Hello ARM community.
This is more about ICU rebuilds. Let us know if we missed some?
Some highlights:
- Some of our kernels got updated
- Most packages have a rebuild against ICU 70.1. Let us know if you see any issues with that.
- LibreOffice 7.2.3 is now available
- Many python packages got updated
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Sun Nov 28 13:05:02 CET 2021)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-11-26 2021-11-28
chatty 0.5.0beta+42+gd11f868-1 0.5.0beta+47+ge5775de-1
eg25-manager 0.4.1-4 0.4.1-5
libmm-pp-glib 1.18.2-1 1.18.4-1
modemmanager-pp 1.18.2-1 1.18.4-1
phoc 0.9.0+156+g026ae2c-1 0.9.0+160+gb5b41db-1
phosh 0.14.0+66+gf0a5e49-1 0.14.0+80+gffc9253-1
squeekboard 1.14.0+60+gdd70845-1 1.14.0+61+gf3eeedc-1
vvmd 0.6.1-1 0.6.1-2
:: Different sync package(s) in repository community aarch64
age 1.0.0-3 1.0.0-4
ansible 4.8.0-1 4.9.0-1
awxkit 19.4.0-1 19.5.0-1
bpython 0.21-1 0.22.1-1
btop 1.1.1-1 1.1.2-1
calc 2.13.0.1-2 2.14.0.8-1
calibre 5.32.0-1 5.32.0-2
cargo-sort 1.0.5-2 1.0.6-1
containers-common 0.46.0-5 0.46.0-6
cutefish-settings 0.4-2 0.4-3
diesel-cli 1.4.7-1 1.4.8-1
diffoscope 192-1 193-1
dino 0.2.2-1 0.2.2-2
docker-compose 2.1.1-1 2.2.0-1
dovecot 2.3.16-2 2.3.16-3
dovecot-fts-xapian 1.5.1-1 1.5.2-1
dwdiff 2.1.4-2 2.1.4-3
elementary-icon-theme 6.0.0-1 6.1.0-1
emscripten 2.0.27-1 3.0.0-1
flameshot 0.10.1-1 0.10.2-1
freerdp 2:2.4.1-1 2:2.4.1-2
fwbuilder 5.3.7-9 5.3.7-10
gala 6.2.1.r86.78a5f881-1 6.3.0-1
geary 1:40.0-4 1:40.0-5
gerbv 2.7.0-2 2.8.1-1
gftp 2.7.1b-1 2.8.0b-1
git-delta 0.9.2-2 0.10.2-1
glewlwyd 2.5.4-5 2.6.0-1
gnustep-base 1.28.0-2.1 1.28.0-3
go-ethereum 1.10.12-1 1.10.13-1
go-yq 4.14.2-1 4.15.1-1
granite 6.1.2-1 6.2.0-1
gtk-theme-elementary 6.1.0-1 6.1.1-1
haproxy 2.4.8-1 2.5.0-1
htmlhint 0.16.1-1 1.0.0-1
icewm 2.8.0-1 2.9.0-1
iddawc 1.1.0-1 1.1.1-1
imv 4.3.0-1 4.3.0-2
interception-tools 0.6.7-2 0.6.8-1
ipython 7.29.0-1 7.30.0-1
jenkins 2.321-1 2.322-1
jmol 14.31.61-1 14.31.63-1
jsmol 14.31.61-1 14.31.63-1
jupyter-server 1.12.0-1 1.12.1-1
just 0.9.1-1 0.10.4-1
k9s 0.25.5-1 0.25.7-1
kbibtex 1:0.9.2-5 1:0.9.2-6
kiwix-lib 9.4.1-5 9.4.1-6
klayout 0.27.4-1 0.27.5-1
lcalc 2.0.3-1 2.0.4-1
lesspipe 1.91-2 1.91-3
lhapdf 6.4.0-1 6.4.0-2
libdatovka 0.2.0-1 0.2.0-2
libmodsecurity 1:3.0.6-1 1:3.0.6-2
libperconaserverclient 8.0.26_16-2 8.0.26_16-3
libretro-beetle-pce-fast 1150-1 1152-1
libretro-beetle-psx 2576-1 2582-1
libretro-beetle-psx-hw 2576-1 2582-1
libretro-beetle-supergrafx 929-1 932-1
libretro-dolphin 33001-1 33003-1
libretro-gambatte 942-1 947-1
libretro-genesis-plus-gx 1867-1 1868-1
libretro-play 6833-1 6863-1
libretro-shaders-slang 847-1 854-1
libspf2 1.2.10-7 1.2.11-1
libtpms 0.9.0-1 0.9.1-1
libzim 7.0.0-1 7.0.0-2
libzim6 6.3.2-2 6.3.2-3
lollypop 1.4.23-1 1.4.24-1
maim 5.7.4-1 5.7.4-2
mapnik 3.1.0-5 3.1.0-6
mdbook 0.4.13-1 0.4.14-1
mediawiki 1.36.2-1 1.37.0-1
mediawiki-math 1.36.2-1 1.37.0-1
mongo-c-driver 1.19.0-1 1.19.0-2
ncmpcpp 0.9.2-3 0.9.2-4
nodejs 17.1.0-1 17.1.0-2
nodejs-lts-erbium 12.22.7-1 12.22.7-2
nodejs-lts-fermium 14.18.1-1 14.18.1-2
nodejs-lts-gallium 16.13.0-1 16.13.0-3
nomad 1.2.1-1 1.2.2-1
nomad-driver-nspawn 0.7.0-2 0.8.0-1
openethereum 3.2.6-1 3.3.0-1
