Issues with starting Live USB Manjaro on HP Omen 16 (16-u0190nd)
Hi everyone,
I’m newbie on this forum and sorry don’t know how to properly address the issue on the forum.
I recently bought a new laptop HP Omen 16 (16-u0190nd).
And now I’m trying to launch first the Live USB and then the installation of Manjaro (manjaro-cinnamon-23.0.1-230921-linux65.iso) on this laptop.
Unfortunately, I faiced with following issue, Manjaro Linux does not always start from Live USB.
There is no question of launching with proprietary drivers, so I tried to launch with opensource drivers.
But even in this case, Manjaro sometimes starts and sometimes it doesn’t, and unfortunately I don’t quite understand how to influence this situation.
For some reason I can attach screenshots to the post :frowning:
But Live USB starts freeze on:
Failed to Start User Login Manager
That is because we don’t want screenshots - only text.
Failed to start Login Manager is usually caused by GPU drivers.
Please search the forum for other mentions of your device - possibly it is because you choose an old community ISO - try one of the official ISO dated 241223 with Linux 6.6. kernel.
I know it is the one available with Cinnamon - but it is a community edition and not updated very often.
Hi @jury.borisov, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Please and do this:
I was looking for a mention of my device, but it looks like I’m the first one to come up with this issue.
[quote=“linux-aarhus, post:3, topic:154182”]
[/quote]
Could you please share link to download?
You can use Manjaro Downloads or an automation tool
Thanks for provided links
I tried the following iso images:
manjaro-gnome-23.1.1-231223-linux66.iso
manjaro-kde-23.1.1-231223-linux66.iso
manjaro-xfce-23.1.1-231223-linux66.iso
And all with approximately the same result.
When starting from a USB flash drive, the launch of Manjaro freezes in the same place.
I tried several flash drives and ways to write an iso image to a flash drive (rufus and ventoy) but result is the same.
I also tried turning off the video card in settings of UEFI and using only discrete video adapter but result is the same.
I don’t know - I only use hardware where I am sure it is working with Linux.
Most systems is designed to work with windows and may require tweaking to work with LInux - which is why I do some research before bying hardware.
Thanks for reply,
Maybe I need to make some changes in boot options?
There’s no way to know without knowing more about the errors.
But this might help some:
Possibly - have you tried a search engine?
