Hi! Any reason why polkit is being held back and not pulled from Arch directly?
Arch version as of now: 0.120-2
Manjaro package is: 0.119-1
Nope. I guess it got missed. Just pushed 0.120-2 to unstable.
We’re using a patch.
Please update netbeans to 12.5, it was released on 2021-10-04
It’s already flagged out of date. You’ll have to wait for the Arch maintainer to update it
A post was merged into an existing topic: Update requests for packages built by Manjaro developers
IBM has updated ttf-ibm-plex from version 5.2.1 (2021-07-24) to version 6.0.0 (2021-09-28).
Same answer as above. Please read the first post.
Thank you @Yochanan for moving my post to the right topic. I have checked Arch Linux Packages, and yes, the package was already flagged out of date.
Hi
btop needs to be updated (at the least, in Stable repos it’s on version 1.1.0 , but the latest is 1.1.2).
Best system monitor I’ve found so far
I’ve moved your post to the appropriate thread. Please read the first post before making requests.
sorry
I read it, but I thought it wasn’t on arch
my fault
Could we get a quick update for geogebra? The current version is broken (saving a construction is impossible, I just spent half an hour doing a construction which I then wasn’t able to save…): FS#72846 : [geogebra] electron15 breaks sign-in function
The updated package just uses electron14 when building geogebra, otherwise no changes, so no breakage beyond what is already broken should occur: Use electron14 (FS#72846) · archlinux/svntogit-community@4ce8c45 · GitHub
geogebra 6.0.676.0-2 is now available in all branches.
That was real quick, thanks a lot! Looks like the issue is still not fixed but I will comment upstream about it.
mediathekview 13.8.1 contains a security fix to patch CVE-2021-44228 (log4j)
13.8.1-2 contains the patch and is available in the unstable branch.
thank for contribution, but please, read first message, it’s not a manjaro package
(read “Packager”)
And is updated in testing
rebuild-detector 4.3.0 includes bugfix that will help with python 3.10 updates. Please fast-track so stable branch skips 4.2.0 (contains regression, currently in testing)
A post was split to a new topic: Blender is missing compression options when exporting to glTF