openrct2 0.3.5-1 0.3.5.1-1
openttd 12.1-1 12.1-2
openvdb 9.0.0-2 9.0.0-4
pantheon-applications-menu 2.9.1-1 2.10.0-1
pantheon-code 6.0.1-1 6.1.0-1
pantheon-onboarding 6.0.0-1 6.1.0-1
percona-server 8.0.26_16-2 8.0.26_16-3
percona-server-clients 8.0.26_16-2 8.0.26_16-3
perl-graphics-colornames 2.11-9 3.5.0-1
perl-graphics-colornames-www 1.13-9 1.14-1
perl-proc-processtable 0.60-1 0.61-1
perl-test2-suite 0.000141-1 0.000142-1
php-mongodb 1.11.1-1 1.11.1-2
php7-mongodb 1.11.1-1 1.11.1-2
poedit 1:3.0-3 1:3.0-4
pop-icon-theme 2.1.0.r2415.a5a10f9725-1 2.1.0.r2419.9998b20b78-1
pyright 1.1.189-1 1.1.190-1
python-aiohttp 3.7.4.post0-1.1 3.8.1-2
python-aiohttp-socks 0.4.2-3 0.7.1-1
python-async-timeout 3.0.1-5 4.0.1-2
python-cmd2 1.5.0-1 2.1.2-1
python-cysignals 1.10.3-1 1.11.0-1
python-gnupg 0.4.7-1 0.4.8-1
python-isort 5.10.1-1 5.10.1-2
python-lexicon 1.0.0-1 2.0.0-1
python-pdftotext 2.2.0-1 2.2.2-1
python-plumbum 1.7.0-4 1.7.1-1
python-prettytable 0.7.2-14 1.0.0-1
python-proxmoxer 1.1.1-3 1.2.0-1
python-pyicu 2.7.4-1 2.8-1
python-python-socks 1.2.4-1 2.0.0-1
python-quart 0.15.1-1 0.16.1-1
python-scipy 1.7.2-1 1.7.3-1
python-sphinx 4.3.0-1 4.3.1-1
python-sword 1.9.0-2 1.9.0-3
python-toposort 1.6-1 1.7-1
python-xattr 0.9.7-5 0.9.8-1
python-zope-testrunner 5.3.0-2 5.4.0-1
radeontop 1.3-2 1.4-1
rgbds 0.5.1-1 0.5.2-1
rhit 1.5.3-1 1.5.4-1
rhonabwy 1.1.1-1 1.1.2-1
rofi 1.7.0-1 1.7.1-1
rspamd 3.1-1 3.1-2
scribus 1.5.7-7 1.5.7-8
seamonkey 2.53.9.1-2.1 2.53.9.1-3
sile 0.12.0-4 0.12.0-5
skopeo 1.5.1-1 1.5.2-1
slop 7.5-5 7.5-6
solaar 1.0.7-1 1.1.0-1
stardict 3.0.6-8 3.0.6.2-1
switchboard-plug-desktop 6.0.0-1 6.1.0-1
switchboard-plug-keyboard 2.5.1-1 2.6.0-1
switchboard-plug-locale 2.5.5-1 2.5.6-1
switchboard-plug-security-privacy 2.2.5-1 2.3.0-1
switchboard-plug-sound 2.2.7-1 2.3.0-1
switchboard-plug-user-accounts 2.4.1-1 2.4.2-1
tesseract 4.1.1-7 4.1.1-8
ttf-sarasa-gothic 0.35.0-1 0.35.1-1
unarchiver 1.10.7-4 1.10.7-5
v2ray-domain-list-community 20211119143108-1 20211126110355-1
v2ray-geoip 202111180029-1 202111250029-1
viewnior 1.7-3 1.8-1
vim-nerdcommenter 2.5.2-2 2.6.0-2
vim-spell-af 20190731-2 20200604-2
vim-spell-am 20190731-2 20200604-2
vim-spell-bg 20190731-2 20200604-2
vim-spell-br 20190731-2 20200604-2
vim-spell-ca 20190731-2 20200604-2
vim-spell-cs 20190731-2 20200604-2
vim-spell-cy 20190731-2 20200604-2
vim-spell-da 20190731-2 20200604-2
vim-spell-de 20190731-2 20200604-2
vim-spell-el 20190731-2 20200604-2
vim-spell-en 20190731-2 20200604-2
vim-spell-eo 20190731-2 20200604-2
vim-spell-es 20190731-2 20200604-2
vim-spell-fo 20190731-2 20200604-2
vim-spell-fr 20190731-2 20200604-2
vim-spell-ga 20190731-2 20200604-2
vim-spell-gd 20190731-2 20200604-2
vim-spell-gl 20190731-2 20200604-2
vim-spell-he 20190731-2 20200604-2
vim-spell-hr 20190731-2 20200604-2
vim-spell-hu 20190731-2 20200604-2
vim-spell-id 20190731-2 20200604-2
vim-spell-it 20190731-2 20200604-2
vim-spell-ku 20190731-2 20200604-2
vim-spell-la 20190731-2 20200604-2
vim-spell-lt 20190731-2 20200604-2
vim-spell-lv 20190731-2 20200604-2
vim-spell-mg 20190731-2 20200604-2
vim-spell-mi 20190731-2 20200604-2
vim-spell-ms 20190731-2 20200604-2
vim-spell-nb 20190731-2 20200604-2
