I have a Dell Laptop where Manjaro is running on since 2019. Always just did the updates.
With kernel 6.x the system hangs at boot, right after loading docker containers. This is the last startup message I see. I don’t know what it’s doing at this point and if it’s trying to start X11/Wayland at this point.
It did that with the first version of kernel 6.x, starting from 6.1, 6.6 and now 6.12. Tried all, nothing changed.
The 5-series starts fine, now on 5.15.
System just freezes, no reaction on keyboard, no power button, nothing. CPU is getting warm and after a while the fan kicks in, so it does something.
When I start the system from a Live-Stick with 6.12, it starts fine (but with X11).
And yes, the system has a Nvidia Graphics [GeForce GTX 1050 Ti Mobile], what I disabled with a kernel param “nouveau.modeset=0 nouveau.blacklist=1”
What can I do to debug the problem? Any ideas?
$ inxi --filter --verbosity=8
Kernel: 5.15.189-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=eb21bdea-4d0b-4e61-8531-56f3937650c9 rw
cryptdevice=UUID=029e2447-8913-4368-a9fe-e27a84b1b635:luks-029e2447-8913-4368-a9fe-e27a84b1b635
root=/dev/mapper/luks-029e2447-8913-4368-a9fe-e27a84b1b635
resume=/dev/mapper/luks-029e2447-8913-4368-a9fe-e27a84b1b635
nouveau.modeset=0 nouveau.blacklist=1 mem_sleep_default=deep
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.16.0
Type: Laptop System: Dell product: XPS 15 9570 v: N/A
Mobo: Dell model: 0F3DC8 v: A06 serial: <superuser required> part-nu: 087C
uuid: <superuser required> UEFI: Dell v: 1.18.1 date: 12/14/2020
ID-1: BAT0 charge: 95.9 Wh (100.0%) condition: 95.9/97.1 Wh (98.7%)
volts: 13.2 min: 11.8 model: LGC-LGC8.33 DELL 5XJ28 type: Li-ion
serial: <filter> status: full
Device-1: hidpp_battery_0 model: Logitech K850 Performance Wireless
Keyboard serial: <filter> charge: 55% (should be ignored)
rechargeable: yes status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master
status: discharging
System RAM: total: 32 GiB available: 31.03 GiB used: 11.45 GiB (36.9%)
Device-1: DIMM A type: DDR4 detail: synchronous size: 16 GiB
speed: 2667 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: 01980000802C part-no: 9905700-047.A00G
serial: <filter>
Device-2: DIMM B type: DDR4 detail: synchronous size: 16 GiB
serial: <filter>
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
Topology: cpus: 1x dies: 1 cores: 6 threads: 12 tpc: 2 smt: enabled cache:
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 800 min/max: 800/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 52815
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep sgx sgx_lc smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
vulnerable
prctl and seccomp
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
ports: active: DP-1,eDP-1 empty: DP-2,DP-3 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell
driver: N/A alternate: nouveau, nvidia_drm, nvidia non-free: 550-570.xx+
status: current (as of 2025-04; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8c
class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:7
chip-ID: 0c45:671d class-ID: 0e02
Device-4: Logitech Logitech Webcam C925e driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5.2.2:12
chip-ID: 046d:085b class-ID: 0102 serial: <filter>
alternate: fbdev,vesa dri: iris gpu: i915 d-rect: 5760x1600 display-ID: 0
Monitor-1: DP-1 pos: primary,left model: Dell U3824DW serial: <filter>
built: 2024 res: mode: 3840x1600 hz: 60 scale: 100% (1) dpi: 111 gamma: 1.2
chroma: red: x: 0.686 y: 0.310 green: x: 0.263 y: 0.667 blue: x: 0.141
y: 0.059 white: x: 0.314 y: 0.329 size: 880x367mm (34.65x14.45")
diag: 953mm (37.5") modes: 3840x1600, 2560x1440, 2560x1080, 1920x1080,
1600x1200, 1280x1024, 1280x800, 1152x864, 1280x720, 1024x768, 800x600,
720x576, 720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 90
Monitor-2: eDP-1 pos: right model: Sharp 0x149a built: 2018 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red:
x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white:
x: 0.314 y: 0.329 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) device-ID: 8086:3e9b memory: 30.31 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 2 device: 0 type: integrated-gpu name: Intel
UHD Graphics 630 (CFL GT2) driver: mesa intel v: 25.1.6-arch1.1
device-ID: 8086:3e9b surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
Device-2: Logitech Logitech Webcam C925e driver: snd-usb-audio,uvcvideo
API: ALSA v: k5.15.189-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.6 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with:
