philm
2 April 2022 02:36
1
Hello community,
here comes another testing branch update.
Don’t miss out on 20% discount for all Manjaro Merch!
Our Kernels got updated to fix some security issues
Plasma is now at 5.24.4
Mesa got renewed to 22.0.0
Deepin got some packages renewed
A second point release is now available for LibreOffice 7.3
PipeWire is now at 0.3.49
Wine got renewed to 7.5
and even more Python and Haskell packages have arrived
You may need to rebuild any AUR packages that install files to site-packages …
You may need to rebuild any Python packages you’ve installed from the AUR. To get a list of them, you can run:
pacman -Qoq /usr/lib/python3.9
And to rebuild them all at once with an AUR helper such as yay, you can do:
yay -S $(pacman -Qoq /usr/lib/python3.9) --answerclean All
But if any of the packages don’t work with Python 3.10 yet, this might fail halfway through and you’ll have to do rebuild the remaining ones one or a few at a time.
Get our latest daily developer images now from Github: Plasma , Gnome , XFCE . You get the latest stable releases of Manjaro from CDN77 .
Our current supported kernels
linux49 4.9.309
linux414 4.14.274
linux419 4.19.236
linux54 5.4.188
linux510 5.10.109
linux515 5.15.32
linux516 5.16.18
linux517 5.17.1
linux515-rt 5.15.32_rt39
linux516-rt 5.16.2_rt19
linux517-rt 5.17.1_rt16
Package Updates (Sat Apr 2 04:04:04 CEST 2022)
testing community x86_64: 1337 new and 1356 removed package(s)
testing core x86_64: 38 new and 40 removed package(s)
testing extra x86_64: 421 new and 454 removed package(s)
testing kde-unstable x86_64: 275 new and 274 removed package(s)
testing multilib x86_64: 26 new and 27 removed package(s)
A detailed list of all package changes can be found here .
No issue, everything went smoothly
Yes there was an issue. I was able to resolve it myself.(Please post your solution)
Yes i am currently experiencing an issue due to the update. (Please post about it)
philm
2 April 2022 02:38
2
Known issues and solutions
2022-04-02
2022-03-12
Cannot mix incompatible Qt library (5.15.2) with this library (5.15.3)
Check the mirror you use is up to date:
sudo pacman-mirrors -f 5 && sudo pacman -Syyu
If you use qt5-styleplugins (AUR), rebuild it:
pamac build qt5-styleplugins
FIXED? VPN via L2TP might not work anymore
See FS#74089 - networkmanager 1.36 breaks vpn with networkmanager-l2tp
You may need to downgrade to 1.34.0:
sudo pacman -U https://archive.archlinux.org/packages/l/libnm/libnm-1.34.0-1-x86_64.pkg.tar.zst https://archive.archlinux.org/packages/n/networkmanager/networkmanager-1.34.0-1-x86_64.pkg.tar.zst
FIXED? DSL/PPPoE may require downgrading 2 packages
See my-internet-connection-is-no-longer-working and FS#73948 - networkmanager 1.36.0 breaks DSL connection
Please check if 1.36.2-1.0 of NetworkManager improve things, else downgrade to 1.34.0:
2022-01-03
New warnings when building the fallback initcpio - Possibly missing firmware for module: bfa, qed, qla1280, qla2xxx
That’s due to the recent changes to the linux-firmware package. Note these are warnings, not errors. You only need those firmwares if you have Mellanox Spectrum switches, Marvell devices, Qualcomm SoCs, Cavium LiquidIO server adapters, QLogic devices and Broadcom NetXtreme II 10Gb ethernet adapters. if you have that hardware you can install linux-firmware-qlogic to get rid of those warnings. If you do not have that hardware you can safely ignore those warnings.
pamac install linux-firmware-qlogic
2021-12-31
Python packages from PIP and AUR - how to upgrade them - detailed instructions
Read this post .
I put the wrong choice for the poll. Easyeffects doesn’t work anymore. I’m still checking where I could find a solution.
[EDIT] I’ve found the source. It is related to gtk4
opened 04:02PM - 22 Feb 22 UTC
### EasyEffects Version
6.2.3 g83c94be6
### What package are you using?
AUR (… easyeffects-git)
### Distribution
Arch Linux
### Describe the bug
easyeffects crashes before even showing the gui.
### Expected Behavior
easyeffects should launch.
