Wifi disapeared after downgrading the kernel
Consecutively to the operation described here, which concluded with a downgrading of the kernel from 5.19 to 5.15, my wifi connection desapeared.
I tried many solutions proposed by the forum without any success.
Luckily, the ethernet wired connection works.
[pierre@Crest ~]$ mhwd-kernel -li
Currently running: 5.15.65-1-MANJARO (linux515)
   * linux510
   * linux515
[pierre@Crest ~]$
[pierre@Crest ~]$ inxi -xN
  Device-1: Realtek vendor: Hewlett-Packard driver: N/A port: 3000
    bus-ID: 0000:01:00.0
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
    driver: r8152 bus-ID: 2-1.2.1:5
[pierre@Crest ~]$
More info about my config
[pierre@Crest ~]$ cat /etc/lsb-release && hostnamectl && uname -a
DISTRIB_ID=ManjaroLinux
DISTRIB_RELEASE=22.0.0
DISTRIB_CODENAME=Sikaris
DISTRIB_DESCRIPTION="Manjaro Linux"
 Static hostname: Crest
       Icon name: computer
      Machine ID: ac6e07ef833243a687a4b64d45d9208c
         Boot ID: 7331f7cbd8594200b9b4e976cbe64679
          Kernel: Linux 5.15.65-1-MANJARO
    Architecture: x86-64
 Hardware Vendor: HP
  Hardware Model: HP Pavilion Laptop 14-dv1xxx
Firmware Version: F.02
Linux Crest 5.15.65-1-MANJARO #1 SMP PREEMPT Mon Sep 5 10:15:47 UTC 2022 x86_64 GNU/Linux
[pierre@Crest ~]$
The loss of the wifi is quite embarassing, could anybody help me?
Many thanks in advance
P.
Hi @piechevall,
Welp, it’s kind of obvious why you wifi doesn’t work :point_down:
It’s because there isn’t a driver for the adapter. So in order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Hope you manage!
Yes I noted that the issue was the absence of driver. However I don’t know how to re-install it (it was working correctly before the kernel downgrade ).
More infos on my config:
       Icon name: computer
 Hardware Vendor: HP
[pierre@Crest ~]$ inxi -v7azy
  Kernel: 5.15.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=deba7d74-5d4f-4aa5-9486-152ca001c934 rw quiet apparmor=1
    security=apparmor resume=UUID=b96f6933-7018-4d59-8ea1-60b1845db6d2
    udev.log_priority=3
  Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
    v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: HP product: HP Pavilion Laptop 14-dv1xxx
    v: Type1ProductConfigId serial: <superuser required> Chassis: type: 10
  Mobo: HP model: 8987 v: 34.46 serial: <superuser required> UEFI: Insyde
    v: F.02 date: 10/07/2021
  ID-1: BAT0 charge: 40.6 Wh (100.0%) condition: 40.6/40.6 Wh (100.0%)
    volts: 12.9 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
    status: full cycles: 25
  Device-1: hidpp_battery_0 model: Logitech K520 serial: <filter> charge: 70%
    (should be ignored) rechargeable: yes status: discharging
  Device-2: hidpp_battery_1 model: Logitech M310 serial: <filter> charge: 55%
  RAM: total: 15.38 GiB used: 2.82 GiB (18.4%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: 11th Gen Intel Core i7-1195G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 built: 2020 process: Intel 10nm
    family: 6 model-id: 0x8C (140) stepping: 2 microcode: 0x28
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 792 high: 953 min/max: 400/4800:5000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 953 2: 722 3: 708 4: 923
    5: 767 6: 561 7: 887 8: 815 bogomips: 46712
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
    movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
    sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    prctl and seccomp
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Hewlett-Packard
    driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
    ports: active: HDMI-A-1 off: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
    bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Luxvisions Innotech HP Wide Vision HD Camera type: USB
    driver: uvcvideo bus-ID: 3-3:3 chip-ID: 30c9:000e class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
    compositor: xfwm v: 4.16.1 driver: X: loaded: modesetting
    alternate: fbdev,vesa gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x318mm (20.00x12.52")
    s-diag: 599mm (23.6")
  Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary model: Dell U2412M
    serial: <filter> built: 2013 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
    size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
    max: 1920x1200 min: 720x400
  Monitor-2: eDP-1 note: disabled model: AU Optronics 0x543d built: 2017
    res: 1920x1200 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
    diag: 355mm (14") ratio: 16:9 modes: 1920x1080
  Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
    chip-ID: 8086:a0c8 class-ID: 0401
  Sound Server-1: ALSA v: k5.15.65-1-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.21 running: no
  Sound Server-4: PulseAudio v: 16.1 running: yes
  Sound Server-5: PipeWire v: 0.3.57 running: yes
  Device-1: Realtek vendor: Hewlett-Packard driver: N/A modules: wl port: 3000
