Hey everyone,
I’ve a problem with my Wi-Fi which completely freezes the kernel when I try to disable it.
I tried to disabled it with Gnome and nmcli r wifi off.
I can enable the Wi-Fi, everything is fine, I can connect to my SSID. The problem appear when I try to disable it.
I’m on the new compiled 6.6.6-2-MANJARO kernel.
I tried the 6.5 and the 6.1 (same problem).
I’ve read (and did not find the soluce) :
Information :
Host: workstation Kernel: 6.6.6-2-MANJARO arch: x86_64 bits: 64 Desktop: GNOME
v: 45.2 Distro: Manjaro Linux
Type: Laptop System: Dell product: Latitude 5500
Mobo: Dell model: 0M14W7 v: A01 serial: <superuser required> UEFI: Dell
v: 1.23.0 date: 12/19/2022
Info: quad core model: Intel Core i5-8365U bits: 64 type: MT MCP cache:
L2: 1024 KiB
Speed (MHz): avg: 3079 min/max: 400/4100 cores: 1: 4077 2: 3851 3: 400
4: 3944 5: 400 6: 4070 7: 3801 8: 4092
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi
IF: wlo1 state: down
I tried to understand the problem, here is what comes out in the logs:
# I activate the Wi-Fi
kernel: [ 149.200559] iwlwifi 0000:00:14.3: RF_KILL bit toggled to enable radio.
kernel: [ 149.200563] iwlwifi 0000:00:14.3: reporting RF_KILL (radio enabled)
kernel: [ 149.400904] iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 1
kernel: [ 152.569051] wlo1: authenticate with ff:ff:ff:ff:ff:ff
kernel: [ 152.573234] wlo1: send auth to ff:ff:ff:ff:ff:ff (try 1/3)
kernel: [ 152.612831] wlo1: authenticated
kernel: [ 152.612973] wlo1: VHT capa missing/short, disabling VHT/HE/EHT
kernel: [ 152.613974] wlo1: associate with ff:ff:ff:ff:ff:ff (try 1/3)
kernel: [ 152.616549] wlo1: RX AssocResp from ff:ff:ff:ff:ff:ff (capab=0x411 status=0 aid=1)
kernel: [ 152.619235] wlo1: associated
# I deactivate it
kernel: [ 154.701975] iwlwifi 0000:00:14.3: RF_KILL bit toggled to disable radio.
kernel: [ 154.701997] iwlwifi 0000:00:14.3: reporting RF_KILL (radio disabled)
kernel: [ 154.714097] wlo1: deauthenticating from ff:ff:ff:ff:ff:ff by local choice (Reason: 3=DEAUTH_LEAVING)
kernel: [ 156.717307] iwlwifi 0000:00:14.3: fail to flush all tx fifo queues Q 5
kernel: [ 156.717366] iwlwifi 0000:00:14.3: Queue 5 is active on fifo 3 and stuck for 10000 ms. SW [3, 4] HW [4, 4] FH TRB=0x080305003
kernel: [ 158.720630] iwlwifi 0000:00:14.3: fail to flush all tx fifo queues Q 5
kernel: [ 158.720710] iwlwifi 0000:00:14.3: Queue 5 is active on fifo 3 and stuck for 10000 ms. SW [3, 4] HW [4, 4] FH TRB=0x080305003
kernel: [ 158.720737] ------------[ cut here ]------------
kernel: [ 158.720737] WARNING: CPU: 1 PID: 571 at net/mac80211/sta_info.c:1442 __sta_info_destroy_part2+0x243/0x330 [mac80211]