vim-spell-nl 20190731-2 20200604-2
vim-spell-nn 20190731-2 20200604-2
vim-spell-ny 20190731-2 20200604-2
vim-spell-pl 20190731-2 20200604-2
vim-spell-pt 20190731-2 20200604-2
vim-spell-ro 20190731-2 20200604-2
vim-spell-ru 20190731-2 20200604-2
vim-spell-rw 20190731-2 20200604-2
vim-spell-sk 20190731-2 20200604-2
vim-spell-sl 20190731-2 20200604-2
vim-spell-sr 20190731-2 20200604-2
vim-spell-sv 20190731-2 20200604-2
vim-spell-sw 20190731-2 20200604-2
vim-spell-tet 20190731-2 20200604-2
vim-spell-th 20190731-2 20200604-2
vim-spell-tl 20190731-2 20200604-2
vim-spell-tn 20190731-2 20200604-2
vim-spell-uk 20190731-2 20200604-2
vim-spell-yi 20190731-2 20200604-2
vim-spell-zu 20190731-2 20200604-2
wingpanel-indicator-network 2.3.1-1 2.3.2-1
wingpanel-indicator-sound 6.0.0-1 6.0.1-1
xalan-c 1:1.12-3 1:1.12-4
xh 0.14.0-1 0.14.1-1
yaml-language-server 1.2.0-1 1.2.1-1
yaz 5.31.0-1 5.31.0-2
znc 1.8.2-4 1.8.2-5
doctest - 2.4.6-1
sentry-cli - 1.71.0-1
sqlc - 1.11.0-1
vim-spell-tr - 20200604-2
:: Different overlay package(s) in repository core aarch64
linux-pinephone 5.15.5-2 5.15.5-4
linux-pinephone-headers 5.15.5-2 5.15.5-4
linux-pinephonepro 5.16rc2-3 5.16rc2-4
linux-pinephonepro-headers 5.16rc2-3 5.16rc2-4
linux-rpi4-mainline 5.15.4-1 5.15.5-1
linux-rpi4-mainline-headers 5.15.4-1 5.15.5-1
:: Different sync package(s) in repository core aarch64
bash 5.1.008-1 5.1.012-1
btrfs-progs 5.15-1 5.15.1-1
ca-certificates-mozilla 3.72-1 3.72-2
icu 69.1-1 70.1-1
nss 3.72-1 3.72-2
python 3.9.7-2.1 3.9.9-1
python-tests 3.9.7-2.1 3.9.9-1
xfsprogs 5.13.0-1 5.14.0-1
:: Different overlay package(s) in repository extra aarch64
boxit-arm 2.1.3-7 2.1.3-8
boxit-arm-server 2.1.3-6 -
calamares 3.2.45-1 3.2.45-2
manjaro-settings-manager 0.5.6-9 0.5.6-10
manjaro-settings-manager-kcm 0.5.6-9 0.5.6-10
python-es2-pyqt5 5.15.6-1 5.15.6-2
qt5-es2-base 5.15.2+kde+r256-1 5.15.2+kde+r260-1
qt5-es2-xcb-private-headers 5.15.2+kde+r256-1 5.15.2+kde+r260-1
:: Different sync package(s) in repository extra aarch64
389-ds-base 2.0.10-2 2.0.10-3
archinstall 2.2.0-1 2.3.0-1
archlinux-appstream-data 20211122-1 20211122-2
boost 1.76.0-1 1.76.0-2
boost-libs 1.76.0-1 1.76.0-2
brltty 6.4-1 6.4-2
chromium 96.0.4664.45-1 96.0.4664.45-2
devhelp 41.2-2 41.2-3
devhelp-docs 41.2-2 41.2-3
egl-wayland 1:1.1.9+2+gdaab854-12:1.1.9+r3+g582b2d3-1
enchant 2.3.1-1 2.3.1-2
evolution-data-server 3.42.1-2 3.42.1-3
geoip-database 20211026-1 20211123-1
geoip-database-extra 20211026-1 20211123-1
git 2.34.0-1 2.34.1-1
gpaste 3.42.1-1 3.42.2-1
harfbuzz 3.1.1-1 3.1.2-1
harfbuzz-icu 3.1.1-1 3.1.2-1
kdb 3.2.0-7 3.2.0-8
libcdr 0.1.7-2 0.1.7-3
libe-book 0.1.3-9 0.1.3-10
libexif 0.6.23-1 0.6.24-1
libical 3.0.11-1 3.0.11-2
libmm-glib 1.18.2-1 1.18.4-1
libmpdclient 2.19-3 2.20-1
libmspub 0.1.4-10 0.1.4-11
libphonenumber 8.12.36-1 8.12.37-1
libqalculate 3.21.0-1 3.21.0-2
libqxp 0.0.2-6 0.0.2-7
libreoffice-fresh 7.2.2-3 7.2.3-1
libreoffice-fresh-af 7.2.2-1 7.2.3-1
libreoffice-fresh-am 7.2.2-1 7.2.3-1
libreoffice-fresh-ar 7.2.2-1 7.2.3-1
libreoffice-fresh-as 7.2.2-1 7.2.3-1
libreoffice-fresh-ast 7.2.2-1 7.2.3-1
libreoffice-fresh-be 7.2.2-1 7.2.3-1
libreoffice-fresh-bg 7.2.2-1 7.2.3-1