### Debug Log
<details><summary>Debug Log</summary><br/>
$ G_MESSAGES_DEBUG=easyeffects easyeffects -w ─╯
(process:210376): easyeffects-DEBUG: 11:53:19.400: easyeffects version: 6.2.3
(process:210376): easyeffects-DEBUG: 11:53:19.402: main: locale directory: /usr/share/locale
(easyeffects:210376): easyeffects-DEBUG: 11:53:19.457: presets_manager: system input presets directory: "/etc/easyeffects/input";
(easyeffects:210376): easyeffects-DEBUG: 11:53:19.457: presets_manager: system input presets directory: "/etc/xdg/easyeffects/input";
(easyeffects:210376): easyeffects-DEBUG: 11:53:19.457: presets_manager: system input presets directory: "/home/simon/.config/kdedefaults/easyeffects/input";
(easyeffects:210376): easyeffects-DEBUG: 11:53:19.457: presets_manager: system output presets directory: "/etc/easyeffects/output";
(easyeffects:210376): easyeffects-DEBUG: 11:53:19.457: presets_manager: system output presets directory: "/etc/xdg/easyeffects/output";
(easyeffects:210376): easyeffects-DEBUG: 11:53:19.457: presets_manager: system output presets directory: "/home/simon/.config/kdedefaults/easyeffects/output";
(easyeffects:210376): easyeffects-DEBUG: 11:53:19.457: presets_manager: user presets directory already exists: /home/simon/.config/easyeffects/
(easyeffects:210376): easyeffects-DEBUG: 11:53:19.457: presets_manager: user presets directory already exists: /home/simon/.config/easyeffects/input
(easyeffects:210376): easyeffects-DEBUG: 11:53:19.457: presets_manager: user presets directory already exists: /home/simon/.config/easyeffects/output
(easyeffects:210376): easyeffects-DEBUG: 11:53:19.457: presets_manager: user presets directory already exists: /home/simon/.config/easyeffects/autoload/input
(easyeffects:210376): easyeffects-DEBUG: 11:53:19.457: presets_manager: user presets directory already exists: /home/simon/.config/easyeffects/autoload/output
(easyeffects:210376): Adwaita-WARNING **: 11:53:20.625: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.714: pipe_manager: compiled with PipeWire: 0.3.47
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.714: pipe_manager: linked to PipeWire: 0.3.47
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.997: pipe_manager: core version: 0.3.46
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.997: pipe_manager: core name: pipewire-0
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.997: pipe_manager: found metadata: settings
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.997: pipe_manager: found metadata: default
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.997: pipe_manager: found metadata: route-settings
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.997: pipe_manager: Audio/Sink 45 alsa_output.pci-0000_00_1b.0.analog-stereo with timestamp 1645545200997849799 was added
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.997: pipe_manager: Audio/Sink 61 bluez_output.0C_89_10_77_29_A2.a2dp-sink with timestamp 1645545200997975387 was added
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.998: pipe_manager: Stream/Output/Audio 57 Elisa with timestamp 1645545200998031016 was added
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.998: pipe_manager: Elisa port 51 is connected to bluez_output.0C_89_10_77_29_A2.a2dp-sink port 85
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.998: pipe_manager: Elisa port 80 is connected to bluez_output.0C_89_10_77_29_A2.a2dp-sink port 67
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.998: pipe_manager: Stream/Output/Audio 93 Nightly with timestamp 1645545200998116939 was added
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.998: pipe_manager: Nightly port 60 is connected to bluez_output.0C_89_10_77_29_A2.a2dp-sink port 85
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.998: pipe_manager: Nightly port 74 is connected to bluez_output.0C_89_10_77_29_A2.a2dp-sink port 67
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.998: pipe_manager: Audio/Sink 70 easyeffects_sink with timestamp 1645545200998200282 was added
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.998: pipe_manager: Audio/Source/Virtual 56 easyeffects_source with timestamp 1645545200998240003 was added
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.998: pipe_manager: new metadata property: 0, default.audio.sink, Spa:String:JSON, {"name":"bluez_output.0C_89_10_77_29_A2.a2dp-sink"}
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.998: pipe_manager: new metadata property: 0, default.audio.source, Spa:String:JSON, {"name":"bluez_output.0C_89_10_77_29_A2.a2dp-sink"}
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.999: pipe_manager: easyeffects_sink node successfully retrieved with id 70 and timestamp 1645545200998200282
(easyeffects:210376): easyeffects-DEBUG: 11:53:20.999: pipe_manager: easyeffects_source node successfully retrieved with id 56 and timestamp 1645545200998240003
(easyeffects:210376): easyeffects-DEBUG: 11:53:21.608: lv2_wrapper: http://lsp-plug.in/plugins/lv2/sc_compressor_stereo requires feature: http://lv2plug.in/ns/ext/urid#map
(easyeffects:210376): easyeffects-DEBUG: 11:53:21.673: lv2_wrapper: http://lsp-plug.in/plugins/lv2/comp_delay_x2_stereo requires feature: http://lv2plug.in/ns/ext/urid#map
(easyeffects:210376): easyeffects-DEBUG: 11:53:21.757: lv2_wrapper: http://lsp-plug.in/plugins/lv2/para_equalizer_x32_lr requires feature: http://lv2plug.in/ns/ext/urid#map
(easyeffects:210376): easyeffects-DEBUG: 11:53:21.895: lv2_wrapper: http://lsp-plug.in/plugins/lv2/sc_limiter_stereo requires feature: http://lv2plug.in/ns/ext/urid#map
(easyeffects:210376): easyeffects-DEBUG: 11:53:21.923: lv2_wrapper: http://lsp-plug.in/plugins/lv2/loud_comp_stereo requires feature: http://lv2plug.in/ns/ext/urid#map
(easyeffects:210376): easyeffects-DEBUG: 11:53:21.952: lv2_wrapper: urn:zamaudio:ZaMaximX2 requires feature: http://lv2plug.in/ns/ext/urid#map
(easyeffects:210376): easyeffects-DEBUG: 11:53:21.952: lv2_wrapper: urn:zamaudio:ZaMaximX2 requires feature: http://lv2plug.in/ns/ext/options#options
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.002: lv2_wrapper: http://lsp-plug.in/plugins/lv2/sc_mb_compressor_stereo requires feature: http://lv2plug.in/ns/ext/urid#map
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.069: soe: rnnoise using the default model
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.101: soe: output_level successfully connected to PipeWire graph
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.103: soe: spectrum successfully connected to PipeWire graph
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.138: soe: output_level: new PipeWire blocksize: 512
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.211: lv2_wrapper: http://lsp-plug.in/plugins/lv2/sc_compressor_stereo requires feature: http://lv2plug.in/ns/ext/urid#map
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.267: lv2_wrapper: http://lsp-plug.in/plugins/lv2/comp_delay_x2_stereo requires feature: http://lv2plug.in/ns/ext/urid#map
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.348: lv2_wrapper: http://lsp-plug.in/plugins/lv2/para_equalizer_x32_lr requires feature: http://lv2plug.in/ns/ext/urid#map
