CPU, memory and Swap at 100%
Hi
Started my pc yesterday and after a little while it went unresponsive and cpu, memory and Swap was at 100%. Rebooted but it’s the same. Fine at once but after a little while it becomes unresponsive. If I let it sit for 3-10 minutes it goes back to normal. Started htop and noticed that pamac uses 99% cpu and memory. What’s wrong and how can I fix it?
Hi @PihlT,
While I’ve never heard of such a thing, I do believe anyone trying to help would need more information.To that end, please see:
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Please also provide the output for:
journalctl --grep="pamac" --boot=-1
Where:
  • The --grep= argument limits the output to any mention of pamac;
  • the --boot= argument limits the output to be from the previous boot. You can change this to be 0 for the _current_boot, -1 for the previous one, -2 for the one before that, and so on, and so forth.
Thanks
Just tried to check for updates from the package manager and it hangs at 90%…
Please don’t post images, and please provide the info as requested above:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
Thanks. Will try later. The pc is unresponsive so the only thing I can do is take a photo with my phone.
The command(s) for the logs and more doesn’t have to be run while the problem is occurring.
mars 03 11:09:00 SH61R kernel: [   1768]  1000  1768    89730        0   274432     3634             0 pamac-tray
mars 03 11:09:00 SH61R kernel: [   2418]  1000  2418  3155279  1431106 25006080  1669354             0 pamac
mars 03 11:09:00 SH61R kernel: oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/user.slice/user-1000.slice/session-2.scope,task=pamac,pid=2418,uid=1000
mars 03 11:09:00 SH61R kernel: Out of memory: Killed process 2418 (pamac) total-vm:12621116kB, anon-rss:5724424kB, file-rss:0kB, shmem-rss:0kB, UID:1000 pgtables:24420kB oom_score_adj:0
mars 03 13:11:08 SH61R kernel: [   1768]  1000  1768    89730        0   274432     3654             0 pamac-tray
mars 03 13:11:08 SH61R kernel: [   2816]  1000  2816  3118036  1426437 24702976  1637311             0 pamac
mars 03 13:11:08 SH61R kernel: oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/user.slice/user-1000.slice/session-2.scope,task=pamac,pid=2816,uid=1000
mars 03 13:11:08 SH61R kernel: Out of memory: Killed process 2816 (pamac) total-vm:12472144kB, anon-rss:5705748kB, file-rss:0kB, shmem-rss:0kB, UID:1000 pgtables:24124kB oom_score_adj:0
mars 03 13:23:38 SH61R dbus-daemon[990]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.92' (uid=1000 pid=3837 comm="pamac-manager")
mars 03 13:23:38 SH61R systemd[1]: Starting Pamac Daemon...
mars 03 13:23:38 SH61R dbus-daemon[990]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
mars 03 13:23:38 SH61R systemd[1]: Started Pamac Daemon.
