID: 0300
  Device-2: Realtek Intergrated Camera 2M type: USB driver: uvcvideo
    bus-ID: 1-4:3 chip-ID: 0bda:5609 class-ID: 0e02 serial: <filter>
  Device-3: Realtek Intergrated Camera 5M type: USB driver: uvcvideo
    bus-ID: 1-7:9 chip-ID: 0bda:5612 class-ID: 0e02 serial: <filter>
  Display: wayland server: X.org 1.21.1.3 compositor: gnome-shell driver:
    loaded: i915 note: n/a (using device driver) - try sudo/root
    unloaded: modesetting alternate: fbdev,vesa display-ID: 0
  Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
    vendor: Lenovo driver: snd_hda_intel v: kernel
    alternate: snd_soc_skl,snd_sof_pci_intel_apl bus-ID: 00:0e.0
    chip-ID: 8086:3198 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.19-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.45 running: no
  Device-1: Intel Gemini Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:0c.0 chip-ID: 8086:31dc class-ID: 0280
  IF: wlp0s12f0 state: down mac: <filter>
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
    bus-ID: 2-1.1:3 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp0s21f0u1u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
    driver: btusb v: 0.8 bus-ID: 1-9:10 chip-ID: 8087:0aaa class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 146.2 GiB used: 29.41 GiB (20.1%)
  ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: SanDisk model: DA4128
    size: 116.48 GiB block-size: physical: 512 B logical: 512 B type: SSD
    serial: <filter> rev: 0x8 scheme: GPT
  ID-2: /dev/mmcblk1 maj-min: 179:24 vendor: SanDisk model: SC32G
    size: 29.72 GiB block-size: physical: 512 B logical: 512 B type: SSD
    serial: <filter> scheme: MBR
  ID-1: / raw-size: 69.44 GiB size: 67.85 GiB (97.71%) used: 29.39 GiB (43.3%)
    fs: ext4 dev: /dev/mmcblk0p5 maj-min: 179:5 label: N/A
    uuid: d1b85899-cc2f-489e-8ed8-a89062284a10
  ID-2: /boot/efi raw-size: 497 MiB size: 496 MiB (99.80%)
    used: 28.6 MiB (5.8%) fs: vfat dev: /dev/mmcblk0p1 maj-min: 179:1
    label: SYSTEM_DRV uuid: B6E8-D9A6
  ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/mmcblk0p6 maj-min: 179:6 label: N/A
    uuid: ac965b1e-21e7-4b9e-ad36-4230184af56f
  ID-1: /dev/mmcblk0p2 maj-min: 179:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/mmcblk0p3 maj-min: 179:3 size: 41.66 GiB fs: ntfs
    label: Windows uuid: 7C7CEBD67CEB896A
  ID-3: /dev/mmcblk0p4 maj-min: 179:4 size: 1000 MiB fs: ntfs
    label: WINRE_DRV uuid: 8816EC3B16EC2C3E
  ID-4: /dev/mmcblk1p1 maj-min: 179:25 size: 29.72 GiB fs: bitlocker
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0
  Hub-2: 1-1:2 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1 speed: 480 Mb/s
    chip-ID: 2109:2817 class-ID: 0900
  Hub-3: 1-1.3:5 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 1-1.3.1:7 info: Logitech Keyboard K120 type: Keyboard,HID
    power: 90mA chip-ID: 046d:c31c class-ID: 0300
  Hub-4: 1-1.4:6 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
    chip-ID: 045b:0209 class-ID: 0900
  Device-1: 1-1.5:8 info: Anker Innovations Limited Anker USB-C Hub Device
    type: Billboard driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 291a:8365 class-ID: 1100 serial: <filter>
  Device-2: 1-4:3 info: Realtek Intergrated Camera 2M type: Video
  Device-3: 1-7:9 info: Realtek Intergrated Camera 5M type: Video
  Device-4: 1-9:10 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
    type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 8087:0aaa class-ID: e001
  Hub-5: 2-0:1 info: Super-speed hub ports: 7 rev: 3.0 speed: 5 Gb/s
  Hub-6: 2-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
    chip-ID: 2109:0817 class-ID: 0900
  Device-1: 2-1.1:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
    power: 288mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  Hub-7: 2-1.3:4 info: Genesys Logic Hub ports: 4 rev: 3.2 speed: 5 Gb/s
    chip-ID: 05e3:0626 class-ID: 0900
  Hub-8: 2-1.4:5 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
    chip-ID: 045b:0210 class-ID: 0900
  System Temperatures: cpu: 52.0 C mobo: N/A
  Processes: 230 Uptime: 2h 2m wakeups: 6 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1486 pacman: 1482 lib: 383
  flatpak: 0 snap: 4 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.12
What services ?
What about telling the real problem ?
How to increase your chances of solving your issue:
Hi Andreas85,
my real problem is
With a working debug_shell I should be able to help myself. If I could contribute more information to this problem, I would be happy to do so.
The underlying problem
was actually solved in arch forum in the meantime but unfortunately was deleted as they do not want manjaro topics in their forum. The solution that worked until now is the disable of windows fast startup (Dual boot with Windows - ArchWiki). Shutting down windows through the windows 10 Shift-Restart advanced options menu should do the same. But that didn’t help, as I had to learn. For better debugging I also activated from General troubleshooting - ArchWiki debug and ignore_loglevel.
It is probably not going to be that this fast windows startup makes the debug_shell malfunctioning. I will try to investigate further. Would be good if the shell works when I need it. Any help is welcome.
sid
This might give some ideas.
As it turned out, there was no error with systemd. The debug_shell works perfectly. In the initial ramdisk the module for the Lenovo keyboard was missing. With the addition of usbhid in /etc/mkinitcpio.conf
# MODULES
# The following modules are loaded before any boot hooks are
# run.  Advanced users may wish to specify all system modules
# in this array.  For instance:
#     MODULES=(piix ide_disk reiserfs)
MODULES=(usbhid)
and regeneration of initial ramdisk with
mkinitcpio -P
it is possible to debug the boot process and to track down the cause of the boot problems.
Where and how should I file a bug report? The missing load of usbhid in initial ramdisk for this laptop should be fixed.
sid