kernel: [ 158.720791] Modules linked in: ccm uhid rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device typec_displayport snd_hda_codec_hdmi snd_ctl_led snd_hda_codec_realtek snd_hda_codec_generic 8021q garp mrp stp llc cmac algif_hash algif_skcipher af_alg qrtr bnep hid_multitouch snd_sof_pci_intel_cnl snd_sof_intel_hda_common soundwire_intel snd_sof_intel_hda_mlink soundwire_cadence snd_sof_intel_hda intel_tcc_cooling snd_sof_pci snd_sof_xtensa_dsp x86_pkg_temp_thermal intel_powerclamp snd_sof coretemp snd_sof_utils soundwire_generic_allocation kvm_intel soundwire_bus mousedev snd_soc_skl kvm snd_soc_hdac_hda snd_hda_ext_core snd_soc_sst_ipc irqbypass snd_soc_sst_dsp crct10dif_pclmul snd_soc_acpi_intel_match crc32_pclmul snd_soc_acpi polyval_clmulni polyval_generic snd_soc_core gf128mul snd_compress ghash_clmulni_intel vfat dell_rbtn iwlmvm ac97_bus sha512_ssse3 fat snd_pcm_dmaengine sha256_ssse3 mei_wdt mei_pxp mei_hdcp i915 uvcvideo snd_hda_intel mac80211 videobuf2_vmalloc snd_intel_dspcfg uvc sha1_ssse3
kernel: [ 158.720821] snd_intel_sdw_acpi r8153_ecm aesni_intel snd_hda_codec videobuf2_memops dell_laptop crypto_simd videobuf2_v4l2 cdc_ether snd_hda_core libarc4 iTCO_wdt dell_wmi cryptd usbnet intel_pmc_bxt ee1004 dell_wmi_sysman snd_hwdep iTCO_vendor_support intel_rapl_msr videodev drm_buddy dell_smbios rapl firmware_attributes_class processor_thermal_device_pci_legacy snd_pcm i2c_algo_bit iwlwifi intel_cstate ledtrig_audio processor_thermal_device dcdbas videobuf2_common wmi_bmof dell_wmi_descriptor spi_nor snd_timer intel_wmi_thunderbolt ttm processor_thermal_rfim mei_me snd intel_lpss_pci dell_smm_hwmon intel_uncore psmouse e1000e mc mtd pcspkr cfg80211 drm_display_helper intel_lpss processor_thermal_mbox mei i2c_i801 ucsi_acpi processor_thermal_rapl idma64 soundcore typec_ucsi cec typec intel_rapl_common r8152 intel_gtt i2c_smbus i2c_hid_acpi video intel_soc_dts_iosf intel_pch_thermal roles cdc_acm mii i2c_hid int3403_thermal int340x_thermal_zone wmi int3400_thermal dell_smo8800 joydev intel_hid acpi_thermal_rel
kernel: [ 158.720856] acpi_pad sparse_keymap mac_hid squashfs btusb btrtl btintel btbcm btmtk bluetooth ecdh_generic rfkill sg crypto_user fuse loop dm_mod bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 usbhid rtsx_pci_sdmmc serio_raw atkbd mmc_core libps2 vivaldi_fmap nvme crc32c_intel nvme_core spi_intel_pci xhci_pci rtsx_pci spi_intel nvme_common i8042 xhci_pci_renesas serio
kernel: [ 158.720874] CPU: 1 PID: 571 Comm: NetworkManager Not tainted 6.6.5-3-MANJARO #1 ad3eb75f027a1b8df7292b0c07e8b74bd60258b5
kernel: [ 158.720877] Hardware name: Dell Inc. Latitude 5500/0M14W7, BIOS 1.23.0 12/19/2022
kernel: [ 158.720878] RIP: 0010:__sta_info_destroy_part2+0x243/0x330 [mac80211]