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.476: lv2_wrapper: http://lsp-plug.in/plugins/lv2/sc_limiter_stereo requires feature: http://lv2plug.in/ns/ext/urid#map
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.504: lv2_wrapper: http://lsp-plug.in/plugins/lv2/loud_comp_stereo requires feature: http://lv2plug.in/ns/ext/urid#map
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.530: lv2_wrapper: urn:zamaudio:ZaMaximX2 requires feature: http://lv2plug.in/ns/ext/urid#map
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.530: lv2_wrapper: urn:zamaudio:ZaMaximX2 requires feature: http://lv2plug.in/ns/ext/options#options
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.574: lv2_wrapper: http://lsp-plug.in/plugins/lv2/sc_mb_compressor_stereo requires feature: http://lv2plug.in/ns/ext/urid#map
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.636: sie: rnnoise using the default model
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.665: sie: output_level successfully connected to PipeWire graph
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.667: sie: spectrum successfully connected to PipeWire graph
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.667: sie: Input device id is invalid. Aborting the link between filters in the microphone pipeline
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.673: sie: Input device id is invalid. Aborting the link between filters in the microphone pipeline
easyeffects-INFO: 11:53:22.673: application: disabling global bypass
easyeffects-INFO: 11:53:22.673: application: Hiding the window...
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.674: presets_manager: destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.675: sie: destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.675: effects_base: destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.675: sie: stereo_tools destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.677: sie: rnnoise destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.677: sie: reverb destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.679: sie: pitch destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.679: sie: multiband_gate destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.682: sie: multiband_compressor destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.686: sie: maximizer destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.688: sie: loudness destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.690: sie: limiter destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.692: sie: gate destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.694: sie: filter destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.696: sie: exciter destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.698: sie: equalizer destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.703: sie: echo_canceller destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.703: sie: delay destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.706: sie: deesser destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.708: sie: crystalizer destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.708: sie: crossfeed destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.708: sie: convolver destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.708: sie: compressor destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.710: sie: bass_loudness destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.712: sie: bass_enhancer destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.714: sie: autogain destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.715: sie: spectrum destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.716: sie: output_level destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.719: soe: destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.719: effects_base: destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.719: soe: stereo_tools destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.723: soe: rnnoise destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.723: soe: reverb destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.726: soe: pitch destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.726: soe: multiband_gate destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.728: soe: multiband_compressor destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.731: soe: maximizer destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.733: soe: loudness destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.736: soe: limiter destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.738: soe: gate destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.740: soe: filter destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.742: soe: exciter destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.744: soe: equalizer destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.749: soe: echo_canceller destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.749: soe: delay destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.751: soe: deesser destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.753: soe: crystalizer destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.753: soe: crossfeed destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.753: soe: convolver destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.753: soe: compressor destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.756: soe: bass_loudness destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.759: soe: bass_enhancer destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.763: soe: autogain destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.764: soe: spectrum destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.765: soe: output_level destroyed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.766: pipe_manager: Destroying PipeWire registry...
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.766: pipe_manager: Disconnecting PipeWire core...
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.766: pipe_manager: Audio/Sink alsa_output.pci-0000_00_1b.0.analog-stereo was removed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.766: pipe_manager: Audio/Sink bluez_output.0C_89_10_77_29_A2.a2dp-sink was removed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.766: pipe_manager: Stream/Output/Audio Elisa was removed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.766: pipe_manager: Stream/Output/Audio Nightly was removed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.766: pipe_manager: Audio/Sink easyeffects_sink was removed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.766: pipe_manager: Audio/Source/Virtual easyeffects_source was removed
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.835: pipe_manager: Stopping PipeWire's loop...
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.835: pipe_manager: Destroying PipeWire's context...
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.836: pipe_manager: Destroying PipeWire's loop...
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.836: application: shutting down...
