Update requests for packages imported from Arch Linux
Qspectrumanalyzer seems in need to be rebuilt:
Can someone please fasttrack spotify-launcher 0.6 to all branches please?
The .deb changed the compression format of the data, so that the arch wrapper had to be updated too.
Until then start is possible with spotify-launcher --skip-update
Sorry, a convenience package for a music player doesn’t count.
Did nano-syntax-highlighting get rolled back on Testing for a reason?
Why is Testing behind Stable?
https://manjaristas.org/branch_compare?q=nano-syntax-highlighting
It’s not. :wink:
I don’t know if this is the right place for the arm requests. But the X-org server hasn’t been updated from 21.1.13-1.
https://manjaristas.org/branch_compare?q=xorg-server&arm=on
Database last updated on: 2024-11-01 18:45:57 (UTC)
xorg-server
    stable
    21.1.11-1
    testing
    21.1.13-1
    unstable
    21.1.13-1
xorg-server and xorg-server-common have not been updated for x86 Testing branch
Branch compare for Manjaro - xorg-server
stable :21.1.14-0
testing :21.1.13-1
unstable :21.1.14-1
Latest versions of xorg-server packages are included in Testing Update 2024-11-01
Would it be possible to update the nextcloud-client to 2:3.15.0-1?
This would fix a login regression with linux which I’m currently affected by.
skrooge error
skrooge
##FATAL: Cannot mix incompatible Qt library (5.15.15) with this library (5.15.16)
https://bbs.archlinux.org/viewtopic.php?id=301436
skrooge 2.33.0-4 is available from Unstable branch
Branch compare for Manjaro - skrooge
stable :2.33.0-1
testing :2.33.0-1
unstable :2.33.0-4
Since 2.33.0-1 is confirmed broken, I’ll forward 2.33.0-4 to testing & stable as well.
hello!
the spotify-launcher 0.6.0 package that’s in manjaro stable is currently defunct because spotify has rotated their update signing key.
This has happened before (Spotify-launcher does not start - solution), if possible you may want to fast-track the version that’s currently in testing again.
Thank you!
Since this happens on a regular basis and they do not fast track it, a solution is to use the aur package.
Please fast track cairo-dock-plug-ins from unstable to stable. Currently cairo-dock is at 3.5.1 while cairo-dock-plug-ins is still at 3.5.0. This leads to cairo-dock crashing due to version mismatch. See also [Stable Update] 2025-03-05 - Kernels, Plasma 6.3, Cosmic a6, LibreOffice - #37 by unmasked
Yes, the cairo-dock and cairo-dock-plugins packages should have matching versions. It seems there was a few days in between each package being updated that caused the mismatch between branches. I’ll sort that shortly. Thank you for mentioning it.
Related Links:
The upstream ArchLinux packaged vulkan-validation-layers were not working properly, and have been repackaged with a new version 1.4.304.1-2 to fix the problem. But now Manjaro has not been updated and the package still has problems
FYI, both vulkan-utility-libraries and vulkan-validation-layers 1.4.304.1-2 have been available in the Manjaro unstable branch for a week.
Since the updates were belated fixes for existing package versions, I will forward them to the testing and stable branches.
Thank you for letting us know.
I’ve a server running Manjaro and after the last update all my docker containers in different networks were disconnected from outside of their own network. I had to back to iptables-nft 1.8.10-2.
According to bug report number 1087210 in debian bug tracker, it should be fixed in 1.8.11-2, so please, update the package in stable branch as soon as possible.
Thanks!
