Manjaro 26.1 Bian-May - released
Manjaro 26.1
Since we released Anh-Linh in January 2026 we worked hard to get the next release of Manjaro out there. We call it Bian-May.
The GNOME edition has received several updates to Gnome 50 series. This includes a lot of fixes and polish when Gnome 50 originally was released in March 2026. You can find find release dates of each upcoming point-release here: Release Calendar. Weekly updates around GNOME can be found here.
Highlights of 50 release series are:
GNOME’s parental controls have made a massive leap forward in GNOME 50. For the first time it is now possible for parents and guardians to monitor screen time and set limits for child accounts, including bedtime schedules. The new features allow automatically locking the screen when a screen limit or bedtime is reached. Parents and guardians also have the ability to extend screen time past the limit when needed. We also ship Big Parental Controls 1.0 from our sister-project Big Linux from Brazil, to comply with recent laws there.
GNOME’s built-in remote desktop capabilities have seen significant improvements in version 50. A major performance boost comes from new hardware acceleration support (using Vulkan and VA-API). By using your computer’s graphics processor to stream video, remote sessions are now significantly smoother with much less lag and lower power consumption. Compatibility has also been improved for a wider range of hardware with the integration of explicit sync, which provides a more stable experience for those using NVIDIA drivers.
GNOME’s display technologies have received a massive set of stability and performance updates in GNOME 50.
Improved Variable Refresh Rate (VRR) and Fractional Scaling Support: VRR and fractional scaling have both been improved for GNOME 50, with bug fixes, stability, and user experience improvements. For users with compatible monitors, VRR provides a tear-free experience where the display’s refresh rate matches the application’s frame rate, resulting in significantly smoother motion. Fractional scaling allows what is displayed on screen to be scaled in increments, to better suit a range of display densities. When it is enabled, users can natively select scales like 125% or 150% in the display settings.
Low-Latency Cursor in VRR: The mouse cursor now operates independently of the application’s frame rate while VRR is active. This ensures the cursor remains fluid and responsive at the monitor’s maximum refresh rate (e.g., 144Hz) even if a game or professional app is running at a lower frame rate.
NVIDIA Performance Boosts: Workarounds for NVIDIA driver quirks have been implemented, targeting stuttering and frame-timing issues. The result is noticeably smoother window animations and general desktop fluidity for users with NVIDIA GPUs.
Next-Gen Color Management: Support for version 2 of the Wayland color management protocol has landed. This provides the technical foundation for creative professionals to achieve higher color accuracy across different apps and hardware.
HDR Screen Sharing: Building on GNOME’s modern color pipeline, it’s now possible to screen share monitors displaying High Dynamic range (HDR) content. This allows screen recording software to record the screen content with the same vivid colors as displayed on the physical screen.
The Plasma edition comes with the latest Plasma 6.7 series, Frameworks 6.28 and KDE Gear 26.04. It brings exciting new improvements to your desktop.
Plasma 6.7 includes a number of highly-requested features:
It brings powerful new features to KDE’s classic desktop, and refines its user experience to new levels. Enjoy thoughtfully-designed improvements that solve real problems, a sneak peek of future theming bliss, better performance, and more.
In Plasma 6.6 the ability to create your own Global Themes got introduced, and switch between them as part of the day-night cycle. Plasma 6.7 puts you even more in control with a quick toggle to switch between light and dark Global Themes immediately.
The System Tray is already the place for monitoring apps running in the background using traditional methods. Plasma 6.7 extends this support by also showing apps using the newer “Background Apps” system, which is more common for apps using the Flatpak package format.
Plasma 6.7 puts a particular focus on refining the desktop experience to make common tasks faster than ever:
  • Faster virtual desktop switching in the Overview
  • Drag and drop to add and remove favorites
  • More intuitive software management
  • Easier to compare different time zones
  • “Type-ahead” on the desktop
And finally: Plasma’s Notifications have been given a fancier animation: they now slide in from the nearest screen edge. This makes them more visually prominent and less likely to be missed, while at the same time avoiding being too attention-grabbing.
With our XFCE edition, we have now Xfce 4.20. Here some highlights: A new file highlighting feature (accessed from the file properties dialog) in Thunar file manager lets you set a custom colour background and a custom foreground text colour – an effective way to call attention to specific file(s) in a directory laden with similar-looking mime types. On the subject of finding files, Thunar includes recursive search.
The panel picks up a pair of new preferences. First, panel length is now configured in pixels rather than percentages, as before. Second, there’s a new “keep panel above windows” option. This allows maximised app windows to fill the area behind the panel rather than maximise its bottom or top edge to sit flush against it.