libreoffice-fresh-bn 7.2.2-1 7.2.3-1
libreoffice-fresh-bn-in 7.2.2-1 7.2.3-1
libreoffice-fresh-bo 7.2.2-1 7.2.3-1
libreoffice-fresh-br 7.2.2-1 7.2.3-1
libreoffice-fresh-brx 7.2.2-1 7.2.3-1
libreoffice-fresh-bs 7.2.2-1 7.2.3-1
libreoffice-fresh-ca 7.2.2-1 7.2.3-1
libreoffice-fresh-ca-valencia 7.2.2-1 7.2.3-1
libreoffice-fresh-ckb 7.2.2-1 7.2.3-1
libreoffice-fresh-cs 7.2.2-1 7.2.3-1
libreoffice-fresh-cy 7.2.2-1 7.2.3-1
libreoffice-fresh-da 7.2.2-1 7.2.3-1
libreoffice-fresh-de 7.2.2-1 7.2.3-1
libreoffice-fresh-dgo 7.2.2-1 7.2.3-1
libreoffice-fresh-dsb 7.2.2-1 7.2.3-1
libreoffice-fresh-dz 7.2.2-1 7.2.3-1
libreoffice-fresh-el 7.2.2-1 7.2.3-1
libreoffice-fresh-en-gb 7.2.2-1 7.2.3-1
libreoffice-fresh-en-za 7.2.2-1 7.2.3-1
libreoffice-fresh-eo 7.2.2-1 7.2.3-1
libreoffice-fresh-es 7.2.2-1 7.2.3-1
libreoffice-fresh-et 7.2.2-1 7.2.3-1
libreoffice-fresh-eu 7.2.2-1 7.2.3-1
libreoffice-fresh-fa 7.2.2-1 7.2.3-1
libreoffice-fresh-fi 7.2.2-1 7.2.3-1
libreoffice-fresh-fr 7.2.2-1 7.2.3-1
libreoffice-fresh-fur 7.2.2-1 7.2.3-1
libreoffice-fresh-fy 7.2.2-1 7.2.3-1
libreoffice-fresh-ga 7.2.2-1 7.2.3-1
libreoffice-fresh-gd 7.2.2-1 7.2.3-1
libreoffice-fresh-gl 7.2.2-1 7.2.3-1
libreoffice-fresh-gu 7.2.2-1 7.2.3-1
libreoffice-fresh-gug 7.2.2-1 7.2.3-1
libreoffice-fresh-he 7.2.2-1 7.2.3-1
libreoffice-fresh-hi 7.2.2-1 7.2.3-1
libreoffice-fresh-hr 7.2.2-1 7.2.3-1
libreoffice-fresh-hsb 7.2.2-1 7.2.3-1
libreoffice-fresh-hu 7.2.2-1 7.2.3-1
libreoffice-fresh-id 7.2.2-1 7.2.3-1
libreoffice-fresh-is 7.2.2-1 7.2.3-1
libreoffice-fresh-it 7.2.2-1 7.2.3-1
libreoffice-fresh-ja 7.2.2-1 7.2.3-1
libreoffice-fresh-ka 7.2.2-1 7.2.3-1
libreoffice-fresh-kab 7.2.2-1 7.2.3-1
libreoffice-fresh-kk 7.2.2-1 7.2.3-1
libreoffice-fresh-km 7.2.2-1 7.2.3-1
libreoffice-fresh-kmr-latn 7.2.2-1 7.2.3-1
libreoffice-fresh-kn 7.2.2-1 7.2.3-1
libreoffice-fresh-ko 7.2.2-1 7.2.3-1
libreoffice-fresh-kok 7.2.2-1 7.2.3-1
libreoffice-fresh-ks 7.2.2-1 7.2.3-1
libreoffice-fresh-lb 7.2.2-1 7.2.3-1
libreoffice-fresh-lo 7.2.2-1 7.2.3-1
libreoffice-fresh-lt 7.2.2-1 7.2.3-1
libreoffice-fresh-lv 7.2.2-1 7.2.3-1
libreoffice-fresh-mai 7.2.2-1 7.2.3-1
libreoffice-fresh-mk 7.2.2-1 7.2.3-1
libreoffice-fresh-ml 7.2.2-1 7.2.3-1
libreoffice-fresh-mn 7.2.2-1 7.2.3-1
libreoffice-fresh-mni 7.2.2-1 7.2.3-1
libreoffice-fresh-mr 7.2.2-1 7.2.3-1
libreoffice-fresh-my 7.2.2-1 7.2.3-1
libreoffice-fresh-nb 7.2.2-1 7.2.3-1
libreoffice-fresh-ne 7.2.2-1 7.2.3-1
libreoffice-fresh-nl 7.2.2-1 7.2.3-1
libreoffice-fresh-nn 7.2.2-1 7.2.3-1
libreoffice-fresh-nr 7.2.2-1 7.2.3-1
libreoffice-fresh-nso 7.2.2-1 7.2.3-1
libreoffice-fresh-oc 7.2.2-1 7.2.3-1
libreoffice-fresh-om 7.2.2-1 7.2.3-1
libreoffice-fresh-or 7.2.2-1 7.2.3-1
libreoffice-fresh-pa-in 7.2.2-1 7.2.3-1
libreoffice-fresh-pl 7.2.2-1 7.2.3-1
libreoffice-fresh-pt 7.2.2-1 7.2.3-1
libreoffice-fresh-pt-br 7.2.2-1 7.2.3-1
libreoffice-fresh-ro 7.2.2-1 7.2.3-1
libreoffice-fresh-ru 7.2.2-1 7.2.3-1
libreoffice-fresh-rw 7.2.2-1 7.2.3-1
libreoffice-fresh-sa-in 7.2.2-1 7.2.3-1
libreoffice-fresh-sat 7.2.2-1 7.2.3-1
libreoffice-fresh-sd 7.2.2-1 7.2.3-1
libreoffice-fresh-sdk 7.2.2-3 7.2.3-1
libreoffice-fresh-si 7.2.2-1 7.2.3-1
libreoffice-fresh-sid 7.2.2-1 7.2.3-1
libreoffice-fresh-sk 7.2.2-1 7.2.3-1