    bus-ID: 0000:01:00.0 chip-ID: 10ec:a85a class-ID: 0280
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
    bus-ID: 2-1.2.1:5 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp0s13f0u1u2u1 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 3-10:7 chip-ID: 0bda:385a class-ID: e001 serial: <filter>
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 2.75 TiB used: 689.78 GiB (24.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
    model: KBG40ZNV1T02 KIOXIA size: 953.87 GiB block-size: physical: 512 B
    rev: HP00AE00 temp: 58.9 C scheme: GPT
  ID-2: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
    model: WD20NMVW-11EDZS3 size: 1.82 TiB block-size: physical: 512 B
    logical: 512 B type: HDD rpm: 5200 serial: <filter> rev: 1065 scheme: MBR
  ID-1: / raw-size: 944.77 GiB size: 928.86 GiB (98.32%) used: 689.78 GiB
    (74.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: deba7d74-5d4f-4aa5-9486-152ca001c934
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 288 KiB
    (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
    uuid: 6613-4560
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: b96f6933-7018-4d59-8ea1-60b1845db6d2
  ID-1: /dev/sdc1 maj-min: 8:33 size: 1.82 TiB fs: ntfs label: Ele1
    uuid: 134F30282E00D6CF
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 2-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
    chip-ID: 2109:0817 class-ID: 0900
  Hub-4: 2-1.2:3 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
  Device-1: 2-1.2.1:5 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.2 speed: 5 Gb/s
    power: 288mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  Device-2: 2-1.4:4 info: Alcor Micro Mass Storage Device type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 800mA
    chip-ID: 058f:8468 class-ID: 0806 serial: <filter>
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-6: 3-1:2 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 4 rev: 2.0
    speed: 480 Mb/s power: 2mA chip-ID: 0424:2514 class-ID: 0900
  Device-1: 3-1.2:4 info: Logitech Unifying Receiver
    type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-2: 3-3:3 info: Luxvisions Innotech HP Wide Vision HD Camera
    type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
    power: 500mA chip-ID: 30c9:000e class-ID: 0e02
  Hub-7: 3-4:5 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    chip-ID: 2109:2817 class-ID: 0900
  Hub-8: 3-4.2:8 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  Device-1: 3-4.2.2:9 info: VIA Labs USB 2.0 BILLBOARD type: Billboard
    driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s chip-ID: 2109:0102
    class-ID: 1100 serial: <filter>
  Device-2: 3-7:6 info: Elan Micro ELAN:ARM-M4 type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
    chip-ID: 04f3:0c00 class-ID: 0000
  Device-3: 3-10:7 info: Realtek Bluetooth Radio type: Bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
  Hub-9: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Device-1: 4-2:2 info: Western Digital Elements Portable (WDBUZG)
    type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
    power: 896mA chip-ID: 1058:1078 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 44.0 C mobo: N/A
  Processes: 250 Uptime: 36m wakeups: 138 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
  Packages: 1840 pm: pacman pkgs: 1802 libs: 399 tools: octopi,pamac,yay
  pm: flatpak pkgs: 38 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
  inxi: 3.3.21
[pierre@Crest ~]$
According to this page, the driveer for that adapter is in kernel 5.16 and up. From what I gather on the page, it’s the rtw89 driver. Luckily it’s in the AUR:
$ pamac search rtw89
rtw89-dkms-git        1:r148.4dc5371-3              AUR
Driver for Realtek 8852AE, an 802.11ax device
But any dkms package requires the kernel headers. So install the kernel headers, by running:
pamac install $(pamac list --quiet --installed | grep "^linux[0-9]*[-rt]*$" | awk '{print $1"-headers"}' ORS=' ')
This will install the headers for all installed kernels.
Next, install the driver:
pamac build rtw89-dkms-git
If successful, do a little dance, cross your heart, say a prayer, reboot and hope for the best!
Hope this helps!
Thanks to you, I noticed that the issue is kernel dependent.
So I reinstalled the kernel 5.19 that I had previously desinstalled because it impeached the run of Virtualbox. AND it works without need of any addition :grinning: (linux-headers was already installed). Quite strange for me.
So I have now the following alternative:
  • using 5.19: wifi works but not virtualbox
  • using 5.15: virtualbox works but without wifi
Following Zesko, it concerns only the Intel 11th gen computers with the 5.19 kernel.
I hope that the kernel 6.0 will definitely solve this issue/bug.
In any case, our discussion help me a lot. Is a Rolling Stone music convenient? I’m from the old school!
