Blender is missing compression options when exporting to glTF: "compression" option missing in the export dialog (Blender 3.0 on manjaro) · Issue #1542 · KhronosGroup/glTF-Blender-IO · GitHub
We get blender from Arch, so you would need to ask the Arch maintainers to include it.
But as draco is currently only in the AUR, it probably won’t happen.
Have you tried installing the AUR package and see if that fixes it?
It did not help unfortunately. It seems it is not coming with the required libextern_draco.so
I tried cheating by symlinking things after install just in case:
ln -s /usr/lib/libdraco.so /usr/bin/libextern_draco.so
and declaring it as an environment variable:
export BLENDER_EXTERN_DRACO_LIBRARY_PATH="/usr/bin"
Blender does get fooled and offers the compression option in the interface, but i get errors in the console when trying to export:
'/usr/bin/libextern_draco.so' exists, draco mesh compression is available
10:20:02 | INFO: Starting glTF 2.0 export
10:20:02 | INFO: Extracting primitive: Cube
10:20:02 | INFO: Primitives created: 1
Python: Traceback (most recent call last):
File "/usr/share/blender/3.0/scripts/addons/io_scene_gltf2/__init__.py", line 637, in execute
return gltf2_blender_export.save(context, export_settings)
File "/usr/share/blender/3.0/scripts/addons/io_scene_gltf2/blender/exp/gltf2_blender_export.py", line 46, in save
json, buffer = __export(export_settings)
File "/usr/share/blender/3.0/scripts/addons/io_scene_gltf2/blender/exp/gltf2_blender_export.py", line 63, in __export
__gather_gltf(exporter, export_settings)
File "/usr/share/blender/3.0/scripts/addons/io_scene_gltf2/blender/exp/gltf2_blender_export.py", line 80, in __gather_gltf
gltf2_io_draco_compression_extension.encode_scene_primitives(scenes, export_settings)
File "/usr/share/blender/3.0/scripts/addons/io_scene_gltf2/io/exp/gltf2_io_draco_compression_extension.py", line 32, in encode_scene_primitives
dll.encoderCreate.restype = c_void_p
File "/usr/lib/python3.10/ctypes/__init__.py", line 387, in __getattr__
func = self.__getitem__(name)
File "/usr/lib/python3.10/ctypes/__init__.py", line 392, in __getitem__
func = self._FuncPtr((name_or_ordinal, self))
AttributeError: /usr/lib/libdraco.so.1: undefined symbol: encoderCreate
I have reported this to Arch, hopefully in the right place: FS#73415 : [blender] Blender 3.0 does not offer compression when exporting to glTF
‘/usr/bin/2.82/python/lib/python3.8/site-packages/libextern_draco.so’ does not exist, draco mesh compression not available
According to this issue, the recommended way is to use the official release on Download — blender.org :
You can also try out the Flatpak version:
indeed the flatpak version works!
