System freezes due to unknown reason
I have been using Manjaro on my HP ProBook 650 G1 with 8GB of RAM Laptop for over a year without any problem, however since a couple of weeks my system has begun freezing randomly.
The first time it froze I was on a certain website and I thought that particular website [deleted] had left some malware script on my system because the system froze twice on that website.
Yet, later it began freezing on other websites like Youtube. Sometimes I suspect this happened after the last major update. I tried updating the kernel headers and it appeared that the problem had disappeared, but it came back again after I installed the software “Bottles”.
The problem disappeared for a day after uninstalling Bottles, but it has come back again.
After the system freezes I try the REISUB commands, but the system does not shutdown or restart, only the screen goes blank with only the mouse pointer showing, but not moving, when I press the ‘I’ key. The other keys give no response.
Here is the output of the inix report:
inxi -zv8c0
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
       LANGUAGE = "",
       LC_ALL = (unset),
       LC_CTYPE = (unset),
       LC_NUMERIC = "en_US.UTF-8",
       LC_COLLATE = (unset),
       LC_TIME = "en_US.UTF-8",
       LC_MESSAGES = (unset),
       LC_MONETARY = "en_US.UTF-8",
       LC_ADDRESS = "en_US.UTF-8",
       LC_IDENTIFICATION = "en_US.UTF-8",
       LC_MEASUREMENT = "en_US.UTF-8",
       LC_PAPER = "en_PK.UTF-8",
       LC_TELEPHONE = "en_US.UTF-8",
       LC_NAME = "en_US.UTF-8",
       LANG = "en_US.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
  Kernel: 6.16.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.16-x86_64
    root=UUID=1b22633b-d152-47c4-be6a-2bc37b9d5d1a rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.18.0
  Type: Laptop System: Hewlett-Packard product: HP ProBook 650 G1
    v: A3009DD10303 serial: <superuser required> Chassis: type: 10
  Mobo: Hewlett-Packard model: 2101 v: KBC Version 16.3A
    serial: <superuser required> part-nu: J5P25UT#ABA uuid: <superuser required>
    BIOS: Hewlett-Packard v: L78 Ver. 01.31 date: 12/24/2014
  ID-1: BAT0 charge: 38.6 Wh (97%) condition: 39.8/39.8 Wh (100%) volts: 12.25
    min: 10.8 model: Hewlett-Packard Primary type: Li-ion serial: <filter>
    charging: status: not charging cycles: N/A
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
    charge: 55% (should be ignored) rechargeable: yes status: discharging
  System RAM: total: 8 GiB available: 7.62 GiB used: 2.79 GiB (36.6%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: Top - Slot 1 (top) type: DDR3 detail: synchronous size: 4 GiB
    speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Samsung part-no: M471B5173CB0-YK0 serial: <filter>
  Device-2: Top - Slot 2 (under) type: DDR3 detail: synchronous size: 4 GiB
    manufacturer: Samsung part-no: M471B5173EB0-YK0 serial: <filter>
  Info: model: Intel Core i7-4610M bits: 64 type: MT MCP arch: Haswell
    gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
    family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 3592 min/max: 800/3700 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 3592 2: 3592 3: 3592 4: 3592 bogomips: 23944
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    fsgsbase fxsr ht ibpb ibrs ida invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
    rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xsave xsaveopt xtopology xtpr
    vulnerable
  Type: spectre_v1 mitigation: usercopy/swapgs barriers and \__user pointer
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Intel 4th Gen Core Processor Integrated Graphics
    vendor: Hewlett-Packard driver: i915 v: kernel arch: Gen-7.5
    process: Intel 22nm built: 2013 ports: active: eDP-1 empty: DP-1, DP-2,
    DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1 bus-ID: 00:02.0
    chip-ID: 8086:0416 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: crocus gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1368x768 s-dpi: 97 s-size: 360x202mm (14.17x7.95")
    s-diag: 413mm (16.25")
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x15c2 built: 2013 res:
    mode: 1368x768 hz: 60 scale: 100% (1) dpi: 101 gamma: 1.2 chroma: red:
    x: 0.620 y: 0.341 green: x: 0.341 y: 0.580 blue: x: 0.153 y: 0.078 white:
    x: 0.314 y: 0.329 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
  EDID-Warnings: 1: parse_edid: unknown flag 2
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
    device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11:
    drv: crocus inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.3-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4600 (HSW
    GT2) device-ID: 8086:0416 memory: 1.46 GiB unified: yes
  API: Vulkan v: 1.4.321 layers: 1 device: 0 type: integrated-gpu name: Intel
    HD Graphics 4600 (HSW GT2) driver: mesa intel v: 25.2.3-arch1.2
    device-ID: 8086:0416 surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:03.0
    chip-ID: 8086:0c0c class-ID: 0403
  Device-2: Intel 8 Series/C220 Series High Definition Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:8c20 class-ID: 0403
  API: ALSA v: k6.16.8-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I217-LM vendor: Hewlett-Packard driver: e1000e
    v: kernel port: 3080 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
  IF: enp0s25 state: down mac: <filter>
  Device-2: Intel Centrino Advanced-N 6235 driver: iwlwifi v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:088e
    class-ID: 0280
  Device-1: Intel Centrino Bluetooth Wireless Transceiver driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-12:3
    chip-ID: 8087:07da class-ID: e001
  Local Storage: total: 1.94 TiB used: 1.72 TiB (89.1%)
  ID-1: /dev/sda maj-min: 8:0 model: P3-128 size: 119.24 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 6327 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: ST2000LM003 HN-M201RAD
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: MBR
  ID-1: / raw-size: 119.24 GiB size: 116.81 GiB (97.96%)
    used: 67.28 GiB (57.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 1b22633b-d152-47c4-be6a-2bc37b9d5d1a
  ID-2: /run/media/me/KHAZANA raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
    used: 1.66 TiB (91.2%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17 label: KHAZANA
    uuid: E6745024744FF5B9
  Hub-1: 1-0:1 info: full speed or root hub ports: 3 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
  Hub-3: 2-0:1 info: hi-speed hub with single TT ports: 15 rev: 2.0
  Device-1: 2-9:2 info: Logitech Nano Receiver type: keyboard,mouse
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c534 class-ID: 0301
  Device-2: 2-12:3 info: Intel Centrino Bluetooth Wireless Transceiver
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 8087:07da
    class-ID: e001
  Hub-4: 3-0:1 info: full speed or root hub ports: 3 rev: 2.0
  Hub-5: 3-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
  Hub-6: 4-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 67.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1963 pm: pacman pkgs: 1903 libs: 449 tools: pamac,yay pm: flatpak
    pkgs: 60
    1: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    2: https://mirror.init7.net/manjaro/stable/$repo/$arch
    3: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    5: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
    6: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 198
  1: cpu: 98.3% command: libredefender pid: 998 mem: 12.4 MiB (0.1%)
  2: cpu: 8.7% command: konsole pid: 5571 mem: 234.2 MiB (3.0%)
  3: cpu: 6.5% command: firefox pid: 1760 mem: 603.5 MiB (7.7%)
  4: cpu: 4.5% command: systemd-journald pid: 301 mem: 140.0 MiB (1.7%)
  5: cpu: 3.9% command: firefox pid: 2003 mem: 367.3 MiB (4.7%)
  Memory top: 5 of 198
  1: mem: 603.5 MiB (7.7%) command: firefox pid: 1760 cpu: 6.5%
  2: mem: 416.0 MiB (5.3%) command: plasmashell pid: 785 cpu: 0.3%
  3: mem: 387.4 MiB (4.9%) command: firefox pid: 1947 cpu: 2.4%
  4: mem: 367.3 MiB (4.7%) command: firefox pid: 2003 cpu: 3.9%
  5: mem: 320.8 MiB (4.1%) command: systemsettings pid: 3418 cpu: 0.0%
  Processes: 198 Power: uptime: 1h 22m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.03 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.3.3 running-in: konsole inxi: 3.3.39
Thank you.
Mod edit:- I would question the logic of posting the URL of a site suspected of disseminating malware. URL removed.