libreoffice-fresh-sl 7.2.2-1 7.2.3-1
libreoffice-fresh-sq 7.2.2-1 7.2.3-1
libreoffice-fresh-sr 7.2.2-1 7.2.3-1
libreoffice-fresh-sr-latn 7.2.2-1 7.2.3-1
libreoffice-fresh-ss 7.2.2-1 7.2.3-1
libreoffice-fresh-st 7.2.2-1 7.2.3-1
libreoffice-fresh-sv 7.2.2-1 7.2.3-1
libreoffice-fresh-sw-tz 7.2.2-1 7.2.3-1
libreoffice-fresh-szl 7.2.2-1 7.2.3-1
libreoffice-fresh-ta 7.2.2-1 7.2.3-1
libreoffice-fresh-te 7.2.2-1 7.2.3-1
libreoffice-fresh-tg 7.2.2-1 7.2.3-1
libreoffice-fresh-th 7.2.2-1 7.2.3-1
libreoffice-fresh-tn 7.2.2-1 7.2.3-1
libreoffice-fresh-tr 7.2.2-1 7.2.3-1
libreoffice-fresh-ts 7.2.2-1 7.2.3-1
libreoffice-fresh-tt 7.2.2-1 7.2.3-1
libreoffice-fresh-ug 7.2.2-1 7.2.3-1
libreoffice-fresh-uk 7.2.2-1 7.2.3-1
libreoffice-fresh-uz 7.2.2-1 7.2.3-1
libreoffice-fresh-ve 7.2.2-1 7.2.3-1
libreoffice-fresh-vec 7.2.2-1 7.2.3-1
libreoffice-fresh-vi 7.2.2-1 7.2.3-1
libreoffice-fresh-xh 7.2.2-1 7.2.3-1
libreoffice-fresh-zh-cn 7.2.2-1 7.2.3-1
libreoffice-fresh-zh-tw 7.2.2-1 7.2.3-1
libreoffice-fresh-zu 7.2.2-1 7.2.3-1
libreoffice-still 7.1.7-2 7.1.7-3
libreoffice-still-sdk 7.1.7-2 7.1.7-3
libsoup 2.74.1-1 2.74.2-1
libsoup3 3.0.2-1 3.0.3-1
libsynctex 2021.58686-3 2021.58686-4
libvisio 0.1.7-5 0.1.7-6
libxml2 2.9.12-2 2.9.12-3
libzmf 0.0.2-10 0.0.2-11
m17n-lib 1.8.0-10 1.8.0-11
meson 0.60.1-1 0.60.2-1
modemmanager 1.18.2-1 1.18.4-1
mousepad 0.5.7-1 0.5.8-1
mpd 0.23.4-1 0.23.4-2
nuspell 5.0.1-1 5.0.1-2
nyacc 1.04.1-1 1.05.1-1
openmpi 4.1.1-3 4.1.2-1
ostree 2021.5-1 2021.6-1
perl-date-manip 6.85-2 6.86-1
perl-try-tiny 0.30-6 0.31-1
php 8.0.13-1 8.0.13-2
php-apache 8.0.13-1 8.0.13-2
php-cgi 8.0.13-1 8.0.13-2
php-dblib 8.0.13-1 8.0.13-2
php-embed 8.0.13-1 8.0.13-2
php-enchant 8.0.13-1 8.0.13-2
php-fpm 8.0.13-1 8.0.13-2
php-gd 8.0.13-1 8.0.13-2
php-imap 8.0.13-1 8.0.13-2
php-intl 8.0.13-1 8.0.13-2
php-odbc 8.0.13-1 8.0.13-2
php-pgsql 8.0.13-1 8.0.13-2
php-phpdbg 8.0.13-1 8.0.13-2
php-pspell 8.0.13-1 8.0.13-2
php-snmp 8.0.13-1 8.0.13-2
php-sodium 8.0.13-1 8.0.13-2
php-sqlite 8.0.13-1 8.0.13-2
php-tidy 8.0.13-1 8.0.13-2
php-xsl 8.0.13-1 8.0.13-2
php7 7.4.26-1 7.4.26-2
php7-apache 7.4.26-1 7.4.26-2
php7-cgi 7.4.26-1 7.4.26-2
php7-dblib 7.4.26-1 7.4.26-2
php7-embed 7.4.26-1 7.4.26-2
php7-enchant 7.4.26-1 7.4.26-2
php7-fpm 7.4.26-1 7.4.26-2
php7-gd 7.4.26-1 7.4.26-2
php7-imap 7.4.26-1 7.4.26-2
php7-intl 7.4.26-1 7.4.26-2
php7-odbc 7.4.26-1 7.4.26-2
php7-pgsql 7.4.26-1 7.4.26-2
php7-phpdbg 7.4.26-1 7.4.26-2
php7-pspell 7.4.26-1 7.4.26-2
php7-snmp 7.4.26-1 7.4.26-2
php7-sodium 7.4.26-1 7.4.26-2
php7-sqlite 7.4.26-1 7.4.26-2
php7-tidy 7.4.26-1 7.4.26-2
php7-xsl 7.4.26-1 7.4.26-2
postfix 3.6.3-2 3.6.3-3
postfix-cdb 3.6.3-2 3.6.3-3
postfix-ldap 3.6.3-2 3.6.3-3
postfix-lmdb 3.6.3-2 3.6.3-3
postfix-mysql 3.6.3-2 3.6.3-3
postfix-pcre 3.6.3-2 3.6.3-3
postfix-pgsql 3.6.3-2 3.6.3-3
postfix-sqlite 3.6.3-2 3.6.3-3
postgresql 13.4-3 13.4-4
postgresql-docs 13.4-3 13.4-4
postgresql-libs 13.4-3 13.4-4
postgresql-old-upgrade 12.8-3 12.8-4
python-numpy 1.21.2-1 1.21.3-1
python-pyopenssl 20.0.1-1 21.0.0-1
python-tomli 1.2.1-1 1.2.2-2
python2-pyopenssl 20.0.1-1 21.0.0-1
qt5-3d 5.15.2+kde+r33-2 5.15.2+kde+r37-1
qt5-base 5.15.2+kde+r257-1 5.15.2+kde+r260-1
