I just finished setting up and installing software packages for my version of Manjaro. I don’t know why, but I find the system quite slow and often freezes. Could this be related to the swap setting?
At the moment, it literally freezes after I open a few programs or a few tabs of Edge.
Hi @Eragonvn, and welcome!
In order for us or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
- [HowTo] Provide System Information,
- [HowTo] Post screenshots and links,
- [HowTo] Request support, and
- [HowTo] Post command output and file content as formatted text.
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Yes, it could. But it also could not. More info should help with determining the cause.
Hope you manage!
Basic troubleshooting would involve monitoring your system while active.
Hi @Mirdarthos , I would be glad if you could help. I have attached here my system information:
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "en_GB:en_US:vi",
LC_ALL = (unset),
LC_ADDRESS = "vi_VN",
LC_COLLATE = "vi_VN.UTF-8",
LC_IDENTIFICATION = "vi_VN",
LC_MEASUREMENT = "blt_VN.UTF-8",
LC_MONETARY = "vi_VN.UTF-8",
LC_NAME = "vi_VN",
LC_NUMERIC = "vi_VN.UTF-8",
LC_PAPER = "vi_VN",
LC_TELEPHONE = "vi_VN",
LC_TIME = "vi_VN.UTF-8",
LANG = "vi_VN.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("vi_VN.UTF-8").
Kernel: 5.10.105-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=925141c7-f3fe-4c8c-ba20-8196a3f37fb7 rw quiet apparmor=1
Desktop: KDE Plasma 5.24.3 tk: Qt 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Latitude E6530 v: 01
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 0GMVN7 serial: <superuser required> UEFI: Dell v: A22
date: 11/30/2018
RAM: total: 3.77 GiB used: 2.88 GiB (76.3%)
RAM Report:
Info: model: Intel Core i5-3210M bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2081 high: 2464 min/max: 1200/3100 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1638 2: 2140 3: 2084
4: 2464 bogomips: 19940
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: NVIDIA GF108GLM [NVS 5200M] vendor: Dell driver: nvidia v: 390.147
alternate: nouveau,nvidia_drm pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:0dfc class-ID: 0300
Device-2: Microdia Laptop_Integrated_Webcam_E4HD type: USB
driver: uvcvideo bus-ID: 1-1.5:3 chip-ID: 0c45:6449 class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 143 s-size: 341x191mm (13.4x7.5")
s-diag: 391mm (15.4")
Monitor-1: LVDS-0 res: 1920x1080 hz: 60 dpi: 142
size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: NVS 5200M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.147
direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Device-2: NVIDIA GF108 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
Sound Server-1: ALSA v: k5.10.105-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
Device-2: Intel Centrino Ultimate-N 6300 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:422b
class-ID: 0280
Device-3: Lite-On Dell Wireless Mouse WM314 type: USB
driver: hid-generic,usbhid bus-ID: 3-3:2 chip-ID: 04ca:0077 class-ID: 0301
Local Storage: total: 585 GiB used: 22.73 GiB (3.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: OSC model: SSD 128GB size: 119.24 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 7A scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HTS725050A7E630
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: A3C0 scheme: GPT
ID-1: / raw-size: 45.47 GiB size: 44.45 GiB (97.77%) used: 22.71 GiB (51.1%)
fs: ext4 dev: /dev/sdb8 maj-min: 8:24 label: N/A
uuid: 925141c7-f3fe-4c8c-ba20-8196a3f37fb7
ID-2: /boot/efi raw-size: 121.4 MiB size: 120.4 MiB (99.20%)
used: 13.5 MiB (11.2%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: E6DB-C750
ID-1: /dev/sda1 maj-min: 8:1 size: 119.12 GiB fs: ntfs label: 64WinXP
uuid: 01D7E6D3E6159120
ID-2: /dev/sdb1 maj-min: 8:17 size: 11.72 GiB fs: ext4 label: N/A
uuid: f3766176-407f-4e3e-bd56-9930c1fa32c4
ID-3: /dev/sdb2 maj-min: 8:18 size: 102 MiB fs: vfat label: N/A
uuid: 0F57-105F
ID-4: /dev/sdb3 maj-min: 8:19 size: 465 MiB fs: ntfs label: N/A
uuid: 48900B4F900B4344
ID-5: /dev/sdb4 maj-min: 8:20 size: 183.01 GiB fs: ntfs
label: Ph\xc3\xa2\xcc\x80n m\xc3\xaa\xcc\x80m uuid: 00078446000E7AE5
ID-6: /dev/sdb5 maj-min: 8:21 size: 182.74 GiB fs: ntfs
label: Ta\xcc\x80i li\xc3\xaa\xcc\xa3u uuid: 0000DFF30009FEEF
ID-7: /dev/sdb6 maj-min: 8:22 size: 42.16 GiB fs: ntfs label: N/A
uuid: 18AB63AD63C99A1D
ID-8: /dev/sdb7 maj-min: 8:23 size: 99 MiB fs: ntfs label: N/A
uuid: 12AFB0A74B87E1FD
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.5:3 info: Microdia Laptop_Integrated_Webcam_E4HD type: Video
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Lite-On Dell Wireless Mouse WM314 type: Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 04ca:0077 class-ID: 0301
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 62.0 C mobo: 42.0 C sodimm: SODIMM C gpu: nvidia
temp: 60 C
Fan Speeds (RPM): cpu: 2794
Processes: 242 Uptime: 21m wakeups: 2 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1442 pacman: 1434 lib: 374
flatpak: 8 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.13
LC_ALL = (unset),
LC_NAME = "vi_VN",
LC_PAPER = "vi_VN",
date: 11/30/2018
RAM Report:
Type: l1tf
direct render: Yes
class-ID: 0403
class-ID: 0280
uuid: E6DB-C750
uuid: 0F57-105F
temp: 60 C
inxi: 3.3.13
These are locale warnings. Please see: Locale - Manjaro on how to setup your locale settings.
This machine seems to be on the older side, with not enough memory for no SWAP space. It could simply be that it doesn’t have enough juice.
See
For more. And your CPU also looks sort of old, so I just think it doesn’t have enough power to give.
I would think you need a swap file with that low amount of ram. I have an older pc like that except it has 4 cores with 8 threads but the same amount of ram with an SSD. It did lag at times 100%. I found with firefox it ran smooth with 5 or 6 tabs until I had other things going in the background. I did not try edge ever with any linux.
Thanks, I looked at the wiki post and set up a swap file. Can you advise me whether using a swap file or a swap partition is better for my machine’s performance?
Hi, Can you explain it more specifically and instruct me on how to do it?
AFAIK using a file or a partition has no impact on performance. The main benefit of the file is that its size can be changed more easily.
Keep the system monitor open, for instance?..
This
@Mirdarthos Currently, I’m tinkering around with zswap and when I use the command swapon it shows up like this:
Filename Type Size Used Priority
/swapfile file 4194300 315616 -2
/var/lib/systemd-swap/swapfc/1 file 524284 519812 50
Should I set the priority of swapfc higher or lower than swapfile ? Thanks
I can honestly not answer you on that. I have absolutely no experience with swap files. I always used to leave settings on default and lately I’ve got 16GB RAM, so I don’t use the swap. (Although it’s there, somewhere, and configured and 8GB in size, I know nothing more than that.)
Your best bet would be to look here: Swap - ArchWiki
Why do you go from “mah PC broken” to “let try various multiple things I don’t understand at the same time and complicating everything before seeing if one step brings some light on my issue”?
Test a SWAP file, see if your issue is fixed.