Mod edit: Added proper code formatting for you, this time. :wink:
System information a.k.a. inxi? Error log a.k.a. journalctl?
And use the </> button to paste code please.
Please provide your system information as described (below) formatted according to forum guidelines. It may be difficult to provide a meaningful response without those details.
What follows is from a standard template.
Waiting for others to blindly ask questions can be counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Highly Recommended
Technical Resources
Required Reading
Here is the journal report:
journalctl --boot=-1 --priority=3 --catalog --no-pager
Oct 29 14:56:16 me-manjaro kernel: Bluetooth: hci0: unexpected event for opcode 0x0000Oct 29 14:56:16 me-manjaro kernel: spi-nor spi0.0: BFPT parsing failed. Please considerusing SPI_NOR_SKIP_SFDP when declaring the flashOct 29 14:56:16 me-manjaro kernel: spi-nor spi0.0: probe with driver spi-nor failed witherror -95Oct 29 14:56:20 me-manjaro dbus-broker-launch[598]: Ignoring duplicate name 're.sonny.Tangram’ in service file ‘/usr/share//dbus-1/services/re.sonny.Tangram.service’░░ Subject: Invalid service file░░ Defined-By: dbus-broker░░ Support: ░░░░ A service file is a ini-type configuration file.░░░░ It has one required section░░ named [D-BUS Service]. The section contains the required key ‘Name’, which░░ must be a valid D-Bus name that is unique across all service files. It also░░ contains at least one of the two optional keys ‘SystemdService’ and ‘Exec’,░░ as well as optionally the key ‘User’. Exec must be a valid shell command and░░ User must be a valid user on the system.░░░░ A service file should be named after the D-Bus name it configures. That is░░ a file containing Name=org.foo.bar1 should be named org.foo.bar1.service.░░ For backwards compatibility, we only warn when files do not follow this░░ convention when run as a user bus. The system bus considers this an error░░ and ignores the service file.Oct 29 14:56:28 me-manjaro dbus-broker-launch[665]: Ignoring duplicate name 're.sonny.Tangram’ in service file ‘/usr/share//dbus-1/services/re.sonny.Tangram.service’░░ Subject: Invalid service file░░ Defined-By: dbus-broker░░ Support: ░░░░ A service file is a ini-type configuration file.░░░░ It has one required section░░ named [D-BUS Service]. The section contains the required key ‘Name’, which░░ must be a valid D-Bus name that is unique across all service files. It also░░ contains at least one of the two optional keys ‘SystemdService’ and ‘Exec’,░░ as well as optionally the key ‘User’. Exec must be a valid shell command and░░ User must be a valid user on the system.░░░░ A service file should be named after the D-Bus name it configures. That is░░ a file containing Name=org.foo.bar1 should be named org.foo.bar1.service.░░ For backwards compatibility, we only warn when files do not follow this░░ convention when run as a user bus. The system bus considers this an error░░ and ignores the service file.Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Microcode SW error detected.  Restarting 0x2000000.Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Loaded firmware version: 18.168.6.1 6000g2b-6.ucodeOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Start IWL Error Log Dump:Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Status: 0x0000044C, count: 6Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x00001030 | ADVANCED_SYSASSERT
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x0000C5F0 | uPc**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x0000C5E8 | branchlink1**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x0000C5E8 | branchlink2**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x0000DBEA | interruptlink1**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x00000000 | interruptlink2**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x001A0072 | data1**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x00000000 | data2**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x00000800 | line**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0xE740B192 | beacon time**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0xFBC22E6D | tsf low**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x00000169 | tsf hi**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x00000B59 | time gp1**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x7C67ABB2 | time gp2**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x00000000 | time gp3**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x754312A8 | uCode version**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x000000B0 | hw version**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x00484B00 | board version**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x0100001C | hcmd**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0xAFF63004 | isr0**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x11C9F800 | isr1**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x00000F1A | isr2**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x01473CC0 | isr3**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x00000000 | isr4**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x10008112 | isr_pref**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x0002443C | wait_event**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x000000C4 | l2p_control**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x00000B78 | l2p_duration**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x00000007 | l2p_mhvalid**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x00101042 | l2p_addr_match**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x00000015 | lmpm_pmg_sel**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x13011136 | timestamp**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x0000C0D8 | flow_handler**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: Start IWL Event Log Dump: nothi**
ng in log
