Hello,
Thank you for your responses and for guiding me on how to provide the necessary information. I apologize for not including all the required details initially.
Here is the output of the inxi --admin --verbosity=8 --filter --no-host --width command as requested:
Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=455bde0e-83ac-42d5-af69-d7d038e5d75f rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Laptop System: HP product: HP Pavilion Laptop 15-eg2xxx v: N/A
Mobo: HP model: 89F7 v: 14.27 serial: <superuser required>
part-nu: 6W540UAR#ABA uuid: <superuser required> UEFI: AMI v: F.14
date: 11/08/2023
ID-1: BAT0 charge: 33.1 Wh (100.0%) condition: 33.1/41.0 Wh (80.7%)
volts: 12.5 min: 11.3 model: HP Primary type: Li-ion serial: <filter>
status: full cycles: 198
System RAM: total: 16 GiB available: 15.29 GiB used: 2.81 GiB (18.4%)
Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
Device-1: Bottom - Slot 1 (left) type: DDR4 detail: synchronous size: 8 GiB
speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: Samsung part-no: M471A1K43EB1-CWE
serial: <filter>
Device-2: Bottom - Slot 2 (right) type: DDR4 detail: synchronous
size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: Samsung
part-no: M471A1K43EB1-CWE serial: <filter>
Info: model: 12th Gen Intel Core i7-1255U bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x435
Topology: cpus: 1x dies: 1 clusters: 4 cores: 10 threads: 12 mt: 2 tpc: 2
st: 8 smt: enabled cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32
KiB, 8x64 KiB L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 400 min/max: 400/4700:3500 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 62688
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs
pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
sdbg sep serialize sha_ni smap smep smx split_lock_detect ss ssbd sse sse2
tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel alternate: xe arch: Gen-12.2 process: Intel 10nm
built: 2021-22+ ports: active: HDMI-A-1,eDP-1 empty: DP-1, DP-2, DP-3, DP-4
bus-ID: 00:02.0 chip-ID: 8086:46a8 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce MX550] vendor: Hewlett-Packard
driver: nvidia v: 550.135 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 4 speed: 16 GT/s lanes: 4
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f9f class-ID: 0302
Device-3: Luxvisions Innotech HP Wide Vision HD Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2
chip-ID: 30c9:0065 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia unloaded: nouveau
alternate: fbdev,nv,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: right model: 24N5C serial: <filter>
built: 2023 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2 chroma: red: x: 0.655
y: 0.329 green: x: 0.220 y: 0.682 blue: x: 0.149 y: 0.051 white: x: 0.310
y: 0.329 size: 523x293mm (20.59x11.54") diag: 600mm (23.6") ratio: 16:9
modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x720,
1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
Monitor-2: eDP-1 pos: primary,left model: ChiMei InnoLux 0x1544 built: 2021
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 chroma: red: x: 0.592 y: 0.349
green: x: 0.329 y: 0.557 blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
modes: 1920x1080
EDID-Warnings: 1: parse_edid: unknown flag 2
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a8 memory: 7.47 GiB unified: yes
API: Vulkan v: 1.4.303 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce MX550 driver: N/A device-ID: 10de:1f9f
surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel Graphics
(ADL GT2) driver: N/A device-ID: 8086:46a8 surfaces: xcb,xlib
Device-1: Intel Alder Lake PCH-P High Definition Audio
vendor: Hewlett-Packard driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0401
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-10:3 chip-ID: 13d3:3567
Local Storage: total: 476.94 GiB used: 99.26 GiB (20.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: BC711 HFM512GD3JX013N size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS1 temp: 26.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 99.26 GiB (21.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 455bde0e-83ac-42d5-af69-d7d038e5d75f
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 98C8-3A2D
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-2:5 info: Logitech G102/G203 LIGHTSYNC Gaming Mouse
type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
chip-ID: 046d:c092 class-ID: 0300 serial: <filter>
Device-2: 3-3:2 info: Luxvisions Innotech HP Wide Vision HD Camera
type: video driver: uvcvideo interfaces: 2 rev: 2.0
Device-3: 3-10:3 info: IMC Networks Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 13d3:3567 class-ID: e001 serial: <filter>
System Temperatures: cpu: 32.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0 fan-2: 0
Packages: pm: pacman pkgs: 1267 libs: 360 tools: pamac,yay pm: flatpak
pkgs: 0
1: http://mirror.fcix.net/manjaro/stable/$repo/$arch
2: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
5: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
6: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
7: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
8: http://manjaro.grena.ge/stable/$repo/$arch
Processes:
CPU top: 5 of 281
1: cpu: 26.7% command: firefox pid: 1362 mem: 499.7 MiB (3.1%)
2: cpu: 11.0% command: firefox pid: 1633 mem: 247.1 MiB (1.5%)
3: cpu: 9.9% command: konsole pid: 2053 mem: 224.0 MiB (1.4%)
4: cpu: 6.8% command: kwin_x11 pid: 862 mem: 191.9 MiB (1.2%)
5: cpu: 5.9% command: zsh pid: 2077 mem: 9.63 MiB (0.0%)
Memory top: 5 of 281
1: mem: 499.7 MiB (3.1%) command: firefox pid: 1362 cpu: 26.7%
2: mem: 409.2 MiB (2.6%) command: plasmashell pid: 901 cpu: 2.7%
3: mem: 247.1 MiB (1.5%) command: firefox pid: 1633 cpu: 11.0%
4: mem: 225.5 MiB (1.4%) command: firefox pid: 1739 cpu: 1.6%
5: mem: 224.0 MiB (1.4%) command: konsole pid: 2053 cpu: 9.9%
Processes: 281 Power: uptime: 5m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 6.09 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
running-in: konsole inxi: 3.3.36
If you need additional information or output from other diagnostic commands, please let me know, and I will provide it promptly.
Thank you for your assistance!
Best regards,
Caleb Mora
