when I use something a little bit heavy software like, vscode, postman, mongodb compass etc… I face a visual problem on window border and whole layout!
I don’t know what should call this but you can see there’s something like dot . . . inside red marked area!
mainly I use manjaro for coding but this kind of visual glitch are too much distrubing for me!
how can I fix this?
btw, for let you know… I use custom screen resolution using xrandr (/etc/X11/xorg.conf.d/10-monitor.conf)
Hi @muhammadabir,
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Those are called artifacts that happen with a failing gpu, your VRAM might be done for. Try another OS, but I think you will get the same result. Also like @Mirdarthos said paste your System Information.
this not happen on peppermint, linux lite, endeavouros, kali, zoirn… I’ve used a lot of distro just some of them happen this issue!
Kernel: 5.15.28-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_2125 quiet
systemd.show_status=1 apparmor=1 security=apparmor driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: P8H61-M LX2 R2.0 v: Rev X.0x
serial: <superuser required> BIOS: American Megatrends v: 0605
date: 07/03/2012
RAM: total: 3.53 GiB used: 1.61 GiB (45.7%)
RAM Report:
Info: model: Intel Pentium G620 bits: 64 type: MCP arch: Sandy Bridge
family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x26
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB
desc: 1x3 MiB
Speed (MHz): avg: 1600 min/max: 1600/2600 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1600 2: 1600 bogomips: 10405
Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb est fpu fxsr ht
lahf_lm lm mca mce mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp
rep_good sep sse sse2 sse4_1 sse4_2 ssse3 syscall tm tm2 tsc
tsc_deadline_timer vme xsave xsaveopt xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: ASUSTeK driver: i915 v: kernel ports: active: VGA-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0102 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1024x768 s-dpi: 96 s-size: 270x203mm (10.6x8.0")
s-diag: 338mm (13.3")
Monitor-1: VGA-1 res: 1024x768 hz: 60 size: N/A modes: max: 1024x768
min: 640x480
Message: Unable to show GL data. Required tool glxinfo missing.
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
vendor: ASUSTeK P8 series driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-2: Realtek RTL8188GU 802.11n WLAN Adapter (After Modeswitch)
type: USB driver: N/A bus-ID: 2-1.4:7 chip-ID: 0bda:b711 class-ID: 0000
serial: <filter>
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Local Storage: total: 140.7 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD SSD 120GB
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: <unknown>
type: SSD serial: <filter> rev: 0108 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB model: USB DISK 3.0 size: 28.91 GiB
block-size: physical: 512 B logical: 512 B speed: <unknown> type: N/A
serial: <filter> rev: PMAP scheme: MBR
Message: No partition data found.
ID-1: /dev/dm-0 maj-min: 254:0 mapped: ventoy size: 3.33 GiB fs: iso9660
ID-2: /dev/sda1 maj-min: 8:1 size: 549 MiB fs: ntfs label: System Reserved
uuid: 3CD0F0B6D0F0778A
ID-3: /dev/sda2 maj-min: 8:2 size: 111.25 GiB fs: ntfs label: N/A
uuid: 5CF6F41AF6F3F1DE
ID-4: /dev/sdb1 maj-min: 8:17 size: 28.88 GiB fs: exfat label: Ventoy
uuid: 4E21-0000
ID-5: /dev/sdb2 maj-min: 8:18 size: 32 MiB fs: vfat label: VTOYEFI
uuid: 0922-588F
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Device-1: 2-1.2:3 info: Kingston SP Mobile C31 (64GB) type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 498mA
chip-ID: 13fe:6300 class-ID: 0806 serial: <filter>
Device-2: 2-1.3:4 info: USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 0000:3825 class-ID: 0301
Device-3: 2-1.4:7
info: Realtek RTL8188GU 802.11n WLAN Adapter (After Modeswitch) type: WiFi
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 0bda:b711 class-ID: 0000 serial: <filter>
Device-4: 2-1.6:5 info: CASUE USB KB type: Keyboard,HID
power: 100mA chip-ID: 2a7a:938f class-ID: 0300
System Temperatures: cpu: 64.0 C mobo: 27.8 C
Processes: 174 Uptime: 3m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1151 lib: 319
flatpak: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.13
No offense meant, but that sounds very aggressive, dude!
Nevertheless, it doesn’t change the fact that it is quite possibly hardware. And the fact that it did happen on others as well, reaffirms that theory.
If you think it’s a manjaro-only problem, to find out if it’s hardware related try a distro you mentioned to do a benchmark that overloads the VRAM and see if they appear again. But to me it looks like a hardware problem.
thanks @Dullnets & @Mirdarthos for your time but trust me, I only notice this on manjaro, ubuntu, deeping & linux mint but these all was my favourite distro’s!
Let me explain, maybe I expressed myself wrong, you are using integrated graphics which is a GPU integrated into the processor. The integrated graphics hardware does not use a separate memory bank for graphics / video. Instead, the GPU uses system memory shared with the CPU. The fact that this happens to you with these distros over other lighter ones confirms my theory that it can be a hardware problem. That’s why I asked you to try making a benchmark that overloads the VRAM in those distros. If it’s not a hardware problem, that’s better
But first you should test.
Do you know what kernel the distributions that works use?
@Mirdarthos all of them use 5.4, 5.10 & + higher
but 5.10 works well on my machine
Have you tried using a different Kernel version?
yes… I’ve upgrade & downgraded into different kernels
If the ones giving the problem(s) are all 5.4 and above, try 4.19. It’s LTS and will be supported until December 2024 AFAIK.
Edit:
Also,
From what I can see, this machine is kind of old-ish. So it’s not really surprising if something reach their end of life. And this might just be part of it.
