[ARM Testing Update] 2021-11-26 - SignalRS, Electron and kernels
Hello ARM community.
Pretty small update this time around.
SignalRS is a new Signal client written in rust
Some highlights:
  • Most of our kernels got updated
  • SignalRS is a new Signal client written in Rust and using Kirigami2 frontend
  • A new version of Electron brings us to 16.0.2
  • Lots of Mobile specific packages got updated
  • Many python packages got updated
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Fri Nov 26 21:43:30 CET 2021)
  • arm-testing community aarch64: 182 new and 176 removed package(s)
  • arm-testing core aarch64: 27 new and 25 removed package(s)
  • arm-testing extra aarch64: 35 new and 34 removed package(s)
  • arm-testing kde-unstable aarch64: 171 new and 174 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2021-11-21         2021-11-06
                              chatty0.5.0beta+24+g4da8b0b-10.5.0beta+42+gd11f868-1
                        eg25-manager              0.4.1-2              0.4.1-4
                            electron             15.3.2-1             16.0.2-1
                          electron12             12.2.2-1             12.2.2-2
                          electron13             13.6.2-1             13.6.2-2
                          electron14             14.2.1-1             14.2.1-2
                     element-desktop              1.9.4-1              1.9.5-1
                         element-web              1.9.4-1              1.9.5-1
               gnome-software-mobile             41.0-1.3               41.1-1
                                inxi           3.3.08.1-1           3.3.09.1-1
                                 kgx              0.4.0-1              0.4.0-2
                          libgbinder             1.1.13-1             1.1.14-1
                         libglibutil             1.0.58-1             1.0.61-1
                               phosh 0.14.0+31+g46b4f0f-1 0.14.0+66+gf0a5e49-1
                     pico-wizard-git       r145.3577d18-2       r147.da08b61-2
           pico-wizard-plamo-scripts       r145.3577d18-2       r147.da08b61-2
            pinephone-manjaro-tweaks           20211013-1           20211124-1
              plasma-mobile-settings           20211105-1           20211126-1
                          rpi-eeprom           20211027-1           20211123-2
                   rpi4-post-install           20211014-1           20211125-3
                  rtl8723bt-firmware   20200705.8840b10-1   20200705.8840b10-2
             rtl8723bt-firmware-megi   20201030.4ec2645-1                    -
                         squeekboard 1.14.0+14+g4efe57c-1 1.14.0+60+gdd70845-1
                           vvmplayer                1.3-1                1.3-2
                          electron15                    -             15.3.2-1
                           signal-rs                    -  0.0.0.r76.fe8c162-1
                      xxd-standalone                    -           8.2.3533-1
:: Different sync package(s) in repository community aarch64
                               acorn            1:8.5.0-1            1:8.6.0-1
                             adljack              1.2.0-2              1.2.0-3
                                 apm              2.6.4-1              2.6.4-3
                               arrow              5.0.0-1              6.0.1-1
                        avisynthplus              3.7.0-1              3.7.0-2
                bash-language-server              2.0.0-2              2.0.0-5
                           borgmatic             1.5.20-1             1.5.21-1
                                btop              1.1.0-1              1.1.1-1
                          cargo-edit              0.8.0-1              0.8.0-2
                             chezmoi              2.7.5-1              2.8.0-1
                             chicken              5.2.0-1              5.3.0-1
                                croc              9.4.2-1              9.5.0-1
                                crun                1.2-1                1.3-1
                             diffuse              0.6.0-1              0.7.2-1
                                 din             51.1.1-1             51.1.1-2
                      efm-langserver             0.0.37-1             0.0.38-1
                fcitx5-pinyin-zhwiki   1:0.2.3.20211016-1   1:0.2.3.20211121-1
                           findomain              5.0.0-1              5.0.1-1
               firefox-ublock-origin             1.38.6-1             1.39.0-1
                       geany-plugins               1.38-1               1.38-2
                         ghostwriter              2.0.2-1              2.1.0-1
                               giada             0.19.0-1             0.19.0-2
                          git-absorb              0.6.6-2              0.6.6-3
                           git-delta              0.9.2-1              0.9.2-2
                               gitui             0.18.0-1             0.18.0-2
                                 gmt              6.2.0-1              6.3.0-1
                             gmt-doc              6.2.0-1              6.3.0-1
                     gnome-flashback             3.40.0-1             3.42.1-1
                              gpxsee               9.11-1               9.12-1
                         gupnp-tools             0.10.1-1             0.10.2-1
                             hashcat            1:6.2.4-1            1:6.2.5-1
                                hugo             0.89.3-1             0.89.4-1
                         jami-daemon           20211104-1           20211104-2
                             jenkins              2.320-1              2.321-1
                                jp2a              1.1.0-2              1.1.1-1
                      jupyter-server             1.11.2-1             1.12.0-1
                                 k9s             0.25.3-1             0.25.5-1
