Using iGPU instead of dGPU
Hello everybody
I recently bought an Asus Pro 15 and installed Manjaro alongside Windows 11.
My dGPU is active, and I can’t figure out how to switch to the iGPU to save power and extend my battery life.
I’m not a Linux expert user, but I think this command output might help.
> lspci -k | grep -A 2 -E "(VGA|3D)"
0000:00:02.0 VGA compatible controller: Intel Corporation Meteor Lake-P [Intel Arc Graphics] (rev 08)
        DeviceName: Onboard - Video
        Subsystem: ASUSTeK Computer Inc. Device 3698
0000:01:00.0 VGA compatible controller: NVIDIA Corporation GA107BM / GN20-P0-R-K2 [GeForce RTX 3050 6GB Laptop GPU] (rev a1)
        Kernel driver in use: nvidia
> inxi --filter --verbosity=8
  Kernel: 6.14.6-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64
    root=UUID=bedd2cd0-00db-486d-88df-c30be3b8747c rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.14.0
    wm: kwin_wayland with: krunner vt: 1 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: ASUSTeK product: ASUS Vivobook Pro 15 N6506MJ_Q543MJ
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: N6506MJ v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: N6506MJ.311
    date: 02/25/2025
  ID-1: BAT0 charge: 76.0 Wh (100.0%) condition: 76.0/75.0 Wh (101.3%)
    volts: 17.7 min: 15.9 model: S560647 type: Unknown serial: <filter>
    status: full cycles: 4
  System RAM: total: 24 GiB available: 22.84 GiB used: 13.5 GiB (59.1%)
  Array-1: capacity: N/A slots: 2 modules: 2 EC: None max-module-size: N/A
  Device-1: Controller0-ChannelA type: DDR5 detail: synchronous size: 8 GiB
    speed: 5600 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: Micron Technology
    part-no: MTC4C10163S1SC56BD1 serial: N/A
  Device-2: Controller1-ChannelA-DIMM0 type: DDR5 detail: synchronous
    size: 16 GiB speed: 5600 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M425R2GA3PB0-CWMOL serial: <filter>
  Info: model: Intel Core Ultra 9 185H bits: 64 type: MST AMCP
    arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
    family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x24
  Topology: cpus: 1x dies: 1 clusters: 9 cores: 16 threads: 22 mt: 6 tpc: 2
    st: 10 smt: enabled cache: L1: 1.6 MiB desc: d-10x32 KiB, 6x48 KiB; i-16x64
    KiB L2: 18 MiB desc: 9x2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 400 min/max: 400/4800:5100:3800:2500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
    5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
    15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 21: 400 22: 400
    bogomips: 135168
    bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
    f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
    ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
    movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
    rdpid rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep
    smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
    tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
    user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
    conditional; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
  Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: ASUSTeK
    driver: i915 v: kernel alternate: xe arch: Xe-LPG process: Intel 4 (7nm+)
    built: 2023+ ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
    bus-ID: 0000:00:02.0 chip-ID: 8086:7d55 class-ID: 0300
  Device-2: NVIDIA GA107BM / GN20-P0-R-K2 [GeForce RTX 3050 6GB Laptop GPU]
    vendor: ASUSTeK driver: nvidia v: 570.144 alternate: nouveau,nvidia_drm
    non-free: 550-570.xx+ status: current (as of 2025-04; EOL~2026-12-xx)
    arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 ports:
    active: none off: HDMI-A-1 empty: eDP-2 bus-ID: 0000:01:00.0
    chip-ID: 10de:25ac class-ID: 0300
  Device-3: Shinetech ASUS 5M WebCam driver: hid-sensor-hub,usbhid,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-9:3
    chip-ID: 3277:0058 class-ID: fe01 serial: <filter>
    compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
    unloaded: nouveau alternate: fbdev,nv,vesa dri: iris
    gpu: i915,nvidia,nvidia-nvswitch d-rect: 3840x1200 display-ID: 0
  Monitor-1: HDMI-A-1 pos: primary,left model: BenQ GW2381 serial: <filter>
    built: 2019 res: mode: 1920x1200 hz: 60 scale: 100% (1) dpi: 100 gamma: 1.2
