System freezes on KDE Wayland, stable on X11
Hi,
I’m experiencing random full system freezes on KDE Plasma Wayland on Manjaro. The whole system becomes unresponsive and only a hard reboot helps.
After switching to X11, the system is stable so far, but I sometimes see flickering at the top of the screen.
Relevant log before freeze:
amdgpu: [gfxhub] page fault
Process kwin_wayland
GCVM_L2_PROTECTION_FAULT_STATUS
System info:
• Manjaro
• KDE Plasma
• Kernel: 6.18.7-1 (linux618)
• CPU: Intel i5-14600KF
• GPU: AMD Radeon RX 6800 XT
• RAM: 32 GB DDR5
• Display: AOC C27G1 (VA, DP) + IPS monitor (HDMI)
GPU settings:
• Undervolt -100 mV
Notes:
• Freezes only happen on Wayland
• No freezes on X11
• Temps are fine
Thanks
Relevant logs from journalctl -b -1 -p err
(time of freeze ~17:58–17:59):
Feb 01 17:56:24 kernel: amdgpu: Overdrive is enabled, please disable it before reporting any bugs unrelated to overdrive
Feb 01 17:58:51 kernel: amdgpu 0000:03:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:24 vmid:5 pasid:32775)
Feb 01 17:58:51 kernel: amdgpu 0000:03:00.0: amdgpu: Process kwin_wayland pid 1127 thread kwin_wayla:cs0 pid 1173
Feb 01 17:58:51 kernel: amdgpu 0000:03:00.0: amdgpu: in page starting at address 0x0000004380068000 from client
Feb 01 17:58:51 kernel: amdgpu 0000:03:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00501031
Feb 01 17:58:51 kernel: amdgpu 0000:03:00.0: amdgpu: Faulty UTCL2 client ID: TCP (0x8)
Feb 01 17:58:51 kernel: amdgpu 0000:03:00.0: amdgpu: PERMISSION_FAULTS: 0x3
(similar page faults repeated ~8 times with different addresses)
Feb 01 17:58:52 kwin_wayland[1127]: Wait failed
Feb 01 17:59:01 kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx_0.1.0 timeout
Feb 01 17:59:01 kernel: amdgpu 0000:03:00.0: amdgpu: Starting gfx_0.1.0 ring reset
Feb 01 17:59:01 kernel: amdgpu 0000:03:00.0: amdgpu: Ring gfx_0.1.0 reset succeeded
(timeout + reset repeats several times)
Hi @jansamaj, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
inxi --filter --verbosity=8 --color=0
Please also note and heed: Forum Rules - Manjaro
Those with privacy concerns: note that when -z, or --filter is used, all personally identifiable information is filtered out from the resulting inxi output. :eyes:
Hope you manage!
:bangbang: Tip for legibility: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Note that the above text is partially pre-prepared as a general introduction for new forum users. Please take the time to follow links given and learn how to create effective support requests and encourage quality responses.
Please do not cherry-pick “relevant” parts. There are quite possible more information to why something is going on, and we need to find out why something if happening and fix that so that the problem is resolved.
  Kernel: 6.18.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=79d667ce-d129-4dd6-a550-b85a84f85c97 rw quiet splash
    resume=UUID=5f66d60e-6214-41ad-9789-b48a6e6ff664 udev.log_priority=3
    amd_pstate=active mitigations=off
  Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.22.0
  Mobo: ASUSTeK model: ROG STRIX B660-I GAMING WIFI v: Rev 1.xx
    Firmware: UEFI vendor: American Megatrends v: 3811 date: 10/22/2025
  System RAM: total: 32 GiB available: 31.15 GiB used: 2.96 GiB (9.5%)
  Array-1: capacity: 128 GiB slots: 2 modules: 2 EC: None
    max-module-size: 64 GiB note: est.