                                 ksh           2020.0.0-2           2020.0.0-3
                                 kup              0.9.1-2              0.9.1-3
               kvantum-theme-materia           20211027-1           20211123-1
                        languagetool                5.5-1                5.5-2
                             lazygit             0.31.3-1             0.31.4-1
                  level-zero-headers              1.5.4-1              1.6.2-1
                   level-zero-loader              1.5.4-1              1.6.2-1
                           libfabric             1.13.2-1             1.14.0-1
                       libimagequant             2.16.0-1             2.17.0-1
                      libmodsecurity            1:3.0.5-1            1:3.0.6-1
                             libspf2             1.2.10-6             1.2.10-7
                                lmms              1.2.2-5              1.2.2-6
                      magic-wormhole             0.12.0-5             0.12.0-6
                                mame              0.237-1              0.238-1
                          mame-tools              0.237-1              0.238-1
                         materia-kde           20211027-1           20211123-1
                      matrix-synapse             1.47.0-1             1.47.1-1
                             maturin             0.12.0-1             0.12.1-1
                        milkytracker            1.03.00-1            1.03.00-2
                               munin             2.0.68-1             2.0.69-1
                          munin-node             2.0.68-1             2.0.69-1
                                 nbd               3.21-2               3.23-1
           networkmanager-strongswan              1.5.2-2              1.5.2-3
                                 nnn                4.3-1                4.4-1
                               nomad              1.2.0-1              1.2.1-1
                            onefetch             2.10.2-2             2.11.0-1
                   openapi-generator              5.3.0-1              5.3.0-2
                             openvdb              9.0.0-1              9.0.0-2
                            parallel           20211022-1           20211122-1
                           pdftricks              0.3.1-1              0.4.1-1
                             pelican              4.6.0-1              4.7.1-1
                               pinta                1.7-3              1.7.1-1
                       piping-server              0.9.1-1             0.10.1-1
                            pngquant             2.16.0-1             2.17.0-1
                     profile-cleaner               2.43-1               2.44-1
                               pyenv              2.2.1-1              2.2.2-1
                             pyright            1.1.188-1            1.1.189-1
                      python-astroid              2.8.5-1              2.9.0-1
                     python-autobahn             21.3.1-2            21.11.1-1
               python-awesomeversion            21.10.1-1            21.11.0-1
                     python-flexmock             0.11.0-1             0.11.1-1
                    python-fonttools             4.28.0-1             4.28.2-1
                    python-ipykernel              6.4.1-1              6.5.1-1
               python-jupyter_client             6.1.12-1              7.1.0-1
                 python-jupyter_core              4.8.1-1              4.9.1-1
python-magic-wormhole-mailbox-server              0.4.1-3              0.4.1-4
 python-magic-wormhole-transit-relay              0.2.1-2              0.2.1-3
              python-openstackclient              5.6.0-1              5.7.0-1
                      python-pikepdf              4.0.1-1              4.0.2-1
                       python-pipenv         2021.11.15-1         2021.11.23-1
                      python-pyarrow              5.0.0-1              6.0.1-1
                 python-pycryptodome             3.10.4-1             3.11.0-1
                       python-pygit2              1.6.1-2              1.7.0-2
           python-pytest-localserver              0.5.0-6              0.5.1-1
                      python-rcssmin              1.0.6-4              1.1.0-1
                         python-rope             0.21.1-1             0.22.0-1
                   python-simplejson             3.17.5-1             3.17.6-1
              python-snowballstemmer              2.1.0-1              2.2.0-1
                       python-sphinx              4.2.0-1              4.3.0-1
                        python-webob              1.8.7-1              1.8.7-2
                   python-webob-docs              1.8.7-1              1.8.7-2
                           python-z3             4.8.12-1             4.8.13-1
                   python-zope-proxy              4.4.0-1              4.5.0-1
                python2-pycryptodome             3.10.4-1             3.11.0-1
                          rebuilderd             0.15.0-1             0.16.2-1
                    rebuilderd-tools             0.15.0-1             0.16.2-1
                            restinio             0.6.13-1             0.6.14-1
                  rime-pinyin-zhwiki   1:0.2.3.20211016-1   1:0.2.3.20211121-1
                              rtmidi              4.0.0-2              5.0.0-1
                         ruby-rugged              1.2.0-1              1.2.0-2
                       rust-analyzer           20211115-1           20211122-1
                         sc3-plugins             3.11.1-1             3.11.1-2
                            starship              1.0.0-1              1.0.0-2
                                 stk              4.6.1-3              4.6.2-1
                strip-nondeterminism             1.12.0-1             1.12.1-1
