After rebooting my laptop because i git cloned a link, wifi won’t show up anymore and after running “nmcli connection up” it throws this error : No suitable device found for this connection (device wlp44s0 not available because device is not available). Wifi worked fine before i tried git cloning so i don’t know what’s the problem here.
Also this is my first post im sorry if i missed anything
Hi @6thbird, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Those with privacy concerns: note that when -z, or --filter is used, all personally identifiable information is filtered out from the resulting inxi output.
Hope you manage!
Tip for legibility:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Note that the above text is partially pre-prepared as a general introduction for new forum users. Please take the time to follow links given and learn how to create effective support requests and encourage quality responses.
Sorry, i didn’t know about that,
here’s the output for inxi --full --admin --filter --width:
Here’s the output for inxi --filter --verbosity=8:
Kernel: 6.12.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=1a9b821e-2471-4a03-ac60-ba79ba8132c7 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.13.0
Type: Laptop System: Dell product: Inspiron 5502 v: N/A
Mobo: Dell model: 0HWH1N v: A00 serial: <superuser required> part-nu: 0A02
uuid: <superuser required> UEFI: Dell v: 1.33.1 date: 11/15/2024
ID-1: BAT0 charge: 28.2 Wh (100.0%) condition: 28.2/53.0 Wh (53.2%)
volts: 16.2 min: 15.0 model: SMP DELL 9077G09 type: Li-poly serial: <filter>
status: full
System RAM: total: 8 GiB available: 7.49 GiB used: 1.47 GiB (19.7%)
Array-1: capacity: 128 GiB slots: 8 modules: 1 EC: None
Device-1: DIMM 1 type: DDR4 detail: synchronous size: 8 GiB
speed: 3200 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: 80CE00000000 part-no: M471A1K43DB1-CWE serial: <filter>
Device-2: Controller0-ChannelB-DIMM0 type: no module installed
Device-3: Controller0-ChannelC-DIMM0 type: no module installed
Device-4: Controller0-ChannelD-DIMM0 type: no module installed
Device-5: DIMM 2 type: no module installed
Device-6: Controller1-ChannelB-DIMM0 type: no module installed
Device-7: Controller1-ChannelC-DIMM0 type: no module installed
Device-8: Controller1-ChannelD-DIMM0 type: no module installed
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xB8
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
desc: 4x1.2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1279 min/max: 400/4200 scaling: driver: intel_pstate
governor: powersave cores: 1: 1279 2: 1279 3: 1279 4: 1279 5: 1279 6: 1279
7: 1279 8: 1279 bogomips: 22120
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp
rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2
tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
loop
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
built: 2020-21 ports: active: eDP-1 empty: DP-1,HDMI-A-1
bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX330] vendor: Dell driver: nouveau
v: kernel non-free: 550-570.xx+ status: current (as of 2025-04;
EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 bus-ID: 0000:2b:00.0 chip-ID: 10de:1d16 class-ID: 0302
Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:4 chip-ID: 0bda:5538
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris,nouveau gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: Najing CEC Panda 0x0035 built: 2018 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red:
x: 0.596 y: 0.365 green: x: 0.349 y: 0.557 blue: x: 0.157 y: 0.110 white:
x: 0.314 y: 0.329 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms:
device: 0 drv: iris device: 1 drv: nouveau device: 2 drv: swrast gbm:
drv: iris surfaceless: drv: iris x11: drv: iris inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.3 vendor: intel mesa v: 25.0.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL
GT2) device-ID: 8086:9a49 memory: 3.66 GiB unified: yes
API: Vulkan v: 1.4.309 layers: 4 device: 0 type: integrated-gpu name: Intel
Iris Xe Graphics (TGL GT2) driver: mesa intel v: 25.0.4-arch1.1
device-ID: 8086:9a49 surfaces: xcb,xlib
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8
class-ID: 0401
API: ALSA v: k6.12.25-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel bus-ID: 0000:2c:00.0
chip-ID: 168c:003e class-ID: 0280
IF: wlp44s0 state: down mac: <filter>
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 0cf3:e007
class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 20.71 GiB (4.3%)
model: PC SN530 NVMe WDC 512GB size: 476.94 GiB block-size: physical: 512 B
fw-rev: 21113012 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
used: 20.71 GiB (4.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 1a9b821e-2471-4a03-ac60-ba79ba8132c7
used: 600 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: C7EE-F0CD
ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-4: /swap raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-5: /var/cache raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-6: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swap/swapfile
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:2 info: SHARKOON GmbH [Mediatrack Edge Mini Keyboard]
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 1ea7:0066 class-ID: 0301
Device-2: 3-2:7 info: MediaTek Infinix NOTE 40 type: still imaging
driver: N/A interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0e8d:201d class-ID: 0601 serial: <filter>
Device-3: 3-5:3 info: Shenzhen Goodix FingerPrint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 27c6:538d class-ID: ff00
Device-4: 3-6:4 info: Realtek Integrated_Webcam_HD type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:5538 class-ID: 0e02
serial: <filter>
Device-5: 3-10:5 info: Qualcomm Atheros type: bluetooth driver: btusb
power: 100mA chip-ID: 0cf3:e007 class-ID: e001
System Temperatures: cpu: 47.0 C mobo: 46.0 C sodimm: 40.0 C gpu: nouveau
temp: 46.0 C
Fan Speeds (rpm): cpu: 0
Packages: 1343 pm: pacman pkgs: 1335 libs: 430 tools: pamac pm: flatpak
pkgs: 8
1: http://manjaro.mirror.ac.za/stable/$repo/$arch
2: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
5: http://manjaro.grena.ge/stable/$repo/$arch
6: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
8: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
9: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
10: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
11: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
12: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
13: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
14: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
15: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
16: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
17: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
