You may need to rebuild any Python packages you’ve installed from the AUR. To get a list of them, you can run:
pacman -Qoq /usr/lib/python3.9
And to rebuild them all at once with an AUR helper such as yay, you can do:
yay -S $(pacman -Qoq /usr/lib/python3.9) --answerclean All
But if any of the packages don’t work with Python 3.10 yet, this might fail halfway through and you’ll have to do rebuild the remaining ones one or a few at a time.
Nothing to complain about aside from usual new Plasma issues that are yet to be covered by upcoming point-releases. The first one is just a batch of some fast-and-easy bugfixes.
My point is: pls don’t let it into Stable yet.
Seems only geoclue thinks the permissions should be 755 but other packages for that directory do not. I’m going to leave the permissions at 750 unless the manjaro team advises us to change it.
pacman -Qo /usr/share/polkit-1/rules.d
/usr/share/polkit-1/rules.d/ is owned by flatpak 1.12.6-1
/usr/share/polkit-1/rules.d/ is owned by fwupd 1.7.5-1
/usr/share/polkit-1/rules.d/ is owned by geoclue 2.6.0-1
/usr/share/polkit-1/rules.d/ is owned by polkit 0.120-4
/usr/share/polkit-1/rules.d/ is owned by systemd 250.3-4
( 8/15) Updating the appstream cache...
** (appstreamcli:8035): WARNING **: 18:38:29.505: Found icon of unknown type 'unknown' in 'system/flatpak/flatpak/cc.nift.nsm/*', skipping it.
✔ Metadata cache was updated successfully.
