Servus, ich habe eine Problem mit der Tutanota App seit dem letzten update. Egal ob ich die tutanota-desktop-bin aus dem AUR verwende oder das APPImage direkt von der Seite, immer bekomme ich ein weisses Bild ohne Anmeldemaske oder ähnliches.
So sieht es aus wenn ich das AppImage starte
─swh@kde ~/Applications
╰─$ ./tutanota-desktop-linux_590f7839f256d02d0050f1b43da81f44.AppImage
qt.svg: /home/swh/.config/Kvantum/Fluent-round/Fluent-round.svg:7858:6: Could not resolve property: #paint0_linear
the monkey has been patched
(node:25946) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
(Use `tutanota-desktop --trace-deprecation ...` to show where the warning was created)
version: 3.91.10
resolving key... tutanota-vault
config up to date
Failed to resolve/generate key: tutanota-vault [Error: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.secrets was not provided by any .service files]
libva error: /usr/lib/dri/iHD_drv_video.so init failed
[25985:0217/165820.779035:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
sseInfo corrupted or not present, making sure pushEncSessionKeys and scheduled alarms are cleared
Resetting stored state
[ApplicationWindow] startFile: file:///tmp/.mount_tutanoR1Et82/resources/app.asar/index-desktop.html
[DownloadManager] getting dictionaries from: https://mail.tutanota.com/desktop/dictionaries/
default mailto handler: false
[DownloadManager] spellcheck-dictionary-initialized de
invalidating alarms for all windows
invalidating alarms for window 1
[25946:0217/165823.211419:ERROR:browser_main_loop.cc(269)] Gtk: gtk_widget_add_accelerator: assertion 'GTK_IS_ACCEL_GROUP (accel_group)' failed
[25946:0217/165823.278016:ERROR:browser_main_loop.cc(269)] Gtk: gtk_widget_add_accelerator: assertion 'GTK_IS_ACCEL_GROUP (accel_group)' failed
Webapp ready
[25946:0217/165823.472922:ERROR:browser_main_loop.cc(269)] Gtk: gtk_widget_add_accelerator: assertion 'GTK_IS_ACCEL_GROUP (accel_group)' failed
autoUpdater info:
Checking for update
autoUpdater info:
checking-for-update
desktop file exists, checking version...
scheduling to check sse in 1 seconds
resolving key... tutanota-credentials
Failed to resolve/generate key: tutanota-credentials [Error: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.secrets was not provided by any .service files]
autoUpdater info:
Update for version 3.91.10 is not available (latest version: 3.91.10, downgrade is disallowed).
autoUpdater info:
update not available: {
version: '3.91.10',
files: [
url: 'tutanota-desktop-linux.AppImage',
sha512: 'A72JpH256AtCOUgFTD5rzooJtnoueLo/8ukUp15Jz1Ojjp5aMfwYkkD5AxsrC8cn7OYYzlsHcEqk4S3w5waZIQ==',
blockMapSize: 146839
path: 'tutanota-desktop-linux.AppImage',
releaseDate: '2022-02-09T09:41:05.446Z',
signature: 'elw4nfAiQbCAn9V2aWhn5xPrPtPP/dLqAk1lmN+I4tk7MmbhXnlRgAfDOy1uLNvtfDgJcYUwuGfOH52po942nojBbrcxS1a/0E3w6Kx4Wd9Ad0bwEM6sGMYzKn7WCHpN6O4hTbEIh/MZhs9KKB89t5WWriu9Um7MrX/MfwmIGqcqCysskn6fbIdGuhKInSn2SAtOSYzuJ4raS5zgGGbcxCYLC7qA38/ycY5pmUzDhI+1EGtR76CX2gGwWeSp+A2tpMVI2aZIZTcANm3FcHqiZdqO44ZCu3oM4KphTilWxTkHVCK9NrkF+H4bDZAK0fM6yF/exyvRgp7b35vPZG1QAw=='
scheduling to check sse in 10 seconds
sse info not available, skip reconnect
^C
[25946:0217/165846.829105:ERROR:browser_main_loop.cc(269)] Gtk: gtk_widget_add_accelerator: assertion 'GTK_IS_ACCEL_GROUP (accel_group)' failed
Und das ist die Ausgabe wenn ich tutanota-desktop-bin starte
╭─swh@kde /opt/tutanota-desktop
╰─$ tutanota-desktop
(node:26157) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
version: 3.91.10
config up to date
[26193:0217/170048.522508:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
[ApplicationWindow] startFile: file:///opt/tutanota-desktop/resources/app.asar/index-desktop.html
[26157:0217/170051.218473:ERROR:browser_main_loop.cc(269)] Gtk: gtk_widget_add_accelerator: assertion 'GTK_IS_ACCEL_GROUP (accel_group)' failed
[26157:0217/170051.284033:ERROR:browser_main_loop.cc(269)] Gtk: gtk_widget_add_accelerator: assertion 'GTK_IS_ACCEL_GROUP (accel_group)' failed
Webapp ready
[26157:0217/170051.379811:ERROR:browser_main_loop.cc(269)] Gtk: gtk_widget_add_accelerator: assertion 'GTK_IS_ACCEL_GROUP (accel_group)' failed
autoUpdater info:
Checking for update
autoUpdater info:
checking-for-update
autoUpdater info:
autoUpdater info:
version: '3.91.10',
files: [
^C[26157:0217/170103.777016:ERROR:browser_main_loop.cc(269)] Gtk: gtk_widget_add_accelerator: assertion 'GTK_IS_ACCEL_GROUP (accel_group)' failed
Ich bin nicht so fit um zu verstehen was die Ausgabe bedeutet. Vielleicht findet sich jemand der ein ähnliches Problem hatte oder mir in irgendeiner Form seine Hilfe anbieten könnte.
Danke im vorraus!
