I have been running KDE arm edition 5.10.76 on RPI4 for past 3 or so weeks. Except for the initial updates during installation, no updates have been found when I regularly run Pacman -Syu whereas x86 edition gets updates frequently. I am wondering how the update schedule of arm edition work ?
Last stable update for x86_64 landed with quite a delay, breaking a bit the “frequency” trend …
Maybe you have a broken/outdated mirror? Try instead:
sudo pacman-mirrors -f5 && sudo pacman -Syyu
On the other hand, you can also check the announcements for unstable and testing branches:
That way you will be informed about the progress and what is still on fixing phase, before pushed to stable. Also, you can always switch branches and provide more feedback.
you can check in arm forums
Thank you for the forum link to updates. I can see that it’s 24 days since last stable update and will keep an eye on it for future update
See, it came out
Thanks for the update
