Hi @philm @oberon
Do you know by any chance the reason behind this change on the kernels? See below:
- patch: 0104 removed
Apparently that’s causing the warnings reported in the unstable announcement thread. It seems to be harmless to me though …
While update of
Package (8) Old Version New Version Net Change Download Size
core/linux514 5.14.rc2.d0718.g2734d6c-1 5.14.rc3.d0725.gff11764-1 0.02 MiB 96.45 MiB
I got the new warning I never saw before:
==> WARNING: Possibly missing firmware for module: xhci_pci
Full log of the update ...
:: Synchronising p…
Same behaviour with latest 5.13 and 5.10.
Sorry, can’t post further info. I’m on mobile right now.
Your insights are highly appreciated. Thanks!
alven
8 August 2021 00:14
3
I have
$ mhwd-kernel -li
Currently running: 5.14.0-1-MANJARO (linux514)
* linux514
$ pacman -Qi linux514
Version : 5.14.rc4.d0805.g902e7f3-1
Description : The Linux514 kernel and modules
Architecture : x86_64
$ pacman -Qi linux-firmware
Version : 20210719.r1990.168452e-1
Description : Firmware files for Linux (Manjaro Overlay Package)
Architecture : any
and right before the package installation I tried:
$ sudo mkinitcpio -P
==> Building image from preset: /etc/mkinitcpio.d/linux514.preset: 'default'
-> -k /boot/vmlinuz-5.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.14-x86_64.img
==> Starting build: 5.14.0-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [encrypt]
==> WARNING: Possibly missing firmware for module: qat_4xxx
-> Running build hook: [openswap]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.14-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux514.preset: 'fallback'
-> -k /boot/vmlinuz-5.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.14-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.14-x86_64-fallback.img
I tried the AUR (en) - upd72020x-fw package (Renesas uPD720201 / uPD720202 USB 3.0 chipsets firmware):
Submitter: redchenjs
Maintainer: redchenjs
Last Packager: redchenjs
Votes: 38
Popularity: 4.97
First Submitted: 2020-08-21 15:45
Last Updated: 2020-11-25 07:32
Installed and w/o reboot tried again:
Hm, like magic!
Thank you, @steanne !
How did you know about that package? Why exactly that package with that strange name of 2020 like it was for 2020 year as temp patch and now outdated?
PS
Why so old version? 1 year ago was the first submit and 9 months ago last update. Are there more modern?
the 2020 is part of the name of the chip.
Yep, I confirm that I’ve got a flawless initramfs generation after the patch was re-added.
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> Starting build: 5.10.58-1-MANJARO
-> Running build hook: [usr]
-> Running build hook: [consolefont]
-> Running build hook: [plymouth]
-> Running build hook: [lvm2]
-> Running build hook: [shutdown]
==> Creating zstd-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
This issue should be resolved for the other branches once the newer kernel updates are rolled out.
Thanks @philm for looking after this.
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