(easyeffects:210376): easyeffects-DEBUG: 11:53:22.840: Exitting the main function with status: 1
$ coredumpctl info 194900
PID: 194900 (easyeffects)
UID: 1000 (vosian)
GID: 1001 (vosian)
Signal: 6 (ABRT)
Timestamp: Tue 2022-02-22 00:34:07 -04 (11h ago)
Command Line: easyeffects
Executable: /usr/bin/easyeffects
Control Group: /user.slice/user-1000.slice/user@1000.service/app.slice/app-org.kde.konsole-09e34105dea8412a8ff5b435a46f2d99.scope
Unit: user@1000.service
User Unit: app-org.kde.konsole-09e34105dea8412a8ff5b435a46f2d99.scope
Slice: user-1000.slice
Owner UID: 1000 (vosian)
Boot ID: c3d65d576ac14e73bb4bdb81fb85c8b3
Machine ID: a79a3f0c77e845d8bb91980c35f4b616
Hostname: DeepBlue
Storage: /var/lib/systemd/coredump/core.easyeffects.1000.c3d65d576ac14e73bb4bdb81fb85c8b3.194900.1645504447000000.zst (present)
Disk Size: 13.7M
Message: Process 194900 (easyeffects) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id ce0fd38a02c8dcea67075fafd6ed6e5455ebd202
Module librsvg-2.so.2 with build-id ee2b5961f905a5f62b70dc6222968aaca76a0d81
Module libpixbufloader-svg.so with build-id d31f1f5a38b6d6ef3a41361bd59a05b82bf8900d
Module libspa-audiomixer.so with build-id 4763a43ab0847002ebb47383c30d6952fd48b5c7
Module libpipewire-module-session-manager.so with build-id 1cfaeb2286f3c1a14aced68aebe6eeca13a6b232
Module libpipewire-module-metadata.so with build-id 07486f832c40ebf388161b291c7651ae90240b23
Module libpipewire-module-adapter.so with build-id 3d54905bd189413541e84816e804cf94c0a42aeb
Module libpipewire-module-client-device.so with build-id d932901530f615e1ba3633148ab4f2f6d71a83bc
Module libpipewire-module-client-node.so with build-id 6e0220c8c7374367696515fb6dd724852b5cbea8
Module libpipewire-module-protocol-native.so with build-id bd62306141eb01d596173e2ac295b36acd4dee06
Module libpipewire-module-rt.so with build-id 74c7277ac15f36a97fe77096227658ac357032b2
Module libdbus-1.so.3 with build-id 74f2ab9c60512f3a93c932c3f627564d42e0b11e
Module libspa-dbus.so with build-id c677e18c8a540a313627161eea8ade3aff97d603
Module libgpg-error.so.0 with build-id 82524ee3d1c4c2244d7cfdcc1e6eea5f9855f6c6
Module libgcrypt.so.20 with build-id db45f5d5e0f7af1e77324fea1885f974619ad268
Module libcap.so.2 with build-id eb6dae97527fc89dbb0d5bb581a15acd02ae9f56
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module libsystemd.so.0 with build-id a83a62063b8098eda274d25251d619f0503bf011
Module libspa-journal.so with build-id 06592895de2df06a6c5352f10df43acc1c06fc74
Module libspa-support.so with build-id 616a8aeaf15a6f76012067b6f495936d212b3aa5
Module libpciaccess.so.0 with build-id 9dd24e76ebc38465541313b36446ffb4af842c12
Module libdrm_nouveau.so.2 with build-id af8afb2331ac08c52132102ecbdc6076a8eb4c6f
Module libdrm_radeon.so.1 with build-id 43e0aecc70c4ce905ba35c948e1c9a5d999b14c0
Module libdrm_intel.so.1 with build-id 2e02b4c50b649ee54e88079edaae13389a24ae6a
Module i965_dri.so with build-id 9d48bab35faa994704cfd415ec3a00c365aea45d
Module libXxf86vm.so.1 with build-id 01e8243d0c6c971fa9e743e6e53d606b1cb76f6e
Module libxcb-glx.so.0 with build-id 8ad115382ad874165523dc5b4488c99d73bbc3c4
Module libGLX_mesa.so.0 with build-id b898760e179722f62847965540df7411cf26e8df
Module libGLX.so.0 with build-id 2a08836c6e6126ce9ff4496b6aacaf29ae9b4e7b
Module libGL.so.1 with build-id 912ac4f37a9fa2d5abcf7a9088c9983cfe46f12a
Module libxshmfence.so.1 with build-id 8876d9ccf620858795724ca24b9e567585a77cec
Module libxcb-sync.so.1 with build-id dda14591103b01b1311906053bf1ca9e82ade35c
Module libxcb-present.so.0 with build-id 68f5465258750e2397b1333b3ffc01ee33caa4e1
Module libxcb-dri3.so.0 with build-id 9407a2480e09dc5a1dd9d9a0652fa8d32b328c91
Module libwayland-server.so.0 with build-id 645526447334b85a6f4bf5a8b37737b27696365f
Module libdrm.so.2 with build-id 00816f0a71c7e4e388c10db6245dbb9c031732a9
Module libxcb-xfixes.so.0 with build-id a6b197ace5b9b59f913f5969eb419a88d1194f47
Module libxcb-dri2.so.0 with build-id 2dd6e65129a809dab828a1d26215a3f7a363fcc8
Module libX11-xcb.so.1 with build-id 0db4f94d8ae31b8dc9a83f825a9171656f1e532c
Module libglapi.so.0 with build-id 9331aed5060062bcfafd463d36506312fab59549
Module libgbm.so.1 with build-id 372f8ab71950ad9e59e00d3e4fe4d7c3f3362e44