                          swi-prolog              8.4.0-2              8.4.1-1
                           tailscale             1.18.0-1             1.18.1-1
                           texstudio              4.0.4-1              4.1.1-1
                         tree-sitter             0.20.0-1             0.20.1-1
                         ttc-iosevka             11.0.1-1             11.1.0-1
                    ttc-iosevka-aile             11.0.1-1             11.1.0-1
                   ttc-iosevka-curly             11.0.1-1             11.1.0-1
              ttc-iosevka-curly-slab             11.0.1-1             11.1.0-1
                  ttc-iosevka-etoile             11.0.1-1             11.1.0-1
                    ttc-iosevka-slab             11.0.1-1             11.1.0-1
                    ttc-iosevka-ss01             11.0.1-1             11.1.0-1
                    ttc-iosevka-ss02             11.0.1-1             11.1.0-1
                    ttc-iosevka-ss03             11.0.1-1             11.1.0-1
                    ttc-iosevka-ss04             11.0.1-1             11.1.0-1
                    ttc-iosevka-ss05             11.0.1-1             11.1.0-1
                    ttc-iosevka-ss06             11.0.1-1             11.1.0-1
                    ttc-iosevka-ss07             11.0.1-1             11.1.0-1
                    ttc-iosevka-ss08             11.0.1-1             11.1.0-1
                    ttc-iosevka-ss09             11.0.1-1             11.1.0-1
                    ttc-iosevka-ss10             11.0.1-1             11.1.0-1
                    ttc-iosevka-ss11             11.0.1-1             11.1.0-1
                    ttc-iosevka-ss12             11.0.1-1             11.1.0-1
                    ttc-iosevka-ss13             11.0.1-1             11.1.0-1
                    ttc-iosevka-ss14             11.0.1-1             11.1.0-1
                    ttc-iosevka-ss15             11.0.1-1             11.1.0-1
                    ttc-iosevka-ss16             11.0.1-1             11.1.0-1
                    ttc-iosevka-ss17             11.0.1-1             11.1.0-1
                    ttc-iosevka-ss18             11.0.1-1             11.1.0-1
                          typescript              4.4.4-1              4.5.2-1
                          uncrustify             0.73.0-1             0.74.0-1
         v2ray-domain-list-community     20211115045842-1     20211119143108-1
                         vim-tabular   1.0.0+5+g339091a-1   1.0.0+5+g339091a-2
                         virt-viewer               10.0-2               11.0-1
                           vultr-cli             2.10.0-1             2.11.0-1
                       wireshark-cli             3.4.10-1              3.6.0-1
                        wireshark-qt             3.4.10-1              3.6.0-1
            xfce4-whiskermenu-plugin              2.6.2-1              2.7.0-1
                        zerotier-one              1.8.2-1              1.8.3-1
       python-pytest-console-scripts                    -              1.2.1-2
             python-pytest-tornasync                    -        0.6.0.post2-1
                         rtmidi-docs                    -              5.0.0-1
                            stk-docs                    -              4.6.2-1
:: Different overlay package(s) in repository core aarch64
                               linux             5.15.4-1             5.15.5-1
                       linux-headers             5.15.4-1             5.15.5-1
                        linux-odroid             5.15.2-1             5.15.3-1
                linux-odroid-headers             5.15.2-1             5.15.3-1
                     linux-pinephone             5.15.3-2             5.15.5-2
             linux-pinephone-headers             5.15.3-2             5.15.5-2
                  linux-pinephonepro             5.15.3-2            5.16rc2-3
          linux-pinephonepro-headers             5.15.3-2            5.16rc2-3
                      linux-quartz64           5.15.0-0.3           5.16.0-0.1
              linux-quartz64-headers           5.15.0-0.3           5.16.0-0.1
                            linux-rc           5.16.rc1-6           5.16.rc2-6
                    linux-rc-headers           5.16.rc1-6           5.16.rc2-6
                          linux-rpi4            5.10.78-1            5.10.81-1
                  linux-rpi4-headers            5.10.78-1            5.10.81-1
                 linux-rpi4-mainline             5.15.1-1             5.15.4-1
         linux-rpi4-mainline-headers             5.15.1-1             5.15.4-1
              raspberrypi-bootloader           20211108-1           20211122-1
            raspberrypi-bootloader-x           20211108-1           20211122-1
                  uboot-pinephonepro            2021.10-1       1:2021.01rc3-1
                        linux-khadas                    -             5.15.4-3
                linux-khadas-headers                    -             5.15.4-3
:: Different sync package(s) in repository core aarch64
                              libcap               2.60-1               2.61-1
                            libnftnl              1.2.0-1              1.2.1-1
                             systemd              249.6-3              249.7-1
                        systemd-libs              249.6-3              249.7-1
                  systemd-resolvconf              249.6-3              249.7-1
                  systemd-sysvcompat              249.6-3              249.7-1
:: Different overlay package(s) in repository extra aarch64
                 manjaro-chrootbuild      r233.g5210353-1      r234.g77c74b9-1
                       gnome-keyring                    -           1:40.0-1.1
:: Different sync package(s) in repository extra aarch64
                            alacarte  3.36.0+2+gae6b92d-2           1:3.42.0-1
