I get the same error but for octopi:
unable to satisfy dependency ‘pacman<5.3’ required by octopi
For those users who cannot live without pamac, there is an AUR package with the old libalpm12:
https://aur.archlinux.org/packages/libalpm12/
edit:
Same with packagekit and pacutils, both built by @oberon
seems that pacman 6 needs rebuild of yay and octopi 0.11.0-2 with alpm-octopi-utils 1.0.2-3
I like Octopi more than Pamac.
There are still commits for pacman 6 support: Commits · aarnt/octopi · GitHub
but lastest release was
#### [v0.11.0 ]
* on Jan 11
It looks like that we have to remove Octopi for now to install pacman 6
Because AUR Helpers not ready for pacman 6 yet
I got both pacman 6.0 and pamac working. Looks like pamac was rebuilt today to give support for pacman 6.0. Thanks @philm for that!
This is what I did to get them working back again:
That should be it. Enjoy!
I ignored updates of “pacman”, “pacutils”, “pamac-cli”, “pamac-common”, “pamac-gtk” and “yay”. Do the others updates. Later I will see this…
the Pamac problems seems to be fixed now
I also ignored (and then removed) pamac and all its dependencies in order to update. I merged the pacman.pacnew and uncommented the new parallel download function, and the download speed increase is palpable. Paru AUR-helper works with pacman 6, but I’m unable to re-install pamac at this time due to dependency conflicts.
EDIT: After pacman-mirrors refresh and then new update, I am able to re-install pamac, so all is well.
Yep, I think so. Even updating directly from pamac without workarounds should work right now.
Should I remove “packagekit” and “packagekit-qt”?
:: installing pacman (6.0.0-1) breaks the “pacman<5.3” dependency required by packagekit
When trying to update today’s updates from unstable repo, I got (freely translated):
error: couldn't commit transaction (can't resolve dependency)
:: pacman installation (6.0.0-1) will break dependency 'pacman<5.3' required by packagekit
I guess packagekit update that would require pacman 6 dependency is not yet synced in unstable repo? Or maybe is this some kind of omission?
After refresh, the pacman conflict is gone. Thank you
No more package pamac-common?
wine broke for me with todays update, anyone else had the same?
It’s been replaced by libpamac.
Got help from @Strit Multilib got disabled in pacman.conf during the update from pacman 6 from pacman 5 but fixed it now again thanks
Updating manjaro -system today, I get (partial sample of log:)
Upgrading manjaro-system (20210523-1 -> 20210612-1)...
==> Security fix: recreating gnupg keys for pacman
All systems before 21.0.6 release shipped common private keys for pacman!
This might take a while to complete ...gpg: /etc/pacman.d/gnupg/trustdb.gpg: trustdb created
gpg: no ultimately trusted keys found
gpg: starting migration from earlier GnuPG versions
gpg: porting secret keys from '/etc/pacman.d/gnupg/secring.gpg' to gpg-agent
gpg: migration succeeded
==> Generating pacman master key. This may take some time.
gpg: Generating pacman keyring master key...
gpg: key A4B28660A9E43C29 marked as ultimately trusted
gpg: directory '/etc/pacman.d/gnupg/openpgp-revocs.d' created
gpg: revocation certificate stored as '/etc/pacman.d/gnupg/openpgp-revocs.d/635ED7E4AB9EC962B0095E6CA4B28660A9E43C29.rev'
gpg: Done
==> Updating trust database...
gpg: marginals needed: 3 completes needed: 1 trust model: pgp
gpg: depth: 0 valid: 1 signed: 0 trust: 0-, 0q, 0n, 0m, 0f, 1u
==> Appending keys from archlinux.gpg...
==> Appending keys from manjaro.gpg...
==> Locally signing trusted keys in keyring...
gpg: checking the trustdb
gpg: key 786C63F330D7CB92: no user ID for key signature packet of class 10
Is this okay or do I have an issue here?
Just a heads up:
This might take a while to complete ...gpg: /etc/pacman.d/gnupg/trustdb.gpg: trust-db erzeugt
see