18: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
19: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
20: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
21: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
22: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
23: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
24: https://muug.ca/mirror/manjaro/stable/$repo/$arch
25: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
26: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
27: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
28: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
29: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
30: https://manjaro.ynh.ovh/stable/$repo/$arch
31: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
32: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
33: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
34: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
35: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
36: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
37: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
38: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
39: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
40: https://linorg.usp.br/manjaro/stable/$repo/$arch
41: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
42: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
43: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
44: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
45: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
46: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
47: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
48: https://mirrors.manjaro.org/repo/stable/$repo/$arch
49: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
50: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
51: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
52: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
53: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
54: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
55: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
56: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
57: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
58: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
59: https://manjaro.kurdy.org/stable/$repo/$arch
60: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
61: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
62: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
63: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
64: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
65: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
66: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
67: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
68: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
69: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
70: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
71: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
72: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
73: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
74: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
75: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
76: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
77: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
78: https://mirror.koddos.net/manjaro/stable/$repo/$arch
79: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
80: https://mirror.23m.com/manjaro/stable/$repo/$arch
81: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
82: https://mirror.init7.net/manjaro/stable/$repo/$arch
83: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
84: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
85: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
86: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
87: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
88: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
89: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
90: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
91: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
92: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
93: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
94: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
95: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
96: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
97: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
98: http://mirror.fcix.net/manjaro/stable/$repo/$arch
99: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
100: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
101: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
102: https://mirror.dc.uz/manjaro/stable/$repo/$arch
103: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
104: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
105: https://mirrors2.manjaro.org/stable/$repo/$arch
106: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
107: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
108: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
109: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
110: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
111: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
112: https://mirror.easyname.at/manjaro/stable/$repo/$arch
113: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
114: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 240
1: cpu: 2.3% command: kwrite pid: 2033 mem: 247.5 MiB (3.2%)
2: cpu: 1.8% command: konsole pid: 1743 mem: 225.5 MiB (2.9%)
3: cpu: 0.8% command: zsh pid: 1755 mem: 11.4 MiB (0.1%)
4: cpu: 0.7% command: Xorg pid: 646 mem: 86.3 MiB (1.1%)
5: cpu: 0.7% command: kwin_x11 pid: 829 mem: 187.8 MiB (2.4%)
Memory top: 5 of 240
1: mem: 390.2 MiB (5.0%) command: plasmashell pid: 867 cpu: 0.6%
2: mem: 247.5 MiB (3.2%) command: kwrite pid: 2033 cpu: 2.3%
3: mem: 225.5 MiB (2.9%) command: konsole pid: 1743 cpu: 1.8%
4: mem: 194.0 MiB (2.5%) command: thumbnail.so started-by: kioworker
pid: 2052 cpu: 0.3%
5: mem: 187.8 MiB (2.4%) command: kwin_x11 pid: 829 cpu: 0.7%
Processes: 240 Power: uptime: 20m states: freeze,mem,disk suspend: s2idle
image: 2.96 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 257 default: graphical tool: systemctl
Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
running-in: konsole inxi: 3.3.38
Mod edit: inxi output is only needed once. Some inxi parameters are now deprecated or unnecessary - the command given is preferred even though both commands generate virtually identical output. The output has also been placed in a scrollable preformatted text container (using ``` instead of ~~~).
No worries, that’s why we have the tutorials, after all.