            archlinux-appstream-data           20211018-1           20211122-1
                              basket              2.49b-5              2.49b-6
                            calligra             3.2.1-23             3.2.1-24
                             devhelp               41.2-1               41.2-2
                        devhelp-docs               41.2-1               41.2-2
                                dkms              3.0.1-1              3.0.2-1
                         erofs-utils                1.3-1                1.4-1
                          fluidsynth              2.2.3-1              2.2.4-1
                                gitg1:3.32.1+17+gb4c8155f-22:3.32.1+r23+g33bb5d2d-1
                       gnome-builder               41.2-1               41.2-2
           gnome-builder-libide-docs               41.2-1               41.2-2
                         imagemagick           7.1.0.14-1           7.1.0.16-1
                     imagemagick-doc           7.1.0.14-1           7.1.0.16-1
                              kdiff3              1.9.3-1              1.9.4-1
                     kimageannotator              0.5.2-1              0.5.3-1
                         ktexteditor             5.88.0-1             5.88.0-2
                             libgit2            1:1.2.0-1            1:1.3.0-1
                        libgit2-glib           0.99.0.1-6           0.99.0.1-7
                    libnetfilter_log              1.0.1-5              1.0.2-1
                          libstemmer              2.1.0-1              2.2.0-1
                              mtools           1:4.0.35-1           1:4.0.36-1
                            nftables            1:1.0.0-1            1:1.0.1-1
                            pstoedit               3.76-1               3.78-1
                         python-mako              1.1.5-1              1.1.6-1
                     python-pyqt5-3d             5.15.4-1             5.15.5-1
                  python-pyqt5-chart             5.15.4-1             5.15.5-1
      python-pyqt5-datavisualization             5.15.4-1             5.15.5-1
             python-pyqt5-purchasing             5.15.4-1             5.15.5-1
                            snowball              2.1.0-1              2.2.0-1
                         suitesparse             5.10.1-1             5.10.1-2
                             varnish              7.0.0-1              7.0.1-1
                   wayland-protocols               1.23-1               1.24-1
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi21.08.3.r12647.gb55abe809-121.08.3.r12648.g3e4359f69-1
                    akonadi-calendar21.08.3.r2005.g45e9f2d-121.08.3.r2007.g12048c7-1
              akonadi-calendar-tools21.08.3.r916.gc0b8834-121.08.3.r918.g8f21fc0-1
                    akonadi-contacts21.08.3.r3085.gd9589f26-121.08.3.r3089.g87cc52e5-1
               akonadi-import-wizard21.08.3.r1769.g8a63030-121.08.3.r1771.g1817ae9-1
                        akonadi-mime21.08.3.r1672.g7b2b0b2-121.08.3.r1674.g1ae15d3-1
                       akonadi-notes21.08.3.r1038.ga26fc7b-121.08.3.r1040.g9cd5953-1
                      akonadi-search21.08.3.r1142.g2414159-121.08.3.r1146.g77a8861-1
                      akonadiconsole21.08.3.r1547.g02d61ae-121.08.3.r1550.g188571e-1
                           akregator21.08.3.r6252.g2d498a83-121.08.3.r6254.gca3ecf6b-1
                            amazfish  2.0.3.r2.g3c68bf6-1  2.0.3.r3.g8b82bb1-1
                                 ark21.08.3.r4639.gb11947b3-121.08.3.r4647.g2d6fbadb-1
                          artikulate21.08.3.r1394.gdd917e0-121.08.3.r1396.g25a62c7-1
                           bluedevil1:5.23.3.r2307.g6e52d830-11:5.23.3.r2312.gac160eb6-1
                              breeze5.23.3.r2296.geaf874e6-15.23.3.r2297.g25933f83-1
                          breeze-gtk5.23.3.r430.gc18f2a4-15.23.3.r431.g19e285b-1
                        breeze-icons5.88.0.r1844.gd78695d5-15.88.0.r1848.g56f801f9-1
                     calendarsupport21.08.1.r53.gfecca81-121.08.1.r56.g10e902e-1
                            discover5.23.3.r8414.g0cd9956a-15.23.3.r8425.g96be2a33-1
                             dolphin21.08.3.r6732.g5bb6bf8d1-121.08.3.r6734.gcdb4a7909-1
                             drkonqi5.23.3.r705.gaea7570b-15.23.3.r707.g2da7306b-1
                               elisa21.08.3.r2794.gdf7598ec-121.08.3.r2797.gf5c9f8da-1
                          eventviews21.11.80.r6.g716daf7-121.11.80.r10.g4777296-1
                 extra-cmake-modules5.88.0.r3388.gaa21958-15.88.0.r3394.g9f51998-1
                           granatier21.08.3.r944.gbb777d1-121.08.3.r945.g4140f92-1
                     grantlee-editor21.08.3.r784.g8434a6a-121.08.3.r786.ge8a0fbb-1
                       grantleetheme21.08.3.r360.g172b127-121.08.3.r361.gce776f8-1
                     incidenceeditor21.08.3.r802.g6f0ea41-121.08.3.r805.g19b2eee-1
                            index-fm 2.1.0.r11.g5d99424-1 2.1.0.r13.g00cd246-1
                           itinerary21.08.3.r1611.gee8bd26-121.08.3.r1628.ge41b6d3-1
                                 juk21.08.3.r3122.g1959c02e-121.08.3.r3123.ga0aa1a11-1
                   kactivitymanagerd5.23.3.r1374.g3ad18a6-15.23.3.r1375.gc66bf75-1
                        kaddressbook21.08.3.r6070.g0b453a10-121.08.3.r6073.gd7fb01c1-1
                              kalarm21.08.3.r6517.gac26a471-121.08.3.r6519.g5ffefef2-1
                           kalarmcal21.08.3.r1160.g07bedeb-121.08.3.r1165.g018b19f-1
                              kamera21.08.3.r669.g2f33e88-121.08.3.r672.g537fc7f-1
                              kamoso21.08.3.r1437.gdffbc0d-121.08.3.r1438.geb1cfbc-1
                              kapman21.08.3.r620.g5eb9603-121.08.3.r624.g716825c-1
                            karchive5.88.0.r518.g8ab6047-15.88.0.r519.g0eebc2c-1
                               kasts 21.08.r88.g226176f-1 21.08.r89.gbac19e0-1