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: Device error - SW reset**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: Microcode SW error detected.  R**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: Loaded firmware version: 18.168**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: Start IWL Error Log Dump:**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: Status: 0x0000044C, count: 6**
Oct 29 15:31:09 me-manjaro kernel: **iwlwifi 0000:02:00.0: 0x00001030 | ADVANCED_SYSASSERT**
Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x0000C5F0 | uPcOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x0000C5E8 | branchlink1Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x0000C5E8 | branchlink2Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x0000DBEA | interruptlink1Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x00000000 | interruptlink2Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x001A0072 | data1Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x00000000 | data2Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x00000800 | lineOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x00017DDB | beacon timeOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x7F4E0225 | tsf lowOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x00000169 | tsf hiOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x00000BAF | time gp1Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x000126F4 | time gp2Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x00000000 | time gp3Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x754312A8 | uCode versionOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x000000B0 | hw versionOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x00484B00 | board versionOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x0100001C | hcmdOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0xA7D63006 | isr0Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x01818000 | isr1Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x00000E1A | isr2Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x014210C0 | isr3Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x00000000 | isr4Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x00008110 | isr_prefOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x0002443C | wait_eventOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x000000D4 | l2p_controlOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x00000000 | l2p_durationOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x00000007 | l2p_mhvalidOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x00101042 | l2p_addr_matchOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x00000015 | lmpm_pmg_selOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x13011136 | timestampOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: 0x00004048 | flow_handlerOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Start IWL Event Log Dump: nothing in logOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Device error - reprobe!Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Q: 2, freed 0Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Command REPLY_LEDS_CMD failed:FW ErrorOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Command REPLY_LEDS_CMD failed:FW ErrorOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Command REPLY_TXFIFO_FLUSH failed: FW ErrorOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: flush request failOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Command REPLY_ADD_STA failed: FW ErrorOct 29 15:31:09 me-manjaro kernel: wlo1: failed to remove key (0, 20:df:73:84:2f:c4) from hardware (-5)Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Command REPLY_QOS_PARAM failed:FW ErrorOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Failed to update QoSOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Command REPLY_RXON failed: FW ErrorOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Error clearing ASSOC_MSK on BSS(-5)Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Command REPLY_RXON failed: FW ErrorOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Error clearing ASSOC_MSK on BSS(-5)Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Command REPLY_RXON failed: FW ErrorOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Error clearing ASSOC_MSK on BSS(-5)Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Command REPLY_RXON failed: FW ErrorOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Error clearing ASSOC_MSK on BSS(-5)Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Command REPLY_ADD_STA failed: FW ErrorOct 29 15:31:09 me-manjaro kernel: wlo1: failed to remove key (2, ff:ff:ff:ff:ff:ff) from hardware (-5)Oct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Command REPLY_RXON failed: FW ErrorOct 29 15:31:09 me-manjaro kernel: iwlwifi 0000:02:00.0: Error clearing ASSOC_MSK on BSS(-5)Oct 29 15:31:09 me-manjaro kernel: kernel BUG at mm/slub.c:546!Oct 29 15:31:09 me-manjaro kernel: BUG: kernel NULL pointer dereference, address: 0000000000000000Oct 29 15:31:09 me-manjaro kernel: #PF: supervisor instruction fetch in kernel modeOct 29 15:31:09 me-manjaro kernel: #PF: error_code(0x0010) - not-present page
I am sorry for any mistakes being a newbie.
I can now definitely confirm that this error occurs while using an internet browser, usually Firefox.
Mod edit:- Formatting has been done for you this time. No charge. In future, please practice as much as you can until you get it right. :wink:
A little reading of information and links given can go a long wat toward preventing those mistakes…
All code or command output should be presented as pre-formatted text to conform with forum guidelines.
This is an example of pre-formatted text.
When composing your post, use the </> button to create two rows of three “backtick” characters – each row of three on it’s own line, as shown (below) – paste your code or command output between those rows; for example:
Pasted code or command output goes here.