Control Centre groups all of the desktop’s various modules for managing the system into one easy-to-use window. New options are present in many of these. For example you can disable header bars in dialogs from the Appearance module; show or hide a ‘delete’ option in file context menus from Desktop; and pick a default multi-monitor behaviour before you attach an additional screen – dead handy, that.
Kernel 7.1 is used for this release, such as the latest drivers available to date. With 6.18 LTS and 6.12 LTS we offer additional support for older hardware as needed.
We hope you enjoy this release and let us know what you think of Bian-May.
Bian-May 26.1.3
Download GNOME
Full
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-261028-linux72.iso
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-261028-linux72.iso.sig
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-261028-linux72.iso.sha1
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-261028-linux72.iso.sha256
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-261028-linux72.iso.torrent
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-261028-linux72.iso.pkgs
Full LTS
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-261028-linux618.iso
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-261028-linux618.iso.sig
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-261028-linux618.iso.sha1
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-261028-linux618.iso.sha256
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-261028-linux618.iso.torrent
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-261028-linux618.iso.pkgs
Minimal
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-minimal-261028-linux72.iso
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-minimal-261028-linux72.iso.sig
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-minimal-261028-linux72.iso.sha1
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-minimal-261028-linux72.iso.sha256
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-minimal-261028-linux72.iso.torrent
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-minimal-261028-linux72.iso.pkgs
Minimal LTS
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-minimal-261028-linux618.iso
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-minimal-261028-linux618.iso.sig
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-minimal-261028-linux618.iso.sha1
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-minimal-261028-linux618.iso.sha256
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-minimal-261028-linux618.iso.torrent
https://download.manjaro.org/gnome/26.1.3/manjaro-gnome-26.1.3-minimal-261028-linux618.iso.pkgs
Download KDE Plasma
Full
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-261028-linux72.iso
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-261028-linux72.iso.sig
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-261028-linux72.iso.sha1
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-261028-linux72.iso.sha256
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-261028-linux72.iso.torrent
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-261028-linux72.iso.pkgs
Full LTS
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-261028-linux618.iso
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-261028-linux618.iso.sig
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-261028-linux618.iso.sha1
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-261028-linux618.iso.sha256
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-261028-linux618.iso.torrent
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-261028-linux618.iso.pkgs
Minimal
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-minimal-261028-linux72.iso
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-minimal-261028-linux72.iso.sig
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-minimal-261028-linux72.iso.sha1
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-minimal-261028-linux72.iso.sha256
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-minimal-261028-linux72.iso.torrent
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-minimal-261028-linux72.iso.pkgs
Minimal LTS
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-minimal-261028-linux618.iso
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-minimal-261028-linux618.iso.sig
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-minimal-261028-linux618.iso.sha1
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-minimal-261028-linux618.iso.sha256
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-minimal-261028-linux618.iso.torrent
https://download.manjaro.org/kde/26.1.3/manjaro-kde-26.1.3-minimal-261028-linux618.iso.pkgs
Download Xfce
Full
https://download.manjaro.org/xfce/26.1.3/manjaro-xfce-26.1.3-261028-linux72.iso
https://download.manjaro.org/xfce/26.1.3/manjaro-xfce-26.1.3-261028-linux72.iso.sig
https://download.manjaro.org/xfce/26.1.3/manjaro-xfce-26.1.3-261028-linux72.iso.sha1
https://download.manjaro.org/xfce/26.1.3/manjaro-xfce-26.1.3-261028-linux72.iso.sha256
https://download.manjaro.org/xfce/26.1.3/manjaro-xfce-26.1.3-261028-linux72.iso.torrent
https://download.manjaro.org/xfce/26.1.3/manjaro-xfce-26.1.3-261028-linux72.iso.pkgs
Minimal
https://download.manjaro.org/xfce/26.1.3/manjaro-xfce-26.1.3-minimal-261028-linux72.iso
https://download.manjaro.org/xfce/26.1.3/manjaro-xfce-26.1.3-minimal-261028-linux72.iso.sig
https://download.manjaro.org/xfce/26.1.3/manjaro-xfce-26.1.3-minimal-261028-linux72.iso.sha1
https://download.manjaro.org/xfce/26.1.3/manjaro-xfce-26.1.3-minimal-261028-linux72.iso.sha256
https://download.manjaro.org/xfce/26.1.3/manjaro-xfce-26.1.3-minimal-261028-linux72.iso.torrent
https://download.manjaro.org/xfce/26.1.3/manjaro-xfce-26.1.3-minimal-261028-linux72.iso.pkgs
Minimal LTS
https://download.manjaro.org/xfce/26.1.3/manjaro-xfce-26.1.3-minimal-261028-linux618.iso
https://download.manjaro.org/xfce/26.1.3/manjaro-xfce-26.1.3-minimal-261028-linux618.iso.sig
https://download.manjaro.org/xfce/26.1.3/manjaro-xfce-26.1.3-minimal-261028-linux618.iso.sha1
https://download.manjaro.org/xfce/26.1.3/manjaro-xfce-26.1.3-minimal-261028-linux618.iso.sha256
https://download.manjaro.org/xfce/26.1.3/manjaro-xfce-26.1.3-minimal-261028-linux618.iso.torrent
https://download.manjaro.org/xfce/26.1.3/manjaro-xfce-26.1.3-minimal-261028-linux618.iso.pkgs
Bian-May 26.1.2 (2026-09-10)
Download XFCE
Full
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-260910-linux71.iso
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-260910-linux71.iso.sig
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-260910-linux71.iso.sha1
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-260910-linux71.iso.sha256
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-260910-linux71.iso.torrent
