SWAY version stuck on first start - no ideas left
Hi
I downloaded the latest ARM SWAY image from the website and flashed to USB.
On starting, the screen displays
discover_other_daemon:1
then goes to a splash screen showing ‘ARM’
and freezes.
From TTY2 I can log in as root, with no pw, and have updated
pacman -Syu
reboot
No change.
During the update process the message
systemd could not get information firstboot.service
was displayed.
systemctl list-unit-files
showed firstboot.service as static.
systemctl status firstboot
returned
unit not found.
nano /usr/lib/systemd/system/systemd-firstboot.service
returned the contents of the unit file.
The ArchWiki on GNOME/Keyring at para 6.17 states that the ‘discover_other_daemon:1’ message is returned if the gnome keyring daemon is started twice and recommends disabling it and the associated socket.
systemctl --user list-unit-files
showed gnome-keyring-daemon.service as ‘disabled’
and gnome-keyring-daemon.socket as ‘enabled’
systemctl --user enable gnome-keyring-daemon.service
reboot
Did not work.
systemctl --user disable gnome-keyring-daemon.service gnome-keyring-daemon.socket
reboot
Did not work either.
Out of ideas, other than to set user, pw, locale, timezone and keyboard via the terminal. Have not done that yet.
Cannot ssh into this machine at present because a pw (not yet set) is required for root. ‘root’ and ‘alarm’ do not work. So cannot post any extended output.
Any help gratefully recieved, and prps any changes can be folded into the distro.
Tks
R
Nobody able to help?
Tks R
Done some more digging and found these two posts:
Both these posts relate to running instances with proper user credentials assigned.
I think that firstboot itself must be running - /etc/-machine-id is populated and if I delete it and reboot it is repopulated, which may indicate that at least part of firstboot is working.
I have had no luck with disabling the keyring daemon and socket in systemctl as suggested by the ArchWiki. Don’t know if this is because I can’t get a user specific session.
Given that I have to amend files either by mounting the image and working on a non-running instance, or by using TTY2 on a running instance as root, how can I proceed?
Any help greatly appreciated.
Tks
R
I just booted the sway version of Manjaro ARM for RPI for the first time and it asks for username and password. I have tried various possible alternatives, including manjaro - manjaro or root - manjaro but none of my attempts worked. It always brings me back to login screen with a message “login failed”.
I have downloaded the latest image from github.
Sway has not had a maintainer for a couple of years.
