Hey! I’ve been having issues with my WiFi connection on Manjaro for the past few weeks. It takes a long time to load pages and it looks like it’s been using data in bit sized pieces (not computer bits). Like if a song is playing it’ll load a bit then stop, then it’ll suddenly play and it keeps happening. I’ve been also having issues with page loading time. I don’t see any issues while installing packages through the terminal. Can it be an issue with my applications? Because I’ve tried Chromium, Brave, Firefox and the problem persists. My kernel is 516 right now. Any help would be appreciated.
Share output of inxi -Nazy
Hi @bhargavdabear,
It seems that maybe, perhaps there is some kind of caching and/or buffering issue, somewhere. Although, I, personally don’t know what would cause such an issue. To help anyone trying to assist you in finding the problem, please see [HowTo] Provide System Information, [HowTo] post screenshots and links, and [HowTo] Increase your chances of solving your issue.
Also, please provide the output for:
ping -c 8 8.8.8.8
And
ping -c 8 google.com
And
ip a
And
ifconfig
And
traceroute manjaro.org
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=116 time=43.3 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=116 time=43.6 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=116 time=45.1 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=116 time=208 ms
64 bytes from 8.8.8.8: icmp_seq=5 ttl=116 time=250 ms
64 bytes from 8.8.8.8: icmp_seq=6 ttl=116 time=66.6 ms
64 bytes from 8.8.8.8: icmp_seq=7 ttl=116 time=52.6 ms
64 bytes from 8.8.8.8: icmp_seq=8 ttl=116 time=45.6 ms
PING google.com (216.58.221.46) 56(84) bytes of data.
64 bytes from del03s07-in-f14.1e100.net (216.58.221.46): icmp_seq=1 ttl=116 time=414 ms
64 bytes from kul01s10-in-f46.1e100.net (216.58.221.46): icmp_seq=2 ttl=116 time=55.5 ms
64 bytes from kul01s10-in-f46.1e100.net (216.58.221.46): icmp_seq=3 ttl=116 time=50.6 ms
64 bytes from kul01s10-in-f46.1e100.net (216.58.221.46): icmp_seq=4 ttl=116 time=55.4 ms
64 bytes from kul01s10-in-f46.1e100.net (216.58.221.46): icmp_seq=5 ttl=116 time=50.2 ms
64 bytes from kul01s10-in-f46.1e100.net (216.58.221.46): icmp_seq=6 ttl=116 time=53.7 ms
64 bytes from kul01s10-in-f46.1e100.net (216.58.221.46): icmp_seq=7 ttl=116 time=52.5 ms
64 bytes from 216.58.221.46: icmp_seq=8 ttl=116 time=58.6 ms
— google.com ping statistics —
8 packets transmitted, 8 received, 0% packet loss, time 34037ms
rtt min/avg/max/mdev = 50.188/98.742/413.507/118.998 ms
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eno1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether c8:d9:d2:aa:0a:c2 brd ff:ff:ff:ff:ff:ff
altname enp3s0
3: wlo1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 14:4f:8a:ca:f8:55 brd ff:ff:ff:ff:ff:ff
altname wlp0s20f3
inet 192.168.0.7/24 brd 192.168.0.255 scope global dynamic noprefixroute wlo1
valid_lft 5515sec preferred_lft 5515sec
inet6 fe80::930e:b9e2:7e24:43bd/64 scope link noprefixroute
zsh: correct ‘ifconfig’ to ‘_ifconfig’ [nyae]? y
_arguments:comparguments:325: can only be called from completion function
traceroute to manjaro.org (116.203.91.91), 30 hops max, 60 byte packets
1 _gateway (192.168.0.1) 2.828 ms 3.271 ms 4.281 ms
2 125.99.xxx.x (125.99.xxx.x) 165.297 ms 165.322 ms 165.314 ms
3 192.168.228.245 (192.168.228.245) 21.412 ms 21.001 ms 22.027 ms
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
It was showing my current IP so I had to censor it.