    chroma: red: x: 0.655 y: 0.333 green: x: 0.325 y: 0.612 blue: x: 0.153
    y: 0.059 white: x: 0.314 y: 0.329 size: 488x297mm (19.21x11.69")
    diag: 571mm (22.5") ratio: 15:9 modes: 1920x1200, 1920x1080, 1680x1050,
    1600x900, 1280x1024, 1280x800, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480
  Monitor-2: eDP-1 pos: right model: Samsung 0x4161 built: 2020 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red:
    x: 0.682 y: 0.322 green: x: 0.235 y: 0.725 blue: x: 0.137 y: 0.047 white:
    x: 0.314 y: 0.329 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau drv: nvidia
    platforms: device: 0 drv: nvidia device: 1 drv: nouveau device: 2 drv: iris
    device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland:
    drv: iris x11: drv: swrast
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 25.0.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: llvmpipe (LLVM 19.1.7 256 bits)
    device-ID: ffffffff:ffffffff memory: 22.3 GiB unified: yes
    display-ID: :1.0
  API: Vulkan v: 1.4.313 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3050 6GB Laptop GPU driver: nvidia v: 570.144
    device-ID: 10de:25ac surfaces: N/A device: 1 type: integrated-gpu
    name: Intel Arc Graphics (MTL) driver: mesa intel v: 25.0.5-arch1.1
    device-ID: 8086:7d55 surfaces: N/A
  Device-1: Intel Meteor Lake-P HD Audio vendor: ASUSTeK
    driver: sof-audio-pci-intel-mtl
    alternate: snd_hda_intel,snd_sof_pci_intel_mtl bus-ID: 0000:00:1f.3
    chip-ID: 8086:7e28 class-ID: 0401
  Device-2: NVIDIA GA107 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:2291
    class-ID: 0403
  API: ALSA v: k6.14.6-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
  Device-1: Intel Meteor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 0000:00:14.3 chip-ID: 8086:7e40 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
    vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 0000:2d:00.0
  IF: enp45s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  IF-ID-1: br-47d53651f451 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-2: docker0 state: down mac: <filter>
  IF-ID-3: veth0bfb199 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-4: veth63d0d28 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-5: veth781f7a1 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-6: veth82cad84 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-7: vethadfd92b state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-8: vethd35a70c state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  Info: services: NetworkManager, nginx, systemd-timesyncd
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0033
    class-ID: e001
  Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
    driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:7d0b rev:
    class-ID: 0104
  Local Storage: total: 1.86 TiB used: 51.88 GiB (2.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
    SN740 SDDPNQE-2T00-1102 size: 1.86 TiB block-size: physical: 512 B
    fw-rev: 73113000 temp: 63.9 C scheme: GPT
  ID-1: / raw-size: 200 GiB size: 195.8 GiB (97.90%) used: 51.78 GiB (26.4%)
    fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:9 label: N/A
    uuid: bedd2cd0-00db-486d-88df-c30be3b8747c
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 104.9 MiB (41.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: SYSTEM uuid: 426F-40E3
  ID-1: swap-1 type: partition size: 48 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p10 maj-min: 259:10 label: N/A
    uuid: cd662609-0336-4668-9989-9918554ee7f9
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 757.79 GiB fs: ntfs label: OS
    uuid: F2F470F4F470BC83
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 400 GiB fs: ntfs label: Apps
    uuid: 9A5A2BCC5A2BA3CB
  ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 200 GiB fs: ntfs label: Movies
    uuid: 823CF1D53CF1C3E7
  ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 300 GiB fs: ntfs label: Storage
    uuid: 7636AB0E36AACF05
  ID-6: /dev/nvme0n1p7 maj-min: 259:7 size: 1.42 GiB fs: ntfs
    label: RECOVERY uuid: 84F8F844F8F83650
  ID-7: /dev/nvme0n1p8 maj-min: 259:8 size: 260 MiB fs: vfat label: MYASUS
    uuid: E61A-84D7
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-4: 3-4:2 info: Super Top 4-Port hub ports: 4 rev: 2.0