  Device-1: Controller0-DIMM0 type: DDR5 detail: synchronous size: 16 GiB
    speed: 6800 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: G Skill Intl part-no: F5-6400J3239G16G
    serial: <filter>
  Device-2: Controller1-DIMM0 type: DDR5 detail: synchronous size: 16 GiB
    serial: <filter>
  Info: model: Intel Core i5-14600KF bits: 64 type: MST AMCP arch: Raptor Lake
    gen: core 14 level: v3 note: check built: 2022+ process: Intel 7 (10nm)
    family: 6 model-id: 0xB7 (183) stepping: 1 microcode: 0x132
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
    st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
    KiB, 8x64 KiB L2: 20 MiB desc: 6x2 MiB, 2x4 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 1201 min/max: 800/5300:4000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1201 2: 1201 3: 1201
    4: 1201 5: 1201 6: 1201 7: 1201 8: 1201 9: 1201 10: 1201 11: 1201 12: 1201
    13: 1201 14: 1201 15: 1201 16: 1201 17: 1201 18: 1201 19: 1201 20: 1201
    bogomips: 139776
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdtscp rep_good sdbg sep serialize sha_ni smap smep split_lock_detect ss
    ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    xtopology xtpr
  Type: reg_file_data_sampling status: Vulnerable
  Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
    usercopy barriers only; no swapgs barriers
  Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
    PBRSB-eIBRS: Vulnerable; BHI: Vulnerable
  Type: vmscape status: Vulnerable
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT
    / 6900 XT] vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-2
    code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-2,HDMI-A-1
    empty: DP-1,DP-3,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:73bf
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.21 with: Xwayland v: 24.1.9
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
    s-diag: 1052mm (41.43")
  Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,right model: AOC 27G1G4
    serial: <filter> built: 2018 res: N/A dpi: 82 gamma: 1.2 chroma: red:
    x: 0.686 y: 0.310 green: x: 0.251 y: 0.671 blue: x: 0.145 y: 0.078 white:
    x: 0.314 y: 0.329 size: 598x336mm (23.54x13.23") diag: 686mm (27")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1280x720, 1024x768,
    832x624, 800x600, 720x576, 720x480, 640x480, 720x400
  Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: left model: AOC 2269WM
    serial: <filter> built: 2013 res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 102 gamma: 1.2 chroma: red: x: 0.655 y: 0.337 green: x: 0.325
    y: 0.612 blue: x: 0.149 y: 0.063 white: x: 0.314 y: 0.329
    size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x720,
    1024x768, 832x624, 800x600, 720x576, 720x480, 640x480, 720x400
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 XT (radeonsi
    navi21 LLVM 21.1.6 DRM 3.64 6.18.8-1-MANJARO) device-ID: 1002:73bf
    memory: 15.62 GiB unified: no
  API: Vulkan v: 1.4.335 layers: 7 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6800 XT (RADV NAVI21) driver: mesa radv v: 25.3.4-arch1.1
    device-ID: 1002:73bf surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: lact wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:7ad0 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
  API: ALSA v: k6.18.8-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
  Device-1: Intel Alder Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7af0 class-ID: 0280
  Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0
    chip-ID: 8086:15f3 class-ID: 0200
  IF: enp7s0 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6 chip-ID: 8087:0026
    class-ID: e001
  Local Storage: total: 2.06 TiB used: 1.4 TiB (67.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Kingston model: SNV3S1000G
    lanes: 4 tech: SSD serial: <filter> fw-rev: SDQ00103 temp: 39.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Lexar model: SSD NM790 1TB
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 21572 temp: 45.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Transcend model: TS120GSSD220S
    size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 21.2 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 840 EVO 120GB
    tech: SSD serial: <filter> fw-rev: CB6Q scheme: GPT
  ID-1: / raw-size: 100.59 GiB size: 98.45 GiB (97.87%)
    used: 24.59 GiB (25.0%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:6
    label: N/A uuid: 79d667ce-d129-4dd6-a550-b85a84f85c97
    used: 332 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:9 label: N/A
    uuid: 4AE5-1409
  ID-3: /home raw-size: 822.42 GiB size: 808.44 GiB (98.30%)