                                kate21.08.3.r18449.gd7e4e78b6-121.08.3.r18453.gcd488dd53-1
                               kauth5.88.0.r456.g15ab513-15.88.0.r457.g70c2a5e-1
                           kblackbox21.08.3.r739.gb75ac92-121.08.3.r741.gd4307b6-1
                          kbookmarks5.88.0.r434.ge2180e4-15.88.0.r435.gfc32b5f-1
                             kbounce21.08.3.r819.g31f56ba-121.08.3.r820.g0c66431-1
                           kbreakout21.08.3.r879.gd23d1d2-121.08.3.r880.g7a95091-1
                         kcachegrind21.08.3.r1159.g1c8b855-121.08.3.r1160.g36185db-1
                  kcachegrind-common21.08.3.r1159.g1c8b855-121.08.3.r1160.g36185db-1
                               kcalc21.08.3.r1548.gf4c9c38-121.08.3.r1549.ga742ed2-1
                       kcalendarcore5.88.0.r1266.g08b10b1bf-15.88.0.r1272.g336684ebe-1
                           kcalutils21.08.3.r899.g5e1983a04-121.08.3.r900.g1abbb07ba-1
                              kclock 21.08.r24.gc823d39-1 21.08.r28.g6596b65-1
                            kcmutils5.88.0.r565.g714fca2-15.88.0.r567.ga59c183-1
                             kconfig5.88.0.r882.gc3be6d0-15.88.0.r889.ge40531e-1
                      kconfigwidgets5.88.0.r646.g97b50c5-15.88.0.r647.g5ad1407-1
                         kcoreaddons5.88.0.r1337.ge82b37b6-15.88.0.r1348.gc738e3bf-1
                               kcron21.08.3.r813.g4453e39-121.08.3.r814.g0de4b9f-1
                      kdebugsettings21.08.3.r862.g8496f6a-121.08.3.r863.g81178ce-1
                        kdeclarative5.88.0.r944.g4b0f685-15.88.0.r946.g2caa62d-1
                          kdeconnect21.08.3.r3360.g55f0a814-121.08.3.r3363.gebfe0da7-1
                            kdenlive21.08.3.r15268.gfac1ac2e7-121.08.3.r15302.g1aaa5b755-1
                       kdepim-addons21.08.3.r4420.g29eb2d0f-121.08.3.r4425.gdf67fba8-1
                      kdepim-runtime21.08.3.r15386.gdd94559e7-121.08.3.r15392.g1b45e95b3-1
                    kdeplasma-addons5.23.3.r8607.g668c6b7d4-15.23.3.r8608.g2484b96f6-1
                       kfilemetadata5.88.0.r822.gae5c27b-15.88.0.r825.gf920a31-1
                         kfourinline21.08.3.r994.ga508900-121.08.3.r995.gf7b42a0-1
                          kguiaddons5.88.0.r403.ge4c581e-15.88.0.r404.g0722df7-1
                  khealthcertificate       r100.e4b5201-1       r115.c5bf2c8-1
                               ki18n5.88.0.r517.g97ee556-15.88.0.r520.g737b5f5-1
                         kiconthemes5.88.0.r566.g3a33ccd-15.88.0.r569.g0c42b55-1
                 kidentitymanagement21.08.3.r3842.g2eefc943-121.08.3.r3844.g7c28e1fc-1
                                kigo21.08.3.r534.g64aae3a-121.08.3.r535.g0ddaad2-1
                               kimap21.08.3.r1142.gdcb38ab-121.08.3.r1143.g8ff8997-1
                         kinfocenter5.23.3.r1983.g0962f6b5-15.23.3.r1994.g5121cea-1
                                 kio5.88.0.r5096.g32df02e2-15.88.0.r5103.g24cef5b7-1
                          kio-extras21.08.3.r7166.gfc086a65-121.08.3.r7168.ga126e22f-1
                          kio-gdrive21.08.3.r574.g4f22785-121.08.3.r575.g69a062a-1
                    kirigami-gallery21.08.3.r223.g7c8b00c-121.08.3.r225.gf98c101-1
                           kirigami25.88.0.r2958.g6e3a5167-15.88.0.r2962.g0c03db72-1
                              kiriki21.08.3.r428.g6895dd7-121.08.3.r429.gc9d53d6-1
                               kiten21.08.3.r1157.g21cfe72-121.08.3.r1158.gcc84275-1
                          kitinerary21.08.3.r2023.g2814c9a-121.08.3.r2024.gcf863fa-1
                                 kjs5.88.0.r345.g3c48e79-15.88.0.r347.gfc93534-1
                               kldap21.08.3.r906.g621c0aa-121.08.3.r907.g0d287be-1
                           kleopatra21.08.3.r6064.gd41b933f-121.08.3.r6090.g9cbc2269-1
                            klickety21.08.3.r646.g642c273-121.08.3.r647.g2577443-1
                               kmail21.08.3.r26108.ge67efaee7-121.08.3.r26130.g4a2c01d22-1
                kmail-account-wizard21.08.3.r836.g28da23f-121.08.3.r840.gf7cc2a5-1
                      kmailtransport21.08.3.r1684.g9987ced-121.08.3.r1687.g3056b89-1
                               kmbox21.08.3.r554.g8ed8b7f-121.08.3.r555.gaa824f6-1
                               kmime21.08.3.r1472.gc11600f-121.08.3.r1473.g7f87a49-1
                          kmousetool21.08.3.r404.g4590e04-121.08.3.r405.g9142e12-1
                              kmouth21.08.3.r701.gf98f284-121.08.3.r702.g3950cbf-1
                              knotes21.08.3.r3545.g9967d439-121.08.3.r3548.g965fde67-1
                                kolf21.08.3.r1455.gd2da0d4-121.08.3.r1457.g5ee4533-1
                         kolourpaint21.08.3.r2374.g56fb4a8e-121.08.3.r2375.gec23e7fd-1
                             konsole21.08.3.r8048.g7e42fcc2-121.08.3.r8080.gd3ddaf3c-1
                             kontact21.08.3.r5419.g3c59f5f0-121.08.3.r5422.gd011a877-1
                            kontrast21.08.3.r187.gbaff6d0-121.08.3.r188.g5f0a68d-1
                        konversation21.08.3.r9008.g63b1a650-121.08.3.r9010.g8aafaac7-1
                          korganizer21.08.3.r11551.g3ba80989e-121.08.3.r11555.gdab612d20-1
                              kparts5.88.0.r542.gc37ecff-15.88.0.r543.g066e27e-1
                        kpimtextedit21.08.3.r1476.g6c0f25f-121.08.3.r1479.g202a5af-1
                             kpmcore21.08.3.r1206.g172b76f-121.08.3.r1210.gc79f583-1
                           krecorder  21.08.r9.g6af8673-1 21.08.r10.g3d9f492-1
                            kreversi21.08.3.r1237.ge73b98b-121.08.3.r1239.ga41a878-1
                                krfb21.08.3.r1451.g2c6cb1e-121.08.3.r1453.g384cfdc-1
                              kruler21.08.3.r713.g7d66843-121.08.3.r714.gd38bcad-1
                             kscreen5.23.3.r1387.g4198b65-15.23.3.r1388.gde94daa-1
                               ksirk21.08.3.r987.g45e5a1c-121.08.3.r988.g43ecbb9-1
                               ksmtp21.08.3.r400.g4ee1f28-121.08.3.r402.g21ef259-1