Kernel: 5.16.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=e1cdc115-6c24-4a9d-aaaa-011db970f232 rw quiet apparmor=1
security=apparmor intel_iommu=on udev.log_priority=3
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 info: plank wm: kwin_x11 vt: 1
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-cx0xxx
v: Type1ProductConfigId serial: <superuser required> Chassis: type: 10
Mobo: HP model: 8478 v: 70.60 serial: <superuser required> UEFI: Insyde
v: F.25 date: 11/13/2020
ID-1: BAT1 charge: 41.1 Wh (98.8%) condition: 41.6/52.8 Wh (78.8%)
volts: 12.8 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: N/A
RAM: total: 7.65 GiB used: 3.92 GiB (51.3%)
RAM Report:
Info: model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 890 high: 1037 min/max: 800/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 900 4: 887
5: 800 6: 803 7: 900 8: 1037 bogomips: 36812
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c8d class-ID: 0300
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
Integrated Webcam
type: USB driver: uvcvideo bus-ID: 1-5:3 chip-ID: 05c8:03bc class-ID: 0e02
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.3.4
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Sound Server-1: ALSA v: k5.16.2-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.43 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 931.51 GiB used: 272.74 GiB (29.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
type: HDD rpm: 7200 serial: <filter> rev: A3T0 scheme: GPT
ID-1: / raw-size: 465.56 GiB size: 457.25 GiB (98.22%)
used: 126.53 GiB (27.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: e1cdc115-6c24-4a9d-aaaa-011db970f232
used: 27.7 MiB (9.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 80AA-DF0F
ID-3: /run/media/bhargav/8040511C40511A6C raw-size: 140.56 GiB
size: 140.56 GiB (100.00%) used: 96.24 GiB (68.5%) fs: ntfs dev: /dev/sda4
maj-min: 8:4 label: N/A uuid: 8040511C40511A6C
ID-4: /run/media/bhargav/Games and ■■■■ raw-size: 325.09 GiB
size: 325.09 GiB (100.00%) used: 49.93 GiB (15.4%) fs: ntfs dev: /dev/sda5
maj-min: 8:5 label: Games and ■■■■ uuid: B0D40099D4006446
ID-1: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-1:6 info: Xiaomi Mi/Redmi series (MTP) type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 2717:ff40 class-ID: 0000 serial: <filter>
Device-2: 1-3:2 info: Logitech G402 Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c07e class-ID: 0300 serial: <filter>
Device-3: 1-5:3 info: Cheng Uei Precision Industry (Foxlink) HP Wide
Vision HD Integrated Webcam
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 05c8:03bc class-ID: 0e02
Device-4: 1-14:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 57.0 C pch: 48.0 C mobo: 27.8 C
Processes: 295 Uptime: 4h 42m wakeups: 1 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1439
pacman: 1414 lib: 388 flatpak: 0 snap: 25 Shell: Zsh v: 5.8 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.12```
Thank you very much!
However, we cannot really understand any of it, as is. Please edit your post according to
In particular, see about providing terminal output. I.e.: wrap the text in three backticks, please. Like this:
pasted text here
Quam ut
eu interdum
ac tempus hendrerit
urna nisl
maecenas et nulla nisi erat id.
Instead of like this:
Quam ut eu interdum ac tempus hendrerit urna nisl maecenas et nulla nisi erat id.
Improving legibility and making it easier for those trying to b e of assistance.
I apologize for the mistake. I edited it.
the three ticks are making the whole reply a terminal output.
It’s fine as is, thanks!
Upon investigations, it would seem this driver is kind of problematic. Or whateveryouwannacall it.
Install the uppdated one, it’s in the AUR:
$ pamac search r8168
r8168-dkms 8.049.02-1 AUR
A kernel module for Realtek 8168 network cards (DKMS version)
So it can be installed using:
pamac build r8168-dkms
Hope it hhelps!
Hey! It worked! Thank you so much but can you tell me what might have caused the issue because if I remember correctly I actually had 8169 driver installed when the problem started and then I installed 8168 too but the problem was still there. I recently uninstalled the driver to test something but completely forgot about it.
Quite possibly it wasn’t the *-dkms version, or something so it didn’t survive kernel changes. Or something. I don’t know.
I’m just glad it works now!
Ah I see, Yep I did try changing kernels to try and fix the issue. Anyways thank you for the help! Have a good day/night!
Changing the kernels might have led to it.
Thank you!
Just because DNS was mentioned … heres this:
