X wouldn’t start properly after upgrade. Screen went black and back to console in an endless loop. Not sure if it is an issue with the new nvidia drivers, Xorg or KDE. Booted into console and restored with timeshift for now.
I am running a “NVIDIA GeForce GTX 1060 with Max-Q” and used optimus manager to use the NVidia only.
Here I have the same problem, no X after boot.
I am also using optimus for my nvidia gtx 1650 card.
I can’t use my laptop, I don’t know how should restore with timeshift.
FYI it happened to me on December the 17th ; in both case I had looooots of upgrades from one day to the other, in particular nvidia. Last time I could yay -Syyu directly and it worked just fine. In this case, I’ll obviously wait for the end of my exams since I need my desktop ; but also I had to downgrade yay -Syuu just after the upgrade since local manjaro-hello was newer than repo.
OK, I rebuild the python package.
In the command line with yay you used a “(” character, unfortuntely I can’t see the opposite pair of that, the “)” character. Where should I insert that?
And after the pacman and yay commands, what command will refresh the optimus package?
Thanks for enlighten me about timeshift.
You must to know, the distribution does NOT contain the very useful utility.
If you address me as newbie please enlighten also the manjaro distribution maker group too.
With or without newbie, I must to admit backup is important.
Thanks a lot. Resolved for me. Optimus-manager was also to blame.
Also, for other rookie like me coming here : the below command is to run AFTER the upgrade. Obviously. Yap, I tried to do it before. Of course, it didn’t work and had to timeshift again
$ yay -S $(pacman -Qoq /usr/lib/python3.9) --answerclean All