mars 03 13:23:38 SH61R audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mars 03 13:23:38 SH61R kernel: audit: type=1130 audit(1677846218.437:325): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mars 03 13:23:39 SH61R dbus-daemon[990]: [system] Activating via systemd: service name='org.freedesktop.Flatpak.SystemHelper' unit='flatpak-system-helper.service' requested by ':1.92' (uid=1000 pid=3837 comm="pamac-manager")
mars 03 13:24:33 SH61R polkitd[992]: Operator of unix-session:2 successfully authenticated as unix-user:trond to gain TEMPORARY authorization for action org.manjaro.pamac.commit for system-bus-name::1.92 [pamac-manager] (owned by unix-user:trond)
mars 03 13:26:14 SH61R kernel: [   1768]  1000  1768    89730       81   270336     3535             0 pamac-tray
mars 03 13:26:14 SH61R kernel: [   3837]  1000  3837  3298247  1406462 24752128  1637645             0 pamac-manager
mars 03 13:26:14 SH61R kernel: [   3848]     0  3848    74185        0   172032     1206             0 pamac-daemon
mars 03 13:26:14 SH61R kernel: oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/user.slice/user-1000.slice/session-2.scope,task=pamac-manager,pid=3837,uid=1000
mars 03 13:26:14 SH61R kernel: Out of memory: Killed process 3837 (pamac-manager) total-vm:13192988kB, anon-rss:5625660kB, file-rss:0kB, shmem-rss:188kB, UID:1000 pgtables:24172kB oom_score_adj:0
mars 03 13:27:13 SH61R polkitd[992]: Operator of unix-session:2 FAILED to authenticate to gain authorization for action org.manjaro.pamac.commit for system-bus-name::1.100 [pamac-manager] (owned by unix-user:trond)
mars 03 13:27:31 SH61R polkitd[992]: Operator of unix-session:2 successfully authenticated as unix-user:trond to gain TEMPORARY authorization for action org.manjaro.pamac.commit for system-bus-name::1.100 [pamac-manager] (owned by unix-user:trond)
  Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=52ebb8fb-7706-42a1-8602-f6c8a64fc8f2 rw quiet apparmor=1
    security=apparmor resume=UUID=592fd754-52ea-4994-8603-1a187583a6c5
    udev.log_priority=3 threadirqs mitigations=off
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
    v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: H110M-A v: Rev X.0x
    serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 3805
    date: 05/07/2018
  Device-1: hidpp_battery_2 model: Logitech MX Ergo Multi-Device Trackball
    serial: <filter> charge: 50% (should be ignored) rechargeable: yes
    status: N/A
  Device-2: hidpp_battery_5 model: Logitech M310 serial: <filter>
    charge: 55% (should be ignored) rechargeable: yes status: discharging
  Device-3: hidpp_battery_6 model: Logitech K520 serial: <filter>
    charge: 70% (should be ignored) rechargeable: yes status: discharging
  RAM: total: 7.71 GiB used: 2.13 GiB (27.7%)
  Info: model: Intel Core i5-6500 bits: 64 type: MCP arch: Skylake-S
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x5E (94) stepping: 3 microcode: 0xF0
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
    desc: 1x6 MiB
  Speed (MHz): avg: 800 min/max: 800/3600 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 25610
    dtherm dts erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
    hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
    nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
    pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep
    smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc
    tsc_adjust tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec xsaveopt
    xsaves xtopology xtpr
  Type: itlb_multihit status: KVM: VMX unsupported
  Type: mds status: Vulnerable; SMT disabled
  Type: meltdown status: Vulnerable
  Type: mmio_stale_data status: Vulnerable
  Type: retbleed status: Vulnerable
  Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
    usercopy barriers only; no swapgs barriers
  Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled,
    PBRSB-eIBRS: Not affected
  Type: srbds status: Vulnerable
  Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: eVga.com.
    driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
    status: current (as of 2023-02) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:1c03 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.7 compositor: xfwm v: 4.18.0 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.65x15.00")
    s-diag: 1245mm (49.01")
  Monitor-1: DP-0 pos: primary,left res: 2560x1440 hz: 60 dpi: 118
    size: 553x311mm (21.77x12.24") diag: 634mm (24.98") modes: N/A
  Monitor-2: HDMI-0 pos: right res: 1920x1080 hz: 60 dpi: 92
    size: 528x297mm (20.79x11.69") diag: 606mm (23.85") modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce GTX 1060
    6GB/PCIe/SSE2 direct-render: Yes
  Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 1-4:4 chip-ID: 1852:7022
    bus-ID: 00:1f.3 class-ID: 0102 chip-ID: 8086:a170 class-ID: 0403
  Device-2: NVIDIA GP106 High Definition Audio vendor: eVga.com.
    bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
  Device-3: GYROCOM C&C Fiio E10 type: USB
    driver: hid-generic,snd-usb-audio,usbhid
  Device-4: GYROCOM C&C Fiio E10 type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6:5 chip-ID: 1852:7022
    class-ID: 0102
  Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
  Sound Interface: sndio v: N/A running: no
  Sound Server-1: JACK v: 1.9.22 running: no
  Sound Server-3: PipeWire v: 0.3.65 running: yes
    vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  Local Storage: total: 931.51 GiB used: 816.97 GiB (87.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
    type: SSD serial: <filter> rev: 3B6Q scheme: MBR
  Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SH-224FB rev: SB00
    dev-links: cdrom
  ID-1: / raw-size: 74.5 GiB size: 72.78 GiB (97.69%) used: 64.53 GiB (88.7%)
    fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
    uuid: 52ebb8fb-7706-42a1-8602-f6c8a64fc8f2
  ID-2: /home raw-size: 406.32 GiB size: 398.87 GiB (98.17%)
    used: 337.33 GiB (84.6%) fs: ext4 dev: /dev/sda7 maj-min: 8:7 label: N/A
    uuid: d3b34675-5fce-496f-9567-70ce90be6ad2
  ID-3: /run/media/trond/2082843B82841804 raw-size: 442.67 GiB
    size: 442.67 GiB (100.00%) used: 414.35 GiB (93.6%) fs: ntfs dev: /dev/sda2
    maj-min: 8:2 label: N/A uuid: 2082843B82841804
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
  ID-1: swap-1 type: partition size: 7.45 GiB used: 776.4 MiB (10.2%)
    priority: -2 dev: /dev/sda5 maj-min: 8:5 label: N/A
    uuid: 592fd754-52ea-4994-8603-1a187583a6c5
  ID-1: /dev/sda1 maj-min: 8:1 size: 579 MiB fs: ntfs
    label: Reservert av systemet uuid: 36B4752EB474F22B
  ID-2: /dev/sda3 maj-min: 8:3 size: 1 KiB fs: <superuser required>
    label: N/A uuid: N/A
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
  Device-1: 1-1:8 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
    power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Hub-2: 1-3:3 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 1-4:4 info: GYROCOM C&C Fiio E10 type: HID,Audio
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
    speed: 12 Mb/s power: 500mA chip-ID: 1852:7022 class-ID: 0102
  Device-2: 1-6:5 info: GYROCOM C&C Fiio E10 type: HID,Audio
  Device-3: 1-9:6 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
  Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia temp: 54 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 13%
  Processes: 213 Uptime: 36m wakeups: 33 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: 1822 pm: pacman pkgs: 1759 libs: 455 tools: pamac pm: flatpak
  pkgs: 42 pm: snap pkgs: 21 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
  inxi: 3.3.25
Welp.
I 've gone thorough it, and I don’t see a problem. But, I am no expert, so that doesn’t mean much.
Someone with more knowledge about pamac will have to check.
Hmm, I’m not sure that this is connected but all the partitions are around 90% used, which at least isn’t very good for the drives. As far as I know the system also reserves around 10% so this may well cause issues.
Seems like its sorted out now. after running journalctl --grep=“pamac” --boot=-1 i noticed the out of memory message so I googled a bit. Ran this command sudo pacman -Rns $(pacman -Qtdq) and removed a bunch of stuff. Looks like it ok now and I can also check for updates without it freezing . Thanks for your help :slight_smile:
I’m very happy for you. But just want to tell you to be careful doing something you don’t understand. For all you know, that could have been disastrous! It wasn’t, but it could have been easily. Did you at least inspect and confirmed the packages to be removed? Because your kernel can be in a “bunch of stuff” and you could have ended up worse off than you started.
For more information on what pacman does, check out:
man pacman
Just to add to @Mirdarthos warning; those cache files will accumulate again over time.
The best way to keep your drives/partitions at a healthy 65-75% is to:
  • go through your installed apps (pacman pkgs: 1759 flatpak: 42 snap: 21 is a fair lot) and assess if some can be removed.
  • clean out your home directory or move things to external drives
  • consider running a simple conky to keep an eye on your drives
Thanks :slightly_smiling_face:
I’ll keep an eye on my drives and clean up a bit. I’ll probably upgrade my pc soon so just hoping it’s working until then :slightly_smiling_face:
@PihlT ,
now better to issue the
pamac update --force-refresh
command to fix possible damage of package database files, to force renew them all.
This action could prevent possible further problems if databases were corrupted during previous PC hangs.
Have a nice weekend!
