Nano-syntax-highlighting in Testing is different to Arch, Unstable and Stable branches
Just updated Firefox and received a nano-syntax-highlighting in local (2022.11.02.r102.gbb94603-1) is newer than in extra (2020.10.10-2) warning. My mirrors are all up-to-date.
A branch compare shows Testing to be the odd one out:
mbn info nano-syntax-highlighting -q
Branch         : archlinux
Version        : 2022.11.02.r102.gbb94603-1
Repository     : extra
Build Date     : Tue 17 Sep 2024 22:49:49
Packager       : Andreas Radke <andyrtr@archlinux.org>
Branch         : unstable
Repository     : extra
Branch         : testing
Version        : 2020.10.10-2
Repository     : extra
Build Date     : Sat 13 Jul 2024 09:51:56
Packager       : T.J. Townsend <blakkheim@archlinux.org>
Branch         : stable
Repository     : extra
As with all examples of newer than you can run pacman -Syuu to align with the repos.
( double u allows downgrades when syncing )
This same thing happened with this package at least one other time in the last few months …
This is going to continue to be likely so long the versioning is the weird vcs style.
Thanks for the fast reply @cscs
As I already have the newer version installed & don’t seem to be experiencing any issues, I won’t bother with running the pacman -Syuu command at the moment.
I just found it a little unusual that the version was rolled back in only the Testing repo.
Oh. Yeah. It is.
I think it is by mistake.
(It also would not be the first time that Testing was skipped … for kernels, etc)
https://manjaristas.org/branch_compare?q=nano-syntax-highlighting
Under just about no circumstances should Testing be behind Stable.
I raised it over on Update requests for packages imported from Arch Linux - #371 by cscs
EDIT.
@scotty65
According to phil … the package was pushed as a fix to stable but not testing. :person_shrugging:
phil’s “explanation” made no sense to me I can’t understand why it is like that even when he thinks he explained it.