This topic has be unlisted (hidden from public view) temporarily until you have attended to the previous mistake. :wink:
I see you’re having some difficulty. The backticks should be placed above and below the “block” of pasted command output rather than every single line.
That’s MS-Windows logic. GNU/Linux does not get infected with anything by merely visiting a website, even if it does have malware on it.
In MS-Windows — like in MS-DOS — a file is executable if it has a certain filename suffix, e.g. .EXE or .COM. Therefore, in Windows, open() equals execute(). This is not the case in UNIX systems, where a file must have execute permission at the level of the filesystem layer.
More likely is that your laptop froze because of… :backhand_index_pointing_down:
… while it has only 8 GiB of RAM. Websites can get quite heavy these days, and so do the browsers themselves. With 8 GiB of RAM, you do still need a swap device in this day and age.
Another reason why your system froze could be the fact that it’s a laptop. They run much hotter than a desktop system because the components are all crammed together in a tight space and the chassis does not offer adequate cooling. Dust in the fans and/or the ventilation apertures will only make this worse.
If I were to take a bet, I’d say it was the lack of virtual memory, though. If you don’t have any spare partition sitting around, you can create a swap file instead. There are plenty of HowTos on how to do that.
From what i see i the log and can google, seems like a problem with the wifi driver or the microcode of the wifi card.
The easiest will be to try another kernel, like the latest LTS 6.12 or even 6.6.
If that does not work another easy solution will be to disable this card and use another, if you have such option. Like a usb wifi adapter.
Alternatively, there are different suggestions for tuning diverse parameters of the connection in arch and gentoo forums, but that will be hit and miss experience.
Thank you Aragorn. I will increase the RAM and get back to you. It could be a memory issue, but it is definitely not a cooling issue because the last time the system froze when I turned on the laptop after several hours today and opened the browser to check your reply which took only a few minutes. RISEUB did not work at all and I had to hard start the laptop again. The only new thing is that previously when the problem started the WiFi would turn off and its indicator light would turn orange when the system froze. It does not do that anymore. The system freezes but the WiFi indicator remains white/on. RISEUB never worked completely. It only works partly sometimes. I have begun uninstalling various software I had installed since this problem began.
With or without extra RAM, it is suggested to create swap space - at least qual to RAM size if hibernating, or about half that amount, if not.
Change to older LTS kernel first. Cause there is a very similar topic in the arch forums about kernel 6.16
Kernel 6.12 (LTS) is generally suggested. :eyes:
:warning: Kernels 6.15 and 6.16 have reached EOL and no longer receive updates from the Manjaro repositories.
Thank you soundofthunder. I am reading up on it. Looks scary stuff for a newbie like me :woozy_face:
Most welcome.
Quick tip: Use the @ characher when you wish to mention another member. A modal box will pop up where you can select a User from a dropdown.
This prevents you from mispelling a members username and ensures that the member is notified that they were mentioned – without it, they might never know.
:scream_kevin:
It’s not that scary (or difficult), really, but always ask if there’s something you don’t understand, and I’m sure someone will be happy to help.
@soundofthunder
Thank you. I have moved to the 6.12 kernel, although I was a bit confused because the startup menu had two choices for each kernel, such as: 6.12 and 6.12 intramf. So, which is the correct one please?
The first entry is normally used, so… 6.12.
The second entry is a fallback for when the first one doesn’t work. It uses a bigger initramfs with more driver modules loaded, whereas the initramfs of the first entry contains only the driver modules for the hardware detected in your system during installation.
@Aragorn Thank you. I keep learning more and more from the replies. All this information will come in handy as Win 10 has stopped support and I am suggesting to friends and colleagues to switch to Manjaro instead of buying expensive new hardware for Win 11.
Also, make sure they understand what to expect.
Manjaro (and Linux generally) is not “a replacement for Windows” but a completely different OS for which they will very likely need to invest time and effort to learn.
The following link provides a down-to-Earth comparison that will help clear up any misconceptions. Give it to your friends and colleagues. :wink:
