Starting my computer, it runs into Emergency Modus. journalctl -xb shows 2.200 lines, few that might be important:
Kernel command line: .Boot image ...5.15.-x86 ...
Unknown command line parameters: "text noplymouth BOOT_IMAGE=//boot/vmlinuz-5.15..." will be passed to user space
PCI INT A not connected
fsck failed with exit status 4
... dependency failed for /home
Can you access a TTY? If so, remove text and noplymouth from /etc/default/grub. run sudo update-grub and reboot. One or both of those entries seem to be causing the issue.
If not, boot from a Manjaro ISO and chroot in to your system and do it from there.
saved the file “grub” after removing “text” and “noplymouth” and did # sudo update grub
This produced few lines, the last one
/usr/bin/grub-probe: Warning: Unknown device type nvme0n1 Shall I try to reboot?
I can run journalctl --boot=-1 --priority=3 --catalog --no-pager
this shows issues for four device(s) /dev/disk/by-uuid… If there is a way to save this output (almost full screen) I will upload it here.
My Data-Device is /mnt/Daten. I can cd this and it shows all the files. Also I see the file f.e. in /var, /opt, /etc. Then I did
# cd /home
# ls
and it is empty. Sorry, I’m dead for today and will follow up tomorrow …
restore the timeshift …
or boot into manjaro usb, chroot, and compare uuids in cat /etc/fstab
and blkid
the ones in fstab should match the ones in blkid
This part first:
I booted the System > EmergencyMode > Enter password
So I’m logged in as root in /. I can run cat /etc/fstab and blkid, the outputs look similar with differences: blkid sows timeshift, fstab does not. But I found all UUIDs from fstab in blkid.
Would it be possible, to copy that output to show it here?