Module libEGL_mesa.so.0 with build-id e8cd93d71d40a0da4cf1175e455840fe57b887ed
Module libGLdispatch.so.0 with build-id 501765b3a78d668860fa54229b18107473aeda4c
Module libEGL.so.1 with build-id 686c2e4036c01a3a72349ed0dd04f7c434af14ce
Module libFcitx5GClient.so.2 with build-id ea64e122085c332b91e8fddde3cc08a4336d38e5
Module libim-fcitx5.so with build-id c751728fca88594e52482bfc1971e26eb80d18e8
Module libgvfscommon.so with build-id 90d1858292300e4e1ee3fbe84ab06079af840ec6
Module libgvfsdbus.so with build-id dcb9d652f2e5c65154517fe6934215ec6bd1c29c
Module libdconfsettings.so with build-id 7a4ba7af122c4d11168004a9ea6def330f02089f
Module libbrotlicommon.so.1 with build-id a4ba3f4b4571c8272343b621da812a6e24a202a7
Module libicudata.so.70 with build-id e1dcc2a88cfaafed882d09c90c668af0eed4efed
Module libblkid.so.1 with build-id 9e4bb910a2e63ba71cae0e3b89c07fdd45033ff2
Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
Module libbrotlidec.so.1 with build-id 45defc036e918e0140a72f1fbce6e7692d38241d
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module liblzo2.so.2 with build-id ed8e33ba505954ca344aea58d10c7b8a37fd2f39
Module liblzma.so.5 with build-id 8b615460aa230708c5183f16bede67aa0437d95e
Module libzstd.so.1 with build-id 72f3511cba7db578f6a2647925f35664da6c838b
Module libxml2.so.2 with build-id b710b880b0d4e9c93554fa632129db44c20632cd
Module libjson-glib-1.0.so.0 with build-id 5865be5fcc01b48a0a113e0145ec45529bff89a6
Module libsqlite3.so.0 with build-id 5f711261aabe285f02a673ded77a37b413afbfa2
Module libicui18n.so.70 with build-id 95af755fca990df26753a7d720b8e3ae24270e42
Module libicuuc.so.70 with build-id 2e245c2bf12f95fd8ab79b3a4be99524677cbd70
Module libstemmer.so.0 with build-id aa44a40dfb223020ed8e49cd2d28fc3887128463
Module libexpat.so.1 with build-id c3b8b6921f5b323540b84acd301ccc7bc5bc0428
Module libgraphite2.so.3 with build-id 47761dc11e553f519cde97ed9ee985be12ccdae2
Module ld-linux-x86-64.so.2 with build-id c09c6f50f6bcec73c64a0b4be77eadb8f7202410
Module libfftw3.so.3 with build-id 5d2df7d00e89133c944ec88377955deb732c246a
Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Module libvorbis.so.0 with build-id ad0a6c1af8f219b4e314090b6e8847223d424cbe
Module libopus.so.0 with build-id 35fafc4024675e9cfe57c7d50c3965eac6bac358
Module libFLAC.so.8 with build-id e568dc3d434723c72d6d302eb0b2559f27e91faa
Module libvorbisenc.so.2 with build-id 28ed815b8b1d322e6bf2bfdce4b0af2789b74335
Module libsratom-0.so.0 with build-id 3343126affc106c3e012e4296e6cdfdb905190e4
Module libsord-0.so.0 with build-id 35fd298c0c03f2c52b83350372c026f6c7952890
Module libserd-0.so.0 with build-id 208451202d5636cc0357cb02ff9d3039ab1ad465
Module libdl.so.2 with build-id bb9bd2657bfba9f60bd34d2050cc63a7eb024bc4
Module libffi.so.8 with build-id f90d8b734f6de9b25faedb8cbfab7054dafc0a42
Module libresolv.so.2 with build-id 46ffdf3d477a170314060c26927470d7399bc900
Module libmount.so.1 with build-id 765508fe9812e693ac41fd3d0aedd65d7a78b287
Module libpixman-1.so.0 with build-id 341f793dcada3a48a306a793d265a517e3f2e7d6
Module libxcb-shm.so.0 with build-id fb797f299a446f559a95afcc168227482cc800d1
Module libxcb-render.so.0 with build-id a37bdb37744b508be9dd29fd9ccb9bb0170d43e5
Module libxcb.so.1 with build-id 0d1ef11740a5daad2ee331e812a51aa6574af222
Module libXrender.so.1 with build-id 97e0b9ab6ba96ebc86527cc2b3c3078aad8616b3
Module libfreetype.so.6 with build-id 26c5f833068ff72660d1975cbc2074c3eb47fad8
Module libz.so.1 with build-id 0c1459c56513efd5d53eb3868290e9afee6a6a26
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libcairo-script-interpreter.so.2 with build-id a3dad249e313cbbadf1212802a04bca6bf4a0b91
Module libXinerama.so.1 with build-id dbb6adece34ea2766d3efcd628af8f9757344dd6
Module libXrandr.so.2 with build-id d4e869b5c72541e1de8f96b456248987ea52d51b
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libXdamage.so.1 with build-id a1d867e093c16944b2c0083be98050ef35c9e5c2
Module libXcursor.so.1 with build-id eb6315bcd7526aaf51b0a1307efdc587cea0a152
Module libXext.so.6 with build-id d70f24beb4fad748d6becffdcc13e51be0a2ebfa
Module libwayland-egl.so.1 with build-id 791e39283cdcc5a08cfd091b8cd4c59869a11278
Module libwayland-client.so.0 with build-id 0a237f2fd096bada4ca381eec5d64474c4078be4