                          ksnakeduel21.08.3.r819.g80427b3-121.08.3.r820.g340dc6a-1
                          kspaceduel21.08.3.r643.g01e6055-121.08.3.r647.g719f1d4-1
                            ksquares21.08.3.r530.g46e15c3-121.08.3.r531.g1bfa0ca-1
                         ktexteditor5.88.0.r2996.ge3ec93f2-15.88.0.r2997.g544203c4-1
                        ktextwidgets5.88.0.r424.g95e9014-15.88.0.r425.g4b86697-1
                               ktnef21.08.3.r682.g7333736-121.08.3.r684.gecf0571-1
                               ktrip  21.08.r1.g62b9a40-1  21.08.r3.gb93eeb7-1
                          ktuberling21.08.3.r1019.g3a04f6e-121.08.3.r1021.ged19439-1
                     kunitconversion5.88.0.r386.g83ab7a8-15.88.0.r387.g488a4a5-1
                            kwayland5.88.0.r1122.gf4f18ac-15.88.0.r1123.g10e3d60-1
                kwayland-integration5.23.3.r193.g1791ee6-15.23.3.r194.g8cd4f71-1
                            kweather 21.08.r22.g6ef18e3-1 21.08.r27.gc6362e8-1
                      kwidgetsaddons5.88.0.r892.gfa1524d9-15.88.0.r893.g294fe8dd-1
                                kwin5.23.3.r20368.gf07c66f04-15.23.3.r20408.gdc3d0444e-1
                              kwrite21.08.3.r18449.gd7e4e78b6-121.08.3.r18453.gcd488dd53-1
                             kxmlgui5.88.0.r824.g07255b8a-15.88.0.r825.gb9dfccb5-1
                      layer-shell-qt5.21.5.r51.g80f6a62-15.23.3.r51.g80f6a62-1
                          libakonadi21.08.3.r12647.gb55abe809-121.08.3.r12648.g3e4359f69-1
                         libgravatar21.08.3.r382.g1ba7083-121.08.3.r384.g96b5592-1
                           libkdepim21.08.3.r866.gb306bc6-121.08.3.r868.gf875a44-1
                             libkleo21.08.3.r1012.g51f2bd6-121.08.3.r1028.g6509c50-1
                          libkscreen5.23.3.r1604.ge755e97-15.23.3.r1607.g1c9e32c-1
                           libksieve21.08.3.r1620.g40f50104-121.08.3.r1622.g4b59e7df-1
                        libksysguard5.23.3.r2322.gcabef91-15.23.3.r2324.g6356303-1
                         libquotient    r2174.g02fa42b8-1    r2187.g91c1d93d-1
                          mailcommon21.08.3.r1151.geacdfca-121.08.3.r1157.gb7d1feb-1
                        mailimporter21.08.3.r485.gb3cd987-121.08.3.r486.g2875fa9-1
                             mauikit2.1.0.r13.ga6a5a7ed-12.1.0.r16.gf62eca0f-1
                mauikit-filebrowsing  2.1.0.r5.g5f8a2f1-1  2.1.0.r7.gccfc510-1
                  mauikit-imagetools  2.1.0.r0.g1c23d87-1  2.1.0.r2.gc401dbb-1
                       mbox-importer21.08.3.r530.g832b06f-121.08.3.r532.gc31a1f0-1
                          messagelib21.08.3.r6288.gd2854f8d-121.08.3.r6299.gb051e85d-1
                        modem-daemon21.08.2.r431.gadff20f-1                    -
                             neochat    r1953.gbf08303a-1    r1960.g8c0a6c10-1
                              okular21.08.3.r9524.gc701758f7-121.08.3.r9540.g8d078c419-1
                              oxygen5.23.3.r4436.gbf968845-15.23.3.r4437.g83b71a39-1
                     pico-wizard-git       r145.3577d18-5                    -
           pico-wizard-plamo-scripts       r145.3577d18-5                    -
                   pim-data-exporter21.08.3.r2519.g19a6a824-121.08.3.r2520.ge51b54b3-1
                    pim-sieve-editor21.08.3.r1532.gdb7c0ec-121.08.3.r1534.gf9d3a82-1
                           pimcommon21.07.80.r1145.gd0ec3a8-121.07.80.r1148.gde5731e-1
                      plasma-desktop5.23.3.r8785.gb23f7f80b-15.23.3.r8816.g5ce435eee-1
                    plasma-dialer-mm 21.08.r11.g2997fa9-221.08.r416.gd2c4715-1
                    plasma-framework5.88.0.r16100.g82998d90d-15.88.0.r16106.gdf4843687-1
                    plasma-mobile-nm5.23.1.r3122.g9196a015-15.23.3.r3122.g9196a015-1
                           plasma-nm5.23.3.r3122.g9196a015-15.23.3.r3123.g7663885e-1
                           plasma-pa5.23.3.r997.g73f9984-15.23.3.r1003.gd034998-1
             plasma-phone-components5.23.3.r1526.ga63dcf2d-15.23.3.r1527.gd544f70d-1
              plasma-wayland-session5.23.3.r10956.g644588739-15.23.3.r10969.g0870f666f-1
                    plasma-workspace5.23.3.r10956.g644588739-15.23.3.r10969.g0870f666f-1
                          powerdevil5.23.3.r2496.ge82df04a-15.23.3.r2497.g5eccafda-1
                             purpose5.88.0.r911.g6c362bf-15.88.0.r912.g16f1534-1
                         qcachegrind21.08.3.r1159.g1c8b855-121.08.3.r1160.g36185db-1
                                sddm0.19.0.r95.g6a7d25f-10.19.0.r112.ge8e2a0f-1
                               solid5.88.0.r725.g59dc501-15.88.0.r727.g839c211-1
                            spacebar 21.08.r31.g1b168e3-1 21.08.r45.g87db1bb-1
                           spectacle21.08.3.r1213.g03f5d2c-121.08.3.r1215.g16ef5cc-1
                      systemsettings5.23.3.r2566.g266f884f-15.23.3.r2567.g2dcc904b-1
      telepathy-kde-common-internals21.08.3.r1997.g86dbde3-121.08.3.r1998.g87aed0a-1
                             tokodon 21.08.r22.g659c13e-1 21.08.r26.g3038bcb-1
                            umbrello21.08.3.r8271.g788fcb8b4-121.08.3.r8276.g88582909d-1
                         vakzination       r101.2c228cd-1       r105.3dfac9d-1
                               vvave  2.1.0.r4.g3333d67-1  2.1.0.r5.gbdb8743-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
  1. create /etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
    chain input {
        iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
    chain forward {
        iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
        ct state {established, related} counter accept comment "accept established connections"
  1. any time you launch waydroid, run the following after it has started:
echo "ip route add default via 192.168.250.1" |sudo waydroid shell
Old Issues
Plasma Mobile has does not launch after update
This was caused by an error in kwin 5.23.2 which only affects installs based on openGLES (qt5-es2).