kernel: [ 158.720916] Code: bb d4 00 00 00 00 0f 84 68 ff ff ff 45 31 c0 b9 01 00 00 00 48 89 da 4c 89 f6 4c 89 e7 e8 35 86 ff ff 85 c0 0f 84 4a ff ff ff <0f> 0b e9 43 ff ff ff 41 0f b6 d5 be 03 00 00 00 48 89 df e8 75 b5
kernel: [ 158.720917] RSP: 0018:ffffa592c26ef868 EFLAGS: 00010282
kernel: [ 158.720918] RAX: 00000000ffffff92 RBX: ffff8a3d4ca36000 RCX: 0000000000000027
kernel: [ 158.720919] RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8a3d530c2098
kernel: [ 158.720920] RBP: 0000000000000000 R08: 0000000000000000 R09: ffffa592c26ef3c0
kernel: [ 158.720921] R10: 0000000000000003 R11: ffffffff9f0ca408 R12: ffff8a3d530c0900
kernel: [ 158.720922] R13: ffff8a3d4ca36ab8 R14: ffff8a3d528449c0 R15: ffff8a3d528449c0
kernel: [ 158.720923] FS: 00007f91ddb43200(0000) GS:ffff8a449c440000(0000) knlGS:0000000000000000
kernel: [ 158.720924] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
kernel: [ 158.720925] CR2: 00007f88852fd000 CR3: 000000010619a003 CR4: 00000000003706e0
kernel: [ 158.720926] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
kernel: [ 158.720927] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
kernel: [ 158.720928] Call Trace:
kernel: [ 158.720929] <TASK>
kernel: [ 158.720930] ? __sta_info_destroy_part2+0x243/0x330 [mac80211 cdd5371aa1ed88dac40cf81412c5e9db295da8ba]
kernel: [ 158.720968] ? __warn+0x81/0x130
kernel: [ 158.720971] ? __sta_info_destroy_part2+0x243/0x330 [mac80211 cdd5371aa1ed88dac40cf81412c5e9db295da8ba]
kernel: [ 158.721009] ? report_bug+0x171/0x1a0
kernel: [ 158.721012] ? handle_bug+0x3c/0x80
kernel: [ 158.721014] ? exc_invalid_op+0x17/0x70
kernel: [ 158.721015] ? asm_exc_invalid_op+0x1a/0x20
kernel: [ 158.721018] ? __sta_info_destroy_part2+0x243/0x330 [mac80211 cdd5371aa1ed88dac40cf81412c5e9db295da8ba]
kernel: [ 158.721055] ? __sta_info_destroy_part2+0x23b/0x330 [mac80211 cdd5371aa1ed88dac40cf81412c5e9db295da8ba]
kernel: [ 158.721092] __sta_info_flush+0x169/0x1f0 [mac80211 cdd5371aa1ed88dac40cf81412c5e9db295da8ba]
kernel: [ 158.721129] ieee80211_set_disassoc+0x16c/0x620 [mac80211 cdd5371aa1ed88dac40cf81412c5e9db295da8ba]
kernel: [ 158.721180] ieee80211_mgd_deauth+0x13f/0x3d0 [mac80211 cdd5371aa1ed88dac40cf81412c5e9db295da8ba]
kernel: [ 158.721229] cfg80211_mlme_deauth+0xba/0x1e0 [cfg80211 e28223dc89cd16b9f23c60caf67620e898ecaa45]
kernel: [ 158.721281] cfg80211_mlme_down+0x65/0x90 [cfg80211 e28223dc89cd16b9f23c60caf67620e898ecaa45]
kernel: [ 158.721322] cfg80211_disconnect+0x180/0x1f0 [cfg80211 e28223dc89cd16b9f23c60caf67620e898ecaa45]
kernel: [ 158.721364] cfg80211_netdev_notifier_call+0x141/0x4d0 [cfg80211 e28223dc89cd16b9f23c60caf67620e898ecaa45]
kernel: [ 158.721398] ? iwl_mvm_send_cmd+0x1f/0x60 [iwlmvm 4d6ea748ec60ea85998f2ec1b1a3b5662de65bc7]
kernel: [ 158.721421] ? iwl_mvm_mc_iface_iterator+0xcd/0xf0 [iwlmvm 4d6ea748ec60ea85998f2ec1b1a3b5662de65bc7]