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-260910-linux71.iso.pkgs
Minimal
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-minimal-260910-linux71.iso
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-minimal-260910-linux71.iso.sig
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-minimal-260910-linux71.iso.sha1
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-minimal-260910-linux71.iso.sha256
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-minimal-260910-linux71.iso.torrent
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-minimal-260910-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-minimal-260910-linux618.iso
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-minimal-260910-linux618.iso.sig
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-minimal-260910-linux618.iso.sha1
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-minimal-260910-linux618.iso.sha256
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-minimal-260910-linux618.iso.torrent
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-minimal-260910-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-minimal-260910-linux612.iso
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-minimal-260910-linux612.iso.sig
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-minimal-260910-linux612.iso.sha1
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-minimal-260910-linux612.iso.sha256
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-minimal-260910-linux612.iso.torrent
https://download.manjaro.org/xfce/26.1.2/manjaro-xfce-26.1.2-minimal-260910-linux612.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-260910-linux71.iso
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-260910-linux71.iso.sig
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-260910-linux71.iso.sha1
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-260910-linux71.iso.sha256
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-260910-linux71.iso.torrent
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-260910-linux71.iso.pkgs
Minimal
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-minimal-260910-linux71.iso
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-minimal-260910-linux71.iso.sig
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-minimal-260910-linux71.iso.sha1
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-minimal-260910-linux71.iso.sha256
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-minimal-260910-linux71.iso.torrent
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-minimal-260910-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-minimal-260910-linux618.iso
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-minimal-260910-linux618.iso.sig
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-minimal-260910-linux618.iso.sha1
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-minimal-260910-linux618.iso.sha256
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-minimal-260910-linux618.iso.torrent
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-minimal-260910-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-minimal-260910-linux612.iso
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-minimal-260910-linux612.iso.sig
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-minimal-260910-linux612.iso.sha1
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-minimal-260910-linux612.iso.sha256
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-minimal-260910-linux612.iso.torrent
https://download.manjaro.org/gnome/26.1.2/manjaro-gnome-26.1.2-minimal-260910-linux612.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-260910-linux71.iso
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-260910-linux71.iso.sig
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-260910-linux71.iso.sha1
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-260910-linux71.iso.sha256
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-260910-linux71.iso.torrent
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-260910-linux71.iso.pkgs
Minimal
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-minimal-260910-linux71.iso
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-minimal-260910-linux71.iso.sig
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-minimal-260910-linux71.iso.sha1
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-minimal-260910-linux71.iso.sha256
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-minimal-260910-linux71.iso.torrent
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-minimal-260910-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-minimal-260910-linux618.iso
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-minimal-260910-linux618.iso.sig
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-minimal-260910-linux618.iso.sha1
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-minimal-260910-linux618.iso.sha256
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-minimal-260910-linux618.iso.torrent
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-minimal-260910-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-minimal-260910-linux612.iso
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-minimal-260910-linux612.iso.sig
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-minimal-260910-linux612.iso.sha1
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-minimal-260910-linux612.iso.sha256
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-minimal-260910-linux612.iso.torrent
https://download.manjaro.org/kde/26.1.2/manjaro-kde-26.1.2-minimal-260910-linux612.iso.pkgs
Bian-May 26.1.1 (2026-08-25)
Download XFCE
Full
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-260825-linux71.iso
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-260825-linux71.iso.sig
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-260825-linux71.iso.sha1
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-260825-linux71.iso.sha256
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-260825-linux71.iso.torrent
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-260825-linux71.iso.pkgs
Minimal
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-minimal-260825-linux71.iso
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-minimal-260825-linux71.iso.sig
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-minimal-260825-linux71.iso.sha1
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-minimal-260825-linux71.iso.sha256
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-minimal-260825-linux71.iso.torrent
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-minimal-260825-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-minimal-260825-linux618.iso
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-minimal-260825-linux618.iso.sig