qt5-location 5.15.2-3 5.15.2-4
qt5-webengine 5.15.7-1 5.15.7-2
qt5-webkit 5.212.0alpha4-10 5.212.0alpha4-11
qt5-xcb-private-headers 5.15.2+kde+r257-1 5.15.2+kde+r260-1
qt6-5compat 6.2.1-1 6.2.1-2
qt6-base 6.2.1-2 6.2.1-3
qt6-webengine 6.2.1-1 6.2.1-2
r 4.1.2-1 4.1.2-2
raptor 2.0.15-16 2.0.15-17
ristretto 0.12.0-1 0.12.1-1
samba 4.15.2-2 4.15.2-3
smbclient 4.15.2-2 4.15.2-3
sof-firmware 1.9-1 1.9.2-1
sof-tools 1.9-1 1.9.2-1
tepl 6.00.0-2 6.00.0-3
texlive-bin 2021.58686-3 2021.58686-4
thunderbird 91.3.2-1 91.3.2-2
thunderbird-i18n-af 91.3.2-1 91.3.2-2
thunderbird-i18n-ar 91.3.2-1 91.3.2-2
thunderbird-i18n-ast 91.3.2-1 91.3.2-2
thunderbird-i18n-be 91.3.2-1 91.3.2-2
thunderbird-i18n-bg 91.3.2-1 91.3.2-2
thunderbird-i18n-br 91.3.2-1 91.3.2-2
thunderbird-i18n-ca 91.3.2-1 91.3.2-2
thunderbird-i18n-cak 91.3.2-1 91.3.2-2
thunderbird-i18n-cs 91.3.2-1 91.3.2-2
thunderbird-i18n-cy 91.3.2-1 91.3.2-2
thunderbird-i18n-da 91.3.2-1 91.3.2-2
thunderbird-i18n-de 91.3.2-1 91.3.2-2
thunderbird-i18n-dsb 91.3.2-1 91.3.2-2
thunderbird-i18n-el 91.3.2-1 91.3.2-2
thunderbird-i18n-en-gb 91.3.2-1 91.3.2-2
thunderbird-i18n-en-us 91.3.2-1 91.3.2-2
thunderbird-i18n-es-ar 91.3.2-1 91.3.2-2
thunderbird-i18n-es-es 91.3.2-1 91.3.2-2
thunderbird-i18n-et 91.3.2-1 91.3.2-2
thunderbird-i18n-eu 91.3.2-1 91.3.2-2
thunderbird-i18n-fi 91.3.2-1 91.3.2-2
thunderbird-i18n-fr 91.3.2-1 91.3.2-2
thunderbird-i18n-fy-nl 91.3.2-1 91.3.2-2
thunderbird-i18n-ga-ie 91.3.2-1 91.3.2-2
thunderbird-i18n-gd 91.3.2-1 91.3.2-2
thunderbird-i18n-gl 91.3.2-1 91.3.2-2
thunderbird-i18n-he 91.3.2-1 91.3.2-2
thunderbird-i18n-hr 91.3.2-1 91.3.2-2
thunderbird-i18n-hsb 91.3.2-1 91.3.2-2
thunderbird-i18n-hu 91.3.2-1 91.3.2-2
thunderbird-i18n-hy-am 91.3.2-1 91.3.2-2
thunderbird-i18n-id 91.3.2-1 91.3.2-2
thunderbird-i18n-is 91.3.2-1 91.3.2-2
thunderbird-i18n-it 91.3.2-1 91.3.2-2
thunderbird-i18n-ja 91.3.2-1 91.3.2-2
thunderbird-i18n-ka 91.3.2-1 91.3.2-2
thunderbird-i18n-kab 91.3.2-1 91.3.2-2
thunderbird-i18n-kk 91.3.2-1 91.3.2-2
thunderbird-i18n-ko 91.3.2-1 91.3.2-2
thunderbird-i18n-lt 91.3.2-1 91.3.2-2
thunderbird-i18n-ms 91.3.2-1 91.3.2-2
thunderbird-i18n-nb-no 91.3.2-1 91.3.2-2
thunderbird-i18n-nl 91.3.2-1 91.3.2-2
thunderbird-i18n-nn-no 91.3.2-1 91.3.2-2
thunderbird-i18n-pa-in 91.3.2-1 91.3.2-2
thunderbird-i18n-pl 91.3.2-1 91.3.2-2
thunderbird-i18n-pt-br 91.3.2-1 91.3.2-2
thunderbird-i18n-pt-pt 91.3.2-1 91.3.2-2
thunderbird-i18n-rm 91.3.2-1 91.3.2-2
thunderbird-i18n-ro 91.3.2-1 91.3.2-2
thunderbird-i18n-ru 91.3.2-1 91.3.2-2
thunderbird-i18n-sk 91.3.2-1 91.3.2-2
thunderbird-i18n-sl 91.3.2-1 91.3.2-2
thunderbird-i18n-sq 91.3.2-1 91.3.2-2
thunderbird-i18n-sr 91.3.2-1 91.3.2-2
thunderbird-i18n-sv-se 91.3.2-1 91.3.2-2
thunderbird-i18n-th 91.3.2-1 91.3.2-2
thunderbird-i18n-tr 91.3.2-1 91.3.2-2
thunderbird-i18n-uk 91.3.2-1 91.3.2-2
thunderbird-i18n-uz 91.3.2-1 91.3.2-2
thunderbird-i18n-vi 91.3.2-1 91.3.2-2
thunderbird-i18n-zh-cn 91.3.2-1 91.3.2-2
thunderbird-i18n-zh-tw 91.3.2-1 91.3.2-2
tracker 2.3.6+7+gb27396252-2 2.3.6+7+gb27396252-3
tracker-miners 2.3.5+2+gec09554af-3 2.3.5+2+gec09554af-4
tracker3 3.2.1-1 3.2.1-2
tracker3-docs 3.2.1-1 3.2.1-2
tracker3-miners 3.2.1-1 3.2.1-2
