KDE apps don't work on LXQt
KDE apps don’t work under LXQt anymore
For example ark:
 ➜ ark
    ark: symbol lookup error: /usr/lib/libKF5KIOWidgets.so.5: undefined symbol: _ZNK5Solid13StorageAccess11isEncryptedEv
I still cannot use any kde app on lxqt
for example dolphin:
➜ dolphin
dolphin: symbol lookup error: /usr/lib/libKF5KIOWidgets.so.5: undefined symbol: _ZNK5Solid13StorageAccess11isEncryptedEv
Is this a fault on my end?
You sure you have all the dependencies installed and that your system is up to date?
Check if kio is the right version (and not a -git package):
$ pacman -Qi kio
Yes, my system is up to date
according to pacman and pamac
I also have all the dependencies installed
Just now explicitly reinstalled every dependency (did not help)
and I have the normal kio installed (not the git version)
➜ pacman -Qi kio
Version         : 5.83.0-1
Description     : Resource and network access abstraction
Architecture    : x86_64
URL             : https://community.kde.org/Frameworks
Licenses        : LGPL
Groups          : kf5
Provides        : None
Depends On      : solid  kjobwidgets  kbookmarks  libxslt  kwallet  ktextwidgets  kded
Optional Deps   : kio-extras: extra protocols support (sftp, fish and more) [installed]
                  kdoctools: for the help kioslave [installed]
                  kio-fuse: to mount remote filesystems via FUSE [installed]
Required By     : baloo  ffmpegthumbs  index  kactivitymanagerd  kdeclarative  kdegraphics-mobipocket  kdegraphics-thumbnailers  kinit  kio-extras  kio-fuse  kmag  kmenuedit  knewstuff  knotifyconfig  kparts  kpimtextedit  krename
                  partitionmanager  plasma-integration
Optional For    : falkon  libreoffice-fresh  nextcloud-client
Conflicts With  : None
Replaces        : None
Installed Size  : 26.04 MiB
Packager        : Antonio Rojas <arojas@archlinux.org>
Build Date      : Sa 12 Jun 2021 11:25:02 CEST
Install Date    : Mo 05 Jul 2021 12:28:07 CEST
Install Reason  : Explicitly installed
Install Script  : No
Validated By    : Signature
kio looks fine - so what’s causing dolphins symbol lookup error? Something does not fit together.
$ pacman -Qi dolphin
$ pacman -Qs '\-git$'
Ok, my bad :sweat_smile:
I used $ pacman -Qs '\-git$' and had solid-git, sonnet-git and attica-git installed
I now have the normal version and KDE apps work again
Thanks and sorry, didn’t realize I still had -git packages.
I had a problem with kio in the past and kio-git was the solution.
After the non git version started working again, apparently I forgot to also use the normal version for all the dependencies
