My wireless quit working on one machine after this update. Then the entire system froze. I even rebooted with 6.1 kernel with no success.
I had to use Timeshift to revert to the previous version before the update.
Kernel: 6.6.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: KDE Plasma v: 5.27.9 Distro: Manjaro Linux base: Arch Linux
Same here. The computer freezes; I have to switch the computer off because it becomes stuck on shutdown on thinks network-related. Bummer…
It seems to work with Xorg and kernel 5.15 (but in 5.15 I have no wireless driver; maybe is that one the cause of the problem?) (update: it also works with wayland and 5.15 kernel, so definitely kernel-related)
I will try to dig out something with the logs. But it’s complex because the PC locked hard… it was working ok with the 23.12.01 update, it broke now with 23.12.10.
There are multiple threads active right now with similar issues as you guys.
Seems to be kernel related.
Some report it works on linux61, some have to use linux515.
You could try to install drivers from AUR, but I would say it’s better to use a different kernel until the issue is fixed.
Edit
I just saw this, might be related.
And
Try to sync and update. Make sure your mirrors are up to date before running update by confirming with pacman-mirrors.
If at least one mirror is [OK] run sudo pacman -Syu
I mean, sure, if you want to complicate things for you. Otherwise I would just use the 515 kernel until it is fixed. I feel that a severe issue like this with so many users affected, the fix will be in the repos very soon on all kernels.
WiFi broke for me. Specifically, I am using rtl8821cu-morrownr-dkms-git from AUR. Had to revert to LTS kernel 5.15 to regain use of my USB WiFi adapter.
Kernels 6.1 and 6.6 have just been updated (Stable), specifically to fix WiFi issues resulting from the regression @philm mentions. Try updating now to see if your issue is also resolved. Cheers.
6.6.5 is bad, if you see it sneeze at it, cross your heart and say a silent prayer. If you see 6.6.6 its good, like a baby rabbit bunny, kiss it, pet it, download and install it. At least that’s what worked for me, if it does not work for you, well, Merry Christmas to you too.
