hi and thanks for your time and help.
i install manjaro the latest stable version on my acewr aspire 5750g
but when i start my system bevor the login screen shows i become black an white screen like i have a artifacte gpu problem but my gpu from my laptop is not damaged.
i have a GT 520M Geforce it is a optiums system i install manjaro with the propheterie drivers installer what i can do pls help
Hi @Gohji, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
[HowTo] Provide System Information.
At bare minimum we would need you to please provide a detailed description of the problem faced, as well as the output to:
inxi --admin --verbosity=8 --filter --no-host --width -
[HowTo] Post command output and file content as preformatted text.
Please also note and heed: Forum Rules - Manjaro
Those with privacy concerns: note that when -z, or --filter is used, all personally identifiable information is filtered out from the resulting inxi output. ![]()
Hope you manage!
Tip for legibility:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Note that the above text is partially pre-prepared as a general introduction for new forum users. Please take the time to follow links given and learn how to create effective support requests and encourage quality responses.
Tip
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
As I’m a moderator on the forum, I have taken the liberty of doing this for you, this time.
Additionally
Note that the above text is partially pre-prepared as a general introduction for new forum Users. Please take the time to to understand how it is done and encourage quality responses.
Perhaps you need to manually install the drivers for your current kernel
To see the currently running kernel with Manjaro name
mhwd-kernel -li
If the kernel is linux612 the command to install Nvidia drivers manually
sudo pacman -Syu linux612-nvidia-390xx nvidia-390xx-utils nvidia-390xx-settings
If your kernel is not linux612 replace the kernel in the above command
thanks alot for that all answers my problem ist i cant write in the terminal i cant go insite my system it dont let me log in the only thing what i can do is make a picture to show what is my problem .
my system is an Acer Aspire 5750g(intel 2430m Cpu)(Geforce GT 520m Gpu)
and 10gb Ram) and i use the latest manjaro with Kde desktop.
and i install the system with the propietär drivers .
i have to choose.
It’s quite easy to change between proprietary and open-source driver. So you could, maybe even should, try the installation again with the open-source ones.
Edit:
AAAh Yes. I think I see the problem. The GPU is to old for the proprietary drivers included on the live ISO. The latest driver for that GPU is 390.157, released Nov 2022:
https://i.imgur.com/eJJ0bEr.png
While Manjaro’s default is, I think, 550.144.03. Meaning it won’t work on the older card. That driver is available from the extra repository for installation:
$ pamac search nvidia --repos
nvidia-390xx-dkms 390.157-19 extra
NVIDIA drivers - module sources
So can be installed after the fact with:
pamac install nvidia-390xx-dkms
Note:
I know there is quite a bit of difficulty with keeping the 3xx series Nvidia drivers working, so I might b e wrong about how easy it is to get, and keep, it running.
Not even at a tty?
Press Ctrl+Alt+F3 and try logging in at the tty — there are several ttys, all running in parallel with the GUI environment. Then use the command @ManjaroDevOps gave you above. ![]()
After the command has completed, just hit Ctrl+Alt+Del in the tty to safely reboot your system.
know i solve it i turn off my gpu in the bios and update my system and know i can turn on my gpu and log in but i cant install nvidia or switch it .
when i look in the terminal it shows me that bumblebe is installed and my gpu is installed but it is onm false and bumblebbe is also false how i turn it on to true
im so bad on linux sry for my not understanding
With a system that old - and with integrated intel 3000 graphics - stay with the intel gpu until you are more comfortable with Linux.
When you have gained more experience - you can begin experimenting with the Nvidia card.
BUT the Nvidia card may be tricky to get working - always been that way with Nvidia.
Seeing as it seems German is your native language, you might find more joy here:
Or in our Other Languages > Deutsch category. ![]()
thanks a lot for all your help
