[Testing Update] 2026-10-07 - Kernels, Mesa, NVIDIA, GNOME 50.5
Hello Manjaro user community, here we have another set of package updates.
Recent News
Linux 7.1 series is now EOL
As of Linux 7.1.13, the 7.1 series is now EOL (End Of Life). Please install 7.2, and/or 6.18 LTS (Long Term Support) and/or 6.12 LTS.
New for Cinnamon users
As of Xreader 4.6.7, ePub support was removed and a new XApp called Xepub was added for ePub support. There’s also a new calendar application called Clockenstein.
Mkinitcpio >=42 requires manual intervention for TPM2-based unlocking of LUKS devices
2026-09-22 - David Runge
Starting with package version 42-1, the mkinitcpio systemd hook now includes systemd-pcrosseparator.service (as intended by systemd v261).
This affects the measurements of PCR values 0-7, 9 and 12-14. If you configured the systemd hook and unlock LUKS partitions, that depend on these values, you need to re-enroll the TPM2 in use.
For guidance, please refer to systemd-cryptenroll(1), or the ArchWiki article on systemd-cryptenroll, when using pinned values. Refer to systemd-pcrlock(8), when relying on custom policies and a disabled systemd-pcrlock-make-policy.service.
– Arch Linux - News: Mkinitcpio >=42 requires manual intervention for TPM2-based unlocking of LUKS devices
Notable Package Updates
Additional Info
Python 3.14 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux61 6.1.189
  • linux66 6.6.158
  • linux612 6.12.112
  • linux618 6.18.55
  • linux72 7.2.9
  • linux73 7.3.0-rc6
  • linux61-rt 6.1.182_rt67
  • linux66-rt 6.6.151_rt78
  • linux612-rt 6.12.100_rt20
Package Changes
  • testing core x86_64: 89 new and 89 removed package(s)
  • testing extra x86_64: 4443 new and 4577 removed package(s)
  • testing multilib x86_64: 51 new and 50 removed package(s)
A list of all package changes can be found here
  • Yes I am currently experiencing an issue due to the update. (Please post about it)
0 voters
Known issues and solutions
:arrow_right: 2026-10-07
2026-08-24
tar backup/restore scripts have been moved to tar-scripts
tar package no longer ships the helper scripts /usr/bin/backup and /usr/bin/restore.
If you rely on these tools, install tar-scripts
The core tar archiving utility itself is unaffected.
2026-05-11
Dirty Frag vulnerability
A week after Copy Fail, researcher Hyunwoo Kim disclosed a second Linux kernel flaw in the same broad area — IPsec ESP and rxrpc — that they have named Dirty Frag. The bug lives in the in-place decryption fast paths of esp4, esp6, and rxrpc: when a socket buffer carries paged fragments that are not privately owned by the kernel (e.g. pipe pages attached via splice(2)/sendfile(2)/MSG_SPLICE_PAGES), the receive path decrypts directly over those externally-backed pages, exposing or corrupting plaintext that an unprivileged process still holds a reference to.
Like the previous Copy Fail vulnerability, Dirty Frag immediately yields root on all major distributions. Every supported Manjaro release is affected. Dirty Frag chains two distinct kernel bugs, each with its own CVE: CVE-2026-43284 covers the IPsec ESP half (esp4 / esp6), and CVE-2026-43500 (NVD entry pending) covers the rxrpc half. Per Hyunwoo Kim’s public disclosure on oss-security (2026-05-07), the responsible-disclosure embargo was broken before distributions could coordinate, and a working exploit is publicly available. A second public exploit, Copy Fail 2: Electric Boogaloo, targets the same vulnerability under a different name; both reach root through the same esp4/esp6/rxrpc code paths and are blocked by the same fix.