    used: 613.94 GiB (75.9%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:8
    label: N/A uuid: 3579b9ed-1bd8-4834-b2d3-7b265fb3243c
  ID-4: /run/media/jan/82E89FF3E89FE427 raw-size: 953.04 GiB
    size: 953.04 GiB (100.00%) used: 791.72 GiB (83.1%) fs: ntfs
    dev: /dev/nvme1n1p3 maj-min: 259:3 label: N/A uuid: 82E89FF3E89FE427
  ID-1: swap-1 type: zram size: 15.58 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 dev: /dev/zram0
  ID-2: swap-2 type: partition size: 8.01 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:7 label: N/A
    uuid: 5f66d60e-6214-41ad-9789-b48a6e6ff664
  ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: DC9C-FB91
  ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme1n1p4 maj-min: 259:4 size: 731 MiB fs: ntfs label: N/A
    uuid: E6C2CFF5C2CFC7CF
  ID-4: /dev/sda1 maj-min: 8:1 size: 600 MiB fs: vfat label: N/A
    uuid: CFB5-7E44
  ID-5: /dev/sda2 maj-min: 8:2 size: 2 GiB fs: ext4 label: bazzite_xboot
    uuid: 3b6d880f-c54b-42c1-b0fa-466e03d49ce3
  ID-6: /dev/sda3 maj-min: 8:3 size: 109.2 GiB fs: btrfs
    label: bazzite_bazzite uuid: 24930a02-000c-4604-8d6b-4944e84d3e28
  ID-7: /dev/sdb1 maj-min: 8:17 size: 111.79 GiB fs: ext4 label: SamsungSSD
    uuid: 0065f67e-05c1-42d7-a23b-84a451d690e4
  Device-1: 1-2:2 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
    serial: <filter>
  Hub-2: 1-3:3 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Device-1: 1-5:4 info: Logitech G513 RGB MECHANICAL GAMING KEYBOARD
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c33c class-ID: 0300 serial: <filter>
  Device-2: 1-11:5 info: Xenta 2.4G Mouse type: keyboard,mouse,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 1d57:fa60 class-ID: 0301
  Device-3: 1-14:6 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  Hub-3: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
  Hub-4: 2-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  System Temperatures: cpu: 36.5 C mobo: 31.0 C gpu: amdgpu temp: 44.0 C
    mem: 40.0 C
  Fan Speeds (rpm): fan-1: 581 fan-2: 617 fan-3: 0 fan-4: 0 fan-5: 0
    fan-6: 0 fan-7: 0 gpu: amdgpu fan: 0
  Packages: 1356 pm: pacman pkgs: 1339 libs: 377 tools: pamac pm: flatpak
    pkgs: 17
    1: https://manjaro.kurdy.org/testing/$repo/$arch
    2: https://ipng.mm.fcix.net/manjaro/testing/$repo/$arch
    3: https://mirror.raiolanetworks.com/manjaro/testing/$repo/$arch
    4: https://mirror.vinehost.net/manjaro/testing/$repo/$arch
    5: https://forksystems.mm.fcix.net/manjaro/testing/$repo/$arch
    6: https://mirror.csclub.uwaterloo.ca/manjaro/testing/$repo/$arch
    7: https://opencolo.mm.fcix.net/manjaro/testing/$repo/$arch
    8: https://coresite.mm.fcix.net/manjaro/testing/$repo/$arch
Processes:
  CPU top: 5 of 571
  1: cpu: 5.4% command: konsole pid: 4526 mem: 195.9 MiB (0.6%)
  2: cpu: 4.4% command: Xorg pid: 877 mem: 98.8 MiB (0.3%)
  3: cpu: 3.9% command: chrome pid: 3708 mem: 284.6 MiB (0.8%)
  4: cpu: 3.3% command: chrome pid: 3593 mem: 184.6 MiB (0.5%)
  5: cpu: 3.2% command: chrome pid: 3322 mem: 316.1 MiB (0.9%)
  Memory top: 5 of 571
  1: mem: 460.3 MiB (1.4%) command: plasmashell pid: 1217 cpu: 1.1%
  2: mem: 316.1 MiB (0.9%) command: chrome pid: 3322 cpu: 3.2%
  3: mem: 284.6 MiB (0.8%) command: chrome pid: 3708 cpu: 3.9%
  4: mem: 259.3 MiB (0.8%) command: chrome pid: 3389 cpu: 1.4%
  5: mem: 195.9 MiB (0.6%) command: konsole pid: 4526 cpu: 5.4%
  Processes: 571 Power: uptime: 4m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.44 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40
So, do you have a Kernel Panic with blinking LED Num/upper shift/scroll lights on your Keyboard. Or is there another reason why you don’t use MagicSystemHotkeys alias REISUB for a clean restart?
Trying different Kernels is mostly a good option. Today i also had a Plasma Desktop Freeze with Kernel 6.18 related to my Nvidia Driver and Kernel 6.12 at least looks a little bid more stable (besides i have also other problems/Kernel Panic while gaming since this newest stable release update, but that is another story).
I think most people are probably not aware of this option. Running for the reset/power button is the typical Windows ecosystem behavior. :wink:
Yeah probably… or he has just a Kernel Panic, a answer only he can gives.
I know this isnt a fix for what you want to do, but the old adage of “if it aint broke, dont fix it” may apply.
Walyland may be the future, but its still under development. X11 is old but stable. If you want to spend your time chasing bugs, by all means continue on the Wayland path. If you want to use your computer and dont want to deal with bugs just use X11.