    chip-ID: 14cd:8601 class-ID: 0900
  Device-1: 3-4.1:4 info: Cypress type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 04b4:6009 class-ID: 0301
  Device-2: 3-4.2:6 info: MosArt Wireless Keyboard/Mouse
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 062a:4101 class-ID: 0301
  Device-3: 3-4.3:7 info: Shenzhen Rapoo Gaming Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 24ae:4111 class-ID: 0301
  Device-4: 3-9:3 info: Shinetech ASUS 5M WebCam type: video,HID
    driver: hid-sensor-hub,usbhid,uvcvideo interfaces: 6 rev: 2.0
  Device-5: 3-10:5 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 57.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1320 pm: pacman pkgs: 1309 libs: 334 tools: pamac pm: flatpak
    pkgs: 0 pm: snap pkgs: 11
    1: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    2: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    3: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    4: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    5: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    6: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    7: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    8: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 480
  1: cpu: 14.0% command: phpstorm pid: 4438 mem: 3526.0 MiB (15.0%)
  2: cpu: 9.0% command: v2raya pid: 920 mem: 586.9 MiB (2.5%)
  3: cpu: 7.5% command: snapd pid: 66326 mem: 30.3 MiB (0.1%)
  4: cpu: 4.4% command: kwin_wayland pid: 1602 mem: 297.7 MiB (1.2%)
  5: cpu: 4.4% command: firefox pid: 2433 mem: 660.5 MiB (2.8%)
  Memory top: 5 of 480
  1: mem: 3526.0 MiB (15.0%) command: phpstorm pid: 4438 cpu: 14.0%
  2: mem: 1147.1 MiB (4.9%) command: telegram-desktop pid: 3267 cpu: 2.8%
  3: mem: 1037.0 MiB (4.4%) command: firefox pid: 2844 cpu: 1.9%
  4: mem: 660.5 MiB (2.8%) command: firefox pid: 2433 cpu: 4.4%
  5: mem: 586.9 MiB (2.5%) command: v2raya pid: 920 cpu: 9.0%
  Processes: 480 Power: uptime: 2h 17m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 9.1 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 15.1.1 Shell: Zsh v: 5.9 running-in: konsole
    inxi: 3.3.38
Hi @hans-thomas, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Those with privacy concerns: note that when -z, or --filter is used, all personally identifiable information is filtered out from the resulting inxi output. :eyes:
Hope you manage!
:bangbang: Tip for legibility: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Note that the above text is partially pre-prepared as a general introduction for new forum users. Please take the time to follow links given and learn how to create effective support requests and encourage quality responses.
I don’t have, want or use a Laptop, so I have no experience with one and might be wrong. But think I’ve found the reason:
I suspect it’s because you are using the incorrect drivers. I think you need the hybrid drivers. Please provide the output of:
mhwd --list
and
mhwd --listinstalled
mhwd --list
> 0000:01:00.0 (0300:10de:25ac) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-prime            2025.01.13               false            PCI
          video-nvidia            2025.01.13               false            PCI
           video-linux            2024.05.06                true            PCI
> 0000:2d:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2023.09.12                true            PCI
> 0000:00:02.0 (0300:8086:7d55) Display controller Intel Corporation:
> Installed PCI configs:
I faced this today, which may be related to this issue.
> sudo tlp-stat -g
[sudo] password for hans:
--- TLP 1.8.0 --------------------------------------------
+++ Nvidia Graphics
/sys/class/drm/card0/device/driver           = nvidia
+++ Intel Graphics
/sys/class/drm/card1/device/driver           = i915
/sys/class/drm/card1/power/rc6_enable        =  1 (enabled)
/sys/kernel/debug/dri/1/i915_fbc_status      = FBC disabled: pixel format not supported
/sys/kernel/debug/dri/1/i915_edp_psr_status  = PSR mode: disabled
/sys/class/drm/card1/gt_min_freq_mhz         =   100 [MHz]
/sys/class/drm/card1/gt_max_freq_mhz         =  2350 [MHz]
/sys/class/drm/card1/gt_boost_freq_mhz       =  2350 [MHz]
/sys/class/drm/card1/gt_RPn_freq_mhz         =   800 [MHz] (GPU min)
/sys/class/drm/card1/gt_RP0_freq_mhz         =  2350 [MHz] (GPU max)