Temporary mitigation
You can neutralize the attack surface by blacklisting the affected modules. None of esp4, esp6, or rxrpc are loaded on a typical workload that does not use IPsec transport mode or AFS, so on most systems this is safe to apply immediately:
sudo sh -c "printf 'install esp4 /bin/false\ninstall esp6 /bin/false\ninstall rxrpc /bin/false\n' > /etc/modprobe.d/dirtyfrag.conf; rmmod esp4 esp6 rxrpc 2>/dev/null; true"
This writes a modprobe config that prevents the three modules from loading, and unloads them if they happen to be loaded already (the rmmod is best-effort and silent if the module isn’t present). To revert, remove /etc/modprobe.d/dirtyfrag.conf.
The Dirty Frag exploit works by corrupting page-cache pages of sensitive files (such as /etc/passwd or /usr/bin/su). If you suspect the system may have already been targeted before you applied the mitigation, drop the page cache so any tampered pages are evicted and the next read comes fresh from disk:
sudo sh -c 'echo 3 > /proc/sys/vm/drop_caches'
This is safe to run on a live system — it only frees clean cache and dentry/inode entries — and pairs well with the blacklist above.
2026-05-01
On 29 April 2026, a high local privilege escalation vulnerability in the Linux kernel, tracked as CVE-2026-31431 and named “Copy Fail”, was publicly disclosed. The vulnerability affects Manjaro Linux since 2017. A public proof-of-concept exploit has been released.
We have patched most of our kernels and released them to our testing and unstable branches:
  • patched kernels are: 5.10.254+, 5.15.204+, 6.1.170+, 6.6.137+, 6.12.85+, 6.18.22+, 6.19.12+, 7.0-rc7+
  • affected kernels are: 6.1.167_rt62, 6.6.133_rt73, 6.12.79_rt17, 6.17.5_rt7 and lower
Temporary Mitigation
Disable the algif_aead kernel module persistently on all affected systems until a patched kernel is available:
sudo su
echo "install algif_aead /bin/false" > /etc/modprobe.d/disable-algif.conf
rmmod algif_aead 2>/dev/null || true
exit
More Information: CERT-EU - High Vulnerability in the Linux Kernel ("Copy Fail")
Previous testing threads:
Had to manually remove lib32-fluidsynth which was linked to lib32-openal so removed that too, both seem to be moved to AUR, anyway once removed update worked fine.
Also just checked and had about another 8 or 9 packages moved to AUR, mostly lib32 packages, have now removed them all.
I’m off to test the Nvidia Driver and hope it’s as good as people are saying it is.
No issues. Just wanted to say thank you to @Yochanan for your hard work.
about version Grub 2.16 , that now support btrfs
you will have to add theses two lines after
#GRUB_DISABLE_OS_PROBER=false
it should be
GRUB_DISABLE_OS_PROBER=true
GRUB_DISABLE_UEFI_FIRMWARE=false
GRUB_DISABLE_BOOTNEXT=true
…should be pinned.
source:[Unstable Update] October 2026 - #8 by Yochanan
or this one
and not forget to update
sudo grub-mkconfig -o /boot/grub/grub.cfg
I update my Manjaro Linux Testing on VirtualBox. It uses EFI boot and btrfs filing system.
After system reboot the following error Message appears on a black screen:
Error: commands/loadenv.c:check_blocklists:289:sparse file not allowed.
After some seconds, the system starts as usual. This message did not appear before the update. I don’t know if that’s a message from the VirtualBox boot or from GRUB.
Don’t use BTRFS in a virtual machine. These posts might help explain better than I can:
Thank you for your hints.
Changing /etc/default/grub to:
GRUB_SAVEDEFAULT=false
GRUB_DEFAULT=0
solved the issue.
I always choose btrfs when I install Manjaro and had never any problems from that decision.
Was enough on my system
Can someone explain these changes
My current grub file
GRUB_CMDLINE_LINUX_DEFAULT='quiet splash resume=UUID=3b1f599f-b3c9-4d04-a178-886229f403e7 udev.log_priority=3'
The pacnew
GRUB_CMDLINE_LINUX_DEFAULT="loglevel=3 quiet rd.udev.log_level=3"
The logging changes. I’m not interested in the Theme changes.
