Sure, if you didn’t review the .pacnew and merge with your existing file. ![]()
in arch there was need to update alpm-octopi-utils 1.0.2-3…
2 posts were split to a new topic: KDE apps don’t work on LXQt
mediathekview prevents the update of jre-openjdk:
:: installing jre-openjdk (16.0.1.u9-1) breaks dependency 'java-runtime=15' required by mediathekview
That’s odd. The PKGBUILD states it depends on java-runtime>=15, however Pacman shows java-runtime=15:
❯ pacman -Si mediathekview | grep "Depends On"
Depends On : bash hicolor-icon-theme java-runtime=15
Current package in manjaro seems to be an overlay package built by @nightmare-2021 .
Aha! Apparently I haven’t had enough coffee yet this morning.
mediathekview absolutely needs java runtime 15 - it does not work with 16, despite adjustments.
Use the following installer - works perfect.
https://download.mediathekview.de/stabil/MediathekView-latest-linux.sh
Thanks, I ended up using the latest nightly which seems to work with java 16.
Dash to panel v43 is o.K. in unstable AND working in (actual) testing.
Earlier, when I got pacman 6 via update, I got pacman.conf.pacnew with the #ParallelDownloads=5 commented line.
There is the zipped manjaro-kde-21.06-development-unstable-210618-linux510.iso in the Release Release 202106180255 · manjaro-plasma/download · GitHub list. I realized that it’s /etc/pacman.conf lacks the ParallelDownloads option at all: it is completely absent.
If it is right pacman.conf state in the yesterday’s image, then what was the reason to completely remove the option instead of leave all unused but available setting as commented?
I noticed now that linuxXXX-virtualbox-guest is no more in the repositories, should I use virtualbox-guest.iso or is not needed?
The only packages you need on your PC (the host) are virtualbox and linuxXXX-virtualbox-host-modules. Having virtualbox-guest-iso installed is handy as you can mount it in the guest and install the guest-utils. You can also install virtualbox-ext-oracle from the AUR for added functionality.
@nightmare-2021
Probably it is a duplicate, but let it be more know as happens on my PC config also:
while kernel >5.10 installation I got: `WARNING: Possibly missing firmware for module: qat_4xxx`
The PC has the Intel Core i5-8250U CPU.
The warning was present while I was installing linux-5.13-rc6.
Today I got the same warning while I was installing `linux-5.13-rc7`
resolving dependencies...
Package (2) Old Version New Version Net Change Download Size
core/linux513 5.13.rc6.d0613.g009c9aa-1 5.13.rc7.d0620.g13311e7-1 -53.47 MiB 95.49 MiB
extra/qt5-base 5.15.2+kde+r198-1 5.15.2+kde+r199-1 0.00 MiB 13.01 MiB
Total Download Size: 108.50 MiB
Total Installed Size: 165.17 MiB
Net Upgrade Size: -53.47 MiB
:: Retrieving packages...
qt5-base-5.15.2+kde+r199-1-x86_64 13.0 MiB 2.56 MiB/s 00:05 [####################################################################] 100%
linux513-5.13.rc7.d0620.g13311e7-1-x86_64 95.5 MiB 4.20 MiB/s 00:23 [####################################################################] 100%
Total (2/2) 108.5 MiB 4.75 MiB/s 00:23 [####################################################################] 100%
(2/2) checking keys in keyring [####################################################################] 100%
(2/2) checking package integrity [####################################################################] 100%
(2/2) loading package files [####################################################################] 100%
(2/2) checking for file conflicts [####################################################################] 100%
(2/2) checking available disk space [####################################################################] 100%
(1/1) Save Linux kernel modules
(1/2) upgrading linux513 [####################################################################] 100%
(2/2) upgrading qt5-base [####################################################################] 100%
(1/5) Arming ConditionNeedsUpdate...
(2/5) Updating module dependencies...
(3/5) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux513.preset: 'default'
-> -k /boot/vmlinuz-5.13-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.13-x86_64.img
==> Starting build: 5.13.0-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [encrypt]
==> WARNING: Possibly missing firmware for module: qat_4xxx
-> Running build hook: [openswap]
-> Running build hook: [resume]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.13-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux513.preset: 'fallback'
-> -k /boot/vmlinuz-5.13-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.13-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.13-x86_64-fallback.img
(4/5) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-5.13-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.13-x86_64.img
Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
done
(5/5) Restore Linux kernel modules
==> Warning:
-> Kernel has been updated. Modules of the current kernel
-> have been backed up so you can continue to use your
-> computer. However, the new kernel will only work
-> at next boot.
PC was restarted to get rc7 into play.