Fix: Update to kwin 5.23.2-1.2 or above.
No ethernet on rk3399 boards
A recent kernel regression has resulted in built in ethernet on rk3399 based boards, such as RockPro64 and Rock Pi 4’s, no longer works on kernel 5.14. This is an upstream issue that has not been fixed yet.
Fix: Update to linux-5.14.1-2 or newer.
Vivaldi no longer working
The issue is present in all chrome based browser (except Chromium that got a patch for it).
It’s an issue with systemd-resolved and has been reported in the Arch Linux Bug Tracker.
Needs to be fixed by Vivaldi updates in the future.
Fix: Vivaldi 4.1.2369.21 fixed this issue.
Modemmanager-pp dependency issue
modemmanager-pp 1.16.10 depends on libqmi-pp and libmbim-pp, but they are no longer found in the repo.
Fixed by updated to modemmanager-pp 1.18rc1+2+ga20f2c05-2.
systemd-hook unsuccesful after pacman 6 update
After the pacman 6 update, updates will create this message in the post-transation hooks part:
Running the command manually works and there has been no issues reported as the result of this. This will either get fixed at some point in Pacman or SystemD.
Should be fixed with pacman-6.0.0-4
Keyring issues
If you have some gpg keyring issues, you can run sudo systemctl start pacman-init.service which will regenerate your keyring. Will take a few minutes to complete.
Should be fixed with manjaro-system-20210716-1
Plasma Mobile no longer boots
The current update to qt5-es2-base results in Plasma Mobile no longer booting, showing a screen that says to run a loginctl command to login.
Fixed by updating to qt5-es2-base-5.15.2+kde+r199-3.1 and qt5-es2-declarative-5.15.2+kde+r28-3.1.
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
Save the file and reboot.
Update via pacman and being offered to replace rt18723bt-firmware-megi with community/rt18723bt
[Y] leads to
[Removal:]
Systemd-249.-7, Systemd-libs, Systemd-sysvcompat and wayland-protocols
sounds a bit extreme?
I declined the community/rt18723bt and everything has gone well.
Every thing went well…
Update log
~~Website: https://manjaro.org
~~Forum:   https://forum.manjaro.org/c/arm
~~Matrix:  #manjaro-arm-public:matrix.org
Last login: Fri Nov 26 16:27:01 2021 from Not telling..
[joel@pizero2 ~]$ pamac update
Preparing...
Authenticating as: joel
Password:
Refreshing core.db...                                                              Refreshing extra.db...                                                             Refreshing community.db...                                                         Resolving dependencies...                                                          Checking inter-conflicts...
To upgrade (16):
  archlinux-appstream-data  20211122-1  (20211018-1)  extra      20.0 MB
  firefox-ublock-origin     1.39.0-1    (1.38.6-1)    community  2.8 MB
  libcap                    2.61-1      (2.60-1)      core       80.5 kB
  systemd-libs              249.7-1     (249.6-3)     core       535.5 kB
  libnftnl                  1.2.1-1     (1.2.0-1)     core       62.2 kB
  systemd                   249.7-1     (249.6-3)     core       6.3 MB
  fluidsynth                2.2.4-1     (2.2.3-1)     extra      242.1 kB
  inxi                      3.3.09.1-1  (3.3.08.1-1)  community  304.6 kB
  libstemmer                2.2.0-1     (2.1.0-1)     extra      106.2 kB
  linux-rpi4                5.10.81-1   (5.10.78-1)   core       30.2 MB
  linux-rpi4-headers        5.10.81-1   (5.10.78-1)   core       12.3 MB
  raspberrypi-bootloader-x  20211122-1  (20211108-1)  core       4.0 MB
  raspberrypi-bootloader    20211122-1  (20211108-1)  core       8.8 MB
  rpi-eeprom                20211123-2  (20211027-1)  community  3.5 MB
  rpi4-post-install         20211125-3  (20211014-1)  community  3.7 kB
  systemd-sysvcompat        249.7-1     (249.6-3)     core       5.7 kB
Total download size: 89.5 MB
Total installed size: 1.0 MB
Apply transaction ? [y/N] y
Downloading archlinux-appstream-data (20211122-1)...                               Downloading firefox-ublock-origin (1.39.0-1)...                                    Downloading libcap (2.61-1)...                                                     Downloading systemd-libs (249.7-1)...                                              Downloading libnftnl (1.2.1-1)...                                                  Downloading systemd (249.7-1)...                                                   Downloading fluidsynth (2.2.4-1)...                                                Downloading inxi (3.3.09.1-1)...                                                   Downloading libstemmer (2.2.0-1)...                                                Downloading linux-rpi4 (5.10.81-1)...                                              Downloading linux-rpi4-headers (5.10.81-1)...                                      Downloading raspberrypi-bootloader-x (20211122-1)...                               Downloading raspberrypi-bootloader (20211122-1)...                                 Downloading rpi-eeprom (20211123-2)...                                             Downloading rpi4-post-install (20211125-3)...                                      Downloading systemd-sysvcompat (249.7-1)...                                        Checking keyring...                                                         [16/16]Checking integrity...                                                       [16/16]Loading packages files...                                                   [16/16]Checking file conflicts...                                                  [16/16]Warning: rpi4-post-install: /etc/udev/rules.d/99-vcio-rewrite.rules already exists in filesystem
It has been backed up to /etc/udev/rules.d/99-vcio-rewrite.rules.old
Checking keyring...                                                         [16/16]Checking integrity...                                                       [16/16]Loading packages files...                                                   [16/16]Checking file conflicts...                                                  [16/16]Checking available disk space...                                            [16/16]Upgrading archlinux-appstream-data (20211018-1 -> 20211122-1)...             [1/16]Upgrading firefox-ublock-origin (1.38.6-1 -> 1.39.0-1)...                    [2/16]Upgrading libcap (2.60-1 -> 2.61-1)...                                       [3/16]Upgrading systemd-libs (249.6-3 -> 249.7-1)...                               [4/16]Upgrading libnftnl (1.2.0-1 -> 1.2.1-1)...                                   [5/16]Upgrading systemd (249.6-3 -> 249.7-1)...                                    [6/16]Upgrading fluidsynth (2.2.3-1 -> 2.2.4-1)...                                 [7/16]Upgrading inxi (3.3.08.1-1 -> 3.3.09.1-1)...                                 [8/16]Upgrading libstemmer (2.1.0-1 -> 2.2.0-1)...                                 [9/16]Upgrading linux-rpi4 (5.10.78-1 -> 5.10.81-1)...                            [10/16]===> Remove unwanted data if exists from cmdline.txt...
