I am new to linux and have been using it for a a month or two. I installed manjaro and I am absolutely in love with it but the only problem I’m facing is that, it does not connect to my 5g wifi. It shows two wifis
“MyName” wifi
2.“MyName-5G” wifi. I use this one in all of my phones and also on my windows. It previously worked on linux mint as well.
Please help, it’s causing a havoc in my workflowTT and internet speed.
I am on a asus rog strix g15 and have dual boot. Running windows 11 and manjaro at the same time.
that is an non-information
you can’t connect - we already knew that
please show that error - and the context, not just the one line with the error -
show the log journalctl -f
while you are trying to connect and it fails
another way is: sudo dmesg -w
show us that - either one
both commands will continuously add output to the terminal
letting you see what the system sees in real time
no screenshots, please
copy/paste the text - and format it → </>