vte-common 0.66.1-1 0.66.1-2
vte3 0.66.1-1 0.66.1-2
vulkan-headers 1:1.2.194-1 1:1.2.200-1
vulkan-icd-loader 1.2.194-1 1.2.199-2
vulkan-tools 1.2.194-1 1.2.199-1
vulkan-validation-layers 1.2.194-1 1.2.199-1
webkit2gtk 2.34.1-2 2.34.2-1
webkit2gtk-4.1 2.34.1-2 2.34.2-1
webkit2gtk-5.0 2.34.1-2 2.34.2-1
wpewebkit 2.34.1-2 2.34.2-1
xerces-c 3.2.3-4 3.2.3-5
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.08.3.r12648.g3e4359f69-121.08.3.r12650.gfdfd21ba0-1
buho 2.1.0.r0.g5d6b3b4-1 2.1.0.r0.g5d6b3b4-2
disman-git0.521.80.r1788.g388e893-1 -
dolphin21.08.3.r6734.gcdb4a7909-121.08.3.r6735.g4585f215a-1
elisa21.08.3.r2797.gf5c9f8da-121.08.3.r2798.g546129d9-1
filelight21.08.3.r998.gd329edc-121.08.3.r999.gb2156c3-1
gwenview21.08.3.r6693.ga6c80184-121.08.3.r6695.g605dc74c-1
index-fm 2.1.0.r13.g00cd246-1 2.1.0.r13.g00cd246-2
itinerary21.08.3.r1628.ge41b6d3-121.08.3.r1633.g323b3c8-1
kaccounts-integration21.08.3.r1232.g4fcd38f-121.08.3.r1233.g35c3442-1
kaccounts-providers21.08.3.r385.g88a4a50-121.08.3.r386.g972a54d-1
kalarm21.08.3.r6519.g5ffefef2-121.08.3.r6524.g263f61b3-1
kamera21.08.3.r672.g537fc7f-121.08.3.r673.g269b5a2-1
kate21.08.3.r18453.gcd488dd53-121.08.3.r18455.gac5af3d72-1
kcalendarcore5.88.0.r1272.g336684ebe-15.88.0.r1273.g80ccb9803-1
kconfig5.88.0.r889.ge40531e-15.88.0.r891.g2cd5cdf-1
kcontacts1:5.88.0.r3289.g6cd2a8e3-11:5.88.0.r3290.g9b416670-1
kcron21.08.3.r814.g0de4b9f-121.08.3.r815.g81c0afc-1
kde-cli-tools5.23.3.r1876.g173befe-15.23.3.r1877.g8065203-1
kde-gtk-config5.23.3.r916.g21d547e-15.23.3.r917.gf96bb2f-1
kdebugsettings21.08.3.r863.g81178ce-121.08.3.r865.ge9e2d48-1
kdeconnect21.08.3.r3363.gebfe0da7-121.08.3.r3365.g04dab1e2-1
kdelibs4support5.88.0.r1052.gcfae8b72-15.88.0.r1053.g1b393296-1
kdenetwork-filesharing21.08.3.r895.g3d576da-121.08.3.r896.g7bc3fec-1
kdenlive21.08.3.r15302.g1aaa5b755-121.08.3.r15307.g2e0b9b40a-1
kdepim-runtime21.08.3.r15392.g1b45e95b3-121.08.3.r15393.g2c48a9cd6-1
kdeplasma-addons5.23.3.r8608.g2484b96f6-15.23.3.r8609.g08296e99b-1
kdisplay-git5.21.80.r1435.g24a3e32-1 -
kgamma55.23.3.r463.gc082f80-15.23.3.r464.g8b8358a-1
khealthcertificate r115.c5bf2c8-1 r117.3e24d21-1
khotkeys5.23.3.r2102.g97f9339-15.23.3.r2103.g37a7972-1
ki18n5.88.0.r520.g737b5f5-15.88.0.r521.gbeca408-1
kig21.08.3.r3151.g7babddb9-121.08.3.r3153.gf571c147-1
kio-gdrive21.08.3.r575.g69a062a-121.08.3.r576.g3230ae8-1
kirigami25.88.0.r2962.g0c03db72-15.88.0.r2964.g31efdd66-1
kitinerary21.08.3.r2024.gcf863fa-121.08.3.r2025.g3aa2df6-1
kmail21.08.3.r26130.g4a2c01d22-121.08.3.r26132.g022dcbec4-1
kmime21.08.3.r1473.g7f87a49-121.08.3.r1474.gc85eb46-1
konsole21.08.3.r8080.gd3ddaf3c-121.08.3.r8082.g57ea4d41-1
kontactinterface21.08.3.r645.g376ac09-121.08.3.r647.g74cf88f-1
konversation21.08.3.r9010.g8aafaac7-121.08.3.r9011.ged3d4da4-1
korganizer21.08.3.r11555.gdab612d20-121.08.3.r11556.gf6b9b5994-1
kosmindoormap21.08.3.r675.gf3ca558-121.08.3.r677.gda54601-1
kpat21.08.3.r2572.g69af8f6-121.08.3.r2576.gb98c1fe-1
kpkpass21.08.3.r249.g0f1c9ce-121.08.3.r250.g7550057-1
krecorder 21.08.r10.g3d9f492-1 21.08.r11.gc57451c-1
krfb21.08.3.r1453.g384cfdc-121.08.3.r1454.gdddb127-1
kscreen5.23.3.r1388.gde94daa-15.23.3.r1391.gf1a29e8-1
