I have just installed Manjaro Linux on a Lenovo Ideapad 3 laptop.
The touchpad doesn’t work, it’s just like it didn’t exist. The USB mouse works fine.
If I go to System Settings → input devices → Touchpad it says “touchpad not found”.
Any ideas?
$ inxi --full --admin --verbosity=7 --filter --no-host ✔
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "en_US.UTF-8",
LC_IDENTIFICATION = "en_US.UTF-8",
LC_MEASUREMENT = "en_150.UTF-8",
LC_MONETARY = "es_ES.UTF-8",
LC_NAME = "en_US.UTF-8",
LC_NUMERIC = "en_US.UTF-8",
LC_PAPER = "en_US.UTF-8",
LC_TELEPHONE = "en_US.UTF-8",
LC_TIME = "en_150.UTF-8",
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
Kernel: 5.15.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=1a215379-e21a-47c1-9171-67e1681ddbdf rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
Type: Laptop System: LENOVO product: 81WE v: IdeaPad 3 15IIL05
serial: <superuser required> Chassis: type: 10 v: IdeaPad 3 15IIL05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: EMCN14WW date: 05/11/2020
ID-1: BAT0 charge: 42.1 Wh (100.0%) condition: 42.1/45.0 Wh (93.6%)
volts: 12.6 min: 11.3 model: Celxpert L19C3PF7 type: Li-poly
serial: <filter> status: full cycles: 12
RAM: total: 7.33 GiB used: 3.98 GiB (54.3%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 built: 2019-21 process: Intel 10nm family: 6
model-id: 0x7E (126) stepping: 5 microcode: 0xB2
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3826 high: 3900 min/max: 400/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 3899 2: 3801 3: 3803
4: 3803 5: 3900 6: 3802 7: 3800 8: 3807 bogomips: 23968
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm
fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdtscp rep_good sdbg sep sgx sgx_lc sha_ni smap smep
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes
vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Iris Plus Graphics G7 vendor: Lenovo driver: i915 v: kernel
arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: HDMI-A-1
off: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:8a52 class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-5:4 chip-ID: 174f:118d class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary model: Samsung S24D330
serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 note: disabled model: BOE Display 0x0812 built: 2018
res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT2) v: 4.6 Mesa
22.1.7 direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.65-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.57 running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: TP-Link UE300 10/100/1000 LAN (ethernet mode) [Realtek RTL8153]
type: USB driver: r8152 bus-ID: 1-9:5 chip-ID: 2357:0601 class-ID: 0000
serial: <filter>
IF: enp0s20f0u9 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:6 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 24.54 GiB (5.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFM512GDHTNI-87A0B size: 476.94 GiB block-size: physical: 512 B
rev: 11010C00 temp: 36.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 24.54 GiB
(5.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 1a215379-e21a-47c1-9171-67e1681ddbdf
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
uuid: D3B1-36E9
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: EzKEY USB to PS2 Adaptor v1.09 type: Keyboard,Mouse
power: 100mA chip-ID: 0518:0001 class-ID: 0301
Device-2: 1-2:3 info: Logitech Wireless Receiver type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 50mA chip-ID: 046d:c542 class-ID: 0301
Device-3: 1-5:4 info: Syntek Integrated Camera type: Video
Device-4: 1-9:5 info: TP-Link UE300 10/100/1000 LAN (ethernet mode)
[Realtek RTL8153] type: Network driver: r8152 interfaces: 1 rev: 2.1
speed: 480 Mb/s power: 180mA chip-ID: 2357:0601 class-ID: 0000
serial: <filter>
Device-5: 1-10:6 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 62.0 C mobo: N/A
Processes: 261 Uptime: 20h 24m wakeups: 11 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1328 libs: 356 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.21
