Why is the community repo missing?
Rifled the wiki and the forums before posting. Please forgive me if my search skills failed me. The story: I noticed that the [community] package database has disappeared from the results I get when I enter . For example, this is the result when I enter <Sudo pacman -Syyu>:
[casuist@gilbert-hx90 ~]$ sudo pacman -Syyu
[sudo] password for casuist:
core 144.7 KiB 362 KiB/s 00:00 [######################] 100%
extra 8.6 MiB 8.29 MiB/s 00:01 [######################] 100%
multilib 143.5 KiB 2.22 MiB/s 00:00 [######################] 100%
:: Starting full system upgrade…
there is nothing to do
Formerly, and on my other three machines that run Manjaro, the community package database appears.
I tried refreshing my mirrorlist <user $ sudo pacman-mirrors -c Global> and downloading the databases and updating the system <user $ sudo pacman -Syu >. To no avail.
During one of my many search sessions, I discovered that my <pacman.conf> file was purged of any mention of “community”:
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir     = /
#DBPath      = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
#LogFile     = /var/log/pacman.log
#GPGDir      = /etc/pacman.d/gnupg/
#HookDir     = /etc/pacman.d/hooks/
HoldPkg      = pacman glibc manjaro-system
# If upgrades are available for these packages they will be asked for first
SyncFirst    = manjaro-system archlinux-keyring manjaro-keyring
#XferCommand = /usr/bin/curl -L -C - -f -o %o %u
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
#UseDelta    = 0.7
Architecture = auto
# Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
# We cannot check disk space from within a chroot environment
CheckSpace
#VerbosePkgLists
#ParallelDownloads = 5
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel    = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Manjaro Linux
# packagers with `pacman-key --populate archlinux manjaro`.
# REPOSITORIES
#   - can be defined here or included from another file
#   - pacman will search repositories in the order defined here
#   - local/custom mirrors can be added here or in separate files
#   - repositories listed first will take precedence when packages
#     have identical names, regardless of version number
#   - URLs will have $repo replaced by the name of the current repo
#   - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
#       [repo-name]
#       Server = ServerName
#       Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
# The testing repositories are disabled by default. To enable, uncomment the
# repo name header and Include lines. You can add preferred servers immediately
# after the header, and they will be used before the default mirrors.
[core]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[extra]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
[multilib]
# An example of a custom package repository.  See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
This language is missing for some reason:
#[community-testing]
#Include = /etc/pacman.d/mirrorlist
[community]
I have no clue how it ever got purged, or, more likely, how I ever managed to purge it.
What would be the recommended solution? Edit the pacman.conf file? Or, is there a command I can run to re-add or recover the repository?
The [community] repo has been deprecated for some time and should be removed.
This would have been shown through a pacnew.
Specifically /etc/pacman.conf.pacnew
You may print all your pacnews with
pacdiff -o
For the purposes here, of this single question …
Yes you remove the entry. If you want to be extra careful you can comment it out.
Then
sudo pacman -Sc
(yes to removing unused repos)
Then sync+upgrade again
sudo pacman -Syu
Very grateful. Please forgive me for my ignorance.
No worries.
For more information on how to handle pacnews you can use the search here as there have been more than a few threads discussing how to manage them.
The fast and correct way, including my own opinions, would be
Ensure meld is installed
sudo pacman -Syu meld
Set the DIFFPROG environment variable
echo "DIFFPROG=/usr/bin/meld" | sudo tee -a /etc/environment
Source the environment file to be sure
source /etc/environment
Run pacdiff
pacdiff -s
Use ‘v’ to view, compare, edit, and merge new code.
(note the same file will be presented again after merge/save/close … if satisfied with the marge you can then ‘r’ for remove. Or just ‘s’ to skip … retaining the file for next pacdiff check, such as after a reboot)
The focus is to preserve configurations while adding in the new standards.
Always read Announcements posts. This happened back in May 2023 (Arch / Manjaro unstable) / July 2023 (Manjaro stable).
That was an Arch repo, not a Manjaro repo. Do not mix repos from different distros.
In 2023 after years of prior work the distribution migrated their back-end services to git and in the same run also switched to a new repository layout. In the new layout extra would contain all packages that were previously in community and the testing repositories were split from testing to core-testing and extra-testing , community-testing was removed entirely.
– Official repositories - ArchWiki
Note that I edited your topic title as it was erroneous and misleading.