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-minimal-260825-linux618.iso.sha1
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-minimal-260825-linux618.iso.sha256
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-minimal-260825-linux618.iso.torrent
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-minimal-260825-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-minimal-260825-linux612.iso
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-minimal-260825-linux612.iso.sig
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-minimal-260825-linux612.iso.sha1
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-minimal-260825-linux612.iso.sha256
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-minimal-260825-linux612.iso.torrent
https://download.manjaro.org/xfce/26.1.1/manjaro-xfce-26.1.1-minimal-260825-linux612.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-260825-linux71.iso
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-260825-linux71.iso.sig
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-260825-linux71.iso.sha1
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-260825-linux71.iso.sha256
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-260825-linux71.iso.torrent
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-260825-linux71.iso.pkgs
Minimal
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-minimal-260825-linux71.iso
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-minimal-260825-linux71.iso.sig
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-minimal-260825-linux71.iso.sha1
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-minimal-260825-linux71.iso.sha256
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-minimal-260825-linux71.iso.torrent
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-minimal-260825-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-minimal-260825-linux618.iso
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-minimal-260825-linux618.iso.sig
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-minimal-260825-linux618.iso.sha1
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-minimal-260825-linux618.iso.sha256
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-minimal-260825-linux618.iso.torrent
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-minimal-260825-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-minimal-260825-linux612.iso
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-minimal-260825-linux612.iso.sig
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-minimal-260825-linux612.iso.sha1
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-minimal-260825-linux612.iso.sha256
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-minimal-260825-linux612.iso.torrent
https://download.manjaro.org/gnome/26.1.1/manjaro-gnome-26.1.1-minimal-260825-linux612.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-260825-linux71.iso
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-260825-linux71.iso.sig
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-260825-linux71.iso.sha1
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-260825-linux71.iso.sha256
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-260825-linux71.iso.torrent
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-260825-linux71.iso.pkgs
Minimal
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-minimal-260825-linux71.iso
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-minimal-260825-linux71.iso.sig
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-minimal-260825-linux71.iso.sha1
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-minimal-260825-linux71.iso.sha256
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-minimal-260825-linux71.iso.torrent
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-minimal-260825-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-minimal-260825-linux618.iso
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-minimal-260825-linux618.iso.sig
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-minimal-260825-linux618.iso.sha1
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-minimal-260825-linux618.iso.sha256
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-minimal-260825-linux618.iso.torrent
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-minimal-260825-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-minimal-260825-linux612.iso
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-minimal-260825-linux612.iso.sig
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-minimal-260825-linux612.iso.sha1
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-minimal-260825-linux612.iso.sha256
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-minimal-260825-linux612.iso.torrent
https://download.manjaro.org/kde/26.1.1/manjaro-kde-26.1.1-minimal-260825-linux612.iso.pkgs
Bian-May 26.1.0 (2026-08-12)
Download XFCE
Full
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-260812-linux71.iso
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-260812-linux71.iso.sig
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-260812-linux71.iso.sha1
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-260812-linux71.iso.sha256
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-260812-linux71.iso.torrent
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-260812-linux71.iso.pkgs
Minimal
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-minimal-260812-linux71.iso
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-minimal-260812-linux71.iso.sig
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-minimal-260812-linux71.iso.sha1
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-minimal-260812-linux71.iso.sha256
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-minimal-260812-linux71.iso.torrent
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-minimal-260812-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-minimal-260812-linux618.iso
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-minimal-260812-linux618.iso.sig
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-minimal-260812-linux618.iso.sha1
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-minimal-260812-linux618.iso.sha256
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-minimal-260812-linux618.iso.torrent
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-minimal-260812-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-minimal-260812-linux612.iso
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-minimal-260812-linux612.iso.sig
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-minimal-260812-linux612.iso.sha1
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-minimal-260812-linux612.iso.sha256
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-minimal-260812-linux612.iso.torrent