===> Keeping old config.txt file...
Upgrading linux-rpi4-headers (5.10.78-1 -> 5.10.81-1)...                    [11/16]Upgrading raspberrypi-bootloader-x (20211108-1 -> 20211122-1)...            [12/16]Upgrading raspberrypi-bootloader (20211108-1 -> 20211122-1)...              [13/16]Upgrading rpi-eeprom (20211027-1 -> 20211123-2)...                          [14/16]Upgrading rpi4-post-install (20211014-1 -> 20211125-3)...                   [15/16]Upgrading systemd-sysvcompat (249.6-3 -> 249.7-1)...                        [16/16]Running post-transaction hooks...
Creating system user accounts...                                             [1/13]Updating journal message catalog...                                          [2/13]Reloading system manager configuration...                                    [3/13]Updating udev hardware database...                                           [4/13]Applying kernel sysctl settings...                                           [5/13]Creating temporary files...                                                  [6/13]Reloading device manager configuration...                                    [7/13]Arming ConditionNeedsUpdate...                                               [8/13]Updating module dependencies...                                              [9/13]Updating linux-rpi4 module dependencies...                                  [10/13]Updating linux-rpi4 initcpios...                                            [11/13]==> Building image from preset: /etc/mkinitcpio.d/linux-rpi4.preset: 'default'
  -> -k 5.10.81-1-MANJARO-ARM-RPI -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img
==> Starting build: 5.10.81-1-MANJARO-ARM-RPI
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [plymouth]
  -> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-linux.img
Updating linux initcpios...                                                 [12/13]==> Building image from preset: /etc/mkinitcpio.d/linux-rpi4.preset: 'default'
Reloading system bus configuration...                                       [13/13]A restart is required for the changes to take effect.
[joel@pizero2 ~]$
Yeah, removing systemd shouldn’t be presented. I wonder what’s going wrong there.
Installing vvmd does not install a proper systemd unit file. Uninstalling and reinstalling does not change this. I have to start vvmd manually each time I want to check for voicemails. Perhaps this AUR service file could be used?
https://aur.archlinux.org/cgit/aur.git/tree/vvmd.service?h=vvmd-git
Something is wrong with qt5-webengine 5.15.7-2 . No libQt5WebEngineCore.so.5.
Failed to import PyQt module: PyQt5.QtWebEngineCore with error: libQt5WebEngineCore.so.5
and with icu (after downgrading qt5-webengine)
Failed to import PyQt module: PyQt5.QtWebEngineCore with error: libicui18n.so.69
Tested with calibre-editor
Thanks for this. Adding it.
Are you on Testing branch or Unstable branch? ICU update is only on unstable branch.
unstable.
qt5-webengine 5.15.7-2 has not the libQt5WebEngineCore.so.5 inside (the package is 1,4mo vs 41 for 5.15.7-1)
and calibre is looking after icu 69 vs 70
We get qt5-webengine directly from Arch ARM and theirs is also 1,4 MB in size. So it must be an issue on their end.
Sounds like calibre-editor is not in the repo or in AUR. What package is this from exactly?
If it’s calibre then it indeed has not been rebuilt by Arch ARM since the ICU update.
the package is the editor of calibre (2021-11-27T16:11:35+0100] [ALPM] upgraded calibre (5.32.0-1 → 5.32.0-2)
ebook-edit
Failed to import PyQt module: PyQt5.QtWebEngineCore with error: libicui18n.so.69: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type
  File "/usr/bin/ebook-edit", line 21, in <module>
    sys.exit(ebook_edit())
  File "/usr/lib/calibre/calibre/gui_launch.py", line 104, in ebook_edit
    from calibre.gui2.tweak_book.main import main
  File "/usr/lib/calibre/calibre/gui2/tweak_book/main.py", line 11, in <module>
    from qt.webengine import QWebEngineUrlScheme
ImportError: cannot import name 'QWebEngineUrlScheme' from 'qt.webengine' (/usr/lib/calibre/qt/webengine.py)
it’s after downgrading qt5-webengine
Looks like both Calibre and qt5-webengine needs a proper rebuild against the new ICU from Arch ARM side.
Hi,
Odroid C4 KDE up to date. Something go wrong with samba (like on x86) I solved it.
Odroid N2 not tested for the moment
https://forum.manjaro.org/t/arm-testing-update-2021-11-21-kde-frameworks-shiny-mirrors-pibootctl-and-kernels/91526/18
Personally I would have let 2021-11-21 update sit for a while. Now we are in this ICU limbo …
Seems the needed packages are in arm-unstable. After some other packages we have in our queue we might do another testing snap.
arm-unstable icu
icu-69.1-1-aarch64.pkg.tar.xz ok
icu-70.1-1-aarch64.pkg.tar.xz is bad for qt5 packages
Which is why icu 70.1 is still only in Unstable branch.
Hmm, seems I see it now. Then why post issues from unstable to this thread. Let me open one for Unstable then.
maybe this?