Module libxkbcommon.so.0 with build-id 3a9338b2085f0af41217bc0a90ffcc941938a16e
Module librt.so.1 with build-id 4761858b348db8303e872e515aa8d56c046c921c
Module libjpeg.so.8 with build-id 879ca18a2f58c25d77ba881db3a44a5676ef6c7d
Module libtiff.so.5 with build-id e8d89a0fb0847641ddb75c5f03fa89d68155a75d
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libtracker-sparql-3.0.so.0 with build-id b0eee5a9b660fed5221ea15139e9608282320503
Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
Module libpangoft2-1.0.so.0 with build-id 9b0353693557b4fb68124a9dffac9b07678d86a1
Module libX11.so.6 with build-id 5ba5798d193c0065014b8c6252a0678671c8d478
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libgraphene-1.0.so.0 with build-id 3a967a1f87378940d58d44a233dec7239760884d
Module libepoxy.so.0 with build-id b6357fc6b748c512f90339433d74502b9d0621dc
Module libgdk_pixbuf-2.0.so.0 with build-id ca4beb15a30de8d8767f7bca8222038c61b58b36
Module libfontconfig.so.1 with build-id 9fdeb38479c4090d673efc2e8cb60176efe65da1
Module libcairo-gobject.so.2 with build-id abbf5a8a182ea1b8b7d68540df5c2e25c0bdae0c
Module libfribidi.so.0 with build-id 79124bad061c2aab4ec89f25d067363d5b781114
Module libharfbuzz.so.0 with build-id 716df25c59c91f456ae107457e4250f7c32bde1b
Module libpangocairo-1.0.so.0 with build-id a47bf17ab99c1840764fca52a2d772800d81d6e1
Module libgmodule-2.0.so.0 with build-id 5da4523e8d6b5c244a0193e27093d1e61f6ac9e4
Module libpthread.so.0 with build-id 7fa8b52fae071a370ba4ca32bf9490a30aff31c4
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libc.so.6 with build-id 85766e9d8458b16e9c7ce6e07c712c02b8471dbc
Module libgcc_s.so.1 with build-id 5d817452a709ca3a213341555ddcf446ecee37fa
Module libm.so.6 with build-id 596b63a006a4386dcab30912d2b54a7a61827b07
Module libstdc++.so.6 with build-id 88ad4eff81a00c684abfe0f863e87434123d8943
Module libzita-convolver.so.4 with build-id ba89fb69c20ce27e624e7cb176191a4c20eb0f63
Module libtbb.so.12 with build-id 429d27a99e8b9b1b91a34f2b6fb5bb3fef98a6b1
Module libfmt.so.8 with build-id c3f6708fe8ace56083397602097e9964d80a020f
Module libspeexdsp.so.1 with build-id 49f5531ba5bb2fd7a061726c580c12c682c131d3
Module librubberband.so.2 with build-id 467823c236b75698cd4d3f1962693b9eb0dc097f
Module libsamplerate.so.0 with build-id e7eba744904f8220874bf5883c90c15b887e4deb
Module librnnoise.so.0 with build-id 1cf07a38d4180758d2ac38b72dca99e494f1ef3b
Module libebur128.so.1 with build-id 2acd14dd45e987f86a082427f78c09f08faa985a
Module libfftw3f.so.3 with build-id fa6838f063f97a25b8682a78524dbf6bfc9eaead
Module libsndfile.so.1 with build-id 72d5531e74ed3e9afe49e95e449c40cb8984a258
Module libbs2b.so.0 with build-id 5f9c0e2799649d5b73bb7476a1a266fc039fb62b
Module liblilv-0.so.0 with build-id f8608dcbfa9a6ac739acd09132f328c3f8d63113
Module libsigc-3.0.so.0 with build-id d674e4b5a66b550d806bb27d52cf2f8c38c48c19
Module libadwaita-1.so.0 with build-id dfcdfede85e1f7fb174101f50a5f6d92d77dee87
Module libgobject-2.0.so.0 with build-id 6d7ff6c8e4e9c12caa92cf25a74d3ecdd9461c36
Module libgio-2.0.so.0 with build-id c4e89ca22afc7f17db176d2063fe379dbc88d99b
Module libcairo.so.2 with build-id 06820af9cf79c2deb207d9533a61caf04e67a8ad
Module libpango-1.0.so.0 with build-id f7a7e74f7ade4cbcf3840f685d760da19b0dc38c
Module libgtk-4.so.1 with build-id a1cf09c4790ba18f318fbddfe44bd4358c83af9c
Module libglib-2.0.so.0 with build-id 24e675eddd4654b470e0a892f4a4aec012b04160
Module libpipewire-0.3.so.0 with build-id 86eb6e31f49d742ad29649c758f4b736b346a35d
Module easyeffects with build-id 804aae7977ea99cc8a20a5e9c006f863b984b818
Stack trace of thread 194900:
#0 0x00007f8c7f97434c __pthread_kill_implementation (libc.so.6 + 0x8f34c)
#1 0x00007f8c7f9274b8 raise (libc.so.6 + 0x424b8)
#2 0x00007f8c7f911534 abort (libc.so.6 + 0x2c534)
#3 0x00007f8c7f91145c __assert_fail_base.cold (libc.so.6 + 0x2c45c)
#4 0x00007f8c7f920116 __assert_fail (libc.so.6 + 0x3b116)
#5 0x00007f8c7f446e2d n/a (libX11.so.6 + 0x40e2d)
#6 0x00007f8c7f446ec8 n/a (libX11.so.6 + 0x40ec8)
#7 0x00007f8c7f447282 _XEventsQueued (libX11.so.6 + 0x41282)
#8 0x00007f8c7f44a246 _XGetRequest (libX11.so.6 + 0x44246)
#9 0x00007f8c7f423b28 XChangeProperty (libX11.so.6 + 0x1db28)
#10 0x00007f8c80c4353f n/a (libgtk-4.so.1 + 0x3f753f)
