Suspend brokes my wifi and apps is not opening properly
My suspend is broken
When my laptop goes to suspend everything is okay, but it cannot wake up properly. I see black tty screen with some logs of trying to wake up, but this screen don’t go off until i press CTRL+ALT+F2. Then i log in and my wifi doesnt works, there is no button for wifi, i also cant run any app and reboot or power off, when i try to power off,reboot or suspend it says something like: Cannot reboot, its suspending now. It started happening when i updated my manjaro to 24.2 Yonada, but i had the same problem when i left the bluetooth on and suspended it, but then it just freezed. If someone now how to fix this, please tell.
System info
  Kernel: 6.11.10-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
    root=UUID=a0c3a16a-cad9-43df-aab0-862f028fbeec rw quiet splash apparmor=1
  Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro base: Arch Linux
  Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X515JF_X515JF
    v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: X515JF v: 1.0 serial: <filter>
    uuid: cf4ddab2-7bb5-ae43-a588-55e57bd109a5 UEFI: American Megatrends
    v: X515JF.308 date: 07/04/2022
  Memory: total: 8 GiB available: 7.56 GiB used: 4.6 GiB (60.9%) igpu: 64 MiB
  Processes: 348 Power: uptime: 1h 30m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3 GiB services: gsd-power,upowerd Init: systemd
    v: 256 default: graphical tool: systemctl
  Packages: 1807 pm: pacman pkgs: 1755 libs: 405
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 42 pm: snap pkgs: 10
    Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
    default: Bash v: 5.2.37 running-in: gnome-terminal inxi: 3.3.36
  Info: model: Intel Core i5-1035G1 socket: U3E1 bits: 64 type: MT MCP
    arch: Ice Lake gen: core 10 level: v4 note: check built: 2019-21
    process: Intel 10nm family: 6 model-id: 0x7E (126) stepping: 5
    microcode: 0xC6
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB
    desc: 4x512 KiB L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 3265 min/max: 400/3600 base/boost: 3300/8300 scaling:
    driver: intel_pstate governor: performance volts: 1.0 V ext-clock: 100 MHz
    cores: 1: 3265 2: 3265 3: 3265 4: 3265 5: 3265 6: 3265 7: 3265 8: 3265
    bogomips: 19048
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Hi @lkminv, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
We see no logs :wink:
journalctl -p3 -xb --no-hostname