From reading this
Kernel parameters
Change the kernel parameters using the configuration options of your boot loader, to include the following parameters:
quiet
Note
Adding vga=current as a kernel argument avoids weird behaviors like FS#32309. Keep in mind that this conflicts with KMS, so only use this argument if you are affected by said bug.
If you are still getting messages printed to the console, it may be dmesg sending you what it thinks are important messages. You can change the level at which these messages will be printed by using quiet loglevel=level, where level is any number between 0 and 7, where 0 is the most critical, and 7 is debug levels of printing.
quiet loglevel=3
Note that this only seems to work if both quiet and loglevel=level are used, and they must be in that order (quiet first). The loglevel parameter will only change that which is printed to the console, the levels of dmesg itself will not be affected and will still be available through the journal as well as dmesg. For more information, see kernel parameters.
If you also want to stop systemd from printing its version number when booting, you should also append udev.log_level=3 to your kernel parameters. If systemd is used in an initramfs, append rd.udev.log_level=3 instead. See systemd-udevd.service(8) § KERNEL COMMAND LINE for details.
If you are using the systemd hook in the initramfs, you may get systemd messages during initramfs initialization. You can pass systemd.show_status=false to disable them, or systemd.show_status=auto to only suppress successful messages (so in case of errors you can still see them). Actually, auto is already passed to systemd.show_status=auto when quiet is used, however for some motive sometimes systemd inside initramfs does not get it. Below are the parameters that you need to pass to your kernel to get a completely clean boot with systemd in your initramfs:
quiet loglevel=3 systemd.show_status=auto rd.udev.log_level=3
Also touch ~/.hushlogin to remove the Last login message.
Users of plymouth must use both the quiet and splash kernel parameter, otherwise the details fallback theme is used and shows systemd messages.
I can not see any reason why I need to impliment those changes.
Not even
GRUB_CMDLINE_LINUX_DEFAULT="quiet loglevel=3 rd.udev.log_level=3"
Otherwise I had no problems with the update, and the reboot went perfectly, I have not applied those changes.
Update again before touching the pacnew, I just pushed 2:2.16-3 and the new default is:
quiet must be before loglevel for it to work and rd.udev.log_level must be used when systemd is used in the initramfs.
See Silent boot - ArchWiki and the related discussion in the Unstable Update thread.
A post was split to a new topic: How to revert back to [kernel] 7.1?
After the update, the system would no longer boot in EFI mode. Instead, there was a black screen and the following message:
error: kern/dl.c:grub_dl_resolve_symbols:403:symbol ´ grub_user_error' not found. Entering rescue mode... grub rescure>
Fortunately, it booted successfully after I restarted with EFI disabled in the BIOS.
Banjo’s suggestion mentioned earlier did not solve the problem.
It still won’t boot in EFI mode
I am still not seeing any behaviour on my computer that suggests I need to implement the grub.pacnew.
After reading the documentation. I am still at a loss as to what improvements this should make to may boot.
None it would appear.
Updating grub appears to have added slew of additional options, including a DVD (boot next). I don’t have a DVD player.
From what I’ve read today.
The new options in grub.pacnew just disable superfluous console output, particularly noticeable if your using plymouth from what I understand.
I’m half guessing here because the GRUB documentation doesn’t seem to have been updated, but do you mean there are additional menu options in GRUB? If so the GRUB_DISABLE_BOOTNEXT=true disables those options. It is my understanding that unless you’re dual booting with Windows (or other edge dual boot cases) you should set this option so it doesn’t display.
Interesting I am using Plymouth, and see no difference. The top left corner of the screen still flashes something on the screen, then it’s gone.
It’s not an issue, but, that appears to have made no difference, either.
Ran the update on my system and the update process obviously ran update-grub adding the extra BootNext entries. I then added GRUB_DISABLE_BOOTNEXT=true to /etc/default/grub and ran update-grub again, and it skips BootNext and doesn’t create those entries.
The other options don’t seem to make any difference on my system either.
:grimacing: I forgot to run update-grub i blame the Dog
Does anyone have any idea why it won’t boot in UEFI mode?
