Hello Manjaro user community, here we have another set of package updates. This marks the third point release of 26.1 series.
Note: I’ve super limited time to do Manjaro these days. So expect delayed response from me or none at all …
Recent News
New in Manjaro GNOME!
When choosing an accent color in Settings, the folder colors will now change automatically to match when using the Papirus Dark or Papirus Light icon theme.
To try it out, install gnome-shell-extension-papirus-folders-colorizer from Add/Remove Software, logout / login and enable Papirus Folder Colorizer from Extensions.
Or, if you prefer the command line:
Install:
sudo pacman -Syu gnome-shell-extension-papirus-folders-colorizer
Enable the extension:
gnome-extensions enable papirus-folders-colorizer@NiffirgkcaJ.github.com
Logout:
gnome-session-quit --logout
Also, when applying accent colors from Layout Switcher settings, it will also set the matching folder color. Requires accent-color-change r172.c761c84-2 or newer.
KDE Plasma users with SDDM can now migrate to Plasma Login Manager
After ensuring plasma-login-manager 6.5.90-1 (or newer) is installed, run the following:
sudo pacman -Syu plasma-login-manager
systemctl disable sddm
systemctl enable plasmalogin
sudo pacman -R sddm-kcm sddm
NVIDIA 590 driver drops Pascal support
With the update to driver version 590, the NVIDIA driver no longer supports Pascal (GTX 10xx) GPUs or older.
Impact: Updating the NVIDIA packages on systems with Pascal, Maxwell, or older cards will fail to load the driver, which may result in a broken graphical environment.
Intervention required for Pascal/older users: Users with GTX 10xx series and older cards must switch to a legacy driver to maintain support:
- Install the official
linuxXXX-nvidia-580xx, or related DKMS packages.
- Manjaro 26.1 Bian-May - released
- Manjaro 26.0 Anh-Linh released
- Manjaro Summit public Alpha now available
- As of Linux 6.16.12, the 6.16 series is now EOL (End Of Life). Please install 6.18 LTS (Long Term Support) and/or 6.12 LTS.
- As of Linux 6.17.13, the 6.17 series is now EOL (End Of Life). Please install 6.18 LTS (Long Term Support) and/or 6.12 LTS.
- As of Linux 6.19.14, the 6.19 series is now EOL (End Of Life). Please install 7.2, and/or 6.18 LTS (Long Term Support) and/or 6.12 LTS.
- As of Linux 7.0.14, the 7.0 series is now EOL (End Of Life). Please install 7.2, and/or 6.18 LTS (Long Term Support) and/or 6.12 LTS.
- As of Linux 7.1.13, the 7.1 series is now EOL (End Of Life). Please install 7.2, and/or 6.18 LTS (Long Term Support) and/or 6.12 LTS.
Previous News
Notable Package Updates
Additional Info
Python 3.14 info
You will need to rebuild any AUR Python packages that install files to site-packages or link to libpython3.13.so.
Rebuild them all at once:*
checkrebuild
Info about AUR packages
AUR (Arch User Repository) packages are neither supported by Arch nor Manjaro. Posts about them in Announcements topics are off-topic and will be flagged, moved or removed without warning.
Our current supported kernels
- linux61 6.1.187
- linux66 6.6.156
- linux612 6.12.109
- linux618 6.18.50
- linux71 7.1.13 [EOL]
- linux72 7.2.4
- linux73 7.3.0-rc3
- linux61-rt 6.1.182_rt67
- linux66-rt 6.6.151_rt78
- linux612-rt 6.12.100_rt20
Package Changes (9/10/26 14:06 CEST)
- testing core x86_64: 17 new and 17 removed package(s)
- testing extra x86_64: 1910 new and 1902 removed package(s)
A list of all package changes can be found here
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes I am currently experiencing an issue due to the update. (Please post about it)