If I’m not mistaken it looks like the WiFi card is offline. I’d venture to say disabled. a Git clone is unable to do this. I did a git clone this morning and everything on my computer’s fine, so I’d say that is purely coincidental.
Double check that it hasn’t become disabled in the BIOS/UEFI somewhere, or that it is perhaps disabled VIA hardware key-combination.
If it still doesn’t worik, please provide the output of:
rfikill
and
nmcli device wifi list
I checked the bios, nothing was disabled and i my laptop doesn’t have any key shortcuts that disable the wifi function (besides my knowledge).
heres the output for rfkill:
ID TYPE DEVICE SOFT HARD
0 bluetooth hci0 blocked unblocked
1 wlan phy0 unblocked unblocked
and here’s for nmcli device wifi list:
IN-USE BSSID SSID MODE CHAN RATE SIGNAL BARS SECURITY
My mistake, it should have been:
nmcli device
No worries, here’s the output:
DEVICE TYPE STATE CONNECTION
lo loopback connected (externally) lo
wlp44s0 wifi unavailable --
I’m kind of shooting in the dark here, I don’t use Wifi - I’m a copper user and happy with it.
Please provide the output of:
nmcli radio
Here’s the output:
WIFI-HW WIFI WWAN-HW WWAN
enabled enabled missing enabled
Hmmm…all looks good there. Please provide the output of:
systemctl status wpa_supplicant.service
Edit:
Have you tried with a different kernel perhaps?
This is the output, (i set my desktop’s name to twerp):
● wpa_supplicant.service - WPA supplicant
Loaded: loaded (/usr/lib/systemd/system/wpa_supplicant.service; disabled; preset: disabled)
Active: active (running) since Fri 2025-05-09 14:27:42 WIB; 25min ago
Invocation: 846f9a73045044a7b6abf6e6ccfd1f54
Main PID: 721 (wpa_supplicant)
Tasks: 1 (limit: 9012)
Memory: 5.2M (peak: 5.6M)
CPU: 1.325s
CGroup: /system.slice/wpa_supplicant.service
└─721 /usr/bin/wpa_supplicant -u -s -O /run/wpa_supplicant
May 09 14:28:48 twerp wpa_supplicant[721]: WEXT: Could not set interface 'wlp44s0' UP
May 09 14:28:48 twerp wpa_supplicant[721]: wlp44s0: Failed to initialize driver interface
May 09 14:28:48 twerp wpa_supplicant[721]: wlp44s0: CTRL-EVENT-DSCP-POLICY clear_all
May 09 14:29:00 twerp wpa_supplicant[721]: Could not set interface wlp44s0 flags (UP): Connection timed out
May 09 14:29:00 twerp wpa_supplicant[721]: nl80211: Could not set interface 'wlp44s0' UP
May 09 14:29:00 twerp wpa_supplicant[721]: nl80211: deinit ifname=wlp44s0 disabled_11b_rates=0
May 09 14:29:03 twerp wpa_supplicant[721]: Could not set interface wlp44s0 flags (UP): Connection timed out
May 09 14:29:03 twerp wpa_supplicant[721]: WEXT: Could not set interface 'wlp44s0' UP
May 09 14:29:03 twerp wpa_supplicant[721]: wlp44s0: Failed to initialize driver interface
May 09 14:29:03 twerp wpa_supplicant[721]: wlp44s0: CTRL-EVENT-DSCP-POLICY clear_all
Edit:
Nope, i have only used kernel version 6.12.25-1-MANJARO
Hmmm…according to what I’ve read here:
WPA Supplicant and NetworkManager may conflict if they both attempt to manage the same interface. Try to disable wpa_supplicant with:
sudo systemctl disable wpa_supplicant.service
Then reboot again and test.
After rebooting, i checked the networks menu and the wifi option to turn on and off doesn’t even appear anymore, i checked if it was disabled using
and it is disabled, any other ideas?
Sadly, I have none. Someone else might, though, but I don’t. Sorry.
Now for some reason device wlp44s0 doesn’t appear, this is really stumping me
Try an older kernel. Perhaps 6.6, as it’s also LTS, or 6.14, the latest. That’s all I can suggest otherwise.
Shut down (completely) and unplug the power for 5 minutes (minimum). Then plug it in again and switch on…
Report back if the device seems work then.
I just decided to completely reintsall manjaro and the problem got fixed
OP reinstalled Manjaro which seems to have fixed the issue
@6thbird
Important: New Manjaro 25.0.1 ISO is available from Downloads.
It is highly recommended to recreate your Manjaro Installer USB using the new ISO, or if using a Ventoy USB, replace the existing Manjaro ISO with the new one.