tools: pacat,pactl
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Rivet Networks Killer Wireless-n/a/ac 1535 driver: ath10k_pci
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 3b:00.0
chip-ID: 168c:003e class-ID: 0280 temp: 45.0 C
IF: wlp59s0 state: up mac: <filter>
Device-2: Realtek USB 10/100/1G/2.5G LAN driver: r8152 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5.1:6 chip-ID: 0bda:8156
class-ID: 0000 serial: <filter>
IF: enp0s20f0u5u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: veth5ee552d state: up speed: 10000 Mbps duplex: full
mac: <filter>
Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3
chip-ID: 0cf3:e300 class-ID: e001
Device-1: luks-029e2447-8913-4368-a9fe-e27a84b1b635 maj-min: 254:0
type: LUKS dm: dm-0 size: 229.49 GiB
Components:
p-1: nvme0n1p7 maj-min: 259:7 size: 229.49 GiB
Local Storage: total: 476.94 GiB used: 182.47 GiB (38.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KXG50ZNV512G NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
fw-rev: AADA4106 temp: 30.9 C scheme: GPT
ID-1: / raw-size: 229.49 GiB size: 224.83 GiB (97.97%)
used: 182.36 GiB (81.1%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-029e2447-8913-4368-a9fe-e27a84b1b635 label: N/A
uuid: eb21bdea-4d0b-4e61-8531-56f3937650c9
ID-2: /boot/efi raw-size: 650 MiB size: 646 MiB (99.38%)
used: 112.2 MiB (17.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: ESP uuid: F676-BD10
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 231.04 GiB fs: ntfs label: OS
uuid: 4E422BE3422BCF11
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 990 MiB fs: ntfs
label: WINRETOOLS uuid: 9A74A15974A13941
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 13.51 GiB fs: ntfs label: Image
uuid: F430A1A830A17272
ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 1.17 GiB fs: ntfs
label: DELLSUPPORT uuid: 164EFBA34EFB7A37
Device-1: 1-2:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-4:3 info: Qualcomm Atheros QCA61x4 Bluetooth 4.0
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 1-5:4 info: Realtek 4-Port USB 2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5483
Device-1: 1-5.1:6 info: Realtek USB 10/100/1G/2.5G LAN type: Network
driver: r8152 interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 200mA chip-ID: 0bda:8156 class-ID: 0000 serial: <filter>
Hub-3: 1-5.2:8 info: Realtek 4-Port USB 2.0 Hub ports: 4 rev: 2.1
Device-1: 1-5.2.2:12 info: Logitech Logitech Webcam C925e
type: video,audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
Hub-4: 1-5.3:9 info: Realtek 4-Port USB 2.0 Hub ports: 4 rev: 2.1
Device-1: 1-5.3.4:11 info: Realtek USB2.0 HID type: HID
chip-ID: 0bda:1100 class-ID: 0300
Device-2: 1-5.4:10 info: Realtek U3824DW type: billboard driver: N/A
chip-ID: 0bda:54bb class-ID: 1100 serial: <filter>
Device-3: 1-7:5 info: Shenzhen Goodix Fingerprint Reader
type: abstract (modem),CDC-data driver: N/A interfaces: 2 rev: 2.0
chip-ID: 27c6:5395 class-ID: 0a00 serial: <filter>
Device-4: 1-12:7 info: Microdia Integrated_Webcam_HD type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0c45:671d class-ID: 0e02
Hub-5: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-7: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 44.0 C pch: 61.0 C mobo: N/A
Fan Speeds (rpm): cpu: 2491 fan-2: 2517
Packages: pm: pacman pkgs: 2108 libs: 393 tools: octopi,pamac,yay pm: rpm
pkgs: 0 pm: flatpak pkgs: 0
1: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
2: https://mirror.23m.com/manjaro/stable/$repo/$arch
3: https://mirrors.manjaro.org/repo/stable/$repo/$arch
4: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 376
1: cpu: 19.0% command: chromium pid: 8197 mem: 454.7 MiB (1.4%)
2: cpu: 12.7% command: chromium pid: 7472 mem: 667.3 MiB (2.0%)
3: cpu: 10.9% command: chromium pid: 7523 mem: 282.8 MiB (0.8%)
4: cpu: 8.7% command: chromium pid: 10796 mem: 350.2 MiB (1.1%)
5: cpu: 3.7% command: chromium pid: 7601 mem: 256.2 MiB (0.8%)
Memory top: 5 of 376
1: mem: 667.3 MiB (2.0%) command: chromium pid: 7472 cpu: 12.7%
2: mem: 519.7 MiB (1.6%) command: chromium pid: 8348 cpu: 1.0%
3: mem: 481.1 MiB (1.5%) command: chromium pid: 10293 cpu: 3.7%
4: mem: 468.8 MiB (1.4%) command: plasmashell pid: 2229 cpu: 1.0%
5: mem: 454.7 MiB (1.4%) command: chromium pid: 8197 cpu: 19.0%
Processes: 376 Power: uptime: 1h 29m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.4 GiB services: org_kde_powerdevil,upowerd
Compilers: clang: 20.1.8 gcc: 15.1.1 Shell: Bash v: 5.3.0
running-in: yakuake inxi: 3.3.38
Mod edit:- Removed unnecessary images.