#11 0x00007f8c80c43b58 n/a (libgtk-4.so.1 + 0x3f7b58)
#12 0x00007f8c80c4a381 n/a (libgtk-4.so.1 + 0x3fe381)
#13 0x00007f8c804c184f n/a (libgobject-2.0.so.0 + 0x2184f)
#14 0x00007f8c804c3ae9 g_object_set_valist (libgobject-2.0.so.0 + 0x23ae9)
#15 0x00007f8c804c3da5 g_object_set (libgobject-2.0.so.0 + 0x23da5)
#16 0x00007f8c80b2036d n/a (libgtk-4.so.1 + 0x2d436d)
#17 0x00007f8c80901f37 n/a (libgtk-4.so.1 + 0xb5f37)
#18 0x0000563d8a0a09aa n/a (easyeffects + 0x449aa)
#19 0x00007f8c804d0c96 g_signal_emit_valist (libgobject-2.0.so.0 + 0x30c96)
#20 0x00007f8c804d0e04 g_signal_emit (libgobject-2.0.so.0 + 0x30e04)
#21 0x00007f8c80b0a3fc gtk_widget_realize (libgtk-4.so.1 + 0x2be3fc)
#22 0x00007f8c80b1ea3d n/a (libgtk-4.so.1 + 0x2d2a3d)
#23 0x00007f8c804d0c96 g_signal_emit_valist (libgobject-2.0.so.0 + 0x30c96)
#24 0x00007f8c804d0e04 g_signal_emit (libgobject-2.0.so.0 + 0x30e04)
#25 0x00007f8c80b070d7 gtk_widget_show (libgtk-4.so.1 + 0x2bb0d7)
#26 0x00007f8c804d0c96 g_signal_emit_valist (libgobject-2.0.so.0 + 0x30c96)
#27 0x00007f8c804d0e04 g_signal_emit (libgobject-2.0.so.0 + 0x30e04)
#28 0x0000563d8a1f2489 n/a (easyeffects + 0x196489)
#29 0x00007f8c8056cc82 n/a (libgio-2.0.so.0 + 0x6fc82)
#30 0x00007f8c804d0c96 g_signal_emit_valist (libgobject-2.0.so.0 + 0x30c96)
#31 0x00007f8c804d0e04 g_signal_emit (libgobject-2.0.so.0 + 0x30e04)
#32 0x00007f8c805cc69f n/a (libgio-2.0.so.0 + 0xcf69f)
#33 0x00007f8c805cd71a n/a (libgio-2.0.so.0 + 0xd071a)
#34 0x00007f8c805d867a g_application_run (libgio-2.0.so.0 + 0xdb67a)
#35 0x0000563d8a0995fc n/a (easyeffects + 0x3d5fc)
#36 0x00007f8c7f912310 __libc_start_call_main (libc.so.6 + 0x2d310)
#37 0x00007f8c7f9123c1 __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x2d3c1)
#38 0x0000563d8a09c6b5 n/a (easyeffects + 0x406b5)
Stack trace of thread 194901:
#0 0x00007f8c7f9eb2af __poll (libc.so.6 + 0x1062af)
#1 0x00007f8c81097066 n/a (libglib-2.0.so.0 + 0xab066)
#2 0x00007f8c8103e485 g_main_context_iteration (libglib-2.0.so.0 + 0x52485)
#3 0x00007f8c8103e4d2 n/a (libglib-2.0.so.0 + 0x524d2)
#4 0x00007f8c81070845 n/a (libglib-2.0.so.0 + 0x84845)
#5 0x00007f8c7f9725c2 start_thread (libc.so.6 + 0x8d5c2)
#6 0x00007f8c7f9f7584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 194911:
#0 0x00007f8c7f9f79ae epoll_wait (libc.so.6 + 0x1129ae)
#1 0x00007f8c792ac489 n/a (libspa-support.so + 0x13489)
#2 0x00007f8c7929f7dc n/a (libspa-support.so + 0x67dc)
#3 0x00007f8c811681b7 n/a (libpipewire-0.3.so.0 + 0x3f1b7)
#4 0x00007f8c7f9725c2 start_thread (libc.so.6 + 0x8d5c2)
#5 0x00007f8c7f9f7584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 194920:
#0 0x00007f8c7f9f0a9d syscall (libc.so.6 + 0x10ba9d)
#1 0x00007f8c810910ff g_cond_wait_until (libglib-2.0.so.0 + 0xa50ff)
#2 0x00007f8c8100f993 n/a (libglib-2.0.so.0 + 0x23993)
#3 0x00007f8c8107396b n/a (libglib-2.0.so.0 + 0x8796b)
Stack trace of thread 194921:
Stack trace of thread 194907:
#0 0x00007f8c7f96f15a __futex_abstimed_wait_common (libc.so.6 + 0x8a15a)
#1 0x00007f8c7f971960 pthread_cond_wait@@GLIBC_2.3.2 (libc.so.6 + 0x8c960)
#2 0x00007f8c63180d9c n/a (i965_dri.so + 0x259d9c)
#3 0x00007f8c631807bc n/a (i965_dri.so + 0x2597bc)
Stack trace of thread 194924:
Stack trace of thread 194905:
Stack trace of thread 194925:
#3 0x00007f8c8100fb48 g_async_queue_timeout_pop (libglib-2.0.so.0 + 0x23b48)
#4 0x00007f8c810738ba n/a (libglib-2.0.so.0 + 0x878ba)
#5 0x00007f8c81070845 n/a (libglib-2.0.so.0 + 0x84845)
#6 0x00007f8c7f9725c2 start_thread (libc.so.6 + 0x8d5c2)
#7 0x00007f8c7f9f7584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 194910:
#3 0x00007f8c811b36ca n/a (libpipewire-0.3.so.0 + 0x8a6ca)
Stack trace of thread 194927:
Stack trace of thread 194923:
Stack trace of thread 194922:
Stack trace of thread 194919:
Stack trace of thread 194928:
Stack trace of thread 194926:
Stack trace of thread 194902:
#3 0x00007f8c8120debe n/a (libdconfsettings.so + 0x5ebe)
Stack trace of thread 194903:
#2 0x00007f8c81040463 g_main_loop_run (libglib-2.0.so.0 + 0x54463)
#3 0x00007f8c8060515c n/a (libgio-2.0.so.0 + 0x10815c)
</details>
### Additional Information
This happens with the latest repository package too, so it's not an issue from git. I'm using xorg plasma, if it matters.