kernel: [ 158.721436] ? __iterate_interfaces+0x9d/0x110 [mac80211 cdd5371aa1ed88dac40cf81412c5e9db295da8ba]
kernel: [ 158.721483] ? __pfx_iwl_mvm_mc_iface_iterator+0x10/0x10 [iwlmvm 4d6ea748ec60ea85998f2ec1b1a3b5662de65bc7]
kernel: [ 158.721498] ? iwl_mvm_send_cmd_pdu+0x62/0xb0 [iwlmvm 4d6ea748ec60ea85998f2ec1b1a3b5662de65bc7]
kernel: [ 158.721517] ? rtnl_is_locked+0x15/0x20
kernel: [ 158.721520] ? inetdev_event+0x3d/0x6f0
kernel: [ 158.721522] ? iwl_mvm_recalc_multicast+0x5d/0xa0 [iwlmvm 4d6ea748ec60ea85998f2ec1b1a3b5662de65bc7]
kernel: [ 158.721537] notifier_call_chain+0x5a/0xd0
kernel: [ 158.721539] __dev_close_many+0x5f/0x110
kernel: [ 158.721542] dev_close_many+0x8f/0x150
kernel: [ 158.721545] dev_close+0x83/0xb0
kernel: [ 158.721547] cfg80211_shutdown_all_interfaces+0x4d/0xf0 [cfg80211 e28223dc89cd16b9f23c60caf67620e898ecaa45]
kernel: [ 158.721580] cfg80211_rfkill_set_block+0x2a/0x40 [cfg80211 e28223dc89cd16b9f23c60caf67620e898ecaa45]
kernel: [ 158.721613] rfkill_set_block+0x91/0x160 [rfkill 6bccb42710ce191a7a8dcfaa2e697287262933bd]
kernel: [ 158.721619] rfkill_fop_write+0x161/0x200 [rfkill 6bccb42710ce191a7a8dcfaa2e697287262933bd]
kernel: [ 158.721623] vfs_write+0xef/0x420
kernel: [ 158.721626] ? do_sys_openat2+0x97/0xe0
kernel: [ 158.721628] ? __fget_light+0x99/0x100
kernel: [ 158.721630] ksys_write+0xbb/0xf0
kernel: [ 158.721632] do_syscall_64+0x5d/0x90
kernel: [ 158.721634] ? syscall_exit_to_user_mode+0x2b/0x40
kernel: [ 158.721636] ? do_syscall_64+0x6c/0x90
kernel: [ 158.721638] ? syscall_exit_to_user_mode+0x2b/0x40
kernel: [ 158.721639] ? do_syscall_64+0x6c/0x90
kernel: [ 158.721640] ? syscall_exit_to_user_mode+0x2b/0x40
kernel: [ 158.721641] ? do_syscall_64+0x6c/0x90
kernel: [ 158.721643] entry_SYSCALL_64_after_hwframe+0x6e/0xd8
kernel: [ 158.721645] RIP: 0033:0x7f91dea3506f
kernel: [ 158.721670] Code: 89 54 24 18 48 89 74 24 10 89 7c 24 08 e8 19 4d f8 ff 48 8b 54 24 18 48 8b 74 24 10 41 89 c0 8b 7c 24 08 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 31 44 89 c7 48 89 44 24 08 e8 6c 4d f8 ff 48
kernel: [ 158.721671] RSP: 002b:00007fffda52b9e0 EFLAGS: 00000293 ORIG_RAX: 0000000000000001
kernel: [ 158.721673] RAX: ffffffffffffffda RBX: 000000000000001c RCX: 00007f91dea3506f
kernel: [ 158.721674] RDX: 0000000000000008 RSI: 00007fffda52ba28 RDI: 000000000000001c
kernel: [ 158.721674] RBP: 00007fffda52ba90 R08: 0000000000000000 R09: 0000000000000007
kernel: [ 158.721675] R10: 0000000000000000 R11: 0000000000000293 R12: 0000000000000000
kernel: [ 158.721676] R13: 0000000000000000 R14: 0000557f85173b60 R15: 0000557f851e0130
kernel: [ 158.721677] </TASK>
kernel: [ 158.721678] ---[ end trace 0000000000000000 ]---
If someone has an idea…
Thanks !