I started to try to install other kernel versions:
5.10
$ sudo pacman -S linux510
Package (1) New Version Net Change Download Size
core/linux510 5.10.45-1 78.00 MiB 73.28 MiB
Total Download Size: 73.28 MiB
Total Installed Size: 78.00 MiB
linux510-5.10.45-1-x86_64 73.3 MiB 4.42 MiB/s 00:17 [####################################################################] 100%
(1/1) checking keys in keyring [####################################################################] 100%
(1/1) checking package integrity [####################################################################] 100%
(1/1) loading package files [####################################################################] 100%
(1/1) checking for file conflicts [####################################################################] 100%
(1/1) checking available disk space [####################################################################] 100%
(1/1) installing linux510 [####################################################################] 100%
Optional dependencies for linux510
crda: to set the correct wireless channels of your country [installed]
(1/4) Arming ConditionNeedsUpdate...
(2/4) Updating module dependencies...
(3/4) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> Starting build: 5.10.45-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
(4/4) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
done
5.12
$ sudo pacman -S linux512
core/linux512 5.12.12-1 99.85 MiB 95.01 MiB
Total Download Size: 95.01 MiB
Total Installed Size: 99.85 MiB
linux512-5.12.12-1-x86_64 95.0 MiB 1492 KiB/s 01:05 [####################################################################] 100%
(1/1) installing linux512 [####################################################################] 100%
Optional dependencies for linux512
==> Building image from preset: /etc/mkinitcpio.d/linux512.preset: 'default'
-> -k /boot/vmlinuz-5.12-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.12-x86_64.img
==> Starting build: 5.12.12-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.12-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux512.preset: 'fallback'
-> -k /boot/vmlinuz-5.12-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.12-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.12-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.12-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.12-x86_64.img
Found initrd fallback image: /boot/initramfs-5.12-x86_64-fallback.img
done
5.11-rt
$ sudo pacman -S linux511-rt
community/linux511-rt 5.11.4_rt11-1 150.84 MiB 85.90 MiB
Total Download Size: 85.90 MiB
Total Installed Size: 150.84 MiB
linux511-rt-5.11.4_rt11-1-x86_64 85.9 MiB 2.58 MiB/s 00:33 [####################################################################] 100%
(1/1) installing linux511-rt [####################################################################] 100%
Optional dependencies for linux511-rt
==> Building image from preset: /etc/mkinitcpio.d/linux511-rt.preset: 'default'
-> -k /boot/vmlinuz-5.11-rt-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.11-rt-x86_64.img
==> Starting build: 5.11.4-1-rt11-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.11-rt-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux511-rt.preset: 'fallback'
-> -k /boot/vmlinuz-5.11-rt-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.11-rt-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.11-rt-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.11-rt-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.11-rt-x86_64.img
Found initrd fallback image: /boot/initramfs-5.11-rt-x86_64-fallback.img
done
journalctl has only bluetooth error
$ journalctl -p3 -b
-- Journal begins at Sat 2021-06-19 00:17:47 EEST, ends at Mon 2021-06-21 19:53:55 EEST. --
Jun 21 19:25:54 pc pulseaudio[951]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
and probably did not related with the warning while kernel installation.
There are some rare PC micro-freezes for a fraction of a second, did not find the cause yet (not the CPU temperature (currently is 37.0 C as inxi reports) caused).
For now found only general description Kernel 5.11 warning about qat_4xxx firmware / Kernel & Hardware / Arch Linux Forums and [Testing Update] 2021-05-03 - Kernels, Mesa, Nvidia 465.27, VirtualBox, LxQt 0.17, Deepin, Gnome Apps 40.1 - #40 by philm
5.13 release: the same
:: Synchronising package databases...
core 167.6 KiB 361 KiB/s 00:00 [####################################################################] 100%
extra 1902.2 KiB 1889 KiB/s 00:01 [####################################################################] 100%
community 6.6 MiB 4.85 MiB/s 00:01 [####################################################################] 100%
multilib is up to date
Package (1) Old Version New Version Net Change Download Size
core/linux513 5.13.rc7.d0620.g13311e7-1 5.13.0-1 0.25 MiB 95.74 MiB
Total Download Size: 95.74 MiB
Total Installed Size: 100.60 MiB
Net Upgrade Size: 0.25 MiB
linux513-5.13.0-1-x86_64 95.7 MiB 7.25 MiB/s 00:13 [####################################################################] 100%
(1/1) upgrading linux513 [####################################################################] 100%
done
==> Warning:
-> at next boot.
Thanks just installed kernel 5.13 and the new 21.1 Beta
@freggel.doe
Manjaro got the new (5.13 release) kernel done, uploaded to repos, even a user got update and took it into run, but kernel.org still has the outdated rc7 listed. Looks like unusual delay for the kernel.org and fast adapt by Manjaro.
For those of you running an AMD GPU and wonder why the machine is running hot and consumes a lot of power: There is some issue that causes GPU load to be at 99% all the time (pinning it to use max-clockspeed)
Following kernel versions are affected:
5.12.13
5.10.46
5.4.128
Hopefully it’s fixed with the next patch version.
5.13.0 is not affected. It got fixed prior to release.
Looks like folks at kernel.org updated their website
Fixed in currently available kernels
5.12.14
5.10.47
Did not test the older 5.4 kernel.
