I am running a windows xp virtual machine in virtualbox.
But it shows somehow transparent background.
How to fix this?
(BTW, I’m unable to upload screenshots)
Hi @yh_yeasin, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
- [HowTo] Provide System Information,
- [HowTo] Post screenshots and links,
- [HowTo] Request support, and
- [HowTo] Post command output and file content as preformatted text.
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Also, if your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
system info:
Kernel: 5.15.84-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=e9add983-7619-46d3-9418-7fd06fbc6056 rw rootflags=subvol=@
apparmor=1 security=apparmor
resume=UUID=8e66a957-84c1-4f1d-b80d-7aa8bfcf9352 udev.log_priority=3
bootsplash.bootfile=/bootsplash-themes/manjaro/bootsplash
Desktop: Xfce v: 4.18.0 tk: Gtk v: 3.24.35 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: SAMSUNG product: 300E4C/300E5C/300E7C v: 0.1
serial: <superuser required> Chassis: type: 9 v: 0.1
Mobo: SAMSUNG model: NP300E5X-A08AE v: FAB1 serial: <superuser required>
UEFI-[Legacy]: Phoenix v: P05RAJ date: 02/20/2013
ID-1: BAT1 charge: 48.8 Wh (100.0%) condition: 48.8/48.8 Wh (100.0%)
volts: N/A min: 11.1 model: SAMSUNG Electronics type: Li-ion serial: N/A
status: full
RAM: total: 3.61 GiB used: 1.98 GiB (54.8%)
Info: model: Intel Celeron B820 bits: 64 type: MCP arch: Sandy Bridge
level: v2 built: 2010-12 process: Intel 32nm family: 6 model-id: 0x2A (42)
stepping: 7 microcode: 0x2F
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 2 MiB
desc: 1x2 MiB
Speed (MHz): avg: 1065 high: 1332 min/max: 800/1700 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 1332
bogomips: 6787
Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear
mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
disabled
prctl and seccomp
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Samsung Co driver: i915 v: kernel arch: Gen-6 process: Intel 32nm
built: 2011 ports: active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0106 class-ID: 0300
Device-2: Silicon Motion WebCam SC-13HDL11939N type: USB driver: uvcvideo
bus-ID: 1-1.4:3 chip-ID: 2232:1029 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 model: Seiko Epson 0x384a built: 2011 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Samsung Co NP300E5C driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1e20 class-ID: 0403
Sound API: ALSA v: k5.15.84-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Samsung Co
driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0
chip-ID: 168c:0032 class-ID: 0280
vendor: Samsung Co RTL8168 on a NP300E5C series laptop driver: r8169
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0
Device-1: Qualcomm Atheros AR3012 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 2-1.4:4 chip-ID: 0cf3:3004 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 465.76 GiB used: 30.97 GiB (6.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: ST500LM012 HN-M500MBB
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 0002 scheme: MBR
Optical-1: /dev/sr0 vendor: Slimtype model: DVD A DS8A8SH rev: KS22
dev-links: cdrom
ID-1: / raw-size: 457.82 GiB size: 457.82 GiB (100.00%)
used: 30.93 GiB (6.8%) fs: btrfs dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: e9add983-7619-46d3-9418-7fd06fbc6056
ID-2: /home raw-size: 457.82 GiB size: 457.82 GiB (100.00%)
ID-3: /var/cache raw-size: 457.82 GiB size: 457.82 GiB (100.00%)
ID-4: /var/log raw-size: 457.82 GiB size: 457.82 GiB (100.00%)
ID-1: swap-1 type: partition size: 7.94 GiB used: 35.3 MiB (0.4%)
priority: -2 dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: 8e66a957-84c1-4f1d-b80d-7aa8bfcf9352
Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.4:3 info: Silicon Motion WebCam SC-13HDL11939N type: Video
Hub-3: 2-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
Device-1: 2-1.2:5 info: A4Tech USB Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 09da:c10a class-ID: 0301
Device-2: 2-1.4:4 info: Qualcomm Atheros AR3012 Bluetooth 4.0
type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 0cf3:3004 class-ID: e001 serial: <filter>
System Temperatures: cpu: 55.0 C mobo: N/A
Processes: 213 Uptime: 1h 39m wakeups: 1 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1131 libs: 332 tools: pamac pm: flatpak pkgs: 0
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.24
Screenshot:https://paste.pics/5e7a5b028aa4512d6afaea93072b5966
I see you are using Xfce.
I don’t know what the cause if, but I do know I know absolutely nothing about Xfce. So I’ll not be able to help you, but the information should be helpful for anyone trying to be of assistance.
This is a known issue when Kvantum theming is applied
Please check the forum search function
Which would have lead you to
Thank you very much,sir.