kscreenlocker5.23.3.r888.gd8eb103-15.23.3.r889.g1f092a8-1
kservice5.88.0.r961.g465f20c-15.88.0.r962.g43c0f90-1
ksirk21.08.3.r988.g43ecbb9-121.08.3.r989.g7a7ccc1-1
ksystemstats5.23.3.r208.g15a0383-15.23.3.r209.gb0086cb-1
ktexteditor5.88.0.r2997.g544203c4-15.88.0.r3000.gda5fced4-1
ktorrent21.08.3.r2792.gc938a739-121.08.3.r2793.gb3a15a9a-1
ktuberling21.08.3.r1021.ged19439-121.08.3.r1025.g44a17f9-1
kunitconversion5.88.0.r387.g488a4a5-15.88.0.r388.gfec5d42-1
kweather 21.08.r27.gc6362e8-1 21.08.r30.g667f03b-1
kwin5.23.3.r20408.gdc3d0444e-15.23.3.r20409.g1d95dd3ea-1
kwinft5.23.3.r19775.g43e59510f-15.23.3.r19783.gf9cb2de61-1
kwinft-git5.21.80.r18627.g5409a4b98-1 -
kwordquiz21.08.3.r1152.gfe38a55-121.08.3.r1156.g81b5a5c-1
kwrite21.08.3.r18453.gcd488dd53-121.08.3.r18455.gac5af3d72-1
libakonadi21.08.3.r12648.g3e4359f69-121.08.3.r12650.gfdfd21ba0-1
libgravatar21.08.3.r384.g96b5592-121.08.3.r385.gf1d77c2-1
libkscreen5.23.3.r1607.g1c9e32c-15.23.3.r1608.g8bb4b79-1
libksieve21.08.3.r1622.g4b59e7df-121.08.3.r1623.g2d552bc1-1
libquotient r2187.g91c1d93d-1 r2200.g0425fd28-1
mailcommon21.08.3.r1157.gb7d1feb-121.08.3.r1159.ga0afc3e-1
mailimporter21.08.3.r486.g2875fa9-121.08.3.r487.g7750407-1
maui-clip 2.1.0.r1.g840cc6f-1 2.1.0.r2.ga09503d-2
maui-nota 2.1.0.r1.g36c626a-1 2.1.0.r0.g36c626a-2
maui-pix 2.1.0.r2.g3fe0a8e-1 2.1.0.r3.g4c77aba-2
mauikit2.1.0.r16.gf62eca0f-12.1.0.r17.ge932ac27-2
mauikit-accounts 2.1.0.r1.g709da19-1 2.1.0.r1.g709da19-2
mauikit-filebrowsing 2.1.0.r7.gccfc510-1 2.1.0.r8.g46a68ab-2
mauikit-imagetools 2.1.0.r2.gc401dbb-1 2.1.0.r7.geb592bd-2
mauikit-texteditor 2.1.0.r0.g119b288-1 2.1.0.r1.ge150080-2
plasma-desktop5.23.3.r8816.g5ce435eee-15.23.3.r8820.gb6a4b221d-1
plasma-dialer-mm21.08.r416.gd2c4715-121.08.r416.g1b4f605-2
plasma-framework5.88.0.r16106.gdf4843687-15.88.0.r16107.gb27a365ec-1
plasma-integration5.23.3.r539.g25caaed-15.23.3.r540.g680d9e5-1
plasma-mobile-nm5.23.3.r3122.g9196a015-15.23.3.r3129.gefeafb7e-1
plasma-nm5.23.3.r3123.g7663885e-15.23.3.r3129.gefeafb7e-1
plasma-phone-components5.23.3.r1527.gd544f70d-15.23.3.r1528.gd2f9664a-1
plasma-systemmonitor5.23.3.r514.g09e92cf-15.23.3.r515.gdb67302-1
plasma-vault5.23.3.r354.gf8b184b-15.23.3.r356.g332b0b3-1
polkit-kde-agent5.23.3.r509.gb843d78-15.23.3.r510.g41f613d-1
qcoro0.3.0.r152.ged74dd8-10.3.0.r154.g82c2dc3-1
qqc2-breeze-style5.23.3.r232.ga254696-15.23.3.r233.g94298f3-1
sddm0.19.0.r112.ge8e2a0f-10.19.0.r112.ge8e2a0f-2
spacebar 21.08.r45.g87db1bb-1 21.08.r47.g5d4a994-1
syntax-highlighting5.88.0.r1748.g5d62ad3f-15.88.0.r1757.gd64893e5-1
tokodon 21.08.r26.g3038bcb-1 21.08.r28.g2b89ca6-1
vvave 2.1.0.r5.gbdb8743-1 2.1.0.r6.g4abef5d-2
wrapland-git0.521.80.r1426.g917663b-1 -
zeroconf-ioslave21.08.3.r362.g13a3f15-121.08.3.r363.g3dcd67f-1
Testers needed on arm-unstable branch
So if you are adventurous and want newer software quicker, we would love for you to help us test out the new packages in arm-unstable branch.
- Run this command to switch branch:
sudo pacman-mirrors -aS unstable && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-unstable branch.
We would then love for you to give feedback in our update posts in #arm:unstable-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
