Black screen with cursor after resuming session from lock screen
After a system update today, when I resume my session after locking screen, I get a black screen after logging back in. The cursor is there and can be moved around. Twice this eventually went back to normal with time, the third time the system had to be rebooted. So far, no issues logging in normally - this has only happened after resuming from a locked screen.
Reasonably major inconvenience since a fairly basic and occasionally important piece of functionality now can’t be used.
GPU is Nvidia, desktop is xfce, otherwise completely unsure what is causing this issue. No apparent issues with SSD checking with smartctl.
Hi @000dio,
You are not alone, I assure you. But more information is needed to try and resolve this. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Please also provide the output of:
journalctl --no-pager --catalog --boot=-1
Where:
  • --no-pager formats the output nicely for use here on the forum;
    * --catalog augment log lines with explanation texts from the message catalog; and
    * _--boot=-1 limits the messages to be from the previous boot. Feel free to adjust this as necessary. -1 for the previous boot, -2 for the one before that, -3 for the one before that, and so on, and so forth…
…from after you’ve rebooted.
Sorry if I misunderstand what you are asking: You want messages from the reboot or after the lock screen log in goes to a black screen? The issue doesn’t come up on normal boot, but after logging in after lock screen, it will not be possible to use any terminal.
e.g. if I booted successfully now, but previous time I booted, afterwards I locked the screen and then there was a black screen after logging back in, you want the log from previous boot
Thanks
Correct, yes please.
Let’s try narrowing it down, because, and I should’ve expected this, shyeeeeeeeeeesh…
Run the following, providing the link it spits out:
journalctl --no-pager --catalog --boot=-1 --priority=warning..err | curl -F 'file=@-' https://0x0.st
I’m only adding the --priority= argument to limit the output to warnings and errors, then redirecting the output to https://0x0.st.
here you go, I was wondering whether you wanted the truncated output, but anyway - thanks
OK, after scanning, I’m sad to say that I can’t see anything…not that I’m all-knowing, despite what the forum thinks. So let’s hope someone else does know.
Sorry.
You helped out by letting me know what helpful information to post - thanks. With some luck this may mean it’s a minor issue after an update
post full system info:
inxi -zav7
output from:
sudo ldconfig
create a new test user, reboot, log in with the test user and see if it has the same issue…
A post was split to a new topic: Black screen after resuming session from lock screen
Please don’t necro-bump. See Forum Rules: Old Threads/“Necro-Bumping”.