[EDIT2]
Transitional fix will be to switch to Wayland
You do know you can change your vote?
Update works fine. Thanks!
The only bad thing is, that with kernel version 5.17.1 the network-module (in my case r8168) is still missing.
Can i do something on my own?
Edit: installed a package from the AUR called “r8168-dkms” - works for now - but still strange, that it’s suddenly missing from the kernel.
With this recent testing update ( no matter which kernel 4.9, 5.10, 5.16 ) the Xfce “auto-mounting” device icons do not work with “exfat” formatted devices.
Although it works correct with kernel 5.17 …
Despite working manually via simple mount in shell, the error reports:
Failed to mount “label1”
Error mounting /de/sdd1 at /run/media/user/label1 : unknown filesystem type exfat
I known that the detail belongs to the udisk2 , but how can I start to solve this ?
Just as a note using more recent Kernels (5.16 & 5.17) my WiFi adapter QCA9377 (kernel driver: ath10k_pci) has ran slower at times. Adding to my GRUB Kernel boot command: “ath10k_core.skip_otp=y ath10k_core.nohwcrypt=1” seems to have increase my performance using my WiFi adapter
I just experienced a hard-freeze while closing out the new version of Signal (5.37.0-1.) I’d advise caution while using this app.
some journalctl spam
kernel: Fixing recursive fault but reboot is needed!
kernel: BUG: scheduling while atomic: signal-desktop/16905/0x00000000
kernel: Modules linked in: uvcvideo videobuf2_vmalloc snd_usb_audio videobuf2_memops videobuf2_v4l2 videobuf2_common snd_usbmidi_lib videodev snd_rawmidi snd_seq_devic>
kernel: i2c_smbus snd mei_me mei soundcore nvidia(POE) video wmi mac_hid acpi_pad fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 xhci_pci >
kernel: CPU: 2 PID: 16905 Comm: signal-desktop Tainted: P S D OE 5.17.1-3-MANJARO #1 c9242a592d494bee9c6cffbc288adf97c7b0452a
Zesko
3 April 2022 10:57
9
Ethernet LAN connection does not work in Linux Kernel 5.17, but no error in journactl, it looks like that LAN is disabled.
Solution:
Switch back to Linux Kernel 5.16 that works fine.
Or install r8168-dkms for Linux Kernel 5.17 (I did not try it)
Zesko
3 April 2022 11:00
10
I guess it is related to the issue of Kernel. Try switching to a different Kernel.
Ok guys, r8168 module for kernel 5.17 is finally available to install from the official repos.
gnome-online-accounts forgot all the secrets/passwords/tokens for google accounts after upgrading 3.40.1-1 → 3.44.0-1. For me the solution was to enter the login details.
details
This could be the default ‘you have to enter your passwords again for reason x’ but 4 accounts at the same time is curious.
From the journal I can find these entries for all accounts:
goa-daemon[1386]: secret_password_lookup_sync() returned NULL
goa-daemon[1386]: /org/gnome/OnlineAccounts/Accounts/account_[number]: Setting AttentionNeeded to TRUE because EnsureCredentials() failed with: No credentials found in the keyring (goa-error-quark, 4)
and these after entering the password:
goa-daemon[1386]: /org/gnome/OnlineAccounts/Accounts/account_[number]: Setting AttentionNeeded to FALSE because EnsureCredentials() succeded
mfcmq
3 April 2022 12:41
13
Vulkan library updates are still broken in regard to FBC (namely the changes introduced in lib32-vulkan-icd-loader-1.3.207-1 vulkan-headers-1:1.3.207-1 vulkan-icd-loader-1.3.207-1 vulkan-tools-1.3.207-1). This has been discussed in NVFBC no longer working in Arch Linux: Invalid external buffer capabilities · Issue #511 · keylase/nvidia-patch · GitHub .
For anyone who needs FBC with current vulkan libraries, running
sed -i 's/\xc7\x84\x24\xfc\x01\x00\x00\x00\x00\x40\x00/\xc7\x84\x24\xfc\x01\x00\x00\x00\x10\x40\x00/' "libnvidia-fbc.so.${pkgver}"
fixes the issue, as discussed in the github issue page (second to last comment)
What is NVFBC?
Tried to search for it, but it’s only mentioned in articles overfilled with technical, specified jargon.
Does it do anything for an average player with Nvidia card?
Framebuffer compression it
s specific usage is for energy-saving.
So if it’s not working, then Nvidia users playing Proton games will use up more power?
mfcmq
3 April 2022 20:11
17
@Astalacoucougnasse and @michaldybczak framebuffer capture, not framebuffer compression. effectively the same way shadowplay works on windows
Has anyone tested Wine 7.5 or Lutris? Is everything working again?
What do you mean “again”? Did 7.4 not work for you? Describe more please.
There was a small update today. Crda package has been replaced by wireless-regdb, no errors after update.
Yochanan
Split this topic
4 April 2022 16:53
20
A post was split to a new topic: Firefox sometimes crashes
