Help please - having a lot of trouble with Sway.
I’m trying to build the manjaro-sway edition for RaspberryPi 4B.
First I tried the main webpage Download, but that didn’t work. manjaro-sway-22.0.4-230430-linux61.iso will install but won’t boot - see my post at
SWAY version stuck on first start - no ideas left
which has had no replies.
Then I tried to use manjaro-arm-tools and buildarmimg.
Cloned the git-hub repository
git clone https://manjaro-sway/manjaro-sway.git
cd manjaro-sway
sudo buildarmimg -d rpi4 -e sway
(note buildiso is not available in the aarch64 repository - could be useful)
During the build I get the following error
Cannot stat /var/lib/manjaro-arm-tools/tmp/root/boot/* No such file or directory
and though the flashed image produces both BOOT_MNJARO and ROOT_MNJARO, /boot is empty and so is /root/boot.
I have used the same process with the Gnome edition. The flashed image produces a populated /boot partition without the need to extract files from /root/boot. It boots to desktop, but I cannot get into any apps (including terminal) or TTY2. For now I am leaving it there.
I have built the Sway image twice with the above buildarmimg command with the same result.
What am I doing wrong? Have posted this as a Discussion under the manjaro-sway repository, but had the response that it is an issue for the Manjaro forum.
So far it has proved impossible for me to make this work. Any help appreciated.
Tks
R