https://download.manjaro.org/xfce/26.1.0/manjaro-xfce-26.1.0-minimal-260812-linux612.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-260812-linux71.iso
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-260812-linux71.iso.sig
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-260812-linux71.iso.sha1
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-260812-linux71.iso.sha256
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-260812-linux71.iso.torrent
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-260812-linux71.iso.pkgs
Minimal
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-minimal-260812-linux71.iso
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-minimal-260812-linux71.iso.sig
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-minimal-260812-linux71.iso.sha1
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-minimal-260812-linux71.iso.sha256
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-minimal-260812-linux71.iso.torrent
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-minimal-260812-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-minimal-260812-linux618.iso
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-minimal-260812-linux618.iso.sig
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-minimal-260812-linux618.iso.sha1
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-minimal-260812-linux618.iso.sha256
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-minimal-260812-linux618.iso.torrent
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-minimal-260812-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-minimal-260812-linux612.iso
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-minimal-260812-linux612.iso.sig
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-minimal-260812-linux612.iso.sha1
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-minimal-260812-linux612.iso.sha256
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-minimal-260812-linux612.iso.torrent
https://download.manjaro.org/gnome/26.1.0/manjaro-gnome-26.1.0-minimal-260812-linux612.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-260812-linux71.iso
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-260812-linux71.iso.sig
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-260812-linux71.iso.sha1
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-260812-linux71.iso.sha256
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-260812-linux71.iso.torrent
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-260812-linux71.iso.pkgs
Minimal
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-minimal-260812-linux71.iso
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-minimal-260812-linux71.iso.sig
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-minimal-260812-linux71.iso.sha1
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-minimal-260812-linux71.iso.sha256
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-minimal-260812-linux71.iso.torrent
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-minimal-260812-linux71.iso.pkgs
Minimal (linux618)
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-minimal-260812-linux618.iso
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-minimal-260812-linux618.iso.sig
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-minimal-260812-linux618.iso.sha1
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-minimal-260812-linux618.iso.sha256
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-minimal-260812-linux618.iso.torrent
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-minimal-260812-linux618.iso.pkgs
Minimal (linux612)
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-minimal-260812-linux612.iso
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-minimal-260812-linux612.iso.sig
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-minimal-260812-linux612.iso.sha1
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-minimal-260812-linux612.iso.sha256
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-minimal-260812-linux612.iso.torrent
https://download.manjaro.org/kde/26.1.0/manjaro-kde-26.1.0-minimal-260812-linux612.iso.pkgs
Awesome work <3
When is the next LTS Kernel going to be released?
LTS kernels are always the last release of the year, so most likely 7.3 or 7.4.
Most likely v7.3.y, since v7.4.y is expected in January 2027 …
An article that arrived in my RSS feed reader after yesterday’s Stable Update announcement:
I installed manjaro-kde-26.1.0-minimal-260812-linux618.iso on my laptop HP Elitebook 820 G1 yesterday, and it works perfectly.
The installer starts in US English and time zone New York and US keyboard, despite that in the GRUB boot menu I choose tz=Europe/Copenhagen and keytable=dk and leave lang=en_US and boot with open source drivers. However, this does not hinder installation.
Thank you for another good release :clap:
My prediction: It’s 7.4, released around Christmas.
I have installed a system with the Plasma edition. After installation keyboard in Plasma was in english and not in my selected layout. The solution was to set the X11 keyboard with localectl (as seen in some threads a few weeks ago). Should the installer do this for the user automatically?
I have used virt-manager with qemu-desktop and libvirt to install manjaro-gnome-26.1.0-260812-linux71.iso onto two separate VMs, each with a slightly different configuration.
The configurations differ only in the settings selected at the Partitions phase of the Calamares installer :
Config 1 - EFI, erase disk, swap (no hibernate), BTRFS, encrypt system
Config 2 - EFI, erase disk, swap to file, BTRFS, encrypt system
For both configs, the Calamares installer completes successfully and allows me to select the restart checkbox at the end of the installation.
However, after restarting and successfully entering the LUKS decryption password, the Config 1 VM remains stuck at the Plymouth screen (three animated dots, Manjaro branding).
In contrast, the Config 2 VM works fine : after successfully entering the LUKS password, the VM successfully boots through to the gdm login screen, where I can successfully log in, and where everything else appears fine.
Is there something causing the Config 1 VM to get stuck ?
No. Calamares installer should show Location settings in the 2nd window. Summary window should also show settings before install.
Settings can also be changed after install with Manjaro Settings Manager
Yes, the correct language was selected there, but still Plasma keyboard was in english after installation. I suppose it is due to a recent change in a package: Fix: Keyboard layout reset after the xkeyboard-config update - FAQ and Tutorials - CachyOS Forum
Hallo everyone,
We have a new iso update for manjaro Bian-May 26.1.3 here:
Question: Why is this iso update also no listed in this thread?
Best regards,
VV
It is now. :wink:
